PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 [112] 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. HKS RS Reloaded Intake to fit an Evo 7
  2. balance shaft removal
  3. Exedy or Tilton?
  4. FMIC thickness?
  5. Difference in 03 and 04 trans /transfercase
  6. Best MBC???
  7. Adding a Silencer to my turbo XS 3"
  8. 5 speed MR swap
  9. Exedy Twin HD Install Question?
  10. Evo 9 Cam Install
  11. Weird buzz in higher RPM?
  12. O2 Housing/Heat Shield Question
  13. cam install...need some help
  14. Cleaning Lifters and Rocker Arms???
  15. fuel rail?
  16. Just finish installing the Perrin FMIC and Nisei LICP (Pics Inside)!
  17. Stock Throw Out Bearing Rattle
  18. JM Fab Tubular Manifold
  19. Turbo Flow Brainiac Needed
  20. Is this a 10.5?
  21. Cam Choices
  22. FP Red HP wastegate and boost..
  23. Dtc P0234 On Safc2 And Avcr?
  24. 1st gear vibrations!!!
  25. Tial Q 50mm spring problem
  26. Rpms Jump?
  27. 3 CEL Fix and still an SES Light
  28. hta 86 with drivetrain questions....
  29. Mmm...a taste of RED to quench the thirst
  30. Leak at O2 housing and Downpipe
  31. question about OEM clutch
  32. test pipe or high flow cat?
  33. Shift Clunk (NOT Rear Diff.)
  34. Catalytic converter backup = engine quit
  35. Moaning sound when downshifting
  36. stainless steel UICP
  37. Who goes out drifting/sliding around often? Bad for the drivetrain?
  38. Evo 6gsr
  39. HKS Turbo Manifold for the 4G63T
  40. Red options
  41. Tubular manifolds??
  42. Very Confused Evo Caught On Fire!
  43. FP Red Turbo & ACT HDSS Clutch
  44. EPM 02 Housing + ETS LP2? Will it work
  45. Is there something wrong with my AEM Tru Boost?
  46. Ebay Full Piping
  47. Motor help
  48. Odd noise during deep snow or heavy rain...
  49. P401 - Weird Code
  50. crank pulley?!
  51. B&M shifter install Question
  52. My Summer Build: Suggestions and Vendors Welcome!
  53. greddy td06-25g or hks gt3540r kit
  54. best cames for an MR
  55. Any Evo Holset setups on here?
  56. Headgasket advise!?
  57. BR Deluxe--> Evo 9 turbo solution?
  58. my 14yr old son doodle
  59. what turbo ?? plz help :)
  60. Ebay FMIC toughts?
  61. Modding a stock evo
  62. help my car is cutting out
  63. rpm raise??
  64. Check engine light? O2 Sensor?
  65. Crank pulley
  66. Plugs Look Good?
  67. HG swap questions: block clean? CAS orientation?
  68. What size bolts?? Need help ASAP please! EPM o2 Housing
  69. 420 HP @ 20psi on E-85 so far should be done Monday.
  70. How many amps drawn when car is off?
  71. low end power
  72. Lean Idle 18.4!!!!!
  73. Valve spring, retainer, seat pressure questions
  74. evo 8 tranny amount
  75. Stupid 02 dump
  76. oil leak
  77. throttle and boost pressure?
  78. need help with my Exedy hyper single
  79. Power steering delete????
  80. Crazy noises under de-acceleration (vid inside)
  81. Hobbs pressure swith installation
  82. Spark plugs and coolant suggestion for 9 MR
  83. Battery Is Shot. Are Mini Battery Kits Reliable & Recommended? What Brand Is The Best
  84. Gt3528r
  85. help. super frustrated. dont know what to do
  86. buschur race or perrin?
  87. Squeezing more PWR out of my HKS 272/280 setup!
  88. Ebay LICP installed Pictures?
  89. For those doughting the fp3065 Dyno here...
  90. My build 03 Ly Evo w/pics.
  91. circuit racing Fp V's Garrett
  92. Evo Engine / Turbo / Drivetrain - New organization?
  93. Taking out shortblock
  94. Evo IX Mivec Valve question
  95. Made The Plunge! Exedy Twin HD Clutch Kit!
  96. My FP Red Numbers.. yes another thread
  97. what different between koyo and mishimoto
  98. which clutch - fidanza or rps?
  99. ams mustache bar delete
  100. How to get stock boost!
  101. What's the difference? (RMR vs. RRE Stealth)
  102. Evo 8 engine tick / oil light, please help!!!
  103. Where did my EVO 8's coolant go? Bottle always near empty???
  104. FP Red Waiting List:
  105. Exoticspeed products
  106. Opinions please!!!
  107. FP RED setups, recommendations, and advice
  108. wastgate conversion
  109. Big Turbo Guys how much timing are you running.
  110. Help Please!
  111. best bov/dp/test pipe/cat back for evo8
  112. Need new clutch
  113. clutch slipping
  114. shifting problem?
  115. High Octane fuel guys! How often do you change your O2 Sensor?Mine gave up aftr 15gal
  116. tranny fluid change
  117. Shifter bushing question
  118. Exedy Twin Pull vs. Push
  119. Evo 8 16g Bolt up to 1st Gen Eclipse?
  120. t3 t67 "big kahuna" by garrett?? pros/cons
  121. Best 3" downpipe for my 7
  122. What oil pressure is everyone reading?
  123. Thanks Buschur Racing!
  124. evo 7 oil cooler
  125. quarter master
  126. Checking "service engine soon" light.
  127. Tial Vs Garrett exhaust housings
  128. Oil on manifold...WTF? (Part 2)
  129. Info on turbo upgrade people running "4088R" Chim in plz ;)
  130. timing belt/water pump 8 and 9
  131. CBRD BBK Turbo... video... etc..
  132. Help Please
  133. '06 Evo MR & Quartermaster...
  134. AMS Resonated Test Pipe
  135. Need help with my tranny
  136. Lowest price on a FP-Red?
  137. Injen intake users
  138. Exedy Twin HD Specs? Under rated?
  139. Forced Performance Turbo Reliability
  140. fp green reliability
  141. Whiteline Rearbumpsteer kit and alignment
  142. Help Melted Spark Plugs
  143. Coolant leak evo 8
  144. triple disk + daily driver = FAIL!!!
  145. Please help ID this bov
  146. Turbo XS 3" Downpipe
  147. NGK Plug BR9ES vs BRP7ES
  148. Aftermarket Downpipe question with stock cat
  149. Very cheap exhaust setup
  150. Magnus ???? Pistons and rods ..
  151. 02 Housing and Downpipe mating questions?
  152. Buschur double pumper
  153. Best LICP & FMIC Setup
  154. Exedy Twin Clutch Disengagement
  155. Tranny woes
  156. What should I do next?
  157. e85 dayly driving?
  158. Boost problems
  159. EVo 8 Wastegate Actuator vs Evo 9 Wastegate Actuator
  160. Can anyone tell me why my clutch gets stuck halfway engaged?
  161. Help identify intake part
  162. Video Request: Idle with FP4Rs?
  163. Is this a real fp green?
  164. FP Red+?? Intake
  165. 1000cc, gt35r, e85
  166. Balance shaft Removal
  167. replacing synchros evo viii
  168. Just drilled and installed o2 foolers!
  169. high rpm problems
  170. HKS stopper type head gasket
  171. JUN Baffled Oil Pan & Oil Pan Baffle Plate
  172. Clutch for an auto x/ road race car/ street car
  173. 8 to 9 turbo swap. Did i do wrong?
  174. buschur injector question
  175. WILL THIS WORK FOR MY CAR? Evo 9 TME turbo on a evo 8......
  176. What is 1.8 bar converted to psi???
  177. AMS Downpipe rubbing on subframe?
  178. Probably going to install GSC S1 cams myself, limp to the dyno?
  179. Fuel Cut?
  180. JM FAB Drag Manifold
  181. need some help with mods
  182. Stock Limitations and GT35R
  183. question on cams
  184. power enterprise intake?
  185. Injen Intake w/ intercooler piping
  186. Pics of completed longblock
  187. GSC 264's
  188. MTX Neutral question
  189. Quick Q on mechanical O2 fix
  190. Whirling sound in low 1st gear/Reverse
  191. Anyone ever have issues with resurfaced flywheel?
  192. Haas this ever happened to anyone before?
  193. I cant keep my boost safe, any suggestions? (forge WGA installed)
  194. A/C compressor
  195. Question about stock IX MR clutch
  196. TILTON twin cerametallic users i need you info & experience here.
  197. DSM and EVO PTE injectors the same?
  198. Cam instalation question
  199. A safe psi of boost w/out a tune?
  200. Can you guys recommend me some mods
  201. More FP Red Numbers
  202. epm dump noise
  203. Clutch question
  204. Question on ATP stealth turbo kit
  205. FP Green to Red conversion
  206. Interested in 2.1 destroked from Slowboy
  207. helper over under spring removal!! (tilton clutch)
  208. Engine REV in between shifts ???
  209. TBody VIII & IX Question...
  210. HTA35R and E85?
  211. Pt 6262 63a/r or 82a/r?
  212. FMIC and Meth
  213. exhasut manifold nut..
  214. Clutch overkill?
  215. Something always has to go wrong..
  216. Oil cooler delete
  217. A/F jacked after altitude change
  218. Bad Clutch?
  219. HELP! air/fuel lean at boost
  220. cam seals leaking
  221. !!! Cams Install price???
  222. 4g63 oil squirters
  223. Can a combustion chamber be welded?
  224. list of trany syncro parts to do a rebuild needed
  225. Evo 9 blown...any ideas why
  226. Anyone using GSC cam gears?
  227. Evo IXs with Kelford 272s...
  228. EGR valve, need help!
  229. turboxs dual stage boost controller
  230. Forge MBC/Boost Question
  231. Curious about a turbo setup
  232. help! how to remove vent pipe from valve cover
  233. Comp cover to wheel clearance
  234. Vibrating noise - rear LSD/gearbox
  235. From MR 6-Spd to Shep 5-Spd?
  236. Street or puck clutch for my set up?
  237. sequential turbo set-up from AMS
  238. 750cc too much?
  239. Quick video of Quarter Master Twin disc
  240. Exedy Twin Owners?
  241. TOB so help me god....
  242. Clutch Install need help!!!
  243. installed cable shifter bushings.theres some play
  244. How much power should I expect?
  245. works vs tanabe vs magnaflow
  246. can i tap my HOBBS switch for the br double pumper into this line? PIC
  247. FP Red Getting tuned on 11/17
  248. CEL: P0138 Troubles!
  249. Nasty TB Leak
  250. Carbonetic and another transfer case paranoia...
