View Full Version : Evo Engine / Turbo / Drivetrain
- throwing p0500[speed sensor]...
- injen IC Piping
- Big Turbo, Right Mods, Mellon Tuned, LOW POWER?? HELP!!!
- is 28-29 psi on a fp red with supporting mods and built longblock safe on 93 pump gas
- FP White vs FP Green - same day - same dyno comparision
- Forced Performance Evo 8 intake Pipe
- recirculation issue?
- Building my motor...need help and suggestions
- Help! Not boosting past 15 psi
- Half radiators?
- hit a curb what did i break?
- help me release this stupid TOB UGH!!
- exhaust port dimensions
- axle question please
- Tuning issue?....or?
- White smoke
- Going back to single disc setup instead of twin what will i need?
- Various Spec Clutch Questions
- TB leak, again
- How many people have blown out the TitekO2 housing gasket?
- O2 housing question
- Wilson V2 + Throttle Body
- hard to go into gear?!
- removing acd
- Big Tranny Problem
- sparktech igntion problem
- Help- Stuttering and lag
- Exhaust Gasket help
- Problem...Crackd header...
- FP Red Owners
- cooling system pressure
- 6 speed swap
- Who is still on stock tranny and transfer case?
- Airflow for Evo IX Turbo, FP Green & BBK
- Need installation instructions for Hallman Pro Rx MBC!!!
- opinions on exedy twin disk
- Anybody using the Hks Twin disc??
- Stock EVO VI turbo
- Help with engine problems
- How to replace Throttle Body Shaft Seals
- What intake with Buschur UICP????
- Lowering turbo inlet temps
- Stuck!
- Synapse BOV + HKS EVC Problem???
- MBC Location pics
- Intro & Mod questions
- FacePalm Day
- Difference in Timing belts 8 vs 9
- Camshaft 102130322 & 10213000
- Evo 9 Waistegate - Help
- AEM Tru Boost Big Turbo Guys Using the 5 Bar External Sensor, Questions Please???
- crankshat sproket removal
- New fuel pump car wont start
- Can the Megan exhaust manifold hurt performance
- Cobb Exhaust
- Spec clutch 2+ Shifting Issues
- Need Info on IX Setup
- ??? Anyone gone from HKS to Kelfor or S2s???
- Coolant issues
- Cant shift fast!
- Rear Main Seal Question.
- possible to remove pressure plate bolts while tranny still in car?
- Axel bolts what size help??????/
- Fan controler
- tranny issues
- Drivetrain Noise ( Surprised ?)
- Changing Serpentine Belt
- RED Build
- Reuseable Gaskets
- Motor / Setup Thoughts
- Turbo making odd noises, in high gear only
- NEED HELP on Clutch and Tranny
- Second gear won't go in
- 6sp Tranny How much does it weigh
- Best cams for TS HTA3582R setup (Evo 9)?
- Did the 6spd to 5spd conversion, need to re-tune?
- AMS O2 Housing?
- TBE fail ...
- Oil Filter Housing Question. Please Help!!!
- Help! Rattling sound coming from drivetrain...
- mitsubshi td06 20g questions
- Inline Fuel pump?
- Reading valves?
- overheating
- AMS 3" Turn Down
- weird boost issue.
- cant pick a cam..any help
- FP Green HTA Pics
- RPM fails/failed to read car = dead
- oil pump flange busted?
- Controlling boost with ECU vs. MBC
- new Fuel pump, injectors, installed: Starting issues?
- Recent change of BOV sound & stalling? wtf
- Clutch Material Question
- which epm o2 dump clearing niesi?
- Car Not Boosting
- BC 2.4L stroker kit into a 4G64?
- Low compression cylinder 2
- black smoke when decelerating
- OEM wedge collar question
- kelford 272 question
- New Turbo Setup
- Can Greddy Type S bov be recirculated
- gt35r install over the weekend
- lifter noise??
- greddy boost control valve
- 1st gear grinding
- Springs and Retainers? What to choose?
- Turbo oil line problem
- o2 sensor question
- quick question help please!!
- GSC 2.2 stroker reviews??
- No reverse
- BBK Lite Turbo
- Upgrading to the evo 9 turbo
- Question
- no boost pressure?
- boost and duty cycle?
- Rate MY build
- Need advice on fpred upgrade and which manifold*pics
- Weird Boost Problem
- HKS EVC-S Boost Controller - anybody?
- Testing the AWD 1000R Billet 67 mm Turbo - 820 whp
- Fried ECU
- Who makes manifold for stock turbo
- clutch restrictor pill removal... speed bleeder?
- question about TB Gasket
- wedge collar help!!
- throttle body leaking
- Modifying stock air box
- Upgrade O2 housing question
- GSC 2.2L & twinscroll HTA3076?!?!?! TUNERS OPINION NEEDED PLZ!!
- rear diff bearings
- Help - Lean Idle
- Noise coming from BR double pumper???
- valve locks
- Engine code 0069
- how is the quality of clutch masters
- blown clutch, or ... ?
- Cam upgrade worth it???
- Smoking from engine bay?!?!
- aftermarket clutch help
- 65mm id flat exhaust gasket, where?
- O2 questions..
- will evo 8 turbo fit on 2nd generation eclipse?
- cluth labor?
- Fp red little gains ?
- fp red..Stock cams..evo 9?????
- need help
- ATP gt35r manifold bolt size
- symptoms of a warn clutch?
- new comer few simple ?
- L19 Head Stud Torque
- Oil pooling
- MAF protection??
- Fuel Tank
- that's the limit for HKS 3037s
- Recomended oil for evos
- Need some HELP!!!
- hesitation?
- Been out of the loop for a while
- AMS catch can help??
- new clutch new problem??????
- Evo 8 10.5th turbo vs Evo 9 turbo
- Help! Loud Pop After Spark Plug Change
- Mods for a gt35r upgrade???
- Fp red , weird noise ??
- OEM looking heat shield to fit over Mil Spec cat?
- Opinions please.
- causes for coilpack to fail??? Or better yet, why is my engine bay soo hot?
- WTF.. Brand new Exedy Triple Disk Slipping?
- Tranny removal Suggestions..
- HKS BOV to recirc or not?
- Finally Running Again :)
- 2.3 stroker vs 2.0 long rod, opinions pls
- Bringing Evo back, my new built 2.0 almost assembled.
- Spark plug part number!
- "Overspeed" turbo failure?
- 8 to ix turbo
- Engine Internals
- How Is My BOV Holding On?
- comp or act
- boost leak question for advanced people only
- Boost stutter?
- Drivetrain?
- More broken parts for the Bad Bish
- 500whp on ACT 6 puck
- Need help with next purchase. Input appreciated, Thanks.
- valve guide seals
- Acceleration problem - AUGH
- big power stock MAF people inside here
- Injectors/ Head Question
- Boost / Fuel Cut 15psi
- Stumped, Insight ?
- 100mm crank
- Exedy twin part #s ?
- Transmission identification
- Transfer Case question
- DC Sports vs. Buscher Ported Ex Manifold
- 5th and Reverse issue Please help
- Electrical Madness
- evo 9 boost issue
- How do I?...Hook up two fans to the radiator? pic of radiator incl.
- Autolite Iridium XP Plugs installed- Problem
- clunk noise from transmission driver side/
- Stock Fuel System?
- Wont go into 5th gear?
- Tranny makes a whiney noise... please help
- Loud Whining Noise
- Ivey Trans 6sp Rebuild
- Need Help!!!
- Balance Shaft Delete question
- a couple simple questions!?!?!plz help
- timing belt question
- Replacement cbe for Greddy Ti-C
- busted oil cooler
- AYC Reservior Bleed and Fluid Change
- Ap Racing Brake Pads
- Transmisison whine 3k-5k rpms and little throttle
- Brian Crower Stage 4 Cams 288/288
- Evo viii maf vs evo ix
- speed density !!!!!Need help
- busted oil cooler
- car broke again, wont start!
- Mandrel Bend vs Press Bend?
- Need STOCK UICP FLexpipe coupler to IC
- Bolt from exhaust manifold to turbo fell off....
- Opinions welcome
- Tomei Poncams or Cosworth for IX MR
- evo ix 272/272 cams
- Strange grinding sound with new clutch
- Something in the drivetrain grinding....
- Mivec Compression test numbers. Aftermarket cams.
- My new ride
- Stock ECU, 1000CC injectors, Minibattery...
- Valve cover ?
- catalytic converter heat shields
- need help
- Evo 8 Clutch or master/slave cylinder help.
- 80MM Red Stock Appearing?
- Please help me out on this!!!!!!
- Having some issues
- e85 tune help
- engine problems
- Quieter Exhaust...
- Tough time starting engine..help
- Jm Fabrication "Drag" version smim rubbing.
- Dual Rail wiring
- Full Race Evo 9 Turbo manifold owners: What intake pipe?
- helppp
