- can someone help
- Transfer Fluid Change (pics)
- O2 sensor question
- Question On Exhaust Tapering!!!!
- Blitz Super Cooler hose
- acd and fmic+helix pipes problem?
- new bolt on turbo!! momentumturbos.com
- Help, Hallman likes 19 PSI
- boost surge??
- Aftermarket Header Q's
- Are our injectors capable of this?
- Cracked teeth on first gear... :-(
- Let's talk HKS EVC V
- tc fluid
- DP and HFC question- new to forum
- JUST PURCHASED 3076R Kit from RNR Racing
- megan manifold and o2 housing
- intake noise
- Borla header Gains!!
- installed my XSPower intercooler this week
- Accurate Boost Reading Question.
- gt35 and gt35r
- I need HELP!!!! Thanks
- car won't idle
- Just Got An Evo!!!!
- 500+whp turbo
- How much boost is safe for me?
- Ignition
- stock Vacuum lines
- Mexford Header,10.5 Hot side,O2 Housing installed
- pronlms with idle and ticking very loud
- Buschur/SMC alky kit users...NEED QUICK HELP!
- valve adjustment?
- Gauge install!! Please help!
- Invidia downpipe..
- Leak chasing
- Can you tap a wideband sensor into the exhaust or does a bung have to be welded?
- stock RS blow off valve vs. MR blow off valve
- "Service Engine Light" on at 20,000??
- Apex-i Turbo Upgrade
- Hallman pro rx question??
- people with Weapon R Catch Can
- bleeding lifters
- middle hose on HKS EVC
- Will this pump work on a DIY alky kit?
- HKS S40G/S45G spark plugs
- 3 stage water injection - in progress
- boost spike to 1.6bar on 91 :-O
- which is better the white rabbit or the 20g
- 2005 Drivetrain Whining
- Invidia downpipe!! q??
- My White Rabbit Dyno - 364 on Buschur's MD
- No Boost, Loud Whining Noise Above 2K RPM~
- plug reading
- hks jun cam setup?
- Installing Just a Clutch Disc....
- Twin 16G Setup on ebay.
- Advice on clutch
- Tranny TSB? Where?
- AMS 3071 kit finally tuned ... link to info
- SPL Racing Exhaust
- Boost Taper?
- High altitude, long duration cams, and you.
- people with hks 30anni exhaust
- Increase HP with a larger intake manifold
- Odd situation with coolant gauge .. Please help..!!!
- engine control fuse?
- Weight of Evo Engine.
- 10.5 Hotside???
- Engine backfired, then died.
- wtb greddy 720cc
- 0 on boost gauge!
- Looking for a clutch...help a fellow girl racer out =)
- Switch to XEDE? Is it worth it?
- Only 4 Volts On Mfi, Wheres The Supply For That 4 Volts That Needs To Be 12?!?!!
- clutch install pricing
- 2003 evo 8 possessed after mods!
- cam gear setting problem
- HELP!! Where to place oil pressure sending unit??
- need help with ferrea p/n
- clutch/tranny?
- Whiterabbit: 91octane and C16 Results
- 2.7 Gt42r
- PeakBoost 2.75" upper charge pipe sneak peak..
- What should be my next mod?
- Coolant splashed all over engine bay?
- Confused with symptoms
- 10.5 Hotside's..... ANy power difference?
- ideas on rod & piston combo!
- are any of the 9sec or 10sec evo's using aftermarket pulleys?
- C16 vs. VP104 vs. alky
- LOL Twin turbo kit for Evo8's
- Aluminum flywheel
- Can someone pleeease help me??
- Whats the difference between these BOV
- passive boost solenoid eleminator
- Is this a solution to Lifter noise ?????
- Sludge Master - Why Proper Breakin is Important
- Boost tubing size
- Best bolt on gt30 kit ATP vs Vishnu vs Buschur
- exhaust "cut-out" on evo?
- More Cam questions
- Just buying a clutch disk...will it work?
- Increased boost, now reading lean on wideband
- EVO 6.5 Exhaust housing?
- 2005 Evo 8 with alcohol injection? Anyone?
- Test pipe and tune
- Need Contact Info for RPS
- choosing the correct heat range
- what is this? a Sensor?
- how much gain out of upper and lower 2.5 ic pipes?
- Is it my halfshaft or my TC thats bad?
- Alcohol tuning question....
- Peak Boost manifold
- 264 Cams Tuning?
- Blow Off Valve Question.
- What do I tweak after adding intake?
- Need a bit help with SSQV v.2
- 2871 Turbo
- turbo xs exhaust
- Buddy Club Racing Spec Condenser
- where to place egt bung along #1 runner
- INtake pipe w/Stock Box?
- hks 280 dyno"s/numbers
- Helix RNA Camshafts now testing! :)
- IC sprayer for alky
- Thinking of selling my alky kit...
- EcuTek flash w/K&N drop-in filter
- running rich
- Hks Evc 5
- Good lord, another tranny leak, but from where this time?? HELP!!
- Car got towed...not on a flatbed
- Aftermarket bigger alternator???
- Should I be worried?
- **K&N intake**
- Weak MBC?
- Help: NEED INFO ON WHINE (and thats not the good kind)
- OE WR actuator preload... heavy spring actuator install.
- nice, downpipe->o2 bolt stripped?
- DNP 02 Housing - Stock downpipe bolts?
- cam: gsc vs hks
- Drivetrain durability and Mods
- Looking for Megan exhaust sound clip
- 6.5 Tme Rs Turbo Buschur
- Notchy Shifting on 05
- does anyone know....
- 03 Clutch
- Anybody put an MR tranny in their GSR/RS?
- What would you do next?
- Need Stock Turbo Compressor Outlet Pipe or Outlet Flange
- Bad rear diff?
- RSR ExMag Exhaust - yes I used search
- Ordered ACT clutch kit, wrong part?
- heat issues on the track?
- Will the HKS DP Fit an 05 GSR? (searching provided mixed results..)
- anyone gone from ACT to a twin plate clutch?
- 4 bolt 02 housing flange????
- Terrible starter noise!!
- Installed HKS SSQ BOV on my 05, VTA, now the block off plate blew off!!!
- What HeAt coating do you have and what is your experience with it?
- I think I have broken Syncros, but dealer says no
- Rpm ????
- Somewhat Technical Question
- Is the heat range 9 too cold?
- stock BOV is leaking bad, whats a good replacement?
- 03 helix dp fin on 05?
- turbo seal?
- what next?
- TRE Tranny and WORKS upgrades..First Impression!!
- Taping sound at 1000-3000rpm's
- RnR Manifold installed?
- Help Help blowing fuses
- More newbie questions
- i need help!!! is it time to change bov?
- Boost gauge at idle?
- what i started tuning today...
- Help what should I do?
- who sells JUN cams?
- DC sports Downpipe
- Weirdest clutch problem ever and no one has any ideas!!!
- Seafoam????
- What kind of metal for manifold?
- magnesium valve cover
- How is this tune? (AFC)
- Boost ?
- How many walbro's?
- Replacement Steel Friction Inserts
- S-AFC Tuning Log
- flywheel
- Hks Evc Heeeeelp merge
- Mods With Alky Injection
- hallman pro rx bc question.........
- SHOOTOUT Import vs Domestic IRP may 06!
- Another penzoil syncromesh review
- Tomei vs. JDM MR DV
- bracing an ebay turbo manifold
- Not Sure if i have a boost leak or not HELP
- Tanabe Ultra Medalion And Ams Exhaust Owners Click Here
- Fujitsubo Exhaust Owners Click Here
- Upgrade injectors?
- 264/272 cam ger setting?
- Exhuast and Intake cams
- cam and camgear question
- coolant reserve tank question
- Evo 8 exhaust
- DOG BOX vs STOCK TRANNY
- Forge WG actuator install problem
- Exhaust leak!
- Flywheel bolt heads deformed...any ideas
- Just get it, no questions asked!
- PeakBoost prototype GT kit pics
- Why is my boost ramping up so slow????
- Exhaust Smells Horrible
- Any Apexi WS catback users?
- White Rabbit 1/4 Times
- boost gauge needle vibrates badly.. is there a fix?
- Quiet Helix !!!!!!
- Draining pump gas to put in race gas
- Buschur Racing mini batt & upper ic pipe
- Another Dead, Second Time
- Check out what happens to your stock EVO parts.....
- Buschur Racing Shifter Bushings
- Triple stage water injection
- tick tick tick tick..........
- Side effects of too much timing......?
- question about exhaust systems
- t3/t4 50 trim kit numbers please.....
- Am I being ripped off?
- To pump, or not to pump?
- Gauges question
- oil change question..
- Messing around with venting
- Installed Hallman, got bucking, did i knock???
- Which 4g64 is the right one?
- to flywheel or not
- Black BR EVO goes out again....
- APS 3" TBE on an MR...anyone??
- Long Term Redline 75W90 vs. Pennszoil Synchromesh -- mostly Review
- Buschur Racing AWD Dyno Ready to Rock & Roll
- Q. for those using the gm boost solenoid
- Buschur DP w/ Diff Catback
- debating Hallman MBC
- Is this a good exhaust setup
- What Test Pipe???
- Turbo Smart MBC problems HELP!!!
- Installed Kartboy Short Shifter Today
- Some action from an Auto Cross Event!
- ACD settings: I like Gravel better than Tarmac
- damn boost controller!!
- Anyone running a GT35R and Nitrous?
