- Quick Air Conditioner Condenser Question
- Evo 9 + Aquamist 6 Meth Kit ; will this meet my goal?
- Syncros??? TRE Built Tranny ?????
- axle question
- ACD Banjo bolt - Remove or Not? Help!
- Clutch time...noob help
- Underhood bushing sieze
- LICP Does it actually increase power?
- Old DSM tricks?
- size comparison?
- Mivec vs Non Mivec spool characteristics
- Crappy xmas eve...
- quesiton about manly i beam rods
- VIDEO: Why the FP Red needs the 80mm cover!
- Minimum mods with FP Black?
- Some new stuff!!
- alcohol question
- Engine Revs Unintentionally
- what would help these poor stock turbos up stairs.
- clutch/drivetrain help, cant get in gear
- Heater core location?
- Throw Out Bearing not on Center?
- Opinions on DIY Motor Re-build
- Evo alternator
- Attn: ETS LP2 mild steep pipe owners
- WGA damaged?
- calling all forward facing manifolds
- how much hp can stock evo8 trans hold
- Rad Support Question
- Exhaust install gone wrong
- Iveytune Tests the FP BLACK
- fuel pump issues
- hks 272 and ETS 3.5 IC
- VENDORS! Who can get me driveshaft bushings?
- AEM Meth Users
- All 3 ACD lights lit at the same time?
- Camshaft Markings
- PLX Installed on mild motor
- massive destruction on my old block..pic
- having car issues: need help
- Car chemistry noise baffle
- ?'s 4 those w/ upgraded UICP (mainly Injen)
- Help
- Engine knock increasing over time
- mustache bar eliminator
- Megan Exhaust Mani
- OOOPS Jacked up my OEM O2 Housing. Need some help.
- DEI reflective-a-gold
- Mixing and matching exhaust systems
- Have HFC; want downpipe
- Fuel Rail Upgrade?
- ralco short throw shifter
- Manley springs & retainers any good?
- Weird noise....
- am i missing anything?
- need help with bov problem
- springs/retainers-buschur
- o2 sensor CEL problem. Please help
- block ??
- 2.1L Motor Build, I need your help!
- Trouble Shooting Question
- Strange Idle issue...help.
- rod bearing failure 2nd time same cylinder
- what power lever should you upgrade the ignition
- injectors sizes for e85???
- anyone put an mbc in cabin?
- boost controller recommendation
- Is my tranny doomed?
- 4G64/MIVEC/FPBlack 1st Impressions
- Tons of evo Parts up for Raffle
- Intake change require new tune?
- How exactly does the Greddy Turbo timer Auto setting work? (yeah I searched)
- evo ix build
- bov help
- Power steering delete guys/chicks?
- Winter engine oil for built engines
- Valve springs R&R cost?
- Act ftl tq ftw
- Too much clutch??
- p0138 confusion
- How long have you had your FP RED?
- Which wideband sensor is this?
- Lucas (disc-style) Injectors Vs Ball type (FIC, RC) injectors for E-85
- fp black or best t3 set up for street
- What size injectors should i get? FP Black
- Stri gauge problem
- Is this any good??
- Manley Rotating Assemblies - Experiences?
- Steering shaft question
- HTA gt3582 vs 6262 on 2.3 engine
- Ideal CCA's for a mini battery?
- Thoughts on rear motor mount
- Rattling vibrating noise
- a couple of questions camgears and motor oil
- Speed sensor question?
- 4G64 MIVEC build in Import Tuner Magazine
- ~~Problems shifting on 1st and R Gear~~
- New clutch issue!
- BR Intake Length? WTH?
- It's Alive!
- Acd not bleeding?? Pump problem?
- Filling the TC with fluid
- What helps a turbo spool faster
- does anybody have results with 6262 twinscroll setup with 2.0
- help-car severely lacking power
- Help with P1021 code please
- Oil coming out of breather on my Buschur catch can?
- Where can I get a gasket for a divorced O2 housing?
- Where to dent on the DP to clear ACD
- Motor build shops in Ny or NJ
- 2 issues with motor n drivetrain!!
- Cylinder #4 misfiring
- Spec single disc clutches
- headgasket. =(
- Cat on for emissions and running lean!
- When would an evo benifit from gear based boost?
- Idle Problem (Have Searched)
- cat sensor
- A little help..
- plugs gap and boost.
- K1 crank issue... american language expert needed!!!!
- stupid of me to try .010" oversize bearings?
- CBRD Half width, pics inside
- Rear Diff problem
- exedy twin HD or SD
- help plz (car smoking)
- Cam Switch
- Exedy Daikin OEM Replacement Clutch Kit?
- So many clutches. so many ?
- Money verses o2 sensors
- Ets Turbo kit
- Stripped thread on gearbox - What's the best way to fix?
- HKS 3037 vs stock turbo 9 (can any one explain to me?
- Friends evo9: Is his EGR removed?
- Rear O2 placement?
- ill be doing a clutch soon.....what else should i get...
- Intercooler Pipe Questions before buying
- Cam gears hitting timing belt cover-
- Exhaust Size vs HP & TQ
- FP Red with 9.8T exhaust housing for extra response?
- Defi Oil Pressure Gauge reading EXTREMELY high... HELP
- Misfire Issue(long read)
- Part Number Request - Shifter Linkage White Plastic Clip
- 3" Downpipe vs. o2 Dump
- Need New rods/pistons, etc. SUGGESTIONS!?
- evo IX mr needs help, please!
- Why is Quarter Master clutch not going to last on DD?
- Howling noise @ 65mph in 5th gear
- Works O2 housing, what downpipe???
- Help!!! My baby is whining
- Coolant problems
- Mivec Solenoid Issues?
- Where to find plug and play ignition plugs??
- ACD Pump GONE!
- 02 es - p0421
- Overrevving when accelerating
- Ceramic ball or metal ball
- Here Comes another Beast From Force-Fed 1 of 3 to come, ETS powered
- any pro/cons Kelford Cams 280/282 Evo9
- AYC Noise? CN9
- 1st gear clunk when cold
- Is porting and coating turbo & coating O2 housing worthwhile??
- Driveshaft clunking
- Evo 8 exhaust mani to evo 9?
- Cessna's quest for 9's on a stock motor
- Engine light on then off
- No fire on one coil
- Anyone have experience with Borg airwerks or Borg/bullseye turbos
- Anyone ever experience this:
- ClutchMasters FX200 Experiences?
- turbos are doin my head in!!!
- Help: Exhaust Hitting Driveshaft
- Walbro Double Pumper VS Aeromotive 700HP Fuel Pump
- ACT Lock Out Thread
- Max Boost on Stock Turbo
- Should i change my fuel pump?
- Boost Issues. Need Help!!
- Throw out bearing noise...Need opinions!
- temp drop
- Evo 8 block with mivac head how to make this work ?
- My 2.4l Build and 2.0 History
- Main studs - Align boring really necessary?
- Power Loss Possible Valve Float
- Stock Main Bolts
- supertech valves same as cosworth valves??
- My 2006 Evo MR clutch install/review
- e85 fuel needs.
- Need some advice on turbo
- Wont go into 2nd Gear.
- IS it my transfer case????? vid inside
- Just installed my FP Black
- 86mm bore : safe?
- Downpipe hitting TC
- Help Evo Mexico
- car stalling when cold after rebuild
- Cam help
- Stock Turbo But Injector Choice?
- How much Boost
- Modern Automotive Performance Rods
- Shep trans question
- Good Day!!!
- quick question
- cv axle leaking
- sheetmetal manifold
- Manifolds?
- sucess with inline pumps?
- What Has Happened Here? Please Help!
- Help with exhaust uninstall/install
- Weird Turbo Noise
- A Question on HKS UICP
- Oh boy PLZ HELP! drivetrain!!
- 4088r on a 2.0?
- Anyone with a AMS Resonated Test Pipe?
- Possible clutch issues
- starting issue plz help..
- Spark plug cover cracked!
- Idle issues...please help!
- Get Knock Sensor Indicator in 1st 'round 2.5k RPM
- is the dual pump overkill with 880 injectors?
- K1 billet crank installation
- ID 2000 injector COLD START
- please help!
- clutch problem (help)
- Any guys who switched from Kelford 272 to 280s???
- Evo making low boost
- I got my mods list..wanna help? add to it?
- New clutch - questions
- Help ideintify these rods
- Anyone using an ACT 4 Puck Sprung???
- turbo questions
- Help: BLOX Front Engine Roll Stopper
- HKS 272's or GSC2's on a stock setup?
- Exhaust on an evo 7
- Timing Belt Question
- evo 7 drivetrain question
- Anyone know the Fp black pump gas record?
- Where to buy internal transfercase parts?
- My 2.3 FP red setup Jestr tune
- This is what happens when you add a fuel pump without tuning
- help plzzz
- will a evo 9 starter fit a evo 8??
- Engine died out HELP!!
- Super Rich issue, help please
- COP wiring ?
- water temp sender adapter
- Evo 8 Head Gasket into Evo 7
- Stock Crank Horsepower limitations
- Drive Shaft Carrier Bearings
- Boost Creep help!
- SuperTech Valvetrain
