View Full Version : Evo Engine / Turbo / Drivetrain
- finally....APEXi GT spec exhaust installed
- 8 inch SPAL fan on stock oil cooler!
- Remove what from where???
- max safe rev limit on stock 05 EVO motor with 280's??
- 264/272/280 cams driving videos
- Tomei Cams
- exhaut manifold Q's
- Clutch Cracking Sound answers from Dealership
- Installed Injen Intake and UICP w/ AMS Lower IC Pipe
- 264/272/280 cam idling vid
- anyone using the buschur mini radiator?
- clutch installed...shifter cables wont attach
- How much power can be had with?
- Turbo timer problem
- marks on oil dipstick
- Any Perrin Fitment Issues ???
- Buschur's Alky kit? Help W/Install
- tubular O2 w/cast manny vs. ported O2 w/tubular manny?
- just installed GSC 272 272 cams with fidanza cam gears and arps small problem
- Weird boost spike problem.
- No Love From my EVO HELP!!!
- [B]can u make the GSR 6 speed?[/B]
- question abot the stock clutch?
- Different alky mixes besides 100% and 50/50??
- Stock Turbo
- RalliArt Spark Plug Wires Miracle
- Timing belt tension tool?
- Problems
- Is It Easy To Modify Evo 9 4g63?
- HELP.... Cam fraud???
- Anyone have the Exedy Twin Carbon?
- Intake Manifold? Anyone Tried?
- Which aftermarket Thermostat are you guys using?
- fonky engine sounds
- header
- Anyone dealt with the ACT 4 puck?
- Any TITANIUM Downpipes out there?
- Turbo kit and AEM EMS for sale
- Clutch does not engage, restart car and it works HELP
- what spark plugs are you running?
- Transmisson question
- Where to buy muffler clamp/hanger
- CEL still on...what should I try next?
- Clutch adjustment easy??!
- Someone Guide Me To My Next Move
- How to clean turbo?
- Sheet Metal Intake on Staock Turbo
- maxing out the stock turbo..
- Need Help
- Big turbo, lot's of lag. Solution = Increase compression?
- photoshop help with dynographs please
- Dual Port BOV's
- new clutch and fmic installed
- Cam gear install Q's- also running rich?
- ecu question
- Please critique my engine mod list!!!!
- short shifter without cutting
- HELP!! SS clutch line and restrictor removal problems
- Exedy Clutch Kits, anyone having problems?
- Full tilt WR group buy already half gone...
- boost controller Problem
- Feeler thread
- Intake Help
- how much is 2003 E8'S stock fuel pressure?
- Help!!! 02 Sensor Is Yellow!
- Blown Head Gasket?? Please Help.
- ACD bleeding for 05 evos..
- Ceramic Coating and Jet Coating on exhaust manifold
- TSB for 05's
- spraying radiator and oil cooler? Need tips on mod.
- Oh No! Look at my clutch
- Problems with my used Evo
- best place to buy megan racing dp
- 2 Step/ Flatshift Question...
- ACT clutch premature wear? help!
- Alky/meth users come on in
- 05 EVOS can run VTA w/o problems!
- Timimg Belt Issues, wont line up
- what gear i should use to tune my boost?
- Buschur Racing Builds The Most Powerful 4g63's..period.
- Clutch bleeder screw size??
- best bov?
- New 20G MPH record runs...
- Car and Driver Super Four Challenge RESULTS FINALLY RELEASED!!
- Long term alcohol injection questions
- Turbo kits?
- broke 2 TURBO manifold bolts, am i screwed?
- Loudest recirc bov?
- Downpipe Leak ......
- misfiring?
- Need two easy engine parts.
- AEM + gt35 + precision dyno = 375 awhp
- i owe an apology
- 2005 Evo transmission issues....
- HIGHEST BOOST>>>>>>>>>
- WTB: Diaqueen GL-5
- HKS/APS Hybrid Intake
- Oil Leaking from this hole. What is it?
- Bad Synchro or clutch?
- Downpipe and Check eng lamp?
- Bov Gm Maf
- Where to buy and ACD???
- evo 8 to evo 9
- High 11's what it takes
- test pipe
- ? about exhaust setup
- MR 6-speed vs. 5-Speed What Evo for me
- Crazy exhaust cut out by ATP!
- Newbie ques on revs not going down
- Evo condenser
- Tommi makinen turbo differences.
- Just installed at Atlantic Motorsports
- Drop-in filter question
- need help ASAP
- o2 sensor not connected...is it bad?
- Supercharger in an EVO?
- Service Engine Soon light came on?
- Few new Mods.....Would like some Comments. =)
- getting stiffer?
- Clutch Viagra?
- Is this a good turbo/deal?
- Alky Question
- ARC catch can install directions?
- Coolant leaking everywhere!!
- just installed intake
- Help!! TT Turbo kit with HKS 280's or 272's????
- ams downpipe
- How do I change compressor covers on a GT35R?
- *MOD+Tuning question*
- Post install questions
- Buschur 20G Upgrade
- Turbo sounds like a truck
- anybody have the TME 20G Turbo?
- Stock boost on an MR
- Help,2003 Evo8
- AMS 2.3 stroker & 35R kit vs RNR 2.4 block & 35R kit: 91 Octane
- Wastegate Actuator Mod
- Ordered My Garret GT40R 2 days ago. 35rvs40r?
- boost spike from bad MBC?
- Buchur Racing Exhaust vs. Helix
- Stock ECU/MAF WHP/Torque Dyno Record? Pics & Graphs Inside
- What Clutch?
- Dyno'd my car today
- aftermarket synchros
- Accidently hit 29psi, did i hurt anything?
- clutch aligned? turned crank...
- hks bov intake plug flew off!!
- sensor safe RTV
- Installed a gounding kit
- Wtb Stock Bov Hose
- New dyno plots with w/r turbo and AEM!
- Back to the track with the new cage.....new personal record for BR
- BR Race FMIC Track & Test Results
- My newest ACT story (good)
- Driveline Lash
- To much boost?
- Video/Sound Clip of LPI 3" Turboback Exhaust
- Hard to move gear shift left to right in neutral.
- what do you guys spool up at stock?
- Borla Exhaust Manifold
- clutch went out on the evo at about 40,000 miles
- HELP cam installation screwed up my car!!
- Cam install, more to install gears?
- Bleeding and filling the ACD help?
- Problem!!
- Are all down pipes the same?
- ARC Intake, and RAIN!!!
- Boost leak or Turbo f'd up?
- Got the code and info,now what?
- Apexi EL II Oil Temp Sensor Adapter?
- why do I keep hitting fuel cut?
- Helix O2 housing size compare with stock!!
- i hate my act clutch
- Fujitsubo Exhaust
- I Need a Power Enterprises Boost Control (Black)
- Huge problem, please help!
- Noise is driving me nuts!
- My clutch failed ... but why? Opinions needed.
- palmnstein or pocket logger software?
- What kind of gains With?
- Greddy type s not boosting
- people with gt35r without stroker kit..
- boost
- 05 MR Boost Spike
- Track on friday's
- LPI cat delete question
- stock turbo and alcohol injection
- cheapest way into the 11s (my idea)
- weird POP from my motor
- 23psi spike, should I be worried?
- Just installed my EGT Gauge
- i want 370whp ...wut clutch?
- cooling mist alky pump question
- Invidia N1 - great catback!
- boost leak
- Question about this piece
- EcuTek R&D at Precision Dyno
- Valve Cover vent hole??
- K & N
- Installation of Forge Wastegate Actuator
- Idle Recovery
- Edge Racing Sport header any good?
- Are these any good???
- Air in the cooling system
- Ralliart air pipe installed
- Where can i find TC Fluid?
- Rpm Hang? Help
- hks 272 cam idling(video)
- BOV greddy type S
- Next Mod?
- Fpr
- Question on o2 housing temps
- EGR P0401 can't resolve
- buschur or ams gt35
- boost taper question
- Boost Question
- Modded stock wastegate accuator
- Exhaust Manifold Question
- Little bit in insight on drivetrain problems
- gauge question
- Problems shifting from 1st to 2nd on my 05 Evo
- problem with greddy turbo timer
- Best allround turbo for 500 hp
- Megan exhuast RULZ!!!
- Equal Length Manifold for stock turbo?
- MAF Translator
- 60 Seconds Of Video With Hks 280's On 2005 Evo With Stock Evo On Reflash...
- 475 WHP on dynojet, 10's possible?
- GT35R Power gain poll (just for fun)
- Evo 8 Engine Build Specs, What do you think?
- 20G Upgrade w/ XEDE?
- SSQ Install Q's
- Megan Racing 3" TB install w/pics
- Evo Injectors
- All Mustang Dyno's NOT created equal!
- Running rich?
- 100 cell high flow cats
- Stock clutch and internals
- Is my car ready??
- Changed front driveline fluids . . .
- P0420 code?
- 1/2 a clutch install...need input
- DP leak....
- Boost Problems!
- Shifter Bushings
- Who has BG & Diaqueen IN STOCK
- FS: Stock Exhaust
- Teach me turbo
- fq 400 clutch?
