PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Are these pistons good
  2. What kind of clutch for Evo 6?
  3. factory driveshaft with high whp/tq
  4. Looking for the best cams for my current set up
  5. Evo 8 CYLINDER OIL JETS (SQUIRTER) crush washers??
  6. Hood exit dump
  7. how can I tell the old fp green from the new one?
  8. 4g64 timing mark help!
  9. EVO 8 Need Help
  10. Looking for Dogbox Gearset compatible with EVO 4 5 6
  11. Braided Fuel line, Pump to FPR Length?
  12. Need opinions on Injectors
  13. spark plug stuck help
  14. transmission questions
  15. Intake Manifold -AN Fitting solution question
  16. Need help evo m peeps...
  17. HELP choosing gas tanls to store E85
  18. AMS Full 3" Turbo Back Exhaust System 05 evo 8
  19. Power Steering Problem After Clutch Installation
  20. Which Exhaust manifold ?
  21. want to put a 3bar or 4bar map on evo 6
  22. fuel pressure issues
  23. How to tell if it's a real FP turbo
  24. Trans install issues
  25. Evo 9 lacks power
  26. What intake filter to get?
  27. Evo 9 ayc butchered when bought?
  28. Advice needed on build
  29. Clutch Issues.
  30. Turbo upgrade
  31. Question about Evo 8 turbo oil return line
  32. Gt3582r
  33. Any way to tell between Megan o2 housing and stock visually?
  34. E8 where to connect accusump
  35. Tremendous boost drop?!
  36. 274/278 hks 11mm or gsc s2
  37. Extra parts after head gasket replacement.....HELP
  38. help me figure out what exhaust I have
  39. Which manifolds to buy?
  40. Evo 9 oil filter bracket housing question
  41. Engine ticking noise, new lifters
  42. anybody up for some current turbo size comparisons?
  43. problems with knock
  44. Best turbo to max out stock engine on 93?
  45. Exedy Twin HD question
  46. Will I benefit from now injectors?
  47. best intake manifold for a 2.0liter, pte 6766 combo for 1000whp goal.
  48. Looking to buy a Megan o2 housing but I have a few questions
  49. 2.2 Super Long Rod Stroker Motor
  50. fp green semi build results?
  51. check light on my evo 9 mr jdm.
  52. Exhaust manifold stud kit?
  53. Evo 9 cold start stalling
  54. Ignition breaking up after 7k!
  55. Intercooler options....
  56. Jumpy Erratic idle
  57. quick easy question for you guys
  58. Competition Clutch Stage 3 - experience requested
  59. Video...engine noise please watch.
  60. Anyone know of any aftermarket evo8 shifter cables
  61. Built long block that has been sitting - help
  62. Problems going into 5th
  63. Tranny issue. 5th gear
  64. MAP head oil feed plug issue
  65. Speed sensor
  66. 2.4LR Evo 9 Crank No Start-- Need Help
  67. Oil Pressure light - EVO 9
  68. S90 Throttle Body Help
  69. exedy twin hd noise?
  70. Need some help diagnosing an issue...
  71. Clutch/Flywheel issue questions
  72. how to get stock wastegate to run maximum boost?
  73. Enlighten me please! clutch issue/trans issue?
  74. Blown Ignition Coils
  75. Max whp on Precision 1000cc's and Buschur Dual pump
  76. whistling sound.....? need help!
  77. looking into cams for my evo 8
  78. Let's guess my compression ratio!
  79. Evo lost power
  80. Evo7.5GTA rear diff on Evo7 Manual
  81. serpentine tensioner started knocking with ac on.
  82. JE Pro seal gaskets for 4g64
  83. im replacing my clutch, any recommendations??!!
  84. Transmission problem?
  85. Evo IX Slave Cylinder, are they all created equal?
  86. Help, can't select gear right after depress clutch
  87. Weird Engine Noise...
  88. map ef2.5= worst decision ever
  89. Timing 2.4 - Stock gears
  90. Removing Evo 8 Block but Not Tranny
  91. Carbotic clutch friction material??
  92. replace 5th gear and synchro without removing trans?
  93. Calling all buschur racing downpipe installer
  94. evo 8 drive shaft ???
  95. Gsc zero tick lifters problem
  96. 05 Evo 8: Needs Valve Job
  97. Hesitation with COP system
  98. EVO9 tranny with EVO8 4th gear??
  99. what you guys think my problem is? sounds cam but not problem starting
  100. Got a little problem.....
  101. Evo IV will not allow me to turn up boost
  102. Evo 9 will not start!!! Searched.
  103. Anyone got a HEL 25 row oil cooler fitted on their IX?
  104. Need help or suggestions solving problem on evo 9
  105. Modified 9 turbo build
  106. IAC Warm Up Flapper Valve
  107. Sudden stop question
  108. Aligning the pinion on a tcase
  109. mil spec 65mm tb issues....again
  110. evo 8 torque solution 5 speed mount question...
  111. Evo Clutch Pedal assembly
  112. Crank choice for 2.3 4g63 build
  113. Best fuel pump for race gas?
  114. STM aluminum exhaust with muffler
  115. Coolant Spraying on UICP
  116. please help dyno results bad!!!
  117. Injen intake and IC piping any good?
  118. evo 9 stock block boken connecting rod
  119. fuel fittings need a favour
  120. Gear pops OUT of Reverse only when...
  121. 2.3L EF4 Boosting only28psi
  122. Poll: Balance shaft removal and mileage input please
  123. serpentine belt
  124. Car not going over 12 psi at wot help!!!!!!
  125. RPM hang/IAC valve
  126. clunk issue
  127. How much does boost.....
  128. Need another 70whp.
  129. Pops out of 3rd
  130. Using factory fuel feed for return
  131. Kelford cams grinding off original part number?
  132. AMS/Moroso Wet Sump oil pan sealing: Custom gasket?
  133. Timing belt auto tensioner!
  134. driveshaft question
  135. Calling all EXEDY twin owners/ Past and Present
  136. Transfer case EVO 8
  137. Just an interesting dyno sheet comparison of three different gears.
  138. Cam cap bushing install?
  139. Priming Engine/Turbo oil
  140. Universal downpipe and pipe dump tubes for my build
  141. replacing rear axles
  142. boost leak at 13 psi from oem wg actuator, should I upgrade if tuned at 25psi?
  143. Bell Housing/Clutch Noise
  144. Using LS style v-8 coils on EVO 8/9. Will it work?
  145. PTE Turbo compatible with Tial Flange??
  146. 4g63 2.2
  147. Should the revs climb slightly when I put the clutch in when accelerating
  148. Advice on spark plugs plz!!!! Evo 9 fullbolts on maybe 93-e85 tune 1 step or stock
  149. Very confusing bearing destruction
  150. 2-645-stu any complaints?
  151. TAKE OFF THERMOSTAT???Overheating issue with half size radiator. (Mishimoto and Koyo)
  152. are any Evo VIII's running this IC kit?
  153. Oil Pressure Sender on Engine Head
  154. Bore/Stroke Questions With A Twin Scroll 6266
  155. need some help with freeze plugs
  156. What is your opinion on this stoker kit on part quality and price?
  157. Reccomendation
  158. most valuable engine rebuild part you can buy
  159. Usdm acd pump can be used with ayc swap?
  160. what belt can i use with ATI damper
  161. help oil jets under pistons
  162. ninja boost leak
  163. cam gears setting
  164. Can I run 280 cams on a stock motor?
  165. Exedy TWIN HD rebuild adjustment issues
  166. transfer case leak?
  167. Do I need a tune for an open downpipe?
  168. Best camshafts for my setup
  169. Fuel Chilling System
  170. Evo 8 Knocking/Ticking Noise..Help!!!
  171. Car wont warm start - injectors not firing
  172. Wanted:apexi power fc to evo 6:)
  173. Cylinder wall pitting...guidance needed
  174. after MBC install
  175. Low compression in cylinder #3 after timing belt?
  176. Engine messed up when ACD lights come on
  177. Cant decide on a turbo for Drag setup.
  178. Engine Oil Overheat in the Track
  179. Randomly pegged lean after injector install
  180. 4th gear transmission problem !!
  181. Big puff of smoke when launching
  182. oem DV sticking?
  183. Car starts to overheat when boosting
  184. engine build question
  185. Valves have black residue on top?
  186. clutch trouble
  187. wastegate won't fit on turbo right
  188. Build help questions (yes I've searched :P)
  189. Best manifold exhaust
  190. Crankwalked block sellable???
  191. Built Evo 8 motor in Evo 9 Chassis
  192. Engine oil help
  193. What coupler FP 84mm compressor housing?
  194. The Official Engien Compression Numbers Thread
  195. 3.5"-4" downpipe fitment with AC/PS
  196. any stock frame turbo that have 12mm turbine housing and up
  197. Recommend gaskets/seals for a head rebuild
  198. Grinding sound coming from turbo?
  199. Instant Boost Loss
  200. building a 2.4 dont know with route to go helpp...
  201. Built industries review? built4g63.com?
  202. GSP 70mm Throttle Body Question
  203. Car dies
  204. Weird clutch noise...
  205. JUN 264 cams
  206. FP Black - block build to handle more PSI
  207. Name this part!?!?
  208. Buschur Racing ethanol content testing, mind blown.
  209. Timing belt issue
  210. After Cams and E85, I gained 7WHP? Help me.
  211. Building my own T3 kit
  212. 2003 Evolution; Misfire
  213. How can you tell if you have a Front LSD?
  214. Boost Problem
  215. Nooooo "Death Whine"
  216. Bushur Racing 2.3L short block
  217. Best boost controller to go with?
  218. AFR too lean on FP Black?
  219. Stock Turbo Issue
  220. Clutch wont fully disengage.
  221. Timing belt - cam marks with Mivec?
  222. Battery cold cranking amps! What's to much?
  223. Calling all cam Experts!
  224. knocking/tapping sound when clutch isnt pressed in
  225. Crank Walk, Fuuuuuuu!!!
  226. Tested 25G turbo at 34 PSI
  227. Radiator fan problem
  228. BR Double Pumper w/ AN Fittings
  229. Transfer case whine, help
  230. Crank walk rebuild... Is my clutch too strong?
  231. OK, so not happy with QM8, any recommendations?
  232. Which intake pipe and boost controller?
  233. Issue w/ boost...what exactly am I experiencing?
  234. Whats needed to make 500HP?
  235. Timing Belt whine!
  236. Port matching gasket?
  237. Coolant temp gauge reading high all the time…..any idea of the cause?
  238. turbo setup question...
  239. Help! Loud noise coming from head
  240. Does my Evo9 FQ340 need a new fuel pump before remap?
  241. Opinions of RockAuto Axles?
  242. Mishimoto Baffled Oil Catch Can anybody used it on there 9?
  243. EVO 9 MIVEC adjustable cam gears inside!
  244. Holset Turbos
  245. input shaft bearing fitment
  246. Input shaft bearing fitment
  247. Exhaust manifold to turbo studs?
  248. Slight gear grind. Help.
  249. Help choosing 02 housing and downpipe help!!!!!!
  250. acd code 46 trouble shooting help evo ix acd
