PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 [107] 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Evo8 sounds like Subaru, Help!
  2. competition clutch?
  3. Quieting Down A Buschur Exhaust
  4. Rebuilding the Tranny....what's needed to be done?
  5. axle upgrade
  6. Boost issues (power not smooth)
  7. Cams or Evo 9 turbo for an Evo 8 with bolt ons
  8. Fidanza 4.3 ceramic clutch experiance?
  9. rod specs
  10. AVID motor mounts, anyone run them?
  11. Boost
  12. How much?
  13. belt squeak?
  14. Apexi induction box owners....
  15. cracked transfer case HELP
  16. GReddy Competition Ti-C TBE?
  17. Kinugawa 20G
  18. NEW to the evo seen
  19. Not the normal missfiring problem.
  20. looking into final drive change
  21. MAF honeycomb starting to crumble? :unamused:
  22. BBK or DBB?
  23. OEM LICP coupler question!!
  24. need some input for 500whp+ results
  25. Having some tranny issues, chime in if you have an idea.
  26. Excedy Twin problem possibly, moves car at idle in nuetral!
  27. HELP! More Problems.
  28. any reds on 2.3 strokers?
  29. T3 Twin scroll turbo?
  30. Clutch Pedal Travel ? ? ?
  31. Cylinder wall thickness
  32. Headwork
  33. EVO 9 TURBO OR EVO 9- 20G for 20 PSI+380-400HP / crank ?
  34. Is there a 2.5" T3 GT 4 Bolt To 2.5" V-Band Adapter Turbo Downpipe
  35. Fic injectors?
  36. wastegate wont open??
  37. looking for a picture of evo8 timing belt
  38. witch intercooler is better, AMS or Buschur
  39. Reverse Sensor Location?
  40. Glowing Manifold
  41. Is it common for Cylinder #4 to run leaner???
  42. Tranny making noise in idle and cannot put the stick into gears!
  43. Really Bad News:(
  44. T-Case Death Whining?
  45. Kelford Cams are amazing
  46. Service Engine Soon (SES) Light - Codes Saved?
  47. who makes a uptop turbo kit (see pic)
  48. 4g63 head swaps?
  49. E85 questions
  50. Blown engine at 81k. Looking for Advice
  51. An EvoM shop??
  52. Advantages Hi-FLo Cat vs No cat
  53. Exhaust flange on turbo question (changing it out)
  54. Greddy PRofec B spec-II
  55. Evo 4 engine swap
  56. Tial wastegate question (AMS 50 trim kit)
  57. Car Died.....
  58. pwr radiator and 02 dump
  59. PLEASE HELP ME! After install serious boost spikes(AEM TRU BOOST)please read thanks
  60. 272 cam question
  61. How do u shift when ur daily driving ur evo?
  62. digital boost gauge sensor problem
  63. Replacement Exhaust Mani's
  64. MoTeC ACD controller
  65. what caused this to blow out???
  66. I knew I shouldnt do that 2nd to 3rd gear pull!!
  67. too much oil?
  68. exhaust manifold options
  69. Funny clutch thing
  70. What is that crap on my positive battery terminal?
  71. How do my plugs look
  72. wtb 10.5 hotside
  73. attn: ACT HDSS owners
  74. Synchronic Blow-Off Valve
  75. Evo 8 compressor modded vs evo 9 standard one, difference at power ?
  76. Fuel - Double pumper Vs Single inline
  77. Turbo XS FMIC & Buschur UICP
  78. Where to get stock fuel injector pintle cap?
  79. Ported Cast Exhaust Manifold
  80. Help with Lean Condition
  81. Throttle pedal feel.
  82. Gearbox Issues
  83. Intercooler decisions decisions
  84. Normal operating temperature on Evo 8's?
  85. PCV and Breather Blowby in oil catch cans
  86. ARP headstuds WTF??
  87. BEST Torque Damper / Front Motor Mount Set-up
  88. AN Fittings on Valve cover??
  89. Airbox lid question
  90. bolt type
  91. Tomei Solid Pivots???
  92. Upper IC pipe and BOV help???
  93. evo ix wheels
  94. HELP asap....
  95. HELP problem with my evo
  96. how is to run low 10s
  97. sheps
  98. How to blow 5k
  99. t-case filling?
  100. act hd vs xt
  101. ATI Superdamper
  102. Where can I send in my stock ix turbo for a discount on an FP Red?
  103. coolant issue
  104. Any suggestions? FP Red & mods
  105. hallman mbc vs. forge mbc
  106. TBE gaskets
  107. Evo VIII cat life
  108. Oil for built transmission,T/C and LSD rear diff.
  109. hks ssqv bov
  110. WTF is happening
  111. Car is lean now?
  112. WOT Tick!?
  113. external wastegate on stock turbo
  114. evo 7 compression
  115. Clutch or Transmission?
  116. How bad of a sign is this?
  117. another boost leak question
  118. Magnaflow Catback wit some brand downpipe
  119. ACL Bearings Question
  120. is there an evo(4-9) engine build video like this one anywhere?
  121. boost issue please help!
  122. Idle with Cams
  123. Ams 50 trim (Turbo whine?)
  124. Need rods....
  125. Back from Iraq. Need help with fluid change.
  126. Did the dealer just called me a NOOB!
  127. Low voltage after battery removal.
  128. I don't think my EVO likes the cold...
  129. Exedy twin disk questions....
  130. Can anyone help me with Evo modification voiding warranty?
  131. Cam lope going away??
  132. ACT clutch or tranny causing lock out????
  133. down pipe
  134. Just to make sure... (AMS 50 trim coolant lines)
  135. Evo ignition problems
  136. My AMS aluminum pan showed up today! *PICS*
  137. Turbo Coupling
  138. whining noise when in gear?
  139. Im Depressed :(
  140. Buschurs Filter Kit
  141. Little advice for a manni
  142. stock turbo redhot
  143. LICP keeps falling off
  144. motor swap question
  145. boost controller
  146. Evo 9 Block Evo 8 Head
  147. Help.. How can I mount the slim fan?
  148. FP Red Airflow Logs Wanted
  149. Help needed fast thanks!!!
  150. HELP: Stock turbo clamp
  151. as soon as my car hits boost it cuts out and stutters HELP PLEASE
  152. Q T P external o2 dump housing
  153. Precision Turbo 6262 daily driver???
  154. o2 housing
  155. Weird Pop/Choke.....Pls help
  156. Is it possible to tune evo 8 on 2 wheel drive dyno
  157. Is the Evo IX Stock Turbo Capable of 9's??? Look Inside..
  158. weird noise from cabin
  159. GrimmSpeed
  160. Need help please???
  161. Anyone Running, INJEN HARD PIPES
  162. opinions on best rods.
  163. stock turbo w/ External wastegate
  164. BR race core intercooler installations pics?
  165. At full boost, car stutters, then takes off...
  166. L Support Bar for the Buschurs Filter Kit?
  167. ACT HDSD impressions
  168. Should I be worried?
  169. oil leaking out of the valve cover!
  170. Happy Bday to Me, Happy Bday to Me!!
  171. Buschur Racing doing a start to finish EVO8 build, need input.
  172. Help! Advice needed!!
  173. Quick exhuast install questions
  174. evo9
  175. stock injector questions
  176. what spark plugs?
  177. EXEDY multiplate IMPORTANT QUESTION
  178. Fitment question
  179. rattling at idle and coasting in gear
  180. project evo 10 turbo in evo 1
  181. Fitment Question on Evo 8
  182. what coolant
  183. Battery in trunk
  184. Thinking about future upgrades, need help and advice
  185. FP3065 - Evolution 3
  186. Gift from the gods :P
  187. HELP!!! crank wont line up to TDC!!!
  188. Most-Wanted's Evo IX RS.. 468whp / 492tq.. STOCK TURBO!!!
  189. HTA35r 5 bolt .82 housing?
  190. kelford 272 vs FP4r
  191. 6 Speed Repair/Shop Manual
  192. Bc 280s Cams! Need Answer.
  193. should i get a new diverter valve?
  194. Engine Flush
  195. ACD PUMP Question
  196. Question about 2.3l twinscroll gt40r
  197. Problem with Buschur UICP w/1g bov clearing intake
  198. Looking for a quieter exhaust
  199. stock 8 motor whats the max power?
  200. FIC 1150 Injectors Install Questions
  201. noise coming from engine
  202. alright so clutch line weirdness
  203. Dealer screwed up my clutch?
  204. WTF happened...
  205. t case question
  206. What would ya'll do to the car??? (next mod)
  207. BOV/BPV Sound
  208. Help! Car getting stuck at 3k Rpms when stopped?
  209. ble lifters
  210. QuarterMaster Twin Disc 7.25" V-Drive Clutch / Flywheel (DSM)
  211. Shearer Fabrication Stock Turbo Manifold TESTED!!! +21hp
  212. Perrin drop in?
  213. clicking sound
  214. FP RED updates: For those who have run it for a bit
  215. Ever have the (D) stub shaft stick to the axle?
  216. Wierd coolant temp issue...
  217. Restrictor pill location
  218. Kiggly Racing Oil Pressure Reg for Evos
  219. Motor Mount VS Torque Stiffy Damper
  220. MAF delete?
  221. Think 1st gear is going
  222. Anyone have an evo 9 ecu I can borrow near Queens NY?
  223. Strange issue with cooling fan.
  224. Anyone else love it when this happens?
  225. Twin Turbo Evo?
  226. Weird rattling noise.... Any ideas?
  227. rpms drop at idle? need help
  228. Lower arm brace and engine vibration
  229. burning rubber smell coming from engine bay
  230. Fuel Rail and FPR help
  231. filter size
  232. TurboTrix Racing Fully Built Motor= 2.3 Stroker-Full-Race-FP HTA86-AMS VSR etc...
  233. My injector pulsewidth too high?
  234. GT3076R Problem?
  235. Where to go next!?!?
  236. AVC-R strange RPM readings
  237. tubular manifold measurements ?
  238. where to Buy IAC
  239. Help want to get a tune soon
  240. 6-Speed Sequential Shifter
  241. When do our trannys go boom!?
  242. ACT Clutch Q's
  243. whats stock?
  244. Evo8 3rd and 4th in Evo9
  245. Forge UNOS MBC
  246. Mystery Drip?
  247. Battery Problem, please help!
  248. o2 bolts???
  249. Major Idle prob..help!
  250. Pretty ETS Parts and some other nice stuff!
