PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Lancer evo 8 rear left outer cv joint
  2. Evolution Flywheel Diameter?
  3. After catch can (pcv side) install. Engine won't turn over after short drive.
  4. FP Black on Stock Evo 8?
  5. Need Help, ALL 3 ACD Lights on
  6. Wideband Install
  7. ECU -Evo7GTA vs Airtrek Turbo (4G63T -Auto)
  8. FIXED! Intermittent lean idle.
  9. Evo 5 Cold air intake
  10. Idle issues & low vacuum (with Video)
  11. Brand new Transmission Issues....
  12. Will an Evo 6 ayc pump fit in an Evo 7?
  13. Crankshaft burn
  14. Boreless compressor wheel
  15. My Install and review of FP Cast Race Manifold.
  16. Aftermarket rad +stock fan
  17. Listen to my tick!- Video link
  18. Is the revised HKS GTII 7460R housing reliable?
  19. Opinion about oil return line
  20. Best "push" type clutch that holds 600 wtq?
  21. FUEL Relay 3 Plug/Wire Color Code Diagram
  22. Manley cranks balanced or not?
  23. What springs and retainer???
  24. Boost fluxiating
  25. FP o2 cast housing
  26. HEY SKUNK2, Should have listened to me. HOW TO MAKE YOUR TB WORK.
  27. Wiseco Boostline rod for evo opinions?
  28. Anyone ever heard of this brand?
  29. Broke my Wastegate Solenoid, need fix ASAP
  30. Evo 8 recirculating bov
  31. Super Bad Idle
  32. Front facing turbo without air filter?
  33. Tial MV-S wastegate spring setting
  34. Going to 71HTA on my 05 MR
  35. Who makes this manifold?
  36. Making more power in my IX
  37. What kind of oem turbo in Lancer evolution 8 2004
  38. Evo 8 -6 Fuel Feed Line? How to
  39. Evo 8 blown motor oil cooler question
  40. Timing belt set on ebay
  41. Opinion on oilpan upgrade
  42. Decisive
  43. Replacing clutch hydrualic line options
  44. Axle wear comparison: 25k vs 90k CV bearing inspection
  45. Full Blown to Buschur Help
  46. HKS valvespring retainer options?
  47. WORKS 272 cams
  48. Broken serpentine belt & water pump pulley !
  49. Different actuator springs
  50. KKK K27 on 4g63
  51. Take a journey into my Tranny - let's see what we find
  52. Rpm drop once put in a naturel and want to stall
  53. Coolant overflow/air pockets/ bleeding
  54. Low idle at stop light. Running lean?
  55. Brand new ORC twin plate clutch loud scrapping noise??
  56. Interested in 2.1 destroker build
  57. Acd fluid??
  58. Evo 8 misfire (?) after spark plug and wire change, back to old parts and still same
  59. Best fix for vented TIAL 50mm BOV
  60. Top mount forward facing manifold
  61. Idle Issues
  62. Clutchmasters FCV-2000
  63. Mishimoto half rad not cooling
  64. Wastegate spring vs boost
  65. Curious about S1 vs S2 vs Kelford 272s for my setup
  66. UPP o2 hood dump
  67. transmission noise at idle
  68. Trans Swap: Evo X trans in Evo 8/9
  69. Fitment of evo 8 downpipe on evo 7
  70. How much life my exedy twin has?
  71. AMS piping w ETS intercooler?
  72. Need your help guys about exhaust manifold/turbo
  73. Using IGN1-A coil help?
  74. Stripped Coil Bolt on Valve Cover
  75. Gearbox issue
  76. Throttle clicking?? Help.
  77. Evo7 mivec engine swap no response to ayc pump
  78. 2.4l with mivec, what value of mivec advance represents zero overlap?
  79. How long of a wait for New FP black?
  80. Valve spring install question *searched*
  81. Using aftermarket pistons from SR20 or VG30
  82. Quick question regarding evo9 MR GSR Turbo. Insight needed
  83. Blown evo 5 motor Need Advice or build suggestions
  84. Evo 7 Trans into my Evo 9 MR
  85. lsd options
  86. Please help!!! 05 evo
  87. Evo IX trans rebuild. Options???
  88. Is TSCOMPUSA still alive?
  89. Can I mix MT90 with MTL??
  90. RPM spikes when clutch is disengaged
  91. Clutch not engaging
  92. chatter noise from t-case
  93. advice on my engine package
  94. FP Turbo help
  95. New owner post
  96. ACT ME2-HDSS - Broken Springs?
  97. Evo 4 and Evo 8 Pass. Side Engine mount bracket
  98. Cant Find A Coupler!!!
  99. fixing a rough idle with no cel
  100. Turbo porting and polishing, how high grit?
  101. Evo 8 fresh motor only getting 2-4psi oil pressure
  102. Squealing from tranny/clutch? (Video)
  103. Evo 9 MR 3-4 sticky shifting/grind. Want opinions!
  104. Help Needed! Need new Turbo, Boost Controller & Turbo Timer.
  105. Need Advice: Is the Walbro 255 still what everyone runs on pump gas or ????
  106. rough idle, NO CEL
  107. Evo 7 Downpipe
  108. Evo 8 problems
  109. Street turbo?
  110. Evo9 speed density brass nipple route
  111. Axles for Evo IX rally car
  112. Exedy Twin vs OS Giken R2CD.
  113. GSC 5040 vs 5041 valve spring difference
  114. Rocker arms fell off!
  115. Evo 9 MR Limp Mode? Service Engine Soon Flashing and 3500 RPM
  116. Has anyone used a Quaife sequential tranny
  117. - Seeking Double Pumper Advice -
  118. Gsc cams: s2 vs r2
  119. 86.5mm in evo 8 4g63
  120. rod bearing clearances, need help!
  121. What is your oil pressure at idle hot/cold, WOT, and oil viscosity
  122. Turbo select
  123. opinions about 4g64 Lr, 2,2 or stock?
  124. Forward Facing Turbo Questions
  125. Exedy Triple "From pull to push" ?
  126. 06 MR not boosting need advice
  127. Can a blown turbo seal mess up the engine?
  128. Built shortblock's
  129. Injectors for FP Black on E85
  130. Need help identifying sound in 4g63 - problem
  131. GSC S1 IX Cams with the FP Green
  132. no spark/ no fuel after rebuild.
  133. Boost leak test conundrums
  134. Buschur Hole in the head
  135. I'm pretty sure i ordered the wrong pistons..
  136. Stuck between the fp ss housing or the stock hosung
  137. 1 piece bearing kit?
  138. Clatter noise at 3000rpm built motor
  139. E5 Weird noise after cam install - pls help
  140. Turbo spooling is slow
  141. Help oil residue on spark plug threads
  142. 4'' Exhaust noise reduction using an inline QTP cut-out
  143. Camshaft Backorder??
  144. EVO 9 Mivec timing question
  145. heat not working
  146. TSCOMPTUNED Engine Review - SLVRNBLK's Project MJ
  147. anyone ever used a atp 3071r turbo
  148. Which turbo is best for me?
  149. T3 twin scroll manifold closest to driver side
  150. ME2-XTG6 users
  151. EVO IX Compression Issue
  152. 2.4L MIVEC timing with 4g63 belt
  153. What should I all replace when replacing the clutch?
  154. Mines Manifold- Anyone?
  155. misfire
  156. Hi everyone... help me choose ef4 maperformance or evo 9 turbo
  157. Evo 9 turbo or maperformance ef4 for my evo8
  158. 18 year old kid breaks my car during test drive
  159. Engine Knocking P0300 & P0401, Do I need a new motor?
  160. Lobro joint wear
  161. Trans feels like crap.
  162. ATP hybrid single scroll
  163. car stalled out during flood, now theres a loud whine/screech from ps/ac area?(video)
  164. Transmission problem?? Pls help
  165. Can someone tell me where this (EGR?) hose connects?
  166. GTX3584RS - 1000HP in a GT35 Frame?
  167. ⛔★ Low rpm almost stall after clutch in (tuning)
  168. Help With Stripped Turbo Exhaust Inlet Hole
  169. Forge Internal Wastegate actuator Spring
  170. Dailey Engineering Dry Sump System for the Evo platform now available
  171. OEM rear mount
  172. Torque solutions mount for JDM evo 7
  173. Evo 8 engine, transfer case & 5 speed trans
  174. Rebuilt engine - No oil pressure ( Good Read )
  175. Do i need a retune or is there something else wrong?
  176. good wastegate
  177. Just got my rebuilt motor had some questions.
  178. meth injection
  179. sleeving the 4g63
  180. Transmission hard to shift under high-revs 3rd and 4th
  181. transfercase whine
  182. warped o2 housing
  183. Anyone using the fp xona 96/67
  184. Where to buy a cheap hotside?
  185. Has any heard of an emotor turbo
  186. hard pipes
  187. Stock synchros vs synchrotech
  188. Electronic Boost solenoid for Evo 8 ECU w/ Speed Density?
  189. King Vs Acl bearings, give us your experience
  190. How high can I rev my 2.3 and can I do a super 94 with it? want to trap 155
  191. HELP! Evo 8 w/JDM 7 block Cooling issue
  192. Fp red Boost Leak tester
  193. Borg Warner turbo
  194. JDM Evo 7 ACD/AYC pump making noise
  195. Gsc beehive stock retainers don't fit
  196. First start up and break in.
  197. new owner from uk
  198. STM Sealed Catch Can - Intake Pipe Pictures needed
  199. Want to do Evo 9 1st gear conversion anyone have the part numbers?
  200. Whine from undercarriage!
  201. Ati damper belt size
  202. Exedy Triple disk - issues or input shaft damage?
  203. Need check valves for twin 450 pump setup?
  204. Knock problem.
  205. Evo 8 oil squirters hitting Wiseco pistons?
  206. ETS intake problem evo 8
  207. Evo 8 won't boost or rev over 4k
  208. Evo 8 won't boost or rev over 4k
  209. What to do, what to do? Help me solve a dilemma
  210. safe power and torque figures for an evo 7?
  211. What intake/intercooler setups are people running?
  212. 4g63
  213. Will 6 speed bell housing fit evo 5 speed?
  214. Can a boost leak cause loss of power?
  215. 4g63 block need help
  216. kelford 276 high lift or 284 high lift
  217. Sheepy forward facing kit intercooler fitment issues
  218. Comp clutch high rpm lockout
  219. Cams equivalent or similar to gsc s1
  220. New build . No compression #2-4 cylinder
  221. 4G64 with Mivec head, Timing belt covers that fit??
  222. My 20G Turbo build
  223. Anyone else have this much fun doing the exhaust studs ?
  224. Evo IX Stock Turbo: Real Vs Fake?
  225. FP 84mm silicone intake fitment
  226. D/V question
  227. GSC S1 vs S2 for daily drivability, and my goals, for Evo VIII
  228. ClutchMasters FX300 - Experience?
  229. 450lph e85 pump on straight gas
  230. Exedy Twin Disc issue
  231. Knocking and shutting off
  232. best turbo for high reving 2.3
  233. JMFAb or toxic fab exhaust mani for evo 9
  234. New Set Up
  235. How bad is this turbo
  236. Idle after fan controller install
  237. Final Drive Options for 5 speed manual W5M51
  238. Huge problem please help
  239. Really need help with this clutch/tranny issue. Please help
  240. Garrett Gtx Gen 2
  241. Coil upgrade advice
  242. ETS short route kit compatible with oem?
  243. Anyone know anything about mishimoto intercooler pipe kit for evo 8?
  244. Did I just make my whiney TC worse or is this clutch related?
  245. The Driveshaft Shop 900hp Front Axles Fitment
  246. GSC S3 vs S2. New build
  247. Evo 9 factory turbo oil feed line switchng to head oil feed
  248. Evo 4 head, 3g ECU, 4g64 GDI Galant, possible?
  249. Building a 2.1 LR ...4G63
  250. Evo 9 gearbox
