- Dynojet run fie
- Air Conditioner = Cooler Coolant temp
- Dyno results PeakBoost 3076 Dyno4mance
- Stock 2005 EVO MR clutch question
- dry nitrous users
- REV To 9 Grand
- Has ANYONE had this problem" drivetrain/driveshaft"
- co2 i/c
- Tanabe Concept G - Pass Beer Can Test???
- Less boost taper after intake install
- IC Hardpipes?
- Form Works cams to FPC300... Over 30% increase in TQ
- Fuel filter?
- axle is busted
- Damn, 1800 miles and clutch wont hold a launch..
- Cams and Headgasket
- Ix Turbo
- boost spuddering problem
- exedy clutch question...
- remove mivec?
- exhaust question
- A little idea floating around my noggin..
- what time woudl a wrx run with these mods?
- Ultimate Racing Licp
- New plugs making car run lean?
- Back to back testing of Invidia, Ebay and Works 02 housings......
- wastegate solenoid
- HELP BOOST LEAK testing
- engine coming out next week!
- Exedy twin howl/whine when clutch engages
- Tanabe Medalion Touring Exhaust ::JawDrop::
- Possible Transmission Problems
- motor swap
- Better location for wideband 02 sensor...Pics provided
- Full short shifter linkage
- exedy twin disc
- boost LEAKS and aps bov people all help please
- Evo 9 Spark plugs
- hks 272/272 cam setting
- Silly question
- Exhaust header with wastegate off let
- car making low power : help plz
- Who running a HPF FMIC?
- Does any one build custom turbos?
- Battery Relocation
- BOV question
- Boosting problem
- leaking head...I think I can live with it.
- 60 on IX
- 2.1L from SBR arrived...Pics
- Which o2 housing and throttle body?
- Going with a GT30R on my evo...
- Engine Bog/Sputtering
- Exedy Twin Plate HD set-up?
- 421 Horsepower 91 Octane w/ Meth **Full Function Turbo Kit**
- buschur front motor mount installed
- A little BOV experiment, feedback/answers please....
- How much whine is too much whine when it comes to the TC?
- Cam choice
- normal tranny noises?<--new IX owner
- Are the pedal stops for the tilton available yet?
- 5k and 10k?
- hmmm question...
- Buschur Racing Deluxe FMIC on EVO IX MR, Two thumbs up!!
- blown engine
- can't go WOT!!!!
- oh what to do??
- Hi Performance clutches....
- Where to get a block?
- Fuel injector Physicists, please help!! inj. question.
- AMS LICP vs EBAY LICP
- What does this mean?
- Flywheel resurfacing? what are my options?
- codes
- *HELP* Detailed write up on problems!
- which clutch/ differences???
- O2 housing - (Invidia vs. helix vs. ebay)
- *HELP* Boost Problem
- What happened??
- injen UICP and BR hardpipe intake
- 10.5 hotside w/ o2 housing
- Good turbo w/o sacrificing spool
- Aquamist 2d water injection
- Quick Question on Shaft Play
- -4/-1 or -2/+1 cam timing? Same LSA. What will be different?
- Q on HKS RS intake
- my new setup decission 20g...
- egt probe,best place to put it?
- So how loud is this new Tanabe G blue exhaust?
- EVO IX 20G Stage II Ti/Al setup Turbo
- car not boosting..what can I check for?
- Intercooler holes and intake holes
- Do all 2005 Evos have the 10.5 hotside?
- boost problem found
- help installing hallman mbc
- Stud install causing gasket leak
- **PROBLEM: Greddy V Spec FMIC
- gt35r+meth aem tuned dyno #s
- An interesting question on Stock inj/alky/2.3
- po420 code *no exhaust work
- At what RPM's do you reach full boost??
- Has Anyone Tried a Precision SC34 Turbo?
- My car keeps dying on me??
- Cams and Fuel Pump ?
- O2 Housing hp gain?
- Want a nice aftermarket turbo that's not too bad on lag? Consider a Garrett 3071
- Tuning experts, help. fuel issue/question
- Timeing Belt Replacement
- Exedy twin disc exploded view???
- wastegate actuator ristrictor size?
- Speed Element's DIY FR install phase 2
- Engine wont start
- Evo ECU Help
- EVO 9 Turbo
- need some help on fluid's
- How's your Evo with upgrade cams?
- Best bang for buck Gt3076r turbo kit?
- What to do next
- Revolver Idle
- EVO 9 Turbo Question (guru help please)
- Service Engine Soon Illuminated
- Factory Knock Sensor
- The ultimate HKS272/272 Cam Timing????
- Loud thump noise when I depress the clutch in reverse
- Alky on a IX??
- Need REAL TECH Expert help! No Fuel or Spark after engine swap
- 50 trim on 2.3 stroker
- inner diameter for boost hose.
- opinions preferred
- Fidanza Clutch and Flywheel
- symptoms of a bad rear diff?
- Need More Power Before Tune.
- Which cams
- BBK vs. Accufab TB
- HorsepowerFreaks Turbo Kit Teaser (Pics!)
- Boost creep w/External Wastegate [dsm]... suggestions?
- Twin scroll T3 manifold
- What to do next..
- Anyone use Total Seal Rings ?
- New Evo MR owner, exhaust question
- Intake for an EVO IX
- Buschur Motors Kick Ass!!!!!!!!!!!
- NorCalEvo exhaust sound clips?
- Fujita Intake...
- Wastegate vacuum line question
- How much cam overlap is ok ?
- code fix / cell fix
- I need help with repairing these codes????
- Drain Plug / Oil Temp.
- boost controler line?
- UHH OHH!!!! t-case, front diff, or tranny
- electric cutout on test pipe!
- I know I suck....
- Shaun's dyno sheets, before and after.....
- People with Megan catbacks
- Still waiting....
- evo 9 tach pin on ecu
- I feel so sorry for a friend....
- Act streetlite vs stock flywheel weight measured
- mid cam install, urgent advice needed...
- Bigger BOV needed with Bigger Turbo???
- Boost leak issue
- Full-Race Down Pipe
- Can I use the "Tial 50mm" bov on the stock turbo?
- Should I use Redline Water Wetter in my EVO????
- Anyone running a revhard manifold here?
- 30 PSI?? This can't be right...
- boost leak please help!
- 9mr - stock-modded untuned dyno graph
- 03 New Trans & Clutch Break-In
- Boost Creep?
- GT3076R vs. FP3065??? Which one is better for 93+Methanol?
- Question about adjusting Forge MBC
- How bad is a clutch install?
- Bent MAF screen...NE1 else had it?
- Another BR3065 installed
- Car going into gear feels "sludgy"
- Clutch question
- water temp question
- Boost Leak?
- Blown Motor: Head teardown pics = ???
- advice on turbo manifold...tried the search
- help needed - Car stalling
- what upper ic pipe w/ hks intake?
- What do you think about heatsoak? Dyno proof?
- Would Buschur be willing to build a 2.1L EVO 8 Block in house?
- What Piston to wall clearance and Ring end gap are all you big hp people doing
- Car sputtering and wont boost above 10psi?
- What are the standard 560cc Injector Lag times?
- Drill/tap for EGT: Possible after coating?
- Help! I gotta leak.
- ARP flywheel bolts for EVO8
- At what point are injectors needed?
- how many miles on your 2.3 kit?
- OK to go from Synthetic tranny fluid to NON-Syn?
- Amsoil Or Bg Syncro Shift Ii
- keep blowing alternator fuses
- 03 evo worth it for an LSD?
- AVERG. lifw of stock trans?
- works TBE
- Evo IX vs. STi pumpgas/stock turbo/reliability/gotchas?
- TOB and exedy HD
- Over pressurizing the crank case
- AC condensor leaking! can I start my car and still drive?
- 2.1L Spun Rod Bearing
- Startup difficulties
- Where to find Injen coupler?
- what clutch should I get?
- Can you replace the fuel feed line?
- Evo IX staying basically stock, best bang for the buck?
- MR Tranny takes 2.3 quarts... right?
- whats the exhaust temp....
- Any way to mount "normal" battery?
- Tranny help. Instant help needed!!!
- intercooler piping
- Best place to get my cams
- Surging issue
- anything i should do b4 long trip
- grinding gears
- Octane booster: which ?
- 03 vs 05
- Help!!! Engine Won't Start
- Lessons learned ~ 2.3 stroker w/ stock turbo
- please help with intercooler kit?????
- sliping clutch
- Tilton + TRE tranny & Ralliart LSD
- Best Turbo for....
- injector size???
- Help!! Engine hesitate and misfire
- Best intake manifold
- Odd Drivetrain Whine...
- 3065 lb/min ???
- Aftermarket Fuel Rails: Perrin vs. Agency Power?
- Exhaust pops
- Evo IX BOV question again...
- UICP Qs...
- FIC Injectors 850cc help with install??
- Oil Change today, good info
- Turbo back exhaust??
- Disappointed with agency power bov...
- Stock IC Sprayer
- Lower Your intercooler temps
- Big thanks to Greg@GSC!
- Q on long block and short block
- PrecisionTurbo 680cc Injectors
- Disadvantages of using an Electronic Boost Controller
- Forced Performance(FP) HP Wastegate Actuator opinions
- Why no SC61?
- Big gains from fairly minor parts changes at Buschur Racing...
- Red dust on clutch pressure plate? Could this be bad?
