PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 [136] 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. AMS 2.3L Stroker and Twin Scroll 35R with HTA Upgrade
  2. Turbo Experts, HELP
  3. Wastegate Problems
  4. MAF clamp size.
  5. Evo IX with Stage IV - BR Gt3065 Cast manifold 501 whp on pump with alchy
  6. downpipe question...
  7. Radiator Questions - Evo 5/6 radiator into an 05 VIII?
  8. question (help)
  9. Drool Factor 10 Engine parts from Japan
  10. How stuff works: TURBOS AND WASTEGATES EXPLAINED...
  11. Spacer for O2 sensor...where to buy?
  12. How stuff works: BLOW OFF VALVES EXPLAINED...
  13. Too Much Lag
  14. FP-GRN w/oem int vs. Weapon-R on 91 oct.
  15. boost spike in higher gears
  16. turbo install
  17. RPM Acceleration data on 91 oct.
  18. is O2 housing needed???
  19. Can Fidanza Flywheels be resurfaced???
  20. Reducing sound and remaining the boost.
  21. Are these S1 Cams?
  22. going 30R wat clutch...??
  23. Downpipe Donut Gasket
  24. Cam Cap Problem
  25. Clicking noise in high gear high boost?
  26. Help with TwinScroll 35R Turbo!!!
  27. Experience with ball-type injectors vs Densos
  28. WHAT'S THIS?! HTA35r is off the car??
  29. Bigger fuel pump needed?
  30. Valvesprings and Cosworth Mivec Cams
  31. 2005 VIII and 2006 IX stock turbo hotside is the same, right?
  32. Service Engine Soon
  33. Major WOT sputtering problems AND rpm spike problem when shifting.
  34. Best Exhaust Manifold
  35. ramhorn exhaust manifold, vendors get in on this
  36. Intercooler piping question
  37. turbo choice reliability?
  38. rpm band help
  39. manual boost cont. how much boost??
  40. Perrin FMIC users please help!!!
  41. Please Explain To Me How This Works
  42. Highest whp on pump gas 91 ONLY
  43. Looking for Feedback
  44. ebay downpipes?
  45. 2003 Mitsubishi Lancer OZ Rally question.
  46. NEED HELP! Is my ACD broken?
  47. advice please
  48. Searching for correct MAF Translator
  49. Cosworth M2 Cams STD Turbo
  50. Whiteline diff bushing install?
  51. sc61 anyone?
  52. need help please
  53. To o-ring or not to o-ring that is the question
  54. Shearer Fab. New 42R Setup
  55. my plans... for now.
  56. Support Modifications for HKS GT3240 Turbo
  57. Turbo XS Donut Gasket Needed
  58. Is this a sign of a new cluth ?
  59. Upper & Down Intercooler Pipes!
  60. Random misfire ses light! Opinions please
  61. Best Clutch????
  62. flywheel resurfacing?
  63. what the freakin heck is goin' on!
  64. fidanza 3.2 or act hdss
  65. Choosing turbos TME vrs Evo 9
  66. Magnus motorsports dogbox
  67. knock? blown engine? plz help!!!
  68. high knocks running on toulene
  69. bad wideband???
  70. clutch or syncro? Hard to shift..........
  71. installing evo 9 bov
  72. MY poor car is all tore apart
  73. Help please problem with A/C lines
  74. 10.5 housing
  75. Oil leak between the T-case and Trany( H E L P ! ! ! ! !)
  76. Helppp Pls
  77. ?Question for you twin pump guys?
  78. fuel pressure reg. solenoid?
  79. What mods can I do while replacing intake manifold gasket?
  80. short shift?
  81. no spark...
  82. *** Decision: Non-BB .50 Trim OR 20G-LT ***
  83. Greddy PRofec B Spec 2 problems
  84. best cams with 35r kit
  85. how much hp is the walbro fuel pump good for
  86. GM MAF + intake size
  87. engine damper
  88. mishimoto carbon intake?
  89. why is the clutch pedal feel harder in 03-04 models?
  90. Just finished the build... getting tuned tomorrow
  91. Compression Help?
  92. Help with removing fuel injector connectors
  93. No Boost in lower gears
  94. 3 transfer cases in 3 months... help me!
  95. 822 bhp + 633 ft/lbs on Pump (97 RON = 93 PON)
  96. Car shakes and goes crazy when hitting boost?
  97. Weird Issue
  98. where is ur fuel filter?
  99. Ported VS non-ported shroud comp cover
  100. EVO 8 and EVO 9 axles = same!?
  101. Balance shaft remove or not ??
  102. USP Motorsports Evo Makes 904whp on Gt42r!!!!
  103. BOV that can hold >27lbs boost
  104. Does anyone get backfires from 2 step and exhaust?
  105. boosting 12psi help!!!!
  106. clutch pedal has no pressure
  107. Intake manifold weld problems
  108. HELP #2and#3 arent fireing
  109. R.Purple Oil Mileage intervals?
  110. factory freak? is this possible?
  111. ımportant
  112. Starting problem (intermittent)
  113. 69-6543tr K&n
  114. 35r and what i need
  115. boosting 12psi HELP!!!!
  116. can we replace the pistons.....
  117. Do I have a warped flywheel?
  118. Rpm Problem
  119. Do I NEED to tune first?
  120. what gaskets and seals do i need for a clutch and lsd install
  121. Sputtering after catback install...
  122. Slave cyl pushrod stuck aka piston in slave
  123. Installed/Made Tranny Cooler for my 6 speed.
  124. alan wrench in timing belt
  125. Hks 272 cam instructions for EVO 8 MR JDM
  126. Need help with clutch
  127. SouthBend clutch? Anyone use this?
  128. q? for cali evo owners with cams. SMOG
  129. Primary 02 Sensor failure
  130. my dyno sheet
  131. Works Clutch Kit 2 Reviews?
  132. Anyone running ETS FMIC / piping with other turbo kits?
  133. 4th gear blowing up?
  134. 2006 IX Engine Tick Whine Rattle HELP!!!
  135. clutch went out tonight
  136. ACT clutch disengagment problems HELP what 2 adjust
  137. Question Guys
  138. AEM Intake vs Apexi
  139. 680 Inj On 3065
  140. Quartermaster or exedy twin disc clutch?
  141. Nisei street IC + ETS UICP
  142. Engine noise?
  143. Need Advice
  144. does anybody have a blown mivec head?
  145. arp head studs torque?
  146. Headgames ported my HTA35R you must see it!
  147. banjo bolt from feedline on head
  148. Look at this guys!
  149. AMS 2.3RR + Full Race 3076 TS Kit = faster than stock spool?
  150. Quest for more power 3" exhaust vs 3.5" exhaust
  151. Brian Crower Cams - How do they compare to cams twice the price???
  152. engine stalling when shifting to neutral problem need help
  153. spittin out of the exhaust
  154. Some help with supporting mods
  155. Buschur's New Duel Stage Boost Controller is better than.............
  156. ACT 6 puck clutch
  157. evo iv turbo upgrade?
  158. Need help in choosing valve springs
  159. t-case change out
  160. cam for gt42 1000hp RWD?
  161. what size E-clip on 6spd underhood shift linkage?
  162. I ordered a TBE,drop-in filter,MBC..Have questions..
  163. Just ordered BR HTA 35R...Help with supporting mods??
  164. suspension
  165. Should I port out my Buschur 65mm T-body and intake manifold some more??
  166. My new Buschur Racing engine and car build up for 8's !
  167. TiAL Recirculating BOV
  168. someone please
  169. what intake for 30R ?
  170. rwd adapter plates
  171. Gt30r Setup...???
  172. GT30R setup ...?
  173. think the car pulled timing on me
  174. Mynes vs Vivid
  175. GT3071 comp housing
  176. proper injectors
  177. helpp cant decide
  178. fpgreen or 30r which one
  179. question on oily spark plugs...repost
  180. ignition gurus, will these work?
  181. driveline fluids
  182. Going BB worth extra 500$
  183. BMC Airfilters
  184. question about oily spark plugs
  185. governer?
  186. parts
  187. power
  188. Full-Race manifold/downpipe question
  189. 3065 / 3071
  190. grounding kit points
  191. How many cmf's does a 3076r pump out
  192. evo 8 transmission question
  193. AMS twin rail manifold or 1200cc injectors?
  194. Test Pipe On Stock car?
  195. Clutch slipping only in first gear...?
  196. 4G64 block w/ 4G63 MIVEC head
  197. gsc s1 or hks?
  198. hotside and turbo
  199. Buschur vs AMS racing battery?
  200. HKS Twin GD Pro Installed - Noise when clutch pedal is pressed
  201. MAF Implosion!!!
  202. Throttle sticking/won't start...
  203. Cam Install - Tune Necessary?
  204. Need Sugestions For Clutch!!!
  205. Compressor leak test... help...
  206. recomendation for exhaust?
  207. is this an evo 8 t case??? PICS!!
  208. a little help with exhaust choice
  209. More boost in the LOWER gears???
  210. arc super induction box
  211. wich cam's to go with
  212. cobb and helix test pipes
  213. Brian Crower Cams for Evo IX - run untuned?
  214. stupid question
  215. Question about stutter.
  216. Finally a welding and fabbing forum..
  217. Need new engine.
  218. adding a muffler instead of a test pipe
  219. HTA35R + E85 + Stock 2.0 + Topspeed=:)
  220. valve spring rates
  221. IX fuel pump or Walbro limits
  222. its finally blew up....!
  223. 5 bolt o2 housing???
  224. CBRD and ETS build..
  225. Will a IX mivec map work on a VIII
  226. Help please
  227. P0506 code, what do i do now?
  228. valve train question
  229. nitrous question
  230. head rebuild sorta...
  231. nitpick this setup
  232. cv joint boot
  233. Check This Out
  234. Xvt Stainless/nitrided Valves?
  235. help with trouble code
  236. Exedy Twin Dist Hd Ceramatallic
  237. NEW LOGO for Koyo aluminum radiator?
  238. hard pedal?
  239. AMS Tests: The New EVO AccessPort
  240. new Amsoil study on GL-5 gear lubes
  241. cams...for a green or 30 I dunno...
  242. Tranny Help is here!!
  243. Boost Leak Test past the Throtle Body
  244. Tre Rear Differential Upgrade Service
  245. Tranny Problem with my 9 MR
  246. 5th Gear Lockout
  247. Trans case I think
  248. TTP prototype turbo kits under development
  249. Where to buy turbo?
  250. Dyno tuned finally!!! 572whp 385wtq 24#'s for now....
