PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Balance shaft seized
  2. WTB a 4G63 for my IX Evo
  3. 500hp++ turbo recomendations
  4. Evo 9 shifting issues
  5. downgrading turbo/price question
  6. Timing Belt and Water Pump
  7. Evo 8 oil return line leaking
  8. How Many quarts with a AMS pan?
  9. JIC exhaust manifold reviews?
  10. Completely lost.. New aeromotive FPR wont go above 20 psi!!
  11. No intake or diverter valve sound...
  12. Transmission Rebuild need help
  13. Lost oil pressure after pan reseal!
  14. evo 9 shut off while driving for a hour
  15. Exedy Twin need rebuild?
  16. Daily Driver Cams
  17. Timing belt tensioner/bearing failures
  18. looking for the best springs and retainers for the evo 9
  19. Wastegate ports with higher boost
  20. Fresh build: any tips to make sure everything is in order?
  21. Wastegate question/fitment
  22. It's looking like I blew a coilpack... should I just get OEM ones?
  23. Clutch Master Cylinder MIT MR491945 question
  24. Monster Sport Intercooler Pipes
  25. Best way to hardwire a walbro 450?
  26. Rear Driver Side Freeze Plug
  27. Water Pump Help Gates/OEM
  28. Metal.. liquid in oil
  29. Evo IX low compression
  30. Rod Bearing Clearence in 2.0 long rod help
  31. Help new clutch
  32. Brand new Evo 9 turbo pricing
  33. Piston/ Valve Damage
  34. Weird ECU Flash stall and wont start
  35. Muse/VSFR
  36. Clutch squeal/grind when released only from stop
  37. track / hill climb with a 3586 (or similar) + 2.4L?
  38. Turbo CHRA v-band leak
  39. Turbosmart wastegate difference between 8/9
  40. Help with No valve to piston clearence after Kelford 272 install
  41. Reverse pops out while car running, normal with car off.
  42. Need Help! - Flywheel to clutch question
  43. just ordered my exedy twin.anything else?
  44. Tell the difference between Evo 8 and 9 GSC cams
  45. Evo IX loud engine whine, timing belt torn
  46. Have anyone do GT3000 rear diff on Evo 8-9?
  47. Anyone know where I can get a GT3000 diff kit?
  48. Clunk noise after shop installed alternator
  49. Knocking sound from timing belt side
  50. what oil to use ?
  51. ignition coil question
  52. broken crankshaft pulley
  53. removing cam angle sensor
  54. Pop sound coming from something after clutch/flywheel install
  55. Knock problem.... or is it? HELP PLEASE....
  56. Anyone use the FP Xona Rotor turbos yet?
  57. Any suggestions? Running out of ideas!!
  58. Evo 8 A/C Problems
  59. New engine build, nothing but problems....
  60. Rear outer CV joint removal and install question...
  61. Diamond Race Cars V3 front subframe with manual rack conversion. 41lbs LIGHTER
  62. Buzz
  63. Someone chime in on my transfer case
  64. Best Clutch For High HP
  65. Reseating throw out bearing?
  66. blouch 2.0 (cbrd bbk-b) vs. fp red
  67. Wanted Latency
  68. Anyone use gear-based boost control in Tephra V7?
  69. WTB Kelford 280 Cams For Evo 8
  70. Deck head after only 300 miles?
  71. stainless injectors for e85
  72. some good oil info
  73. Evo 9 head without MIVEC on evo 8 block
  74. evo iv to vii turbo upgrade.
  75. Skunk2 Throttle Body review
  76. Need a little advice
  77. Need Help! Clutch Adjustment issues.
  78. HKS cams
  79. PTE 6266BB Gen 1 Oil restrictor
  80. Quick question regarding my exhaust/intake setup
  81. is this enough to get 550whp 93
  82. P0090 code every other startup...suggestions?
  83. 4g64 oil supply line & dipstick question
  84. who is running an Maperformance block
  85. Can someone listen to this engine tick?
  86. IAC valve plastic broke :( OEM vs non OEM iac
  87. .0015" clearance on main and rod bearings
  88. rods and pistons
  89. Can a Wiseco 2.3L Pistons Use for 2.2L?
  90. Iacv wiring not getting power from ecu
  91. Evo 8 transfer case removal questions
  92. Springs recommendations wanted.
  93. Evo 6 Rear diff problems/ideas
  94. Evo 5 turbo with evo 8 turbo parts?
  95. Broken Injector Seals (Bosch 1000cc) ?
  96. Best boost controller for 1000hp build?
  97. Warped flywheel or master cylinder issues??
  98. 2nd piston ring bigger?
  99. Pulled motor over a year ago and have a question for getting it back together.
  100. Oil cooler install
  101. Approaching 30k miles on 2.3 FP BLACK DBB build
  102. Stock rod bolts with GT3582?
  103. STM Alum exhaust
  104. Driven Fab EFR Turbo Kits
  105. bought an evo 8- found stroker parts in the trunk
  106. New intake, less boost???
  107. 10.5 vs IX turbo- accuator different?
  108. Best head gasket for fully built 2.4LR?
  109. Higher rating Alternator for high electrical loads
  110. 1000 whp build.. carrillo pro H beam vs I beam turbo tuff
  111. advise me for pistons and rods which brands are good to keep a stock replacemen
  112. How noisy is your built motor when cold?
  113. Valve Stem to Guide Clearance Question
  114. BR 280 cams on a 2.0LR motor
  115. Evo 4 AYC diff replacment with Cusco rear LSD
  116. Evo IX won't start
  117. Evo 8 MR build - Power expectations
  118. 1/2 inche head studs/wire ringed block
  119. Really important to change head studs??
  120. Checking Valve Piston Clearance Question
  121. Competition clutch twin Q's???
  122. fan airflow direction?
  123. clutch went out
  124. Too Much Boost, Solenoid stays open
  125. Spoolinup cop kit help please
  126. 03 Evo 8 with a 4G64 stock block/evo8 head combo.. Will it hold 15psi?
  127. No reverse after clutch install!
  128. New evo low boost.
  129. Shifter cable/linkage/cable help?!
  130. Engine Exploded Diagram
  131. bogging wont allow to boost at 3500rpm!! need help asap
  132. EVO GT-A ECU question
  133. Quick question about TB shaft seal
  134. gt35r Exhaust manifold
  135. MBC to Stock Boost Solenoid Conversion
  136. No Fuel Pressure (Evo 9)
  137. evo oem parts
  138. Would you Sleeve a Motor if you plan to Daily Drive it?
  139. New Mil.Spec 65mm ThrottleBody install has sudden P0506 and Low Idle months later
  140. engine vibration problem
  141. Missing target boost (30psi) by 2-3 psi
  142. Turbo to manifold studs - Material?
  143. Whats holding the turbo?
  144. Fp turbos's ?
  145. BC 288 cams settings??
  146. Remove P/S Cooler Loop
  147. Possible t case leak
  148. replacing ACD pump lines going to rear of the ACD transfer case
  149. GFB Response BOV T9033
  150. 2.0 long rod setup - couple questions about these proposed parts
  151. Is this signs of a plate being warped?
  152. Dryden RS diff fitting kit
  153. 71Hta compressor wheel question
  154. FRESH ENGINE; Fuel & Spark but NO START
  155. what can cause rad fan to run constantly ?
  156. Scratched or scortch cylinder wall on bottom part of the cylinder what are the risk?
  157. evo 8 compression test results/questions
  158. Evo 7 MAP Sensor wiring
  159. Full race t4 twin scroll install advice
  160. 02 hood exit dump
  161. Clutch system HELP!!
  162. Injector sizing for FP red on E85?
  163. what brand??
  164. Motor Mount Bolt Caught by the threads
  165. Compression results?
  166. Evo 8 misfire
  167. Opinion needed - Clutch disc wear check (CC stg2)
  168. improving my 2.3 fp black evo 9 -- e85
  169. car won't start
  170. jun bl or rs-r exmag gt2
  171. Oil pressure pickup question
  172. Good clutch/flywheel for how my car is used?
  173. Oil starvation piston 4
  174. Pin Pointing Noises on Moving Parts
  175. Oversize thrust washer available????
  176. A/C repair kit...help
  177. Major issues after new turbo/fuel system install...
  178. Going from quartermaster 8 leg to an exedy twin disk
  179. Play in piston/rod...
  180. Any treadstone cast T3 manifold setups?
  181. oil threw oil cap
  182. Using a Non mivec bottom end on a mivec car.. problem?
  183. 2006 IX catalytic converter
  184. Help! Car sounds like.it's about to die :(
  185. What to look for when buying a used turbo
  186. tomei turbo blowing seals
  187. Racing with OEM plugs
  188. Hard Shifting
  189. stock frame turbo options, misc. questions
  190. Oversized thrust bearings
  191. 2.4L cam gear and timing on EVO 9 HELP!!!
  192. GSC Billet Evolution 9 Mivec S2 Camshafts
  193. Discussion/help for a new IX owner
  194. Max power on single walbro 450 pump?
  195. Best place to mount flex fuel sensor....?
  196. new kid on the block
  197. TIAL gt35r housing
  198. Reconmended Throttle Body, Intake Manifold and Exhaust Manifold for my setup
  199. Evo 8 VERY low boost/spool- almost 5psi at 6krpm, not boost leak or iwg
  200. Doesn't like to idle when warm (new motor)
  201. Need Help!!! Idle sticking at 2k Rpm
  202. Am I neglecting anything for the new valves I bought?
  203. vent to atmosphere synapse diverter valve open at idle
  204. Fuel pump relay clicking?
  205. Wet piston top
  206. Notchy Shifting Issue
  207. Clutch Pedal Adjustment
  208. Transfer Case leak...
  209. Exedy tripple help needed (part numbers)
  210. Tomioka Racing Evo 8/9 manifold Review?
  211. Wastegate diaphragm opinions??
  212. FMIC with Cusco Front Mount Power Brace
  213. Looking for check on mod list for first tune
  214. Lack of oil pressure light
  215. tial bov question
  216. Manifold without Tune?
  217. 3rd blown ayc diff evo 6
  218. Aitrek turbo idle problem
  219. interchangeable tranny
  220. Loud ticking/rattle noise coming from head?
  221. help identify wiring & plugs?
  222. pressure spring for evo 8 cams
  223. pressure spring for evo 8 cams
  224. Piston Diameter and Bore
  225. Complete turbo failure?
  226. Can I use this transmission Fluid?
  227. Has anyone tried this head gasket out?
  228. anyone make their own exhaust manifold?
  229. Removing Charcoal Canister
  230. random tick/pop
  231. stock air box vs open filter
  232. primary fuel pump issue
  233. AMS Race Shaft
  234. Stock Evo 9 Boost gauge needle not moving
  235. Front Facing turbo kit
  236. since i cant get oem power steering fluid
  237. Driveshaft Questions DSS/PST
  238. High lead in oil analyses
  239. Whats the best uicp and licp
  240. New motor and oil
  241. Input/advice on my built evo 9 power numbers.
  242. AEM AFPR installed car runs but turbosmart gauge reads 0
  243. Rough Idle after lots of work has been done
  244. Engine problems
  245. evo 7 gsr clutch suggestions
  246. Vibrations post engine maintenance!
  247. NEED HELP~~~~Engine compression test
  248. Can this be fixed?
  249. hks 280, need upgrade?
  250. Identify these valves stamped TAE
