PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 [239] 240 241 242 243 244 245 246 247 248 249 250 251
  1. how loud is forge bov?
  2. Muffler only!!!
  3. Ralliart ECU
  4. 3" Downpipe, which one?
  5. Do axlebacks work?
  6. leaking intercooler sprayer reservior?
  7. obtainable wheel horsepower?
  8. CEL Fix Help
  9. Mini battery
  10. evo engine(different)
  11. Looking to make a 600hp EVO VIII...what will it take?
  12. Engine revs when shifting...what to do about it?
  13. hks 264 intake cam
  14. Anything else needed to put a turbo-back on?
  15. Safe A/F ratio for dynotune?
  16. Hks Cams
  17. any dyno tests on hks hi power exhaust?
  18. POLL!! Best MANUAL Boost Controller
  19. Another Happy Dynoflash customer!!
  20. Dyno Flash - Fuel Cut Annoncement!!
  21. CEL on and won't go off
  22. Turboback's (cat-deletes) and CEL's?
  23. 5th gear grind
  24. Some advice for everyone installing the B&B exhaust
  25. Front diff & Tranny share same fluid
  26. Had my first gear grind
  27. 2WD evo mod
  28. Drivability? Issues
  29. Is your gas gauge off with large injectors?
  30. Torque Specs for Downpipe
  31. transfer case fluid/for those who changed theirs
  32. First gear shift Thud
  33. bov help
  34. Dynoflash
  35. whats the point of resetting ecu?
  36. Buschur exhausts, a comparison...
  37. Just got the first manifolds in....
  38. JINU0808 Dyno Sheets - YOU decide !
  39. how high is too high?
  40. BOV flange, please help
  41. Anyone crush their AEM intake filter a bit?
  42. Jinu0808 and Dynoflash
  43. nitrous front mount intercooler chiller kit
  44. Intercooler piping modification
  45. ? regarding FMIC upgrade for road courses
  46. Dyno Flash REFUND PLEASE!!!
  47. Stroking Pros & Cons Please!!!
  48. Super AVC-R
  49. Autronic PnP Evo VIII Board
  50. Question on boost control
  51. Stock Airbox or Aftermarket Intake?
  52. OEM Anti-lag System
  53. Got my car back from clutch install, various stuff here
  54. Heat protection for oil pain from DP?
  55. Need Help Defi Link Box install
  56. What was the mileage on your EVO when you bought it?
  57. oil pressure
  58. What is the point of an upgraded clutch?
  59. Denso Iridium Ik20s
  60. Whats a good price for a clutch change?
  61. Question about the stock shifter
  62. egt temp's
  63. Questions for tuners
  64. What FMIC Should I Buy!
  65. EVO VI & VII Parts
  66. For all u 100 octane mixers need some help
  67. i want a 6spd dammit
  68. Check engine light w/ test pipe
  69. Schwitzer turbo
  70. TurboXS HPBC
  71. Evo Problem, can somebody help??
  72. Exhaust Questions
  73. Greddy Type S Adapter for EVO
  74. Dynoflash ROCK
  75. 4G63 exhaust manifold
  76. Is a turbo timer necessary?
  77. Fuel Cut?!?
  78. Anybody else notice a freon leak?
  79. Good turbo article in Hot Rod magazine
  80. Changing spark plugs on the EVO
  81. RMR Intake
  82. K&N filter oil linked to MAF problems?
  83. Diff
  84. intake trouble!
  85. Buschur Exhaust rocks with Dyno Flash again - 93 octane 330 whp!
  86. Turbo Back vs DP Back Power?
  87. Where can I buy my clutch
  88. CEL Please help!! I'm worried
  89. Works Throttle Body????????
  90. Silicone inlet hose for the evo
  91. who actually makes these mufflers
  92. RMR exhaust rubbing
  93. Anyone have the S&B filter for EVO
  94. Boost gauge readings/fluctuations?
  95. Help. Passenger side grommet part number?
  96. catalytic converter
  97. 4g63 bottom end... I did a search>
  98. torbo glowing red please help
  99. Turboback exhaust installation question
  100. HKS Type 1 0-60mph accuracy?
  101. Engine Block Heater
  102. dynoflash is awsome!!!
  103. Hks Sucks?!?!
  104. Buschur Exhaust w/Magnaflow!
  105. ralli art drop in?????
  106. S&B Filter
  107. Autronics who uses it and how is it
  108. hks 2.5" downpipe or Buschur 3"
  109. poll Dynoflash vs. Exede
  110. Engine Pulley Update
  111. A/F Gauge driving me nuts
  112. JUN CAMS? Does anyone have them installed?
  113. DynoFlash Stage Rev.....no more fuel cut in cold.
  114. Blow Off Valve please!!!
  115. Whats a good clutch for the evo?
  116. K&N Typhoon Intake?
  117. K&N filter cleaner
  118. RNR Stage 1, does anyone have it?
  119. Figuring out cfm flow numbers for our 4g63's
  120. MT-90 safe for my JDM EVO?
  121. T3/T4 Bolt-on Turbo Kits
  122. My RMR cat-back cracked!
  123. Buschur Or Jic Exhaust...????
  124. HKS Hi-power with High-flow cat
  125. Evo Motor Experiences......
  126. Will UR test pipe fit B&B exhaust?
  127. Engine management software
  128. ebay downpipe for evo8
  129. EVO8 Economy Kit.......
  130. ECU Tuning - for road course; not drag
  131. HELP! troubleshooting boost fluctuations
  132. Is there every going to be a company that makes bolt on turbos??
  133. the best tunner
  134. New exhaust just fitted....good results!!
  135. New Evo Products!!!!!!
  136. No. 3 Joint (LJ) Replaced
  137. Everyone claims you'll need to replace the clutch right away so list the best clutch
  138. Rear Differential.
  139. Us EVO Buyers got gyped
  140. stock evo boost reading
  141. Notchy Shifter Feel?
  142. Greddy Type S Installation
  143. My Dyno Flash Expectations??
  144. Perrin drop in filter?
  145. K&N or HKS drop in filters?
  146. 2.5" vs 3.0" down pipe
  147. AMS 600hp EVO8 on the street
  148. Freon to cool Intercooler
  149. Front Diff
  150. jic exhaust sound?
  151. custom turbo back
  152. intake adaptor
  153. 38 whp Dynoflash gain! Stage Zero plus - dyno sheet !
  154. Transmission Issue (Yet again)
  155. Cams? 264, 272
  156. Which MBC is best
  157. Warrenty Questions...
  158. hks cams
  159. Flywheels
  160. how good is the XEDE???????
  161. Is anyone running a Thermal exhaust?
  162. Which clutch to buy???
  163. boost gauge
  164. GFB MBC Hiss
  165. Any Info on the Mines exhaust systems??
  166. Test Pipe Question
  167. Buschur Racing Stage 3 dyno charts
  168. Questions about the Pruven dyno day...
  169. Everyone who has cams??
  170. Amsoil Series 2000 vs Redline 75w90
  171. looking for down pipe to replace cat
  172. Help
  173. HKS Valve springs
  174. Shifting gears/loud thump...
  175. What overboosting your turbo may do..
  176. Greddy Emanage and ignition coil packs
  177. Griding day for the 2nd gear...
  178. Need help with fuel pump
  179. 12.4 @ 110 mph with dynoflash!!!
  180. HKS GDmax, whos got em in stock??
  181. Better late than never!
  182. update on evo's idle
  183. Mods list, let me know what you think
  184. The REVOLUTION has just began at Boost Solutions!!!
  185. can't boost over 1.3 bar!!!
  186. Tuning SAFCII for VTA blow off
  187. Blitz DTT X
  188. Turbo Timer Question
  189. What is the likelyhood of passing SMOG w/ cams?
  190. jic downpipe
  191. ? for dynoflash
  192. Big Dyno day results and dyno sheets !!
  193. Stock Clutch HP limit
  194. I finally got my RMR exhaust but.....
  195. AEM Intake a Buschur Racing Upper Ic pipe fitment?????
  196. Evo 8 clutch install in NY area...
  197. Flash vs. Piggy back ?
  198. clicking in engine compartment when ACC is on?
  199. Grinding Gears
  200. Exhuast smack down ! Perrin exhuast to the test at the big Evo Meet Nov 1
  201. Noise backing up.
  202. Cold Air Intake anyone?
  203. Do I have a problem????
  204. How long for tranny fix?
  205. question on buying turbo xs h34
  206. Stand alone engine management on an EVO?
  207. Power Gain From Mods
  208. Pics of my Xede maps (MAF and Timing)
  209. Rattling and dangling sounds while shifting gear 1st to 2nd.
  210. Scanned my car with an OBD2 tool to look at timing tables
  211. best turbo back exhaust for evo
  212. For everyone who's clutch has died
  213. install buschur upper i/c pipe
  214. 3in MAF Pipe Problems
  215. Vishnu muffler?
  216. Modification for an AUTOX car
  217. Faster Accleration
  218. What is this for?
  219. What is it?
  220. Advertising on Evo Engine forum
  221. HKS DP mated with UR 3" test pipe??
  222. help with aquiring parts
  223. burning smell after hard acceleration?
  224. autronic/ apexi power fc
  225. Are you hitting the high boost fuel cut?> we got a cheap fix !
  226. Buschur exhaust
  227. Stock turbo 330 whp Dyno Flash
  228. Record reflash ! nice 450 whp daily driver on stock ecu !
  229. the HKS Hi-Power sucks?
  230. Disadvantages to short shifters?
  231. Clutch installation writeup?
  232. cat back exhaust
  233. Do you have a CEL with cat or not? survey
  234. Turbo Question
  235. how much low end do you loose?
  236. Tune Valve timing
  237. maximum boost on the 4G63
  238. What size injectors should I go with?
  239. Perrin or AMS exhaust?
  240. Big Al's new weapon ! Ferrea rules!!
  241. Cheap Boost Controllers
  242. Selling XEDE and Facotry Guage's
  243. WORKS VS Dynoflash theory of tuning
  244. what to do next?
  245. Buschur Racing EVO 0-60mph ...
  246. looking for 4G64 crank to stroke 4G63
  247. WORKS Rally Parts
  248. Intercooler burn mark
  249. Mobile1 5w-30 or 10w-30 in Evo...does it matter?
  250. new fuel injectors
