PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 [204] 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. O2 Housing Installed but w/o heatshield
  2. stupid question about maf pipe kit from Buschur
  3. spark plug clarity?
  4. Buschur Racing Evo 8 Coil-On Plug Ignition?
  5. Need some suggestions on next mods for 11's
  6. New Clutch....Flywheel Too???
  7. Finally got dyno'd
  8. New clutch set up+pics and more!
  9. Evo fuel pressure at fuel rail...
  10. hallman short rx kit install?
  11. Greddy t-67 guys!
  12. 3" Exhaust Gasket
  13. Boost Leak Issues
  14. Big Boost Question
  15. Greddy EVO2 modified
  16. Cams with stock exhaust? opinions on my upgrade path..
  17. Defi BF Install Help and Questions
  18. Help Diagnose My Car
  19. Car won't idle.
  20. Question about gauge sensor locations
  21. Power before turbo?
  22. Loss of power idle to first gear
  23. Help, o2 housing bolt size?
  24. Will the grease in the APS BOV ever dry out?
  25. Will a dyno run show boost leak???
  26. Opinions on boost control?
  27. Possible Boost Leak?
  28. Recommended s.plug regap ?
  29. Buschur Built Engines
  30. check this out. Damn Curt!
  31. injen intake and greddy type-s
  32. 10psi wastegate spring ????
  33. Greddy Type-S BOV question
  34. Lost a pound of boost, make sense?
  35. Are the Exedy Triple carbons rebuildable?
  36. Diameter of Compressor Inlet
  37. 400whp Possible With 21G on Pump, No Alky?
  38. 80mm Downpipe + Testpipe Combo?
  39. hks ssqv
  40. Car stalls on inclines???
  41. Lets play guess the part...
  42. pushing 350-380whp on stock clutch
  43. spark plug question
  44. If you run over 22psi w/stock head bolts (or have blown a head gasket)...
  45. average mileage on 2dsk carbon
  46. Problem: P0300 Random Misfire at idle on a daily basis.
  47. 02 housing flange
  48. way to test oxygen sensor ?
  49. injector duty - AFR
  50. X Clutch
  51. Tranny Problems Help!!!!!
  52. MBC/PSI Question!!!
  53. My Custom Turbo
  54. Correlation of timing to EGTs
  55. Pass emissions test with mods, yeah
  56. Gt3037s Turbo
  57. Turbo Selection
  58. HKS IC Piping Question
  59. Headers for GT30 Series turbo's??
  60. Knock voltage reading 0
  61. would a bolt on dsm turbo work for an evo?
  62. 4G63 Sounds like a barrel of Monkeys with hammers
  63. ? for the 3071r guys...
  64. Just got done installing some goodies
  65. BR injectors
  66. Amuse Extra Titan Titanium exhaust
  67. "Perfect" Downpipe?
  68. 30th ann. hi power?
  69. NEED your opinions/experience with stock clutch on a 3071
  70. Relocating the IC sprayer tank...
  71. Buschur's MAS pipe kit..
  72. .272 HKS Cams + Dynoflash questions
  73. Resonated Testpipe vs. Regular Testpipe
  74. What Should I Do?
  75. Can i use this turbo?
  76. which ACT clutch to get?
  77. Finally going together!
  78. Who's been tuned and reflashed with these mods?
  79. HKS rs, replace filter with k&n?
  80. T-bolt clamps on stock IC pipes?
  81. In the shop again!
  82. B&M Short Shifter Question
  83. can someone i.d. this turbo?
  84. Evo oil question
  85. Single pod steering column
  86. Compression test questions...
  87. how to take off the timming belt?
  88. symptoms of bad synchros..?
  89. Gt3076r-wg-turbo
  90. DP CARB legal?
  91. Help for Wiseco pistons fitting.
  92. 280 Cams and Stock Turbo?
  93. how do you know when you misfire?
  94. anyone have the Greddy FMIC?
  95. Exhaust extend + Flange question
  96. Front Axle Boot Leak?
  97. check ecu code ?
  98. Grade 7 or 8?
  99. Which testpipe with HKS downpipe and exhaust
  100. Part# Front o2 sensor needed
  101. which ems for alky kit?
  102. Anyone running VTA bov without standalone? EIDS user input welcome!
  103. WHP Estimate..
  104. Cant find that new oil catch can that mounts to strut brace???
  105. HKS SSQ VTA video clip
  106. Boost questions
  107. MBC installation questions....
  108. Do i need a fuel pump?
  109. AEM MAP sensor seems very inaccurate
  110. Axles!!!
  111. turbo problem?
  112. Hi Flow Cat ???
  113. Maf ?
  114. Has anyone changed their own syncros???
  115. Helix intake fits like total ****
  116. Revolvers or HKS 272
  117. How do I remove the throw out bearing from the pressure plate?
  118. How to check for a collapsed lifter?
  119. What causes limp mode?
  120. Turbo Outlet Gasket...
  121. Weapon R Engine Dampener Broke!
  122. Is my fuel pump going bad???
  123. Trunk-mounted alky system options?
  124. minimal 05 EVO 8 mods needed to beat 300WHP SRT4???
  125. help !! with groundin
  126. Helix intake pipe fit the stock air box?
  127. t-66 manifold??
  128. <---IDIOT Note to Self (cam and walbro install)
  129. Lightweigh flywheels
  130. Pics Of My Magnaflow Ti And Tenabe Dp
  131. Pennzoil synchromesh
  132. stock spring Bolt from stock DP
  133. Ground wire kit
  134. HELP! Whining Noise!
  135. Inlet temp
  136. Oil Pressure Problem? Help Needed.
  137. jet fuel? in a evo
  138. BG Syncro Shift Question
  139. should I get a fmic with my mods?
  140. when is a radiator needed?
  141. VTA vs Recirc BOV performance
  142. what does mitsu dealers do for 30,000 tune up
  143. Alky INSTEAD of race gas?
  144. Boost Problem Please Help
  145. Car not performing like others...
  146. lean cylinder
  147. What clutch???
  148. 3" buschur cat back to stock cat? will this work?
  149. how does this exhaust set up sound?
  150. Dynoed 489 awhp on 93 octane and some alky
  151. 20/21G Buschur Upgrade
  152. Injectors / Fuel Pump
  153. clutch adjustment problems!
  154. 240whp-vs-330whp
  155. Evo 8 tranny and Tc?
  156. Houston/use your wideband O2 tomorrow/help
  157. best way to shift?
  158. need help with bov and intake
  159. Just Bought Exedy Hyper Triple Carbon Clutch
  160. Boost leak vs vaccuum leak ???
  161. What is balanced and blueprinted on a engine?
  162. Any feedback on Buschur stage 1 upgrade?
  163. Need some Advice: CODE P0134
  164. crower cams
  165. What to get...
  166. Am I running rich????????
  167. Redline Q?
  168. PLX-m500 help needed
  169. Clutch Chatter, Replace Soon?
  170. Is my wastegate shot?
  171. what to do next?
  172. Jon Rippley TRE... where is he??
  173. Cold Start Issue, Please Help!
  174. Quick question
  175. injen intake ?
  176. any feed back on piper cams ??
  177. Magnaflow TI Exhaust
  178. CUSCO acd
  179. DIS-2 on an EVO ??
  180. ATS Tripple Carbon prob!
  181. where can i purchase an o2 sensor replacement??
  182. boost problem
  183. dumb question
  184. cant remove the intake
  185. Some info about fluids for our tranny/diffs...
  186. evo motor interference or non interference
  187. c16 and race gases...
  188. Another 2.4 question
  189. 2nd gear around 5,500 RPM loss of power and a hiss...
  190. Question about strokers....
  191. Stupid Exhaust Question ...
  192. to all with hallman boost contorllers
  193. Downpipe decision...
  194. Little nipple on the upper portion of the lower IC pipe...what is it?
  195. cooling fan wont shut off
  196. Turbo question
  197. Need Some Kinda 90 Degree O2 Adapter
  198. Need Some Advice!!
  199. just installed HKS bov
  200. Rear diff and Transfer oil
  201. Drivetrain issues - Rear diff?
  202. dyno 10.5 + 280 + alky
  203. CAN port?
  204. Installed cams. Need help!!
  205. turbo turning red
  206. Best Stroker Kit and complete engine
  207. Best Hi-flow Cat?
  208. helix o2 outlet size?
  209. Need: Stroker + Turbo?
  210. hallman mbc tapers down 21-19 psi
  211. pics of my new turbo kit
  212. Upper IC pipe question
  213. XS Engineering Intercooler and Piping
  214. which cams to get?
  215. Test pipe with no cel light
  216. Comp. test done, got a low cylinder.....
  217. springs and retainers
  218. How to tell if you have 10.5 hotside?
  219. any difference in 03 and 04 turbos?
  220. What to do with stock boost controller?
  221. I just want it to be DONE!!!
  222. Lower I/C Popping off
  223. i backfired rreally loud with a cat!! and Q about greddy BOV
  224. Proof afcII is good
  225. dynod my car today
  226. vacuum source, and boost ?
  227. 442awhp dyno sheet W/PICS!
  228. UPgrade Intank Pump ?????????
  229. flat panel vs cone filter re. cold air/flow
  230. MR fuel pump a good upgrade?
  231. stock pistons coated?
  232. Where can i get a new OIL COOLER? (OEM OR AFTERMARKET)
  233. Looking for the Best BOV
  234. B&M Short Shifter Part #
  235. Nisei intercooler installed
  236. What plugs to get?
  237. 05 downpipes
  238. best place to get hallman pro boost controller?
  239. Best short shifter setup?
  240. Is nitrous a safe option for what ime looking for???
  241. 50/50 BOV and driveability?
  242. Intake Manifold pressure source
  243. Best Flywheel on the market
  244. 3 boost gauges and they all read different!
  245. how much nitrous? boost?
  246. Cams After Buschur Stage 1?
  247. Evo 8 block height and rod length.
  248. more boost/less timing or vice-versa w/ high octane fuel or water injection
  249. Well got my syncro replaced...
  250. megan cat back?
