PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 [120] 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. 3582HTA vs 6265 Dyno Comparo
  2. Mitsu dealer gave me the wrong fluid for rear diff and transfer case
  3. Idle after resetting the ECU
  4. Intake opinions
  5. Insecure wrist pin clips
  6. New Record 9.30@150 Evo Ix On E85........
  7. 1117 Dyno Sheet and going back to a 4202 Turbo! Plus a little Carnage!
  8. Exedy clutch problem solution
  9. stock boost guage question?
  10. Ferrea Springs&retainers issue HELP
  11. 4th gear lock out..now scratching
  12. AEM truboost install issue...
  13. 3" exhaust advice
  14. Correct AFR???
  15. Maximizing the stock turbo
  16. AWD Motorsports Evo Street Car.. 1001awhp / 622tq!!!!
  17. Info needed: Oil Jet location
  18. bad coil pack???
  19. Evo Crankwalk - Pics
  20. What happens when we are bored on a Saturday night at the shop...
  21. Now you see it!!!
  22. For those of you running EXEDY TWIN HD.....great mod here for to prevent clip....
  23. Evo 7 oil pump
  24. noisy pump
  25. What Do You Recommend?
  26. Clutch options in my 8
  27. werid noise from turbo housing
  28. Running Meth? Safe or Not
  29. What cause car to stalled out in neutral??
  30. Problem: Rpm rises by 500-1k after releasing throttle.
  31. Anybody with a big turbo with Buschur Magnaflow?
  32. Boost leak
  33. Looking for 350whp...
  34. Clutch retaining clip???
  35. intercooler repair?
  36. I rode in Dave Buschur's Bad Bish
  37. After Boosting This Happens???
  38. Clearing carbon in exhaust with degreaser?
  39. Injectors
  40. new clutch just installed and car wont go into reverse??
  41. BOV recirculating question.
  42. Went to dealer for service today 8-2-08
  43. are adjustable cam pulleys required ?
  44. Oil leaking from somewhere.....need help!!
  45. Did I get the right spark plugs?
  46. Full Race + ETS + 93 pump gas !!!
  47. drivetrain mounts?
  48. Car acting up strangley had for 2 days
  49. FP WHITE................................FTW!(dyno inside)
  50. People running a open dump tube?
  51. Who can help explain? Turbos??
  52. Best 02 Housing?
  53. PCV delete / Road draft tube.
  54. FMIC impressed :)
  55. Another clutch issue ( disengage)
  56. Something missing
  57. which throw out bearing for ACT clutch
  58. wheel baering issue... help
  59. 6265 Turbo porn...
  60. SparkTech Ignitions..
  61. ACD light comes on and off
  62. K&N or WORKS drop in filter?
  63. decisions,decisions????
  64. Clutch pedal high
  65. Blitz RVIT (COLOR)???
  66. Ultimate Street & Street Turbo
  67. p0300 dealer flash tsb
  68. Rear diff question
  69. Persistance+pushing the envelope+dynoflash power + ICS= Pump/meth BEAST
  70. Best LICP for a IX?
  71. cosworth M3 cam question
  72. super noob question sorry that i'm even asking
  73. FMIC testing with the speedy AEM air temp sensor.
  74. Magnus Cast manifold
  75. Skunk2 uses CARBONETIC LSD in their S2R1 Time Attack Evo
  76. Loudest Bov For The Ix
  77. Is this a stock Evo 8 cat?
  78. Question about Compressor Map for 35R
  79. Removing MBC for a few days
  80. car choked on 0.5 bar in sixth gear
  81. is royal purple causing my motor to tick?
  82. Exedy Twin HD...Throw out bearing came off the fork!
  83. ACT Street Doesn't Grip Like It Used To
  84. Evo Overheating problems Help!
  85. Clutch pedal squeeking/binding
  86. IAC sensor issues?
  87. Howling noise..seems turbo related
  88. un recirculated stock bov
  89. Load differences per gear
  90. blew it up
  91. 6262, 6265 or 850R
  92. Stock Intercooler
  93. What boost u guys running on 91oct with bigger turbo..
  94. Subaru FP green reliability
  95. need thoughts and ideas on motor build
  96. Is there an IC sprayer button delete panel?
  97. Evo BOV video I found
  98. Megan EVO 8 Exhaust Manifold - can it be installed on the IX?
  99. AC works sometimes
  100. Head Gasket Blown...
  101. Help! My Evo won't idle!
  102. Question about USDM rear diff
  103. What turbo to buy?
  104. SparkTech Fixed my Misfire on stock ECU
  105. Maximizing the IX Turbo Setup
  106. Clearing My Throat - Exhaust System Refresh
  107. Exedy Triple Plate clutch discs strip out....AGAIN!!!
  108. 4" stainless exhaust
  109. Excessive Transmission Noise/Harshness and Driveline Shunt
  110. Cracked Titlon cerametallic disk
  111. Would like some opinions on doing a Garrett turbo upgrade
  112. Engine rebuild questions.
  113. 20g-9-5 or 20g-9-5-lt?
  114. Weird pulley noise?
  115. Ivey Ems Tune!!!!
  116. question for the tuners and fmic makers!
  117. Car cranks differently...
  118. Finding out what kind of exhaust I have..
  119. Thought i'd share another car tuned by FULL FUNCTION
  120. high flow cat. vs. test pipe
  121. Hi Flow Cat Or Test Pipe?
  122. Is my TOB going bad
  123. Show me your fuel cell installations
  124. Evo 7 Clucht Options
  125. Buying a used Exedy Twin question
  126. Bbk 75
  127. Service engine light and P0335 code after jump start
  128. Evo 1 Oil Filter?
  129. few questions from a newb
  130. is there anyone who actually knows?????!!!!
  131. Can't decide proper turbo for setup
  132. 20g or green
  133. EGT bung install?
  134. Boost issues
  135. 20 HP Loss? Help!
  136. Hood vent, and oil temps
  137. Jacks trans
  138. Ic piping help
  139. Starting problem
  140. custom manifold let me know what you think
  141. exhaust leak
  142. Evo 9 MR blown transmission.. NO Warranty !!! :(
  143. Ex. Mani and other upgrades advice
  144. Help Tcase
  145. Rear diff
  146. My setup, need advice
  147. Precisions 6262 Turbo
  148. ticking or popping sound when taking off from a stop with the wheel turned
  149. NEW Tial Sticking Shut!!
  150. spark plug cover
  151. TOMEI Solid Pivots, instock anyone?
  152. ACD fluid out of transfercase
  153. Installed Powder coated Valve cover and Catch can System
  154. Pulled the intake manifold off and what we found
  155. Injen IC piping/intake question
  156. boost leak on evo8?
  157. question about my spark plug gap
  158. o2 sensor question
  159. welding Buschur exhaust
  160. low boost, cylinder misfire?
  161. plug blew out
  162. What WHP should I be at?
  163. Need help/tips getting transfer case on
  164. EVO7 Oil temp and Pressure readings
  165. Vibrating rear diff evo IX
  166. Engine management for my Evo 6.5 ?
  167. Alky tuning???
  168. Code P0500 - Vehicle Speed Sensor Malfunction...Any idea where the sensor is?
  169. upper &lower icp
  170. 2.3 850R results 551awhp/429tq pump gas!!
  171. name that connector! lol
  172. TTP Sales Parts Service and Tuning - First Tune 374.9AWHP / 371.3AWTQ @ 26lbs.
  173. Evo Engine Building Books?
  174. FFTEC tuned EVO8 GT30R 91oct & C16 dyno results and video
  175. Would you consider this 3" muffler restrictive???
  176. frustrated and not sure whats going on.
  177. Anyone have any BAD experiences with Royal Purple in the tranny?
  178. Difference between evo 8 and evo 9 gearing
  179. Bad day for my MAF!!
  180. Ported Stock O2 or tubular 02 Housing
  181. Fidanza 3.2 Clutch or Clutchmasters Stage 3?
  182. 10.5mm Turbine Housing for 04 Evo VIII
  183. Help, I can't split transfercase from tranny evo9
  184. Buschur ported or Invidia mani
  185. Tranz Clutch line Restricter???
  186. t4z 88hta
  187. po139 only in rain?
  188. Worth it to replace panel filter with a cone before tune?
  189. TTP Built Stock Turbo 433 whp 497 wtq
  190. Thoughts on Bushwacker
  191. Megan Manifold Problems
  192. Evo 6 Spark plugs
  193. Need to order Exedy Twin Disk Suggestions?
  194. rear dif
  195. I'm gonna buy a TurboXS IC; should I buy Samco IC hose?
  196. Can I use Tilton Throw out bearing with Carbonetic Triple carbon clutch?
  197. Troubleshoot: Slow transition to vacuum
  198. Finally, My Evo build.
  199. What happened to the 850R!!!! "Owners" speak up!
  200. Cam advice needed...
  201. Motec MDC and JDM AYC diff?
  202. Boost guage reads lower than ECU.
  203. Removing AC and Power Steering
  204. GTSPEC UpPipe / Turbo Outlet (o2 Housing) Info????
  205. Purpose of fuel pressure regulator solenoid?
  206. engine sound
  207. fp red
  208. shorty radiator
  209. who makes the light-es IC?
  210. What are the important Gauges for the EVO
  211. What turbo, HELP needed
  212. How to tell 20g from 16g ?
  213. HELP ID Cams
  214. 20g Turbo for my Evo8
  215. vibration after front diff install
  216. Why does my boost peak, then taper off?
  217. no power but battery works...
  218. Samco Induction pipe ?'s
  219. Service Manual ?'s...
  220. after market O2 sensor
  221. The new Tial Recir BOV????
  222. Custom LICP for FP Red
  223. odyssey PC680 battery (pissed me off tonight)
  224. Who's shop can dyno test the Magnus Cast vs Indy V2 vs AMS cast in the future?????
  225. need a gooood goood clutch for the track!!!
  226. indy evo and 9sec9's airbox availability ?
  227. sean ivey did it again
  228. WG Flapper fell off on my FPGreen
  229. TIAL 30R Setup
  230. BC 272 cams
  231. Best Hotside for HTA35R: .63, .82, bigger???
  232. Bucking at WOT
  233. ugh downgrading question
  234. External Wastegate on stock turbo!?
  235. DNP stock turbo manifold
  236. downpipe bolt thread
  237. Ported head and setting timing with stock TDC?
  238. Help needed in Rhode Island!!!
  239. Final Stock Turbo Dyno Numbers
  240. Changing to the GT850R!!
  241. Full Race TS 3076 results
  242. stock intake pipe
  243. Car runs fine but........
  244. Are all E9 rear differentials LSD?
  245. Oil return help
  246. Greddy Catch Can
  247. greddy gauges sensors
  248. Exhaust with Turn down muffler?
  249. speed sensor
  250. ACD & Aftermarket Wheels
