PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 [178] 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Best Turbo For my Setup
  2. Need Help, Grinds BAD only when DOWNSHIFTING to second...
  3. Anyone with an Aeromotive A1000 fuel pump?
  4. Safe running on track
  5. Engine Break in
  6. Headgasket, Turbo Kit & Clutch install question?
  7. Anyone know why APS bov causing car to buck?
  8. Misfiring issue...
  9. Just Bought Turbo Kit. Need Some Advice Pls
  10. TOB/Wedge collar removal
  11. Bout to go with a gt35r on my IX
  12. Cert. Tuners or vendors only reply: Tuneing car with highlift cam profiles.
  13. 1st gear redline
  14. Ebay O2 = Boost Creep * Help
  15. Few questions about cams?
  16. heat wrap UIP
  17. HPF intake
  18. torque plates and honing
  19. Injen Products for IX
  20. more stuff for my IX??
  21. RnR GT3076R KIT...pictures
  22. Those who have the balance shafts removed ..
  23. Need Revolvers ASAP!
  24. whats the biggest size front mount for a 9 bumper?
  25. Fuel pump/MBC no tuning device?
  26. Stock plugs after 20k miles
  27. Not very impressed with Buschur's mini battery kit.
  28. Abnormal Idle?
  29. Very interesting observation on Works 3" 02 housing
  30. Just finished the gsc 272 camshaft install...
  31. evo 9 turbo on evo 8 question
  32. sound/video clip of my magnaflow exhaust
  33. atp 35r twin scroll divided housing
  34. valve cover breather filter = blown oil seals??
  35. need advice for my turbo
  36. Titanium turbo manifold?
  37. World industies turbo timer?
  38. Agency Power Ti
  39. Act Clutch + P0300
  40. What are your setting on 264/272?
  41. IX Exhaust Cam Question
  42. 264 Jun cams arrived
  43. Resetting The EVC
  44. *sigh Help.
  45. Gurus, can you verify this info?
  46. 4 inch filter tearing
  47. 4:11's????
  48. Valve cover breather question, bad???
  49. Best clutch for a slightly stock evo?
  50. Saikou kun catch can thread
  51. APS Turbo Kit - Any release date yet?
  52. PCV system theory and Oil catch cans.
  53. Ebay o2 housing for IX
  54. competition clutch???
  55. maxing out the stock engine...
  56. bov on backwards?
  57. how to take off black canister for fuel
  58. Damn 5th gear! Ahhh!
  59. Stalling issue please help
  60. Hks S/s Exhaust Manifold
  61. MSD DIS-2, CBR coils, DSM ignitor...
  62. what turbo kit to go with??
  63. Looking for some info
  64. Where is the boost?
  65. Hesitate to boost...
  66. Just got home from Buschur
  67. Intake manifold Flange
  68. Threw 4 codes on my car?
  69. Trade in my Tilton clutch?
  70. piston engineering
  71. Looking for a 2.2L Stroker kit
  72. Turbo Trix Fix!!!!
  73. Max efficient boost on stock turbo with stock actuator?
  74. The story of APR head studs
  75. Exedy twin disk HD?
  76. Tuned right now but about to put in cams and fuel pump and run without a tune?
  77. Erratic Idle
  78. boost leak almost fixed..
  79. Boost problem!
  80. Need more Vacuum so it woun't stall LOOK
  81. Gadiel Tuning- 404 whp stock turbo EVO 9!!!
  82. Transfer case, prepare for future problems, or hold out.
  83. Never heard of it!
  84. Passed Smog with WORKS Mods!!
  85. Transfer case Rebuild Ring and pinion
  86. 1000cc injectors okay with AMS 50 Trim?
  87. Has anyone tried the turbokits.com 20g upgrade
  88. who has a portable chassis dyno in socal?
  89. compression questions
  90. Controlling the IAC Motor
  91. Need Help weird NOISE, thx for your time.
  92. Exhaust Leak???
  93. cams for a big turbo set up!!!!
  94. Avid Racing!!!
  95. EVOIX 20G TME...anyone running it?
  96. Buschur 2.3 & GT30 or GT35?? Many Questions.
  97. Dont Know What To Do Now??? Need Help
  98. LOOOK!!! transmission fluid?
  99. creaking sound under my car
  100. Has anyone heard of this exhaust?
  101. Rear O2 Sensor removal? Will I be able to run completely without it like this?
  102. exhaust set up
  103. 1 in a Million... So you're tellin' me there's a chance!
  104. CEL--input voltage of o2 sensor reading high?
  105. GReddy TI Exhaust - Any EX owners in here?
  106. Hks Camshafts....272 Or 280's????
  107. Hard to shift.
  108. SBC I-Color Settings.
  109. Timing Tensioner Tool
  110. ToMuchBoost stroker thread!!
  111. holy moly wtf ?
  112. 450-500 hp
  113. Try to solve this one !!! - Boost Creep
  114. Help- please tell me it ain't so...oil in coolant reservoir???
  115. Poor Catalytic Efficecy
  116. Am getting stroker. Do I need tune/injectors for it?
  117. turbo timer?
  118. IX 20g 5 blade vs 6 blade (Lets put this to bed)
  119. Shipping MR Trans to Shep?
  120. Rough Idle, no cams
  121. Question About 272 272 Hks Cams.
  122. buying HF CAT, got a question...
  123. Dia Queen
  124. Motor mounts discussion...need to upgrade both?
  125. Bubbling / hardening near coolant lines + low coolant?
  126. IX untuned MBC boost level?
  127. GRRRR Where is that diagram?
  128. SUN Hyperforce review....
  129. Crank Sensor Question
  130. Why is this happening?
  131. CF Compressor wheel: interest?
  132. Buscur deluxe, AMS or Nisei for stock turbo?
  133. RnR (Daily Driver) HITS THE DYNO!!!!
  134. Battle of the turbos....
  135. Dynoed Intake: open hood vs close hood
  136. 6 speed in regular Evo? how much $
  137. clutch lock out
  138. Oil feed on cyl head...
  139. engine compartment temperature
  140. 05 Turbo Question
  141. I think my Engine is done.....
  142. intake flash bogus????
  143. ? about crushing BOV
  144. Crank Angle Sensor
  145. Evo IX Oil Filter question
  146. Car Throws Anti Lock Signal and Cuts fuel
  147. Helix exhaust = CEL???
  148. Forge Wastegate
  149. It's Killing Me!! Help!!
  150. Broken balance shaft belt or spun bearing.
  151. vacuum question
  152. Whats Wrong With The 9??
  153. blue flames from my exhaust, WTF
  154. Help! No Fire after Washer incident!
  155. I need help Please, no fire!
  156. Whats the best tbe out of these choices?
  157. should install fuel pump ?
  158. 2nd coke can test on downpipe
  159. diaqueen
  160. Video of my dyno runs from 5/6/06 at TurboTrix
  161. Installed JDM MR BOV ????
  162. Mid-Install help... 10.5 Hotside/02 housing
  163. Boost Creep, Need Help!
  164. HKS TI Exuast and Blitz Blow off
  165. What is this line/hose for?
  166. Slowboy racing here I come!! Engine/turbo/head write-up etc...
  167. d.pipe: change lower braces?
  168. My Full Race DIY install
  169. Stock Clutch?????
  170. torque setting for downpipe?
  171. hELP!
  172. Stupid me, turbo put together wrong!
  173. Has anyone tried the ATP bolt on GT turbine housing/turbo?
  174. Dont want A/C what belt size to use?
  175. is a gt35r with a t04 housing that much better then a t3?
  176. do I need a boost controller?
  177. Help... Ignition Problem
  178. GT35R users.. list your specs....
  179. tapping noise from engine after 1/4 run
  180. aftermarket piston specs
  181. Anyone here running the Turblown manifold?
  182. AMS FMIC or Buschur Racing Deluxe FMIC
  183. Helix HFC MELTDOWN!!!
  184. Still looking for a Short shifter for my MR?
  185. Lockout, sticky disengagement, WTF?
  186. Exedy triple carbon= BAD
  187. Read this if concerned about spinning a Rod Bearing.
  188. Oil Restrictor with a 35R
  189. Full Race manifold users.....
  190. 2.0L or 2.3L for street / strip with 109 unleaded
  191. Cams or 20g?
  192. Injectors
  193. Rod Knock? Motor going out? My luck BLOWS!! HELP!!
  194. changing 10.5 hotside
  195. make my own exhaust?
  196. are 720s too big for my car????
  197. Running rich
  198. will these fit out cars?
  199. AMS UICP on IX
  200. Max wheel horsepower for stock tranny?
  201. evo 9 turbo on a evo 8
  202. APS, Type-s Recirc., Forge, GFB
  203. cams on a IX yet?
  204. TME + E9 comp housing . . . who's running it?
  205. 650CC injector out of a DSM into an EVO?
  206. high pitch whine in 1st gear
  207. gt35r question please help
  208. Twin disk to triple disk clutch conversion.
  209. just installed forge unos mbc, setting questions
  210. wartalonish tune....bushur/dynoflash
  211. need clutch help inside?
  212. Ticking noise when turning left
  213. need serious insight!!
  214. Boost question HELP!!
  215. Got My Greddy Uicp Today..no Mini Battery Needed!!
  216. megan bolts up to helix dp?
  217. Turbo Upgrade: If you could do it over again...
  218. Slip-Fit Exhausts? How many are there?
  219. Install kit for 20g-9?!?!
  220. Installed deck but now some of the lights in my car dont work?Hellp plz
  221. how the hell do you get the 10 fuses out of the yellow thing under the hood?
  222. Whats the difference between the 2005 evo turbo and evo 9 turbo?
  223. Questions about Organic Clutches?
  224. theory behind 4-1 long tube header?
  225. BOV that works for high boost
  226. IX Fuel Pump for my mods
  227. 10.5 hotside
  228. removed boost controller= 10 psi boost?
  229. another ACT question
  230. Massive boost taper with hallman pro rx?
  231. fuel pressure/fuel pump problems
  232. Works Power Performance T4 Manifold
  233. common engine failures poll
  234. Anyone had their crank angle sensor fail as yet?
  235. Alcohol Locked
  236. utt ohh freeze plug
  237. Clutch question?
  238. Need new Flywheel Bolts
  239. IC bottle relocating help please....
  240. High Pitched Whine
  241. black inside the plenum
  242. manifolds that fit into the cusco heat sheild =)
  243. Anyone buy from here?
  244. 350 whp on stock turbo possible?
  245. hELp!!
  246. Boosting 12lbs.....??
  247. Evo VII Boost !!
  248. Swapping in the evo 9 engine in a 8!
  249. Evo 9 vs Evo 8
  250. Swapping from 30r to 35r
