PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 [233] 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Greddy Profec e-01 settings
  2. Upgrade boost? Upgrade Injectors too..
  3. HKS 3" dp pn
  4. new turbo kit for our EVOS
  5. Service Engine Light is on
  6. For Those Looking For a Wideband o2
  7. emanage not working after install
  8. Walbro fuel pumps. Failed right out of the box.
  9. HKS IC piping
  10. Turbo for 500+whp
  11. trans problem 03 or 04
  12. fuel injector brand??
  13. what kind of coolant?
  14. retrofitting a quaiffe differential
  15. How long will the clutch last for a newbie?
  16. Which Spark plugs?
  17. What dp to get with the hks 30th???
  18. Buschur 3" TB question
  19. Need help asap!!!
  20. 6 speed conversion since its out anyway
  21. does anybody make adjustable solid lifters for evo 4g63 engines?
  22. Fuel Tank Problem
  23. gear whine???
  24. Clunking Sound...
  25. Smoke @ Startup
  26. Cracking Clicking pull the wheel noise
  27. CEL with new turbo
  28. Greddy Type-S
  29. Upper IC Pipes...What's best???
  30. Gear Problem + Oil report
  31. turbine restrictor
  32. Heat shield
  33. Boost Spike and Boost Surge!?!?
  34. Evo VIII front LSD installed!
  35. Clutch Master Stage3
  36. Espelir exhaust
  37. Anything similar to the Subaru DeltaDash for the Evo?
  38. Question about blow-off valves...
  39. Clutch Extender Rod
  40. P0200
  41. question about the 2.5" Buschur downpipe
  42. evo 8 hood vent shield removal
  43. Deck Manifold
  44. BG Syncroshift II - Does anyone know what GL rating it has?
  45. fuel cut?
  46. short ram or cai
  47. Wideband O2 Sensor INstall
  48. max safe boost?
  49. Hallman MBC owners...put in your heavy spring!!
  50. my goal is 400whp
  51. Shell Helix tranny oil
  52. Titanium turbo
  53. Hks Afr 2!!!
  54. Magnaflow #14835 5"x8" muffler
  55. How Loud Is too loud for diffs?
  56. Rsr Exhaust
  57. "I just got Dynoflashed" thread
  58. Switch from Neutral to first without engaging clutch?
  59. 5th Gear Turbo whine
  60. Fuel Cut
  61. where can you find mits tsb for evo
  62. 2.75 dp to a 2.5 or 3 inch test pipe
  63. Problems help!
  64. Detecting Misfire
  65. Does CEL cause poor performance
  66. stock ecu
  67. Turbo back style DP's
  68. Fluids
  69. turbo upgrade
  70. Diff Whine. Suggestions? Ideas?
  71. Exhaust, AFC, Boost, Intake. What else?
  72. BOV question
  73. HKS down pipe,,, does it need to be wraped?
  74. If your hear any louder than usual tranny whine
  75. Fuelrail ????
  76. Anyone with B&M short shifter & poly bushings!?!?!
  77. Boost drop
  78. Dynoflash
  79. Stupid IC sprayer question
  80. Aftermarket clutch enough or do i need to rebuild tranny?
  81. Hyper Voltage system
  82. Question about tuning
  83. What's the best intake?
  84. Piston Slap????!!!!!!
  85. Dual Evo VIII Exhaust?????
  86. fuel pump
  87. Buschur Intercooler!!!!
  88. E-manage Vs Power Fc
  89. FMIC cooling question
  90. HKS 272 cams CEL!!!
  91. MIL Eliminator
  92. 342whp on mustang dyno...
  93. My buddy's clutch... New record I think.
  94. Disconnect Battery for K&N Drop-in Air Filter?
  95. Will Greddy Titanium catback work with Buschur 3" DP and test-pipe?
  96. Question about Evo Mods
  97. Hallman Pro Evolution RX
  98. Exhaust Manifolds.....
  99. engine blown @ 5000 miles
  100. problems with greddy a/f gauge
  101. td05 dump pipe compatable with a td04 dump pipe????
  102. 330hp and 312tq flashed by Turbotrix!
  103. Custome turbo kit for my EVO
  104. Greddy Intake
  105. weird Idle sound.....
  106. Avoiding heating oil pan with new DP
  107. boost
  108. Wideband question
  109. 3" Catback/Silencer Effectiveness
  110. 2nd gear stick
  111. Dynoed Evo
  112. LancerShop 750cc injectors?
  113. To all those with issues on Pulleys
  114. EVO and APS products....
  115. Thermostat clamp
  116. clutch and flywheel torque specs???
  117. Just got a ticket for exhaust too loud!
  118. question for ACT clutch users...
  119. Are all HKS 4G63 cams the same?
  120. Where to buy a knocklink?
  121. Question about gauge and stock vacuum hose hose
  122. HKS Cam gears SETTING ? PLEASE HELP !
  123. Utec Anyone?
  124. can someone explain to me tuning basics??
  125. GReddy type S BOV limitations: RRE setup
  126. accufab 75mm throttle body.
  127. Vishnu Turbo Upgrade
  128. pocket logger question
  129. ECU Reflash at TurboTrix!
  130. 264/264 cams
  131. Safc II question
  132. Check Engine light FIX! TEST PIPE or hiflow cat! cheap!!!
  133. Magnus Motorsports Intake Manifold
  134. Email your SAFC settings!
  135. HELP!! high pitched scretching noise when boost should be on
  136. Apex-i R-95 exhaust...
  137. Need valve springs and retainers?
  138. Boosting 1.4 bar, yet car feels slow??
  139. EVO Problems
  140. Aif/Fuel ratio - How rich do they run?
  141. Turbo failure
  142. Can I turn up the boost?
  143. Aftermarket intake AF ratios????
  144. Stroker Kits
  145. Why does my EVO Almost stall when....
  146. how to pull o2 sensor?
  147. Noise during deceleration ?
  148. Garrett GT35R turbo
  149. Owners of Xflash/DynoFlash/WorksP2 plz read
  150. Engine power limits (for the guru's).......
  151. clutch squeak???
  152. Warrany Work
  153. Hks 30th with B&B downpipe?
  154. normal knock sensor reading
  155. MAS honecomb mesh?
  156. Went and got 100 oct from 76 in san jose
  157. Stock Intake Vac hose routing question
  158. Test pipe and CEL
  159. My EVO
  160. New Exedy Clutch
  161. Racing Pulleys???
  162. Which Size Injectors??
  163. What do you think????
  164. Exedy Twin Plate Clutch
  165. please tell me
  166. Throttle body question
  167. Dyno On All Exhaust Systems
  168. HELP....EVO-6 Manifolds fit EVO-8?
  169. Cam gears or no cam gears..
  170. Evo8 T51 RSPL update
  171. AEM is fun
  172. HKS RS Intake, Stock ECU, CEL ?'s!
  173. Boost guage reading beyond 1.5
  174. Greddy fmic from boost solutions
  175. AEM gauge type wideband controller
  176. I am lost
  177. 1st gear grind!!!!!!
  178. What would happen if you put a BOV in backwards?
  179. Boost or MAF/rev ?
  180. My clutch is out, RMR disk?
  181. Does Wrapping or Coating an Aftermarket Downpipe help?
  182. Aftermarket Forged Pistons and Connecting Rods
  183. stock exhaust question
  184. Amazing Clutch Install
  185. Need HKS metal gasket 1.2MM
  186. Longevity
  187. Dejontool Fmic
  188. All I want is BANG BANG BANG!
  189. Dealership clutch repair?
  190. yet another "next mod" question
  191. avo compressor map...
  192. Cam Gear Settings PLEASE HELP!!!
  193. Loss of boost
  194. TD05 Running out of puff
  195. Part # for serpentine belt?
  196. Low Boost!
  197. SAFC ver.1 vs. SAFC ver.2
  198. Godspeed Downpipe/Cat Eliminator Combo Pipe
  199. Oil filter question.. MD,MZ,K&N?
  200. aftermarket clutch not clamping as it should
  201. Catback back Exhaust
  202. Twin plate clutch whining noise
  203. Who has cusco twin disc on stock???
  204. What are you ultimate Horsepower goals?
  205. boost dump ??
  206. Fluid Swaps
  207. prob wth my new ACT clutch!
  208. Why no more recerculating BOV's?
  209. help me out real quick
  210. Microtech LTX8
  211. Tightening the IC piping
  212. Which Mod to do Next??
  213. Intake Manifold --David Buschur?
  214. Transfer Cases
  215. GHL Exhaust
  216. Greddy Oil catch can
  217. smell after long drives
  218. AEM intake
  219. DP question. Where did you get spacers if using 3" DP
  220. Did I break my rear diff?
  221. APEXI AVC-R:Where to get replacement boost check unit?
  222. Vacuum hose on lower I/C pipe?
  223. what aftermarket EMS to get??
  224. Boost gauge install
  225. Cel Code P0139
  226. estimated WHP
  227. Fuel
  228. My Evo 8
  229. shifting project
  230. Downpipe Question..
  231. Evo Air/Fuel Ratio For Dummies
  232. My engine keeps stalling! (Help!!!)
  233. Mounting Locations for MBC?
  234. S0HC OR DOHC? Whic one is better for power?
  235. Problem with swapping OEM fuel pump with Walbro 255
  236. Buschur Stage 3 = WOOT!
  237. AFC settings?
  238. does Greddy type S BOV VTA run fine??
  239. Greddy Profec E01 settings?
  240. Anyone have a review of the Buschur 2.5" Downpipe?
  241. Need Help Quick Typhoon Intake
  242. After turbo-back; re-flash?
  243. Exedy Hyper Compe-R clutch?
  244. Stock Turbo Pics
  245. how many quarts of oil?
  246. High Flow Cat, and DP question
  247. Oil catch can
  248. A little Smoke After Oil Change
  249. Hallman boost controller adjustments
  250. Greddy type S problems
