- ARP head studs retorque??
- best cam gears for tuning?
- tune with licp
- Direct Electronic Boost Control
- HKS rs replacement filter? where to buy?
- Fueling a NX wet Kit
- Will the 05-06 TBE fit the 03???
- Evo IX, MBC Settings
- JUN cams...who has them?
- I burned my clutch today...
- What Hot-Side 'A/R' is everyone running on the - GT4202R ??
- Please critique WHP numbers/MODS.
- From ATP GT3071R to ATP GT35R Disappointed
- Case Study # 323 - Cam Gear Settings on BR Stage 3
- alcohol injection tank upgrade? What do u have?
- Case Study #331 - Stock Ecu Controlled boost on a IX with Stage I - killer combo !
- Case Study # 330 - Perfection in a Tune
- Case Study #329 - IX with BR Stage II, Pump and Alchy - Street Dominator!
- Looking for FP or David Buschur to answer ?
- modified the stock airbox
- how long till CEL?
- tubular exhaust manifold and o2 housing
- Got my new Buschur COP setup!
- Please help us Tib owners.
- turbo
- BR SS O2 Housing-- stock turbo + pump gas
- Took my car to the dyno today.
- need help..have question ?
- TPR Magazine - EVO8 Exhaust testing
- Forge Wastegate Actuator...
- How many people are running alky without head studs?
- Best injectors??
- Megan header+02 housing gasket question.
- should I get valve springs and retainers
- back to stock intake?
- IX WOT issue
- Disabling MIVEC ... good idea?
- Oil pressure gauge reading innacurate?
- anybody seen 400 awhp on stock ecu, stock turbo, no nitrous no meth
- Stock Head VS PORTED AND POLISHED HEAD
- MBC help
- Quaife LSD
- new IX, gas drain plug leak?
- Evo8 vs Evo9 valvetrains
- when to upgrade fuel system?
- Oil pan leak?
- 4" Exhaust
- air to fuel ratio
- gruppe- s flywheel bolts??
- What Do You Think About This Radiator???
- Cam gears for the IX?
- I need a clutch that can slip
- Best Clutch for 400 awtq
- running IX stock cat
- knock sensor
- removing ac
- to improve stock 9 intercooler?
- Help me figure this out...
- aem cid
- What clutch for the 6speed?
- What is the best scanning software you can buy?
- oem clutch disc and pressure plate width?
- tfer case ? what actually blows up
- AEm twin fire ignition coils?
- ACT vs F1
- HKS 280 & 272 exact Timing ?
- +Video+ Help with weird sound from tranny.
- clutch install
- Spark Plug Issues
- Mivec on non mivec engines
- anti lag in japan
- Cosworth Mivec Cams and fresh remap
- Best way to check knock
- what could this be?
- Which should I buy Cams or Meth injection????
- Greddy Turbo kit on an Evo9...anyone try it yet
- waste gate spring
- which alky systems ..
- transmission oil
- short shifters on evos
- Why meth/water inj and not more fuel?
- odd sound diagnosis .....
- Maxford exhaust mani help
- Anyone running Forge lower front motor mount ONLY??
- Stock IX Dumpvalve sound
- Curved/Sectioned exhaust tip?
- ARe all driveshafts the same?
- p/s braket??
- Forge Products
- ACT HDSS/Gruppe-S Flywheel Review
- Oppinion and advise on getting a new turbo
- Ignition Amps - Timing Retard Necessary?
- Kind of a stupid question
- Fully Built 2.0 or 2.3
- Gasket Issues
- 5th and 6th Gear Sticking
- confusion on the 35r
- EVO IX owners... Spark plug gap ?
- Hallman Pro vs Pro RX
- Got torque? 345ft/lbs - NO LOSS IN SPOOL :D
- Is the Borla Equal length manifold worth it?
- Which turbo for my IX
- What numbers should I expect on 2.3L Stock turbo
- exedy hyper single clutch rebuild kit?
- Removing air filter for 1 track run?
- Dyno #s on HPF PT67 turbo and BC 2.4 stroker ...stock fuel and lines and maxed walbro
- TBE ok without tune?
- DIY dual catch cans
- 373 whp and 313 trq.....UNHAPPY
- Fuel consumption ?
- 80mm??? help me out .....
- AFR 21 at Idle.....
- New Stage1 clutch smokes out of garage
- BP7ES Spark Plugs ???
- Diagnosing ACD problems?
- another evo 9 dyno result
- Installing Perrin Boost Solenoid!!! Is this correct
- custom IC pipes
- Interesting info on Works tuned Evo...maybe the truth?
- Cosworth IX Camshaft Test Results
- Possible Scam
- mbc install help
- Another over revv
- i need some Help, $$$
- help me choose my next mod
- What is this tranny part for???
- Boost Problems with XEDE/Flash/SMART on Evo IX
- EVO 8 VS Dearler part2
- building buttom end
- spark plugs
- Anyone try Buschur's new White Cone filter???
- Buschur Racing's new 20gLT, EVO Green turbos ready to be ordered.....
- RS R 3"DP ..............
- Walboro 255 normal Pressure output?
- Black or Lower Discharge Pipe
- GP Sports Exhaust?
- 2006 Evo IX MR GG question
- Methanol Injection VS Race Gas...or BOTH!
- 2006 Mitsubishi Lancer Evolution IX MR GG
- Sweet new 50trim kit!
- Boost Leak.
- Car wont start for nothing! Can anyone help?
- Blitz Nür race spec exahust USERS
- SMC Alky problem ....
- my first stage of mods being done this week at rre... thoughts & opinions?
- what are ppl out there using for aftermarket tachs
- Attention all Buschur racing GT35R kit owners: Please give me ur input on this kit!!!
- Aem Tru-boost
- Stock Turbo Outlet?
- engine swap?
- IX EBC boost problems!
- Monster-Sport exhausts
- Exedy Twin Plate???
- Is my MBC broke???
- boost question
- Bolt on 35R
- Engine Oil Insight....
- Turbo XS Exhaust
- 03 EVO vs Dealership Powertrain Warrenty
- Bulgarian Evo 7
- Anyone have issues with KOYO Radiator (drain plug leaking!)
- Serious Over Boosting Problem
- HELP!!! very loud whinding noise evo ix!!!
- Powertrain loss?
- JUN 264s VS HKS 280s
- eBay O2 housing = brings the torque
- first time on dyno!
- Dual disk clutch
- Forge MBC question.
- Odd Idle issue
- clutch problem...
- Car wont start due to blown fuse
- question on where to find a specific exhaust...
- Tranny Vibration...I think
- Idle issue
- clutch adjustment
- anyone have nlmotorsports install stuff?
- ATP turbo "stealth" turbo kits
- blitz exhaust bottle necks
- Br8eix Plugs Gap
- 2 Boost Gauges?
- tapping sound
- What else do i need for my cam install?
- Aftermarket DP/LICP with AM turbo
- Over boooooosting...
- Walbro 255lph Questions
- Anyone use this clutch?
- greddy evo2 catback ......
- Horse Power Freaks?
- name that sound-
- 208 whp on a mustang dyno
- Why wont IT START?!!?
- I need exhaust gasket part numbers!
- Removed my thread??
- HKS RS Intake
- took 15hrs but Buschurs 37r is amazing
- short power loss. any ideas???
- im used to hondas, just trying to get some more info on evos..
- mobile 1 extended life .....
- Fujitsubo RM-01A Exhaust Box Dimensions?
- Post clutch install problems
- Evolution Mass Air Pipe Upgrade...
- New Turbonetics GT-K lineup
- Shifting still notchy
- Does this sound like a good 1st stage?
- oil light
- Quality LICP?
- Is BR3065 same size as a 50trim?
- Apexi intake
- need some help with my trany
- megan manifold owners
- Wideband sensor placement for IX
- which one would you guys use .....
- LM-1 Wideband issue???
- Starting Over - 2.0L/PT67dbb build, pics inside
- Feels like I've lost power??!
- Question about a part...
- Boost hesitation when running high boost
- 02 censor
- Rear diff problems in an EVO8
- Speedo not working :(
- 2005 MR 6spd
- 1 liter enough for full brake flush?
- Difficult boost leak
- BR 3065 & Clutch
- Tuned for test pipe, back to HFC now?
- High Pitched Buzzing Sound
- Help! What turbo do i get?
- Helix Hollow 272 Cams Installed - No Problems At All
- GSC EVO 9 CAM RESULTS DYNO'S Inside!
- IX shift linkage
- My old EVO IX dyno chart (+69ft/lbs with just exhaust)
- engine problem- warr, anybody?
- Fuel/Boost Cut question
- Engine Problem... please help
- ATP 30R vs BUSCHUR FP3065
- atp 35 kit
- ALKY Injection Gone Wrong........ WAY wrong.....
- clutch discs universal?
- 6 Speed Tranny a weak link?
- Lifter?
- Turbo prop play...options?
- Problem: BOOST Spike + Fuel Cut.
- bov leak
- Full Stock Turbo back exhaust with race pipe!!!
- Would this of put my oil pump timing off?
- Lots of vibrations thru clutch pedal...uh oh?
- turbo prices?
- 16G same as 20g?!?!?!
- My clutch made a huge adjustment!
