PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. slight sputtering between shifts
  2. Are Evo 8/9 Axles 30 or 32 spline?
  3. Never-ending Weird Sound, Evo IX
  4. Ams intercooler
  5. Help: AFR Dip at Peak Boost. Why?
  6. no power at coils
  7. Installing half-shafts into rear diff HELP!
  8. Need some help Lean spike issue
  9. Question about Buschur air filter.
  10. home brew Oil supply line for turbo?
  11. I've got a serious problem!!
  12. Non ACD diff in ACD car?
  13. Knotchy / grind shifting questions - maybe clutch adjustment?
  14. Boost leak test / running rich
  15. For all fp turbo owners
  16. 4g64 evo bearing clearances
  17. Looking For more power Evo 7
  18. Intercooler that Fit with Cusco Brace
  19. Road Race o2 housing
  20. Exedy twin hd vs quarter master twin 500-600whp
  21. Going from Evo 9 turbo, to FP Black
  22. Switched power near trunk?
  23. Which head gasket for 2.1/2.4 build?
  24. Evo Head Noise/Tick Help Plz
  25. Intake Manifold Bracket
  26. fp black vs pte 6262 .63 a/r pump gas?
  27. help smoke on decel only
  28. Ralliart Front diff
  29. High Fuel pressure, only 1 pump
  30. Light driveshaft questions ?
  31. clunking noise from tranny/tc area
  32. Fuel pressure regulator
  33. Thinking of switching out of Greddy Ti to ???
  34. Flashed car won't start
  35. Turbo Upgrade vs CA Smog
  36. ACT Street Clutch HD vs 6 Puck
  37. need help with part identification plz?
  38. Fp wga
  39. Evo breaking up 'HELP'
  40. Whining Noise! PLZ HELP!
  41. Car wont turn over all the time! PLEASE HELP!
  42. New BBK full broken in, exhaust smells like oil
  43. Horrible clutch chatter only in reverse?!!!
  44. from no boost to boost creep wtf?
  45. Smog Test FAIL - can leaking donut gasket be the cause?
  46. AMS oil pan question
  47. Evo max power
  48. max ring gap???
  49. Tranny grind :/
  50. Spark Plug Electrodes Broke Off
  51. Check ur Valves!!!!!
  52. Kenne Bell BAP
  53. How can a turbo cause farting (missing noise)?
  54. Tranny,transfer case, and rear diff fluid
  55. longevity of twin disc carbon carbon clutches?
  56. In a rut! To drop the oil pan or not!?
  57. A few pics of my car as I prep it for the SO!
  58. Need help with shifter wobble..
  59. different 4g63???
  60. 2.4 timing belt help
  61. Intercooler Upgrade
  62. My evo 8 misfires .. Help!
  63. Odd sound at startup, a whirring grinding sound that goes away...
  64. is there a way to lock the mivec gear during timing install?
  65. Clutch install same time as tune?
  66. fuel limits
  67. supertech VALVE SEAT question
  68. Running Lean
  69. Divorced vs. factory style o2 housing
  70. New clutch and new tranny problems
  71. Engine build. Parts locations??
  72. Hissing from under the hood, Forge MBC
  73. New turbo
  74. Exedt Twin Disc Thickness
  75. Weird buzzing/grindy sound from rear...
  76. Clutch question?
  77. Injen intake filter replacement (amsoil
  78. Wedge Collar Stuck?
  79. Identification - Genuine or Aftermarket Crankshaft
  80. Any thoughts on Tomei extreme manifold?
  81. Help , the rod is hitting the walls !!!
  82. Vibrating car at takeoff?
  83. Blew ignition coil fuse with non COP kit
  84. Wtb: Rs rear diff conversion
  85. Can I switch from speed density back to stock maf?
  86. p0107 and p0113 codes?
  87. Turbo XS intercooler
  88. What's the best engine oil for Evo 9?
  89. can i make this build possible.....
  90. electrical gremlin !!!
  91. Driven Innovation Intake Manifold w/dual fuel rail Evo 8
  92. best cams for low end power?
  93. Clunck noise
  94. fp red vs 5758??
  95. Evo VIII boost problem..!
  96. Opinions: Use or not to use inline oil filter for GT series (GT35R) turbos?
  97. cars breaking up in rpm
  98. Transfer case help.
  99. Low Oil Pressure (not ops)
  100. anyone DIY'ed their engine mounts?
  101. Boost logging and control?
  102. How do I plug the MIVEC
  103. Rebuild my twin or go with ACT 6 puck??
  104. twin scroll T4 question
  105. Overboost code and my car cut when boost start
  106. turbo suggestion
  107. TB seals and EGR Blockoff?
  108. Swapped my transmission now im overboosting?
  109. What is best cam gear for evo 8?
  110. Best Mivec Cams for FP Black / 2.4 ?
  111. Anyone know what the part number is for the Mivec Feed bolt in the IX mivec head?
  112. Remove/replace front O2 sensor - Tips?
  113. cosworth M3 specs / Kelford 280 specs
  114. misfire in high rpm shifts
  115. Evolution ix rebuild
  116. Need help with Compression ratio on a 2.4lr
  117. Building a 16g optimized for spool
  118. Where to Buy a Ikeya Shifter????
  119. Need Help: p0108, p0113, P0335
  120. can i just replace the disc in my act clutch
  121. Ams cat back question
  122. Oil return line leak 06 evo ix gsr
  123. Oil return line leak 06 evo ix gsr
  124. suspicious engine noise. cant find cause
  125. Wife's BDay present AMS intercooler +?
  126. can you use the pcv nipple on the intake manifold for a boost signal?
  127. Overboring - benefits and worth it?
  128. boost ranges from 21-24 psi randomly?
  129. Transmission rebuild - who is the best?
  130. Time attack E85 fuel system
  131. Full blown twin pump install help
  132. Factory o2 sensor life?
  133. Compression test result
  134. -8 an fitting on a fuel rail?
  135. Adjusting Blitz BOV
  136. AC Whining? Compressor?
  137. discovered drilled holes in baffles under valve cover - anyone else seen or done this
  138. Turbo help for 2.3L and 91oct...
  139. shifting ?
  140. Fast clicking noise
  141. clutch help
  142. HELP PLEASE, coolant in oil pan after fresh rebuild
  143. Manley I Beam rods; Normal vs Lightweight
  144. 6765 2.3 Build question.
  145. Rear LSD Testing
  146. Rear diff dilemma need some advice
  147. Help me identify these mods on this 04 i bought
  148. evo died at 50 mph and never started again
  149. need help with ss lines
  150. Let's really talk exhaust manifolds for a bit, long runner vs short runner
  151. Help!!!
  152. transfer case
  153. Car Won't Start After Short Drives
  154. precision injectors ??
  155. No Fuel Pump Prime/No Tach Signal
  156. where are the AYC and ACD bleeder screwes?
  157. LSD Clicking
  158. Arashi Turbochargers
  159. ETS Intercooler
  160. pistons
  161. ac problem..took it in still no ac...here is the problem
  162. PTE 680cc injectors
  163. Clutch engages late
  164. Evo IX - "Service Engine Soon" light blinking under heavy boost
  165. Need help. No fuel pressure
  166. 5 speed tranny?
  167. Intake manifold???
  168. Whats better sounding than my ETS exuast?
  169. Turbo timer
  170. AMS Oil Pan on a 2.4L Long Rod
  171. new Quarter Master eight leg street twin is out
  172. Boost Leak Tester for HTA Green With 84mm cover
  173. Stock timing belt safe for 500+hp??
  174. Stalls at idle
  175. Reccomendations and critique on setup
  176. Knock, maybe?
  177. Service Engine Soon?
  178. Tilton Twin With HTOB
  179. Evo 7 diff whine?
  180. So i pulled my ayc diff out today out of my Tme Evo 6
  181. Replaced all Injector O rings and still leaking ??
  182. Recommend me an intercooler.
  183. precision 6262 ball bearing question?
  184. Building a turboback
  185. Evo 9 o2 sensors
  186. Hallman cockpit
  187. Suddenly rich. HELP!!
  188. EGR blockoff plate stuck from RTV
  189. need some quick questions answered fast
  190. Knocking higher & Response slower after changing BOV.
  191. New quartermaster V1 disk vs. old V1 disks
  192. Is this Timing Belt timed correctly?
  193. blitz SBC problem
  194. temp sensor in the thermo housing?
  195. Evo 8 head..should i buy one or repair the old one??!!
  196. low oil light
  197. Kelford 272 cams Threaded wrong?
  198. can someone please enlighten me?
  199. Problem with a boost leak test
  200. Warning: Skunk2 Composite Fuel Rail ***DO NOT BUY***
  201. Hallman pro
  202. 90k miles to many for e85?
  203. Gates timing belt whine... normal?
  204. 2.4 LR GT3076r 4G64
  205. replacing my mr transmission.
  206. hks silent exhausts
  207. strange sound coming from my timing belt area
  208. Engine issue, help
  209. Flywheel bolt size
  210. Anyone using the Tomei Procams 270
  211. Will a 3" HFC Fit in a Stock Exhaust System?
  212. Mystery cams, anyone know what these are?
  213. Compressor surge?
  214. Problem with rebuilt engine...
  215. Upgrading evo IV, or stay as is?
  216. O-Ring Block?
  217. tranny in RS?
  218. 6262 questions for building a kit
  219. Pulsing vibration help!
  220. Liqquid FP Black and Pro Efi build
  221. Question on my Synapse DV,
  222. Solid Lifters
  223. Not your typical 4th Gear lockout((low RPM)) Please Read--- {pcfreak}
  224. Does my clutch fork look right?
  225. New clutch, hard going into first, reverse
  226. hks dli 2 wiring
  227. De-activating AYC for Gymkhana pratice...
  228. Rods, Brian Crower I beams?!!
  229. Foggy headlights? This is a great way to fix em.
  230. Thoughts on Lighter Driveshafts?
  231. Compressor replacement
  232. 2.4 teardown ?
  233. AC Stalling/Car wont turn over
  234. Anyone have a short shifter for 6 speed?
  235. Turbo manifold leak??
  236. Does your stock or stock appearing turbo spool to slow? check your wastegate
  237. What valve spring should I use
  238. knocking noise coming somewhere
  239. tranny/clutch issue
  240. Transmission/Transfer Case Leak: Need Advice
  241. Bad idle, loud ticking (w/ video)
  242. evo 8 & 9 transmission question
  243. Idle Speed Control Motor.
  244. quick question about my 5speed gearbox!!!!
  245. Exhaust sound clips
  246. BR8ES or BR7ES problem
  247. Getting Down To Details
  248. Transfer case
  249. Valves? Should I upgrade?????
  250. Clutch/trans problem?... Frustrating
