PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 [232] 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Modified Type -S
  2. Max Boost Pressure on Standard Internals
  3. Question for those with the Exedy Twin Disc
  4. boost solutions(stroker kit)
  5. Need some info about turbo kits
  6. turboxs downpipe
  7. Helix exhaust vs HKS carbon Ti
  8. Need part # for Fuel Pump Kit for EVO 8
  9. pics and info on cam install in head
  10. I broke something. Serious?
  11. Dynoflash street tune in ATL
  12. Stock BOV unloading at altitude???
  13. question about changing tranny fluid for tonight
  14. can people post pics of where they mounted there catch cans??
  15. Anyone had this problem?
  16. mini battery kit, where do you get it?
  17. RMR or Buschur Turboback Exhaust?
  18. Ti GReddy Racing Exhaust (NEW)
  19. electronics scare me
  20. Funny Idle
  21. Post opinions on ACT clutch for EVO
  22. Who can install Head Studs?
  23. will evo 7 header fit evo 8?
  24. Installed PTE 680cc injectors
  25. EVO radiator
  26. Reuse Headgasket When Doing Headbolts
  27. Need Clutch Advice
  28. jun 264 cams?
  29. evo questions
  30. Any major differences between the engine blocks of evo7 and evo8??
  31. P0420 ???
  32. Oil usage and 272 cams
  33. Pennzoil Synchromesh.....anyone?
  34. Some EVOs knock a lot??
  35. When to change injectors and pump?
  36. Any vendors selling HKS Dragger exhaust?
  37. well, time for a fluid change...still a little confused
  38. Strange Whirring Noise After I/C install
  39. Blitz DD BOV
  40. weird problem in my evo!
  41. Sound clips of Greddy Titanium and AVO?
  42. ACT, Cusco, Exedy, Clutch Masters or Center Force?
  43. sparks out tail pipe
  44. Stock intake air restrictor???
  45. breakin for new clutch, gears, synchros, and bearings??
  46. Dyno results 369.9 whp / 347.5 tq
  47. VTA with Greddy Type S
  48. Grounding Kit
  49. Downpipe question
  50. So many Choices....
  51. where can i find the AVO exhaust
  52. P0138
  53. Looking to buy ACT clutch and boost gauge.
  54. Just installed Perrin short-shifter + bushing kit
  55. Well my clutch is going out
  56. which oil filter for 15w-50
  57. Wierd RPM change
  58. Replaced Your transfer Case?
  59. turbo xs hp mbc
  60. Level Evo?
  61. ACT vs. Cusco clutch?
  62. Advanced Tuning Products
  63. $2,000 mods in the next few weeks, which ones first?
  64. Please help me with my Greddy Type s BOV
  65. EVO Con rods & pistons
  66. Engine Oil question.
  67. help, i thnk car is pinging.
  68. Purchased the Perrin Downpipe from Boost Solutions today!
  69. Backwards, Hybrid Evo 3 Meets 7 Drag Car
  70. RSR Exhaust
  71. Check your HKS Hi-Power exhaust
  72. Which is more durable cusco or exedy?
  73. I need exedy twin clutch in socal now!!!!
  74. count me in
  75. does anyone know what exhaust this is?
  76. Pics of Reworked EVO 8 head
  77. AMS Turbo kit pics
  78. New JDM Exhaust - What you think?
  79. ask for cam
  80. PO300 code = NO WARRANTY COVERAGE!!!
  81. new exhaust manifold for EGT
  82. Well this sucks....
  83. JUN cams 262 or 272s? Who has them?
  84. info about hks intake
  85. Greddy gauge problem, help!
  86. HELP, broke of cam belt tension tool
  87. threw a cel code p0401 EGR insufficient flow error
  88. boost controller
  89. if A high flow cat flows almost 600cfm, how much does a cat delete flow?
  90. Whats the best 3'' highflow cat for the USDM evo8
  91. HKS Intercooler
  92. 4 tip spark plug
  93. fq 330
  94. Max HP Greddy Type-V (24V) I/C can handle
  95. AEM? DynoFlash?
  96. 1
  97. Evo VII Mod Questions. read pls! :)
  98. Evo exhaust sound clips
  99. Where can i find and electronic exhaust bypass valve ???
  100. plugs,wires, and exhaust
  101. Bov
  102. HKS spacers to replace the MAS
  103. Power+drag racing times
  104. RPM Stalling- Difficulty
  105. Greddy Intercooler
  106. What about this combo?
  107. 5th gear fixed...
  108. usa and uk specs
  109. My turbo bearing seized and shaft snapped...
  110. RNR O2 Elim. Downpipe?
  111. The Lancer Evolution is a high maintenance toy
  112. Car is knocking!!!
  113. Looking to by Real time Data logger for the Factory EVO ECU
  114. how much hp can handdle
  115. Are you getting the 0300 CEL
  116. COBB Accessport for the EVO8!?
  117. What to get?????
  118. A Listing of All ECU Error Codes (OBD-II)
  119. Which mufflers will bolt to a B&B midpipe
  120. Aem Vs Hks Intake
  121. My Evo Sounds Like A Diesel!
  122. Tomei Evo Vii
  123. EVO 8 valve springs
  124. HKS 264 Cams
  125. safc settings w/272s
  126. Thank You Z1 and Ultimate Racing
  127. Perrin crank pulley
  128. Question about airflow
  129. Beating a dead horse
  130. rev matching destroyed my clutch?
  131. Trans/diff.
  132. my car started stalling and missing out of the blue??!! Any ideas??
  133. Adjustable Blow-Off Valves Question
  134. 5th gear grind question
  135. P0300 Questions and Help.
  136. Exedy Twin-Disc Problems..HELP!!!
  137. Perrin exhaust owners need your advice
  138. Perrin vs B&B vs Buschur
  139. Need lower IC pipes ??
  140. Electronic Exhaust Bypass??
  141. Highflow Cat Vs. No Cat?
  142. Thanks to Mark@Quantum Racing!
  143. how much hp can the evo tranny handle?
  144. Noise in my car??
  145. APS Turbo Back Exhaust w/ Pics
  146. stock injectors
  147. Center Diff Removal Problems.. please help?
  148. Broken Transmission??????
  149. Best Intercooler?
  150. Dyno Baby!!!!!!
  151. Anyone having problems with the Ultimate Racing Downpipe
  152. Mechanical Boost Gauge
  153. B&B downpipe clearance issues?
  154. Oil Change Nightmare
  155. Type-H34 BOV for EVO-8??
  156. CEL just came on and car started bucking...
  157. Stock Turbo Upgrade?
  158. Apexi AFC-2 settings
  159. Perrin Fuel Rail, B&B DP, TP
  160. 264/264 Jun intake cams...
  161. installed fuel pump-idle 1000 ?
  162. Exedy Twin Disk clutch engagement point
  163. RNR turboback ?'s
  164. How do you read the HKS turbo designators??
  165. factory ignition timing
  166. Are all Mitsubishi Injectors the same
  167. head studs?
  168. add one to the jacked tranny list
  169. World Electronics Total Boost Controller
  170. Where to mount SAFCII with relocated HU and gauges where HU used to be???
  171. Which is a better intake system?
  172. Another BOV-type question/discussion
  173. Has anyone seen this HKS BOV kit?
  174. Turbotrix does it again
  175. Hondata heatshield gaskets released for EVO's
  176. Attn: AEM Intake Owners
  177. I got cat and dp w.o a cat delete
  178. ??? about 272 cams
  179. Need a qucik response on AEM/K&N
  180. Aftermarket fuel rail experiences
  181. PICS FOR NEW HKS Ssqv & Greddy Ti Catback
  182. Thermal R & D...
  183. New Ssqv & Greddy Ti Catback --great W/pics
  184. TeamRip Front LSD and Tranny rebuilds
  185. Greddy Racing Full Titanium Exhaust~~HELP!!
  186. anyone consider 3.5in exhaust?
  187. fuel system upgrade path...
  188. pinging with dp and cat-back?
  189. Rev Limiter
  190. transmission question...
  191. Who has hks,greddy or ex engineering intercoolers in stock?
  192. greddy
  193. VENDORS PLEASE READ...DP Fitment Problems
  194. boost controls
  195. Urgent help needed...SAFCII and field harness wiring question
  196. I need HKS 272 Cams ASAP
  197. Ultimate Racing Test Pipe Install
  198. Need Microtech, who have one available?
  199. Cable Across Valve Cover
  200. Cliking Sound when key is in the Ign On
  201. MBC void warranty?
  202. Only seeing 14psi on 1st gear
  203. SP downpipe have you seen it?
  204. Lancer EVO VIII. Rear axle torque
  205. Vendors: does anyone sell Evo 8 O2 Housing Flanges?
  206. Fu Arc!
  207. need advice on turbo ugrage
  208. SAFCII should be here today, no wideband yet, and no dyno to go to
  209. Tuning question?
  210. emanage works need base map
  211. JIC DownPipe
  212. hks downpipe
  213. Best Intake?
  214. Boost Controller
  215. Finally Happened - Evo Stalled
  216. How good is the stock intercooler?
  217. Buschur FMIC
  218. HKS Twin disc clutch(GD MAX)
  219. Please help with UR kit/HKS SSQV install
  220. Low end Torque
  221. Turbo xs RFL BOV
  222. HELIX turboback exhaust
  223. Which Oil Filter?
  224. Downpipe & Tie Bar Problems...Please read and provide help
  225. Where is the relay for the fuel pump on the EVO??
  226. Intake Systems
  227. smoking evo
  228. Need Advise on Greddy Exhaust !!
  229. Anyone have a Turbo XS RFL?
  230. installed hks suction intake system
  231. Need to get several parts for my Evo VIII...please help.
  232. denso 660 injectors?
  233. Buschur Racing Stage 4 pump gas results!
  234. Still looking for the Greddy Type S BOV
  235. Methanol vs alcohol
  236. Possible boost spiking causes with stock parts ?
  237. Intercooler Reservoir Question
  238. Driveline Clunk??!?!??!?
  239. awd and launching
  240. Looking for Greddy type S BOV
  241. Stock ECU Learning
  242. IC piping needed
  243. Best manifold for T0304
  244. Greddy AF Warning Series Gauge
  245. Front end THUMP....THUMP...THUMP????
  246. ses light for egr valve
  247. Need a good price for IC piping
  248. boost
  249. Practical Mods
  250. Shifter bushings
