PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 [161] 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Titanium Pistons,Rods, Cranks, Camshafts,etc....
  2. built motor and 35r ? on oil pressure
  3. Whinning Sound???
  4. Rev limit on the 4g64 crank
  5. Piping blowing off
  6. replacement front o2 or Wideband
  7. st0ck clutch
  8. My 2.0L Motor :)
  9. burning oil
  10. Twin intake/double pumper...more Buschur results..
  11. '04 RS t-case into '03?
  12. Video of 644 whp EVO9 on Buschur Racing's dyno
  13. Stock WGA-Travel distance?
  14. TTP-Engineering High-Flow O2 housing Bolts?
  15. ingalls torque dampener leaking
  16. boost level questions need help...
  17. How many 6 speed owners would put this in their tranny?
  18. Non ACD T/case on ACD + AYC EVO??
  19. MEGAS dp and ULTIMATE RACING test pipe bolt up ??'s
  20. Quiet exhaust with no loss in Performance
  21. Tuning Guides or Books...
  22. boost gague busted or need to turn the boost down?
  23. To much boost?
  24. Evo 9 Cosworth Cams dyno
  25. Timing belt change
  26. IK24 or IW24
  27. which head gasket? head gasket sizing issue..
  28. WAT NEXT upgraded???
  29. s-afc bad???
  30. alky injection kit???
  31. i need opinions
  32. The tip of the spark plug broked,need opinions?
  33. IX w/GSC S1 cams & meh - Need Injectors?
  34. Questions on oil lines RNR guys look!
  35. ATTENTION ATP turbo kit owners and others.
  36. Deceleration Noise?
  37. Strange boost problem
  38. Thinking of buying an Evo, but worried about tranny problems. TSB's?
  39. PEAK BOOST vs Shearer vs AMS <--(50trim)
  40. safe to turn up boost?
  41. Clutch pedal vibration????
  42. aem short ram
  43. greddy type s bov
  44. AUTOmeter z series gauges
  45. 20G-LT Camshaft options....
  46. Idle Problems Hunting
  47. Evo 8 front o2 sensor question
  48. Help please with intercooler piping !!!
  49. Pruven Evolution 9 39psi/687AWHP dyno video
  50. wat next for evo??
  51. Buschur Racing just finished a SICK Evo 9
  52. 400whp IX possible with ONLY cams or ONLY Methanol (Plus supporting mods for both)?
  53. ss clutch line install.. Do i need more brake fluid?
  54. Reseting Ecu
  55. 9k miles & clutch slipping???
  56. got a IX 23k ,,,hearing a little whinng u think its my transfer case ..
  57. Instron tensile test: stock headstuds Vs. ARP headstuds
  58. Official Dual Walbro Flow Test...
  59. What kind of oil is best at Evo engines? Valve ticking..
  60. Difference in Nisei FMIC Street & Competition?
  61. upgrading manifold..
  62. IX upgrades - sanity check
  63. Mail in flashes
  64. heat wrap downpipe.
  65. Intercooler upgrade question
  66. BR Mail-in Flash......PERFECT!
  67. different dyno tunes
  68. Has anyone used the gruppe-s flywheel on their evo?
  69. ECUTEK vs reg custom flash?
  70. Quick exhaust question
  71. Another turbo thread with poll
  72. supertech dual valve springs?
  73. Throw-Out Bearing or Burrs on Clutch Plate
  74. AEM Tru-Boost question
  75. noise coming from back
  76. Coolant leak smell
  77. Megan DP and test pipe. Same for both Evo VIII and IX?
  78. Is this a stupid idea?
  79. Update on second build
  80. zeitronix / knocking
  81. Best Quality High Flow Cat, And JDM Rear Bumper
  82. Benefits of LICP
  83. Changed oil now clicking sound.. help
  84. Ti Upper IC Piping
  85. Boost Cut W/Minimal mods
  86. 20g or 50 trim
  87. Question about MBC
  88. Which 680cc injectors to buy?
  89. Need Help on this subject!
  90. PeakBoost 35r top mount kit
  91. Can i run Nos on my built 2.0L engine
  92. Dual Denso Pumps !
  93. fpevo green dyno numbers
  94. Most WHP on Pump Gas 93/94 Octane Straight up Daily Driver
  95. Can someone help me identify a noise from my car?
  96. agency power lower motor mount
  97. 280 cam install
  98. How Important is this piece??
  99. About LSD
  100. PLEASE READ GT35 impressive setup
  101. Short Shifters
  102. AMS Ti TBE
  103. Wierd coolant temp gauge readings.
  104. BC 272s, BC Springs and Retainers and more
  105. all about CAM GEARS
  106. overboosting after 6k rpm?
  107. HKS carbon TI with dc sport dp NO CAT
  108. FP3065 on 91pump/alky - Who does it? (Compared to 50trim)
  109. How do i remove a pin on the ECU harnes??!!! AARRGGHH!!!
  110. EVO IX GSC cams
  111. **GSC S1 CAMS TUNED** Numbers inside!!!!
  112. what plugs shoud i use?
  113. 3" cutout or TBE
  114. link to TRE?
  115. Evo problem... Boost
  116. plz help hks evc is blinking
  117. Gearing change
  118. WR application question or larger turbo
  119. Pruven Evo IX Updated Pics/480AWHP Pump!
  120. Turbo XS Dtec BCFC
  121. AMS 50 Trim or Buschur 20G LT? I'm torn!!
  122. turbo xs d/s mbc
  123. weird situation...need exhaust advice/help
  124. Are all EVO IX's diffrent do to the MIVEC?
  125. Flywheel Question
  126. Anybody else need to change rear diff fluid at 5k??
  127. Over-rev problem
  128. How is GT SPEC manifold?
  129. Helpppppppppppp
  130. Wtf!?!?
  131. Help car feels like it's dying after Hids
  132. Best turbo for pump gas? 50trim or FP3065?
  133. GSC TruTurbo Back Exhaust System.. Teaser Vid Inside
  134. ORC products are now in the US
  135. 50 Trim Questions
  136. The NEW "GT35R" from Buschur Racing..
  137. Can some one Enlighten me on what a Diff Basket is?
  138. New AMS Engine 23RR Engine = Big Power!
  139. anyone got work done at ExtremeMotorsports?
  140. Which LICP is recommended?
  141. swapping 05 diff into a 03??
  142. Size Does Matter
  143. question for peopel running larger throttle bodies
  144. Boost controller suggestions welcome!
  145. New SPEC twin disc
  146. !!!AEM Gauges Installed By Machine Gone Wild!!!
  147. 5 speed vs 6 speed centre diff
  148. What aftermarket parts are you running with your IX's and are you happy or not?
  149. buschur race ic
  150. MAJOR help needed
  151. Clarification for P0138 EGO Sensor Circuit High Voltage (Bank 1 Sensor 2) needed
  152. **GSC S1 CAMS installed**(Pix Inside)
  153. tuning for 110 oct?? lean it, more timing?
  154. Consumers be weary of misleading information.
  155. Whining Noise
  156. resurfaced flywheel
  157. Lean A/F and Idle stumbling
  158. ATS Triple Disk cltuch
  159. Question after FMIC,LICP,UICP and Forge bypass install...
  160. anyone w/an hks hi-power catback plz stand up
  161. question about dumping the clutch.....
  162. New HKS BOV ????
  163. Garrett Turbo sizing????
  164. dumping the clutch....
  165. 3.5" Over 3.0" Exhaust Debate
  166. Galant inline fuel pump...
  167. Tanabe Medallion Touring
  168. Who has the BR Stage I for the VIII?
  169. Does you exhaust hang low??
  170. Turbo Kit VS Stroker Kit???
  171. Monster Sport Intercooler Piping
  172. Got a baseline dyno today...
  173. help!!! NEED TO KNOW WHAT CLUTCH TO GO WITH!!
  174. Blitz Nur Spec Bl MM3030 ??
  175. Need ACT clutch
  176. Why most popular Evo exhuasts suck - a tube is not a tube - read - case study
  177. Help Water level low / cuts / Temp crazy / Noise at start up
  178. Dual Grey A-Pillar 60mm Gauge Pod
  179. Who's using Ultimate Racings CAI?
  180. Tilton clutch ?
  181. JUN cams in stock? Who has them?
  182. Megan Manifold vs Buschur Manifold
  183. Can a HFC be flipped and still fit?
  184. Input on an 02 housing on a IX
  185. Anyone make a Air filter w/ air funnel built in it?
  186. Exhaust troubles
  187. Full Powerflex Bushings Diagram/Part #s
  188. Truboost gAE question / Evo IX int wg spring?
  189. Help Water level low / cuts / Temp crazy
  190. need a belt for NO a/c
  191. The EBAY Intercooler
  192. Weak Evo IX Turbo?
  193. Mivec
  194. Perrin exhaust clip
  195. Hks Ebc
  196. Greddy Mivec cams.
  197. max boost on stock head gasket?
  198. tranny fluid
  199. size of turbo inlet
  200. Forge wastegate actuator or Buschur's high boost wastegate actuator
  201. how to install meth kit?
  202. GSC S1 Exhaust Cam only results inside.
  203. Stock turbo removal question?
  204. HELP!! high vacuum reading
  205. Biggest Cam on Stock Valvetrain?
  206. zeitronix zt-2 and vacuum @ idle on stock IX
  207. Trouble Code PO401?????
  208. Any one jealous of my stock turbo outlet
  209. Perrin PW1 Water Injection??/
  210. Bad cam gears?
  211. Before/after dynos of BB 50 trim on a IX?
  212. clutch and turbo manifold questions
  213. 6 speed (MR) transmission fluid fill and drain bolts?
  214. Any Evo IX's with the ATP kit?
  215. The "Evo Thump" on the Shift
  216. How much HP?
  217. What do you guys think?
  218. which Kevlar clutch should i go with?
  219. Turbonetics GT-K Series
  220. Cusco Center LSD vs. Stock VCU LSD
  221. going in to get tranny checked
  222. Need a way activate a relay via boost?
  223. 272's vs. 280's
  224. what it takes to get 400-450 whp?
  225. what should I make?
  226. BOV connection on Garett turbo
  227. question for tranny experts
  228. Latest Tune by MZM International
  229. questions on mbc and dv!
  230. Some goodies thanks to Greg@GSC
  231. Path for my ATP GT3076 turbo?
  232. 2 small problems
  233. who sells 8 ga. SS bends?
  234. cosworth isp head flow numbers
  235. Jun 264s
  236. Looking for a BOV Flange....
  237. Motor/Tranny Mounts....Revisited
  238. Fujitsobu catback mated to buschur downpipe/testpipe
  239. Cam Install tips
  240. help my hks evo 5 just broke
  241. Aps
  242. ss 02 housing
  243. buschur modified fuel pump walbro
  244. XS Engineering Intercooler pipe kit questions
  245. ix turbo on VIII
  246. 10.5 hotside
  247. difference between 3037r and 3076
  248. Lean A/F ratio.
  249. Dual Walbro Flow Tested
  250. Clutch problem or tuning problem?
