PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Evo 8 is making a crazy noise sometimes *VIDEO*
  2. P0455 and E85
  3. Lifter Tick, Rod Knock or Piston Slap? -video
  4. shaft play B.B. turbo?
  5. I have like 4000$ to put into my Evo, I want hp! What should I do and purchase?!
  6. Oil pressure problem???
  7. I have a stock evo 8 looking to get new injectors! How many cc's should I get ?!
  8. Turbo shot . What should I do?
  9. REQUIRED: Boost leak tester for Tomie M7960
  10. building stroker
  11. Ported turbo, no boost... HELP!!
  12. stock cams on garrett 3076r
  13. OBX accessory pulleys on IX
  14. acd problem? snow indicator won't go off.
  15. Kelford Cams with Mechanical Lifters
  16. Clutch + Flywheel job now no reverse/2nd/4th
  17. Stuck in reverse?
  18. AGP LICP Popping off
  19. 2.4L options
  20. Oil in exhaust port closest to passenger side
  21. What compression ratio for my build
  22. Help! Identify cause of noise at beginning of load
  23. Crankcase breather
  24. is SS clutch lines necessary????
  25. Cylinder wall wear...normal?
  26. What is this? (Need ID on wire to block)
  27. clutch adjustment
  28. will high psi wga help this issue ?
  29. Emergency HELP on Drivetrain problem !!!!!
  30. Higher CC injectors
  31. What seal/part no.?
  32. Need help - Walbro install
  33. Evo Gear Ratio's Convertion for Hill Climb Run
  34. Oil pressure issues?
  35. Need a crate motor!
  36. One of the weirdest issues you will ever read
  37. Block deck prep 4g64 with MLS gasket?
  38. Another 25g Thread
  39. 2005 Evo V/// S-AYC conversion
  40. Evo ix mivec intake cam gear / pulley
  41. Lets talk about tuning with bolt ons.
  42. Need some advice on oil and also catch can
  43. Fuel system
  44. Tranny improvements
  45. evo 8 getting louder?
  46. Not running the best after injen piping install. Input?
  47. Precision journal bearing turbo...feed from head or oil filter housing?
  48. Injectors
  49. Amsoil ZROD 10w30 vs. Dominator 10w30?
  50. intake tube for MAF/CBRD 3.5" ported cover
  51. experiences with the buschur racing catch can?
  52. Tial qr on sd tune
  53. Help!
  54. How do I check ground for the boost controll solenoid?
  55. 384 WHP and 410 WTQ...
  56. exhaust requirements on stock IX turbo
  57. Build Advice Evo ix
  58. Which cams for 35r setup?
  59. HELP! New intercooler install but now revs to 5k on its own!
  60. HELP! New intercooler install but now revs to 5k on its own!
  61. M2 exhaust system
  62. Info on Ported Manifolds
  63. Valve cover and Spark plug cover
  64. how to i tell if i have a stock turbo
  65. Opinions - www.protuninglab.com
  66. How much to/ how to rebuild evo 9 block to handle 30+psi and NOS
  67. Looking for real facts (VTA)
  68. Need advice on setup!
  69. Notchy Trans when warm
  70. 4th Gear notchy.
  71. JB Red> BB BBK-B (spool difference?)
  72. servicing transmision/transfer case
  73. Which $6,600 build to go with
  74. steering rack question
  75. Chewing on a turbo
  76. Help acheiving 500bhp
  77. Keeping Turbo Cool for Track Use..any tips?
  78. Stock engine, turbo upgrade
  79. SS Braided Power steering lines?
  80. Need help with my Exhaust, 2006 IX MR
  81. humming noise during right turns
  82. EVO rod and main bearings 0.020" oversize
  83. Evolution 7 valve cover AN fitting size help
  84. Which lifters to use
  85. Anyone else see issues like this with Kelford Cams?
  86. Need new turbo unit Evo 8
  87. Cai
  88. Transfer case death whine
  89. perrin fmic evo 8-9 what hp?
  90. Megan Exhaust on JDM evo 7
  91. Evo 7 trouble shooting! need help!
  92. Take a guess at what power I'll make with these two setups and opinions needed
  93. What fluid could leak between trans & tcase
  94. over tightened t bolt on my intercooler end tank. Does this look okay.
  95. Transmission questions...
  96. That's it I quit. Transmission dowel alignment help needed!!!
  97. hardwire full blown?
  98. Problem with front Axle/Trans/Transfercase
  99. Oil lines for PTE turbos
  100. 2.3L daily driver camshaft advice needed
  101. alternator might be going out
  102. Catless cars
  103. Spark gap, boost leaks, EMS TUNE!!! BOV
  104. Having a oil pressure issue..
  105. Exedy Twin Wedge Collar pop off? HELP!
  106. timing belt slop?
  107. Clutch or T-Case chatter/rattle?
  108. You're Looking @ The BADDEST T-3 Turbo In The Marketplace Today...
  109. Does Tomei make a rebuild kit for m7960 turbo?
  110. Walbro whining!
  111. spark plug gap
  112. 2.0l & 2.4l blocks sitting here, What to do?
  113. Serious problems with my ACD transfer
  114. Idle/idling problem and loss of power
  115. Greddy turbo timer shows E?
  116. 2003 VIII belt noise
  117. How can I tell if my car has a shep transmission? (help)
  118. Proper break in procedure for Exedy twin carbon
  119. Factory Balancing?
  120. Best Valve Springs w/ retainers for evo 9?? Need suggestions!
  121. Evo 9 front axle (CV axle)
  122. The Best Throttle Body?
  123. clutch
  124. IX MR possible boost problem HELP!!
  125. Exedy Triple Plate Clutch vs Quartermaster Twin disc
  126. Thinking of Upgrading my Evo 8 turbo..
  127. Funny people...
  128. Stock cams dual valve springs
  129. gsc s2 vs gsc s3?
  130. Does GT35R + T4 Divided 1.15 A/R = LAG?
  131. evo 8 vs evo 9 down pipe
  132. Car will not idle... at all... read all..
  133. CT9A center diff ratio
  134. ATF fluid leaking near transfer case Evo ix
  135. Wastegatege solenoid/misfire issues?
  136. Jmfabcbrd intercooler connections
  137. GTX3071R Exhaust Housing
  138. Acd banjo bolt specs
  139. Comp Clutch Stag3 3.5 break-in Period
  140. Torque Solution Short Shifter question
  141. built evo 9 engine going into evo 8? ( help please!)
  142. Excessive Crank Case Pressure??
  143. Clutch knock/noise..?
  144. 2.4LR Block O-RING
  145. Won't boost past 20psi?
  146. 5 speed Clutch in 6 speed
  147. head gasket change, running lean
  148. One GIANT headache on this trans install
  149. Swap from 6speed to 5 speed
  150. Intercooler Spray on Ausi Evo's?
  151. AMS or ETS FMIC?
  152. Is there any reason NOT to use a 0w30 motor oil?
  153. walbro 255 or 400 ?
  154. 3rd gear grind. during quick shift at high rpm
  155. Evo 9 vs evo 8 engine`s block
  156. MBC - Pls Advise
  157. Evo 8 engine rebuild
  158. Weird issue with MN119784 manifold to turbo stud not threading properly?
  159. Tapping Evo9 thermostat housing for an additional 1/8" NPT coolant temp sensor?
  160. Even cheaper Waterpump alternative than Gates.. AC Delco.
  161. What exhaust manifold is the best bang for the buck?
  162. Fidanza friction plate screw/bolts size?
  163. is it critical damage for exh. wheel ? **pics**
  164. Evo IX 4g64 destroked 2.2l Pressurizing Cooling System
  165. Odd Idle After Switching to 93 Map
  166. Running Lean! Need Hepl!
  167. Transmission swap, quick question.
  168. Need help with fuel rail selection
  169. Fuel Injector Clinic releasing new injector line to flow 1600cc+, safe for all fuels
  170. Grind going into 5th gear at high RPM
  171. Clutch advice needed
  172. Fuel Injector Connection injectors, shady business??
  173. JDM EVO 7 humming/moaning noise!?
  174. Do twin disks clutches mushroom synchro rings and break synchro springs?
  175. Need help! First startup rebuild, won't catch and start..
  176. Custom turbine wheel
  177. Is turbo 16G>20G turbo upgrade worth?
  178. Best oil to run with an FP Red?
  179. Ix mr shifter issue
  180. Funny turbo Kit!
  181. intake manifold...
  182. Evo's Idling Oil Pressure
  183. Timken makes rear hub bearings now?
  184. Overlooked Detail..
  185. Can't plug in injectors!
  186. pulling head help?
  187. evo 8 motor in evo 9
  188. The best ways to gain 100WHP on EVO 8..suggesstions
  189. Need rear an breather valve quick!!
  190. OEM to thicker Cometic head gasket?
  191. Aem ems v1 vs v2
  192. AMS gt3076r Turbo help?
  193. Buschur stage 3 head vs Wiseco e85 pistons
  194. 4g63 on AEM series 2 and Bent cyl 4 ex valve??
  195. bad maf sensor?
  196. stock boost solenoid harness
  197. Electrical Issue
  198. ECU Problem????
  199. New valves/guides/seals for my head
  200. AMS F1-I Intake Manifold
  201. redrilling/reflanging an AMS F-1i manifold
  202. Overlay install during turbo porting?
  203. gtx 94mm wheel?
  204. Evo IV random drop in revs
  205. Evo 4 output shaft removal
  206. oil in exhaust
  207. ACD pump over full when car not running
  208. Shifter bushing question
  209. eboost 2 settings
  210. apexi twin chamber bov
  211. Copper Spark Plug for IX?
  212. Metal shavings in intercooler piping
  213. Transfer case thru shaft play...
  214. question about spark plug
  215. Removing TPS sensor question
  216. evo 4 boost problem
  217. Fp black min 25 psi?
  218. Weapon-R Intake Manifold Thoughts
  219. clutch break in
  220. opinions on my catback exhaust
  221. EVO 8 Transmission Rebuild 5MT questions.??
  222. Battery relocation kit help
  223. Oil filter housing fitment
  224. help with vacuum lines
  225. competition clutch problems
  226. boost creep issue
  227. need some help on p0365 code
  228. Fuel pressure regulator help
  229. AMS 850r Kit- cracked O2 housing..what next?
  230. GSC R2 Stroker Cams Preliminary Testing and data!
  231. For those of you with the Greddy Tic catback...
  232. Homemade COP spark plug gap
  233. advice needed,, for changing pistons
  234. Open the hood and theres oil everywhere!
  235. Need help. Turbo replacement , direct bolt-on
  236. Evolution 5/6 exhaust
  237. Need some cams advice....
  238. Injectors high/low impedence
  239. HKS GD twin plate clutch?
  240. Need HELP deciding on CLUTCH!! 700+hp
  241. Clutch slippage and other stupid questions...
  242. Evo 8 clutch slave cylinder!! ASAP
  243. 9 turbo vertical shaft play question
  244. Please help: 05 MR power drop when WOT at 6800 RPMs
  245. Which lifters are these? pics inside
  246. Invidia question o2 housing
  247. Evo 8.5 build
  248. weird whine sound ?!! + Newbie Question
  249. Any isses with removing/plugging stock intake PCV nipple?
  250. Dies when clutch depressed
