PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 [173] 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Cosworth M2 cams?
  2. HELP!! Over boosting with stock soleniod back on..
  3. Car doesnt seem to be pulling as hard?WHy
  4. Engine longevity with HKS cams
  5. 2.3 or 2.0 for quarter mile
  6. weird issue, please help (could be normal)
  7. 2.3 Stroker!!! What street TURBO??? INFO FOR ALL 2.3 setups
  8. Q on boost controller
  9. New destroyed tranny record?
  10. BG Synchroshift
  11. AEM Boost Controller Guage
  12. Only 17lbs of Boost?
  13. tranny fluid?
  14. 2.4l Problem
  15. Question about going from stock TB to 75mm TB on a SMIM...
  16. Boost Leak Test Results
  17. springs and retainers help!!
  18. AMS Licp fit undertray?
  19. Air Fuel Ratio Question
  20. Question about Tein Flex
  21. Anyone using ralliart air filters?
  22. TME locked up/rebuilding options help
  23. 4th gear grinding problem
  24. Is this a boost leak?
  25. Evo Speed limiter remove "WTF" ??
  26. ACT Install.. please help
  27. Under hood shifter bushing question
  28. Competition Clutches? Any Good?
  29. Custom Turbo Kit Guys!!!!!
  30. Evo 8 spark plugs do not fit a 9
  31. How Does my tranny Look?!
  32. bad Idle Speed Controller (ISC)?
  33. Help me figure this out please!!
  34. Please Help me figure this out!!
  35. A boost/efficiency question
  36. What to Gap Plug's?
  37. No more Heat Soaked intercooler !!
  38. Header design w/ pics
  39. 3" TBE TO LOW
  40. Shift fork help...
  41. Intercooler Piping question
  42. IX cam torque settings
  43. Fluttering at high boost.. Help.
  44. Torco And Boost?
  45. Single clutch
  46. 4th gear grinding problem
  47. Intakes: Buschur vs. HKS RS
  48. help car wont start(ping)
  49. NEED HELP! Shifting problem..
  50. Boost Up then Down?
  51. fuel pressure solenoid resistance?
  52. stroker vs. overbored and head being addressed
  53. 500+whp EVO 200% guaranteed!!! HA
  54. No AEM for alky?
  55. How much Boost on a EVO9
  56. primary 02 sensor....
  57. gas octane questions~~
  58. Questions of 4G63 Stroker kits
  59. Need help with future mods....
  60. Damn rain, we had to stop at 9.22 @ 158 mph
  61. oil viscosity, weights etc-long/neat race car
  62. new aeromotive fuel rails
  63. Big turbo guys- What BOV are you running?
  64. Straight Line Specialties Top Mount T4 Manifold
  65. Modded Ebay 02 w/ Open Atmosphere Dump!
  66. Slgiht grind question..
  67. SpeedElement/Full-Race GT30R DYNO 91 OCTANE
  68. 2.4L w/ 50 Trim owners, Chime in!!
  69. Spacers for tie bar to allow downpipe to fit?
  70. My Budget oil catch can, two cans for < $33.00
  71. br 20-g-9 labor?
  72. Revolver or Jun
  73. white smoke
  74. busted diff/TC?
  75. Switching from Stock IX turbo to a 20g with Ti/AL
  76. how does this happen to a turbo, and whats involved in fixing it?
  77. What To Choose?
  78. Thank you TRE
  79. Stock Evo 9 boosting only 1 bar?
  80. walbro fuel pump failure???
  81. Halfway through o2 housing install, help?
  82. o2 censer on the o2 housing on the IX??
  83. For those of you with tubular manifolds, look here(pics)!
  84. evo runs very rich when step on gas
  85. Boost leak test problem, 0 psi, doesn't hold
  86. Nifty vid of GT35r
  87. GT35R option??
  88. A little trick that could get you 5mph higher trap
  89. 10.5 single flapper,SS o2 installed
  90. Miami Machine Shop
  91. AMS 50 trim dyno chart
  92. GT turbo Install Kits
  93. Looking for insight: XS Power Exhaust on Ebay
  94. Head Work Advice
  95. Can the ATP 3071R kit reach 500+whp on stock bottom end?
  96. Please HELP diagnose my problem! Shutter/heavy vibration when turning at low speeds
  97. Home Depot/Walmart oil catch can
  98. Clutch decision...
  99. Check out my budget oil catchcan... part II
  100. Vendors!!!!
  101. Heat and Boost
  102. Headers
  103. Question?
  104. Water Pressure Gauge
  105. Which 7 bolt 2.4 cranks are suitable for 2.3 builds?
  106. blow off valve
  107. Whats the weight oil on the BGII syncroshift??
  108. Whining Noise - Drivetrain/Clutch Related?
  109. will buschur racing 8 LIC pipe fit a 9 ?
  110. b4 i install my DNP manifold question....
  111. Buschurs modified walboro pump?
  112. Building my engine...
  113. boost problems??
  114. Input needed from those with broken drivetrain parts
  115. went through big puddle now wierd sound.
  116. GL 4 and GL 5 (for transmission) Same thing now???
  117. Need Help - AEM Ignition box bad?
  118. Can I eliminate rear o2 with the LM-1 WB Kit?
  119. Damned Clutches!!
  120. RnR Exhaust
  121. Downpipe Bolt concerns....
  122. 2.3 stroker
  123. Help with my drivetrain
  124. Tranny Oil Change!!
  125. Check out my budget oil catchcan!!
  126. replacement filter for hks rs
  127. MAF Deletion Kit
  128. Just read something interesting in the manual!!
  129. Controlling Boost Manually
  130. Exhaust
  131. Heavy oil buildup inside my MAF
  132. Random/Multiple misfire
  133. Tanabe Dp
  134. I need a quieter exhaust but same gains?
  135. Exhaust Solution?
  136. Valve diameters ?
  137. Untuned.....
  138. Problem - getting BOV sound when I dont have an aftermarket BOV
  139. 2.4L 4g64 Stock Turbo - Dyno
  140. The Intake Manifold Thread
  141. HELP with Radiator, any evo owner can help
  142. Buschur Evo 9 LICP review and install pics
  143. My Poor Sick Evo
  144. clutch restrictor
  145. Built motor or Turbo kit first
  146. How many miles on your BUILT MOTOR!!!!
  147. Exedy Twin Plate HD after install questions
  148. who got the Buschur standard FMIC upgrade, how come mine don't fit ??
  149. BOV, What do I have
  150. Radiator Upper Hose Placement/ 97-02 Mirage/Evo5-6? Radiator the same?
  151. Spun bearing
  152. Ses P0401 Egr Flow Malfunction?
  153. max horsepower engine can take
  154. oops, i think its broke.
  155. Turbine Housing
  156. Anyone have external pictures of the fuel tank?
  157. Need Help With Blow Off Valve Placement ???
  158. switching ECUs Help
  159. Need URGENT help please
  160. 500whp stock block club
  161. Megan Racing Exhaust Manifold
  162. CLutch Install In Socal?
  163. going to the track tomoro
  164. No boost increase with TBE
  165. Best bang for the buck intercooler piping?
  166. Where is the Nitrous?? Choosing a turbo
  167. Best Clutch/Flywheel Combo
  168. MACHV goodness. Can u guess what it is? (pics)
  169. blown head gasket!!!!!!!!
  170. BB 50 trim and Fueling??
  171. 558hp Stock block on 93oct and meth
  172. Initial Mod Review
  173. CEL And Screw Size Help
  174. Stroker guys . . . lend me your ears!
  175. Brian Crower Valve Spring and Titanium Retainer Kit
  176. 03 evo 8 wont boost past 20psi ????
  177. Tilton Twin Disc, Who Has One, Who Installed it, How long, Who Who who...
  178. review of perrin catback.
  179. Evo 8 350hp+
  180. Apex-i, Garret, or HKS? to replace stock JDM Mg Turbo
  181. Question to Bushur Racing about the Bushur Ported & Jet Coated Exhaust Manifold
  182. Got my Evo 9 LICP from Buschur. WOW!!
  183. Adapters for custom oil lines?
  184. So....hot afternoon, cool evening
  185. Which Exhaust is louder?
  186. boost leak is killing me !!!
  187. SES on, now off?
  188. exedy stage 2 just installed
  189. Timing Belt at 60k...HAHA
  190. Temp sensor in DP useful?
  191. how to achieve 425WHP evo IX??
  192. Silicon IC connectors for the Evo IX
  193. Just got the 272/272 gsc cams tuned!!
  194. Idle Misfire
  195. HorsepowerFreaks GT35R (535whp, 421wtq on stock 2.0L) w/videos and dyno
  196. Evo 8 Final Drive Gear known issue/TSB?
  197. p300 code = failed inspection
  198. Does your motor make a ticking noise?
  199. Cams between tunes?
  200. Ti-Al Turbo for the EVO final version
  201. jackson auto machine?
  202. boosting??
  203. White Smoke form radiator
  204. Missing bolt...... again!!!
  205. Intercooler Piping / BOV
  206. Boost control solenoid
  207. Question on afr/rpm
  208. Anyone noticed a little vibration at 2k rpm?
  209. Driving with p0401 CEL code?
  210. Stock EVO Ex-Manifold weight?
  211. Help on Clutch!
  212. Raising Boost... Ignition Help!!
  213. JDM Evo 9 Turbo Problems?
  214. Aftermarket Intercooler
  215. What dp/cat will play nice with Blitz Nur-Spec cat back?
  216. Wastegate Dump
  217. Installed my TBE tonight, no check engine light? how come?
  218. Stupid Fbody made me stall ;/
  219. Oil Pressure Sender Relocation
  220. MBC/stock exhaust?
  221. 12psi problem please help
  222. help please.. what causing this
  223. another TRANS PROBLEm!!!!
  224. Car wont IDLE HELP!
  225. any idea or recomendations for my next mod?
  226. CLunk after car goes into gear and
  227. turbochargers.com turbo owners report here
  228. Which TURBO!! Slowboy, RNR,Shearer,Buschur
  229. anyone running all methanol?
  230. Blitz Dual SBC Spec S installed.. only 12psi
  231. Lean start all of the time
  232. buschar/warrtalon stage one- car wont start- help?
  233. getting locked out of gears
  234. IX Exhaust help
  235. Mild build-up for street Evo PICS!!!!
  236. Probably a stupid question...
  237. Smogrunner's Super Stock Stroker Finally Hits the Track
  238. my 280 cams
  239. EVO IX Dyno Sheet - 75 more ponies than before
  240. Fan Blade Snapped!
  241. Question?? Difference Between Meth/alky Kits
  242. 02 housing/sensor problem...
  243. Thoughts on engine ticking...
  244. Knock Sensor Voltage Question
  245. Good clutch
  246. Sudden boost drop...leak
  247. 2 part A/F ratio?
  248. I have hks 264's, but just upgraded to 50trim
  249. Ported and polished head or stroker??
  250. adjusting boost after Drop in Filter?
