- Weird Sound Right before Boost???
- exhaust and turbo manifoldx
- Full race gt35r twin scroll
- drop in piston on mivec EVO 9
- evo 8 16g to 20g
- ARP headstud torque
- Okada Project Plasma Blast Ignition Coils
- 16g to a 20g
- Drop in pistons, to do or not to do “that’s the question”??
- boost controller/guage
- New Product in Development! Interested?
- Question on dif fluid
- Aem uego widband Help
- Perrin boost control solenoid
- Brian Crower 272 vs GSC S1
- First mod haltech e8?
- Hesitating and sputtering?
- Who has an APS intake? and how do you like it?
- Exhausts: Titianium vs Stainless
- Full Race T3 Twin scroll manifold needed
- Alternator Installation
- new build..... starting problems
- Bypassing Factory Boost Solenoid
- whats the next step up from a green 20g?
- Does anyone use a Slim fan on stock or koyo radiator?
- Adjusting Bearing and Carrier Preloads in Transfer Case.
- To Wrap the Downpipe or Not?
- PCV Valve Question. which vac line goes where ?
- WOT-- always 7.35 on the wideband
- 50 trim or bigger?
- Fluidampr's..........get them while you can.
- GT30R Results
- short shift ot not to short shift?...that is the question!
- br 3065 or hta 35r
- quick question about perrin MBC
- JDM Evo 9 problem, only 11 psi stock! HELP
- A very odd thing happened.......we have turbos in stock.
- turbo xs blow off valve
- Whats the stock turbo worth?
- What springs and retainers for gsc s2's?
- Strange power loss problem...
- Boost Question
- Car wheel hops out of first gear?
- Fuel Question Help!
- New Launching Aide Innovation
- Breaking parts to go faster !
- Muffler Delete question
- Me and My clutch job!
- Need Turbo Help Fast!
- My head is spinning faster than a turbo
- BR3065 Dyno #s, photos, videos...
- flash & cams
- help with modification plans
- gauging effect of high flow exhaust on turbo performance
- Need Help Choosing Turbo Size!!
- Clutch issue
- 50 trim Pump dyno...Round 2 soon!
- Wiseco Wall clearance
- Exedy twin SD disk specs
- Sickest Evo Fabrications...
- Good 12v Keyed Power Source for WB ?
- 4th gear grinds sometimes
- Exedy HD Twin users - I need the installation diagram
- 272 cams OEM Lifters is it ok?
- BEST Turbo Kit ETS provides...
- Removing/Installing Outer Tie Rod and Assemply Passenger Side HELP HELP PLEASE CONFUS
- The Box
- Factory boost solenoid Problems
- Evo OEM Air Filter Replacement.
- Meth or Intercooler?
- mishimoto radiator
- Which clutch to go with on my setup??
- Evo IX, 91 Octane, Meth Inj, Cams 390whp/380trq
- Exedy HD Twin Weight?
- Who here runs their 2.3 stroker motor to 8500 rpms on their daily driver?
- Oil change an car is ticking like crazy...
- UICP help
- Removing Front Axles....
- Does anyone know the lenght of the ams resonated test pipe "newer version"
- found cause for my random misfire
- Exhaust Header Flange?
- Things to do while pulling head.
- Will i pass smog with a turbo upgrade?
- MAP censor placement. What can and cant i do ?
- !HELP! gear jumping out of 4th gear
- Innovative LC-1 WB troubles.
- need help on tuning..
- spark plug problem???
- Losing gear oil from TCase after clutch job
- Review: Magnus Sheet Metal Intake Manifold w/ Dyno Gains
- HKS Final Drive
- 50 mm Bov Fluttering on GT-35r?????
- BR 40R kit. Does anyone use it?
- Which exhaust would you pick?
- TME or IX turbo upgrade
- Another Buschur HTA GT35 Record w/ Bad Bish !
- atp 3071r results
- big problem with my evo
- bad idle 2000rpm
- HKS bov problems help!!!
- Weard metal noise, Please help.
- Which engine builders use rod bolt stretch guages?
- Cosworth M3's too big for FP Green??
- problems with my evo
- This mark on my TC mean anything?
- Anyone with Aeromotive FPR Experience ?
- Where to find over size rod bearings?
- Spun rod bearing. What to do ?
- Fuel Injectors
- spark plug gap
- Are topline hidraulic lifters good?
- so my tranny is stuck
- Hidraulic lifters issue
- FMIC question
- stock intake mani pics, who has them?
- to twin scroll or not to twin scroll. T3 housing comparison
- Magnus Motorsports proves that their Intake Manifold works on an EVO
- bigger turbo
- This time, I am in need of help
- Who has tranny building services?
- Valve Cover Breather Filter
- Carbon Pistons??
- Max boost on FP GREEN
- Superscout03's bad ass IX with Gt3065 507 whp pump gas and meth
- what have I done
- stock intake manifold
- Fpgreen+gsc S2 Cams
- need a clutch ASAP
- Where to buy upper radiator hard pipe?
- evo 8 engine problems
- Max safe power stock internals
- In Need of Harness or Connector
- boost controller not controlling boost?
- Clutch Engaugement has moved itself from bottom to very top, why?
- EVO RS Serpentine Belt
- 85mm drop in's, what checks to do??
- Car is POSESSED PLEASE HELP!
- MR 5th/6th Gear Problem Revealed!
- New Clutch? Or Not New Clutch? That is the Question...
- boost drop
- Tried to search. SUPER response
- p0171 code too lean
- why wont it move
- JUN 272 or GSC S2
- hta 3071r?
- Line Lock for an Evo?
- new green turbo
- HTA 35R really worth it?
- can I leave the stock BOV in place with no vacuum?
- Weird clutch episode
- front motor mount
- Raising the boost
- Anyone use Brian Crower Pro series rods in there motors?
- Tax Check... Cams + tune or FMIC + tune
- exhaust issue's, need opinions
- ETS uicp vs Nisei uicp
- Pressure in valve cover?
- What turbo would I need to run to get 500 whp and 500 wtq with mods on pump gas ?
- Wastegate ?'s
- Buschur Uicp 1g Question ?
- whats this hole in the exhaust port for?
- TS or TIAL housing?
- Mechanical Advantage(s) of Multi-Plate Clutches?
- Will a 65mm throttle body help any?
- What do these codes mean?
- exhaust choosing help!
- hey guys i need help! sputtering and low power problem!
- TILTON or EXEDY... PLEASE CHIME IN!!!
- quick question boost controller related
- Straight pipe?
- Problem
- Just started up the soon to be Highest HP 2.0 EVO again! (sorry no bro's)
- Results On Cossworth M3 Cams???
- HTA TURBO'S CHECK IN,HTA-35R,3076,-3065- T4Z 88mm-ect-ect-
- Annoying sound!!!?
- Buschur Hta35r Cast Mani Or Tubular?
- AMS to now offer the FP HTA series Turbos
- Will not run right...please help!
- Calibrating VEI AFR
- Gsc S1 cam Timing
- Low ACD Fluid?
- HTA35R vs Fullrace GT35R (twin) vs AMS GT35RL
- Another best bang for the buck mod!!!
- fuel pump questions
- leaking bov
- Anyone try the Forced Performance IX cams yet?
- What down pipe for Buschur 3065 cast manifold kit?
- delco remy bcs
- Best downpipe/ecu combo?
- Highest HP 2 liter EVO
- Ceramic Cat vs. 100 cell Metal Substrate Cat
- wrapped damaged cams?
- HKS DLI II Problems
- Cosi M2 vs GSC S1 Evo 8 dyno compare / FP-Grn on 91 octane
- SUPER lightweight Carbon fiber rotors, interested?
- Ask AMS and Buschur Part 1: 2.0l or 2.3l?
- Results of a blown HTA 35r (Pics)
- Increase in boost
- ETS 61mm kit has arrived + some misc. parts
- Anyone running tomei ix cams
- HKS 2.3 Stroker+ HKS Cams+ Cosworth heads with ferrea valvetrain+Full-Race GT35R?.
- Guess what went wrong
- power steering
- Exedy twin plate almost broke my tranny!
- how can I cover the turbine housing
- Important question for the tranny experts
- Test Pipe VS 130 cell MS high-flow cat
- What intercooler are you running with your 3065?
- Decisions, Decisions???
- So i ordered my full race twin scroll 30r 3076 .78 full turbo kit today!!
- Supporting Safety mods for Cosworth Cams
- Cam gear options???
- Turboback with E- cutout
- ACT Street Clutch/ Gruppe-S Flywheel (OR) Exedy Stage 1/ Gruppe-S Flywheel
- zEvo: New pistons and rods for the 2008 engine setup.
- Evo 8 tranny
- Results for FP Green WITHOUT doing up engine
- Brian Crower or Supertech?
- EVO VIII Head...on a IX
- What BOv has v-band?
- VP Import and stock Gas tank is a bad deal
- Pauls Build for 2008
- Water in catch can???
- how to tell if camshafts are really brian crower 272s
- evo green manifold options
- turbo xs down pipe what o2 housing will work
- Clutch Suggestions
- Another Slim Fan Question
- Another BR, 93 octane, 500+ whp build, no problem
- intercooler & pipping
- Cams Question
- Worth upgrading to HTA 35r ?
- 50 trim
- Clutch problem
- Please Help!
- Is the Injen LICP any good?
- Intake help
- AMS 3" Turndown
- F%$& lots of damage to MOTOR???
- Straight Pipe no cat Video GT30R
- LSD problems?
- White smoke under decel?
- upgraded oil feed lines
- weird problems helpp!!
- Drop in Dual Valve Springs set?
- Arc Fmic
- Strange Boost Leak - need some help
- BR Cams-Need Info on these please?
- tranny/gearbox?
- Hood insulator necessary?
