PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 [102] 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Exedy 05803 Stage 1 Clutch
  2. Evo Transmissions
  3. Spark plugs..
  4. boost selenoid
  5. Battery in the Trunk
  6. Any one help me with this?
  7. porting stock manifold and 8 turbo
  8. AMSoil MR tranny fluid
  9. calling all methanol users
  10. half gallon of meth leaked into the UICP
  11. Boost Leak or Slipping Clutch
  12. How much goes in the t-Case
  13. Clutch pedal too high
  14. Went to port my header, tuner said it's a waste
  15. Help with Forge BPV FMEVO15: Spring Question
  16. Fidanza 3.2 noise
  17. Quaife Lsd ........ Wow....
  18. how do i hook up the stock blow off valve again?
  19. Fuel Trims no longer log
  20. Lifter Question's etc....
  21. 03 with front lsd but no acd ok?
  22. Anyone running the push style exedy twin?
  23. 3 Transfer Cases broken - What to do?
  24. unequal length header
  25. Throttle body idle screw setting?
  26. Stock Evo 8 Little help
  27. which tranny fluid to use
  28. car locked up high rpm going into third!
  29. Launch CREADER Universal OBD II OBD2 Trouble Code Reader 14.99 FS
  30. cam angle sensor's rpm signal wire?
  31. Fuel Pumps
  32. FP Red on bearings
  33. Turbo: help needed
  34. Car sputtering really bad
  35. Unknown Boost leak!!
  36. GM 3 Port
  37. eno 9 mivec pulley
  38. Which one will go first?
  39. Water in oil?
  40. blown head gasket??
  41. Cam Gears and Cams Questions!?
  42. Rounded Lobe
  43. Symptoms of Blown HG?
  44. hks ssqv
  45. injen intake with stock uicp
  46. P0031 Code symptom of something else?
  47. REAR Quaife LSD
  48. ANOTHER!!! camshaft question(theres alot)
  49. MAP downpipe
  50. What you think of my cam install plans?
  51. HTA86r vs HTA37r?
  52. My day just got REALLY crappy
  53. Approximate labor for 04 Evo T.C
  54. bbk vs. fp red vs. tomei arms for stock block pump w/meth
  55. coolant leak
  56. HELP: Weird idle issue when refueling...?
  57. 02 housings suck in cold weather
  58. mishimoto tranny cooler
  59. Synapse BOV
  60. Ebaydealer cop ignition system?
  61. drop in pistons and rods!
  62. pleas help with clutch
  63. A/F and IC pipes?
  64. Evo 8 idle and radiator fan issues
  65. Having trouble finding.....
  66. Car dies without constant gas.
  67. Turbo Question
  68. cant make up my mind!!!
  69. screwed myself over !!!!
  70. Is this normal?
  71. Just fished installing o2 dump
  72. Heater Core Leak..?
  73. Look what UPS delivered yesterday (39 PICS)
  74. GD Walbro fuel pump!!!!
  75. Too much knock!
  76. Easiest way to remove copper o-ring
  77. another p0134 question
  78. Clutch Problem?
  79. 04 Evo T.C, where to get it
  80. Aluminum vs stainless steel
  81. Looking for 450awhp on leaded 110...
  82. p0171 question
  83. Precision 1200cc Injector Battery Comp (usec) - Lag timing
  84. Few cam questions before purchase
  85. Quiet Possibly Worst Day! what now?
  86. Does anyone here regret getting a lightweight flywheel for their EVO 8-9?
  87. AMS Oil Pan?
  88. pricey inlet manifold
  89. O2 trouble
  90. boost actuated cut-out
  91. Quick question about Walbro 255lph
  92. Race gas question
  93. Stock Fuel Pressure in a 04 evo 8?
  94. Using Stealth FX BOV
  95. low boost... high boost... spike!?
  96. Evo 6 TME Parts
  97. Small Probem (any info would be great)
  98. Pics of MR 4th gear failure
  99. My FP-RED vs FP-GRN on 91oct dyno compare
  100. NGK BPR6es
  101. turned my perrin hfc into a test pipe
  102. Low vacuum at idle, with idle drop
  103. Buschur uicp and Turbo xs fmic
  104. Something leaking, but only when launched?
  105. Cost for clutch installation
  106. Every time i **** quickly i hear a thump
  107. Slowboy Racing FMIC
  108. Where's the woosh sound? (Greddy RS BOV)
  109. How much power with these mods?
  110. HKS 272 intake cam problem... P0505
  111. NGK spark plug evo 9...
  112. air filters; filtration
  113. Need HELP! Problem Evo
  114. Full Blown Dual Pump Hanger
  115. Constantly Adjusting Boost?
  116. Boost leak issue
  117. Return pipe
  118. looking for oppinions on a couple clutches
  119. (Help) Loud vibration when launching
  120. H-bean or I-bean RODS
  121. Purpose of a Oil Catch Can
  122. i think my clutch master cylinder went bad!
  123. Forge recirc valve to APS twin vent with problems now
  124. Any one with a Fullrace intercooler?
  125. Greddy type RS bov
  126. LICP sludge
  127. What oil do i need to use for the transfer case and rear differential?
  128. Help: Spark plug in 2nd Cylinder from driver side black...?
  129. I have a newb question..
  130. Oil Cooler + Turbo
  131. EVO VII MR - Ti/alloy option
  132. New problem...can't figure it out
  133. wiseco .20 piston pin
  134. Slim fan size?
  135. IX MR; 2nd Gear POP OUT on decel, any ideas?
  136. 37R guy please step in tuning question...
  137. bad wastegate maybe or something else?? (this car is driving me nuts)
  138. crankshaft discussion
  139. Just Ordered my Tomei ARMS kit today
  140. NGK BPR7ES gap on stock evo 8
  141. ACT 6 puck sprung guys ???'s for ya
  142. how do ya take out gearbox????
  143. HELP oil light blinks n idle
  144. Clutch job turns into lil build up :)
  145. Cost of Tcase/Tranny
  146. Does your EPM dump tube leak?
  147. Evo 8 turbo problems please help
  148. balance shaft seized up!! help
  149. MAF sensor orientation?
  150. Blew seals on newish FP Red?
  151. intake cam install help please....
  152. Greddy counter weight shift knob
  153. question about tc and rear diff fluid
  154. Any one have issues with water damage to their BOV?
  155. Oil for BUILT Engine! *Yes, I searched*
  156. fuel pump and fuel filter loction
  157. Buschur or Shep Rebuild?
  158. Manifold Coating
  159. Anyone with a VIII tranny not installed..need help
  160. quick question
  161. To destroke or not to destroke
  162. 4th gear problem
  163. Amsoil severe gear 75w110
  164. Cylinder head testing - Part 1 - 823 whp base line on HTA88
  165. methanol... do or don't
  166. looking for the "how-to" timing belt swap
  167. Evo 9 mivec gear differences??
  168. ? On Apexi exhaust.
  169. evo hesitation
  170. Converting tranny to run FWD (READ BEFORE YOU FLAME)
  171. building block ?
  172. Help me plzzz
  173. Need help asap, injector question.
  174. Boost not holding
  175. GFB BOV leaking from top
  176. I think my 3rd gear syncro is done!
  177. converting my 9 to an 8 (remove mivec)
  178. How much HP can the stock clutch hold before starting to slip?
  179. boost leak?
  180. theory question???
  181. Stainless steel clutch lines???
  182. stupid brake/clutch fluid question
  183. Oil catch can question
  184. help! headgasket blown.
  185. Competition Clutch Flywheel/Clutch Install on Evo IX RS
  186. How much does the Evo muffler/tip weigh
  187. wont boost all the way :(
  188. Loud beep noise
  189. Labor/ Hourly Rate for Install of Cams, S&R, Timing Belt kit, Head Gasket....
  190. Oil temp. sensor on the 5 speed tranny
  191. Kelford Cams Selection
  192. ACD problem
  193. ACD problem
  194. 5 speed tranny lockout
  195. Samco and amsoil 4560?
  196. switching to e85?
  197. Low Boost bad ignition coil boot?
  198. Bad clicking sound, axles maybe or something else?
  199. Weird Noise on first decelerate??? (not throwout bearing)
  200. optima battery
  201. engine whine
  202. RPS Clutch
  203. best fuel pump
  204. mY nEW bOOST leak Tester. (pics)
  205. fidanza 4.3 clutch kit
  206. bubbles in oil on dipstick?
  207. cant track down this t-case leak!
  208. I/C piping
  209. Advise on turbo 850 or 950r
  210. Exedy Twin rebuild
  211. Engine Built - Now Strange sound!!!
  212. Engine vibration after head gasket install
  213. Stock Fuel Lines
  214. holset 256
  215. Cam Gear Setting (hks 280)
  216. aftermarket clutch/tranny??
  217. HKS 280 lift?
  218. Bar to PSI conversion.
  219. Low boost after shifts... help
  220. Grinding from motor mount
  221. Problem please help!!
  222. Best Turbo with 2.2L and E85
  223. Having a problem with lower IC pipe for Buschur Race FMIC
  224. will stock radiator fan fit with Full race single scroll mani and Gt35R?
  225. New Clutch & Flywheel Noises
  226. decel smoke / E85
  227. Evo Intake Manifold from Finland
  228. tial waste gate??????
  229. 35 R with full rase mani on stock motor with stock head studs?
  230. 6 spd tranny fluid quantity?
  231. exedy twin ?
  232. Megan Black CatBack Exhaust, Sound Clip
  233. Need help figuring out what part goes here.....
  234. Full-race t4 1.06ar twin scroll HTAgt3582r tuned on stock motor results
  235. 2.3L Stroker Owners Unite! - Dyno Sheet & Mod Lists
  236. Stock Oil Return Line Bolts ( Turbo Side )
  237. o2 housing to Down pipe Gasket?? 3 inch 2 bolt
  238. Is this walbro pump ok to use?
  239. walbro or denso?
  240. Steering wheel shaking under moderate braking?
  241. evo main bearings
  242. Evo Warm up Time?
  243. Forged Performance RE-Build
  244. Perrin MBC?
  245. Wanted: ACD Service Manual
  246. o2 issue
  247. Question about lowering compression
  248. 1000cc Injectors question??
  249. Trying to find some info tre 6spd upgrade?
  250. whats wrong with mt trans?
