PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Fp red upgrade to black?
  2. evo 8 making a whining sound,
  3. Too HIGH of oil pressure buschur motor
  4. Aftermarket turbo oil and water lines
  5. clutch replacement without removing t-case
  6. COP - Eclipse 4G coils
  7. Crank or cam sensor causing this problem??
  8. What is the best exhaust in the market for big turbo????
  9. Aquamist Flow Sensor Issue
  10. Anyone running a Precision 6266 CEA?
  11. issues with clutch pedal and engagement
  12. Car stalling / dying when slowing down to Idle HELP
  13. 4G64 Cam Gears
  14. Buschur Racing's electric power steering for the EVO8-9
  15. Noob Needs Help!
  16. Need help installing OS Giken clutch please..Wrong relocation kit?
  17. Misfire/Combustion issue
  18. oil light lifter tick
  19. PCV Elbow
  20. exedy s2 HD clutch
  21. Clutch Kit or just Clutch Disc?
  22. Buy clean IX MR or hold off for GSR?
  23. What will a megan catback bring to me? Compared to my current stock exhaust
  24. looking at evo with bad tranny...help...
  25. Koyo radiator cap..too much pressure?
  26. Evo 8 block bad need advice
  27. Decked engine block
  28. What is the best clutch recommendtation for my setup
  29. Are EVO 4's fitted with a windage tray?
  30. block surface prep question
  31. Help with new turbo and manifold!!
  32. Evo IV engine fit in Viii?
  33. MAP T3 / Compgate 40mm Boost problem
  34. MAX Boost
  35. Fuel Cell Setup
  36. After Cams and timing belt install - Misfiring problem
  37. Top mount kits?
  38. I can't depress slave cylinder with hand. Bad slave cylinder?
  39. OS Giken R2CD installation instructions
  40. Compression test results and few questions
  41. Evo 9 Transmission
  42. AYC/ACD delete, make any difference?
  43. Mild Head Build - Evo 9
  44. Need to replace my evo 8 turbo
  45. Car stalls when clutch in, threw p0401 code
  46. Whinning noise Tranny or Tcase? HELP
  47. 34 PSI Boost spike on pump gas
  48. 6466 vs 6466tz results?
  49. sump oil level sensor
  50. Tubo Lag *Need Help*
  51. what cams are best? with evo 9 Turbo
  52. Gates T-belt and pulleys - reliability??
  53. Turbo gasket replacement
  54. Turbo Lag
  55. pics of piston - possible reason of this damage ?
  56. Flywheel/starter compatibility issue
  57. HELP!! changing out cv axles.
  58. having some issues, input?
  59. Brian has got himself a turbo! -FpEvoGreen- Need opinions!
  60. FP ballbearing
  61. question on Shep Trans & Tcase
  62. boost/turbo problems
  63. Another evo won't go into gear after clutch install
  64. Need advise about tranny and transfer case
  65. Walbro 400 lph Burning wires Evo 8
  66. English Racing oil pump gear, did I screw up my oil pan from modding & will it leak?
  67. e85 with FIC 950s
  68. Help!!! Looking for a nice front lip -- NO CARBON FIBER any websites that sell them
  69. Stock intake manifold an TB limits
  70. Is anything salvageable from my motor?
  71. Do anyone have idea of what this black box is
  72. Engine over rev
  73. El Diablo Blanco: 4G69 2.2L Evo IX build
  74. do these valves look bad?
  75. No heatshield on downpipe and o2 housing
  76. Kit for swapping 4G64 block
  77. Tail shaft centre bearings!
  78. Head got decked. Do i need thicker head gasket?
  79. Question filling transfer case
  80. AYC Fluid Help
  81. Another P0300 thread
  82. Need to know if this hotside fits my turbo !
  83. turbo rebuilders in the New Jersey area
  84. Kevlar belts - change interval?
  85. Car bogs, stalls, wont rev past 6000 rpm..map sensor and boost gauge are off
  86. Any cons of having my DV mounted this way?
  87. Fitting on side of RMR intake pipe? Pic inside
  88. Valve springs for S2 cams
  89. stock turbos feed with such a low oil pressure ? *video*
  90. Random Misfire goes away when throttle released and reapplied
  91. rods or pistons for 2.3L?
  92. Wiseco ring gap
  93. Quick question
  94. Dead COP
  95. Bad sparkplug causing high fuel pressure?
  96. ACT XTSS rattle on release?
  97. Evo 9 can anyone post pics of their stock fuel regulator and vaccun lines???
  98. Turbine wheel in evo 9 turbo
  99. Precision Turbo rebuild question.
  100. O2 housing 3 inch outlet?
  101. thinking about swapping my 6466
  102. Ideal Oil running temp for Aluminum Rods? (what's too cold/what's too hot?)
  103. Need E8 TPS screw thread pitch please
  104. Fresh build, sitting for months, will the assembly lube still prevent dry start?
  105. speed sensor retaining clip for plug on wiring harness
  106. Titanium Valve Spring Milage
  107. This looks off...
  108. Wastegate actuator advice needed
  109. Need help! Almost done with build evo 9
  110. ETS Short Route recirc. pipe
  111. QM leg 8 twin disc problem
  112. evo 9 6-speed trans leaking
  113. Going to stock ECU from Haltech EMS
  114. Whats a good turbo?
  115. Broke Rear Diff on Evo5GSR can Lancer GSR Cm5a rear diff work?
  116. Leaking oil from the oil pan skid pad??
  117. Turbo oil drain leaking in crazy spot please help
  118. loss of power
  119. looking for ix 5 speed!!!
  120. looking for ix 5 speed!!!
  121. Evo 9 GSR Stock Turbo
  122. Stroker questions
  123. Troubleshooting a boost issue
  124. hard to shift
  125. Intake Manifold & TB options
  126. Hole burnt into cylinder head
  127. WGA Question!
  128. Transfer case/Driveshaft oil leak
  129. EVO 8 BUILD pictures
  130. Motor build / performance questions
  131. Noob EVO owner with questions!
  132. full blown throttle body question
  133. Clutch lost pressure overnight
  134. Installing Buschur catch can and a lil confused.
  135. new set up now fuel pump wont turn on
  136. Tightening Spark Plugs without a torque wrench
  137. Which Kinugawa Turbo for 2.0L Evo 9
  138. Fake/New Walbro 400?
  139. 5152-2600 Comp Clutch 03-06 Mitsubishi Evo 8 Stage 3 - Segmented Ceramic Clutch kit
  140. Early Mivec Cosworth Cams
  141. Evo 9 Mivec cam lash issue / snap sound - Video attached.
  142. Dual wastegate, Advatage and Disadvantage
  143. Bang for buck fuel injectors?
  144. Newb Quarter Master Install Question
  145. Mivec cam gear default position
  146. gearbox oil holes
  147. Evo 8 feels weak past 4 rpm
  148. weir 12 plate install to EVO 8 2005
  149. Broke TCase..Front Diff?
  150. q45 TB on SD doesn't idle when cold
  151. evo4 give your input
  152. Map dump with wastegate
  153. TB porting - how to?
  154. What OS Giken Clutch should I go with??
  155. is this an EVO exhaust system
  156. Buddy racing cams
  157. More testing with GSC R2 Cams?
  158. water pump leaking from weird spot..is this normal?
  159. Fuel Pressure Gauge Install Help
  160. Looking for insight on the cooling system
  161. Weird idle/driveability issues after build
  162. Have low, but consistent compression numbers? Look Here.
  163. Injector Dynamics
  164. injectors?
  165. Continued fluttering/bucking issue
  166. o2 housing + 3inch downpipe install
  167. Throttle Body Sticks
  168. Help me choose the proper piston
  169. Motor oil recommendation
  170. Spun Balance Shaft Bearing, Need opinions.
  171. Sounds like a subaru when cold...
  172. Tial Q BOV
  173. Where to order oem 4g63 engine?
  174. Where to source a cheap new idle control valve
  175. V-Band Downpipe Help
  176. please help diagnose my problem
  177. RS Rear diff conversion - Evo 4 gsr - advice?
  178. TiAL QR for evo 8/9 using stock UICP
  179. Oil catch can setups Evo IX
  180. I stripped a valve cover bolt thread
  181. Cylinder Head Porting: Exhaust
  182. Egt in #1 runner ok?
  183. COP Question
  184. Evo 9 balance belt position.
  185. Need advice
  186. 05 evo 8 MR 6 speed to 5 speed swap
  187. Evo 9 Front wheel bias on Dyno - Problem with car?
  188. Can someone tell me what this sounds like?
  189. Possible head gasket leak or head lifting?
  190. Hitting the Rev Limiter vs. Raising the Rev Limiter
  191. clutch choice
  192. Tial Bov Issue
  193. Torque Solutions propeller shaft bushing squeak
  194. fluide dampner
  195. Front Differential/ Transfer Case advice
  196. Transfer Case Torque Specs
  197. Changing out Filter System
  198. lean before boost
  199. Clutch grinding.
  200. Missing plug.
  201. RS2 downpipe
  202. no boost ???
  203. OBX Limited slip
  204. No Start, fuel pump, no starter (Intermittent)
  205. Kelford 272 cam install question
  206. 2618 or 4032 pistons
  207. engine tick
  208. Need help, refreshed head, oil on back of valve, is this a bad valve seal?
  209. lightweight flywheel suggestions!??
  210. P0300 Code Disabled to hide alarm after Timing Belt Change?
  211. is it normal for air to escape wga during boost leak test?
  212. Strange turbo issue
  213. Evo X gearboxes into CT9A
  214. Wastegate Leaking At Idle - Closes Under Load
  215. comp clutch stage 2 user's input needed
  216. Manley/ARP conrod bolts lenght
  217. Manley/arp conrod bolt lenght
  218. Turbo problem or something else
  219. What timing belt and water pump for evo9??
  220. Question about my shearer 02 dump
  221. Efr8374 e85?
  222. Full lean AFR at idle only
  223. Monoloc vs clutch stopper
  224. floor harness wiring diagram(LH)
  225. questions about tcases and drive line.
  226. Oil for first start on rebuilt engine?
  227. Trans or synchro?
  228. upgrading from FP black for faster spool. recommendations?
  229. what parts do I need for head gasket job
  230. quartermaster issues
  231. fuel line upgrade question
  232. Please help: Shift issue
  233. Fuel Pump/ Filter
  234. What is this hole for?
  235. TIAL BOV Scratches inside?
  236. Supertech springs and retainers service life
  237. Engine failure.
  238. Help cant tell if burning oil or not
  239. question about my evo 7
  240. Evo 1 problem
  241. Evo 9 MR, oil leaking from the engine? Pics
  242. Mileage VS Piston Ring Wear
  243. help please read
  244. Lean AFR and Partial Throttle Stutter Injector Dying?
  245. Forge wastegate help
  246. L19 arp head stud size and pitch
  247. ignition switch?
  248. evo maf pinout requested
  249. seriously need HELP, secomd gear popping out
  250. Would you build this head??
