PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 [147] 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Transfer case removal
  2. Trans Problem Help
  3. Best Triple Plate Clutch
  4. 20 g bolt ons?
  5. Compressor Surging Explained!!! (tons of text)
  6. Oil light question
  7. Steps in which I should complete?
  8. Can a stock evo 9 turbo REALLY handle 30psi?
  9. dp and 02 housing
  10. Question about twin in-tank setup
  11. Would this be beneficial for Meth Injection? Vid.
  12. How to identify an EVO 9 turbo?
  13. Breather filter on T-case/tranny overflowing?
  14. packages?
  15. Eclipse 2G stroker kit will fit EVO ?
  16. Fuel pump options
  17. Forge UNOS Help!
  18. Which spring comes in a Forge Unos MBC?
  19. Extreme Turbo Systems - Intake System + IC Piping Installed Pictures
  20. Shorter 4th and 5th gear? where can I get them?
  21. My IX won't start!
  22. New Keys.
  23. Bent Some Valves!
  24. tc and tranny removal what do i need
  25. turbo clipping?
  26. Intake Air Temps - Ambient underhood, pre and post intercooler
  27. Strange Sound Need Answers!!!!
  28. problems... :-(
  29. Loose throttle cable, pedal goes all the way to the floor but cable is still attached
  30. Boost gauge needle shaking?
  31. greddy 36mm water temp adapter: what size is sensor hole??
  32. I have a gt35r kit on my car untuned is it ok to run wot under wastegate pressure?
  33. can anybody share some knowledge?pls...
  34. Whistle at certain throttle %
  35. ???? about FP Green
  36. intake manifold
  37. What all companies or businesses make/sell solid MM's?
  38. help!! clutch keeps locking me out!
  39. Differences in cam
  40. meth injection and reflashed ecu?
  41. Cam Help
  42. Wastegate?
  43. Broken intake valve guide question????
  44. Helix V1 DP fit ACD?
  45. CRAZY irregular idle after Cosworth IX Cam install! Why? Does it even make sense?
  46. Dumb, Fuel Pump Question
  47. HKS Evo IX Mivec Cams, who has them?
  48. Parts Advice
  49. Piston to Wall Clearance for forged pistons?
  50. Greddy oil filter block adapter safe for engine?
  51. question about valves,and springs and retainers
  52. Transmission Cooler
  53. More Flywheel chatter than before??
  54. The most advanced water/methanol injection kit
  55. where to route cable for wideband?
  56. DP,TP,CELfix
  57. Soliciting engine rebuild advice
  58. Thanks to Sean Ivey
  59. turbo kit???atp/sbr/buschur/greddy??
  60. Adjusting Forge RS BOV
  61. MBC problems
  62. Please help! The pursuit of better boost control for a 16G.
  63. Vacuum Line Access for BOV
  64. HKS type S or type R?
  65. Ar 63 Or Ar 82
  66. Brian Crower 280 cams require springs?
  67. Who makes quality v-band clamps?
  68. ?'s for guys with 475-500awhp Daily Drivers
  69. Clutch Question
  70. IX Evogreen - Camshaft?
  71. Licp to short??
  72. To Get Valve Spring and Retainers or Not to get?
  73. **ALL EVO IX's BUILT HEADS COME HERE **
  74. Cat Flange leaks water but no air.
  75. Full Race Turbokit.... What exhaust???
  76. my buschur turbo kit bolts keep on backing out!!!!!!
  77. Dyno Flash Evo goes 9.50 in the 1/4 mile
  78. 20g-9LT (green) vs IX turbo
  79. Did I put the right grade oil in my 9? I have valve ticking at idle after the change.
  80. Head flow numbers
  81. Evo 4 RS transfer case
  82. Cylinder pics....
  83. ETS Manifold Vs full Race
  84. (gauges) BSPT to NPT fittings? get em locally?
  85. Dyno sheets of Cosworth cams and -4 and -2 cam gear settings/dyno videos
  86. catless Helix HFC
  87. starts but...........
  88. Need help selecting a turbo
  89. Stock gearset limitations?
  90. Info on build help
  91. service engine soon
  92. Would buying a greddy turbo be worth it.
  93. My AMS Lightweight Front cross member review
  94. A Good Flywheel choice?
  95. My buschur racing pump gas evo..Part deux
  96. Extreme Turbo Systems GT42R Kit is better than sex
  97. Flywheel Removal Tricks?
  98. Help with my new Engine!(clank noise)
  99. Dyno#s with Cosworth cams and camgear settings!!
  100. Evo Crank
  101. clutch vendors
  102. Ultimate racing HFC???
  103. Evo Ix Mr Cams ? Every Opinion Counts.
  104. mivec camshafts
  105. Which MBC?
  106. utec on my bolt on evo and only laying down 264???
  107. Yet Another ~12psi boost limit
  108. 5th gear grind - advice needed
  109. Clutch retention spring: anyone seen or had this happen to them?
  110. a/c noise
  111. Low RPM troubles dip/stall
  112. Engine Size Comparison
  113. 955 Dyno Jet WHP at ICS Dyno Jet - Dyno Flash Evo 8
  114. Question about Boost
  115. 1.1 Bar > 1.3 Bar [Untuned] ????
  116. E3 Spark Plugs
  117. AeM Wideband
  118. 35R Buschur dyno'ed today!
  119. My Tilton Clutch blew.
  120. help me decide
  121. shifting problem "help"
  122. how do i get this o2 housing gasket off?
  123. Clutch Pedal Adjustment Question
  124. Diagram needed!!!
  125. Spiking
  126. hks gd max rebuild clutch kit
  127. need help before buying parts!
  128. new setup coming soon
  129. 280 Cams.. help
  130. Exhaust Question
  131. Exhaust tooo loud.. need advise.
  132. What makes this Turbo Whistling Sound? [VID]
  133. Trying to find the cause! Blown Engine!
  134. what causes a turbo to back spool in high rpm's
  135. devisl own kit
  136. All Evos whine a little right?
  137. 10 psi again?????????????
  138. catch can and breather help
  139. New front 02 sensor shows 0.00 volts??? HELP
  140. Misfire and boost problem
  141. fresh install of Injen intake & IC pipes BOV noise
  142. Intake manifold question
  143. Compressor Wheel is Screwed!!! Please Help
  144. Please Help my compressor Wheel is screwed!!!
  145. Pls help, car wont start after cleaning fuel filter.
  146. Clutches
  147. vacuum hose diagram?
  148. Need help choosing Downpipe and intake.
  149. anyone running megan's new TBE
  150. Wideband O2 Shootout Test & Results
  151. Piston sizes info need.
  152. Anyone have experience with Precision Turbo & Engine either with your G or other car?
  153. ACT prolite flywheel or ACT streetlite flywheel
  154. Fidanza cam gear problems
  155. Evolution III swap
  156. ive noticed my bov
  157. What size tbolt clamps?
  158. synapse synchronic bov???
  159. Losing my mind here...
  160. Custom Turbo Project Turbo Selection?
  161. sick of forge bov flutter??
  162. little help? IX fuel pump
  163. MEGAN o2 housing review.. internal pictures.. not so impressed,,
  164. Stock Clutch
  165. my transfer case makes some noises
  166. The Turbo Landscape in Detail
  167. Can close gap cause Over Heating?
  168. My EVO hated me today
  169. Guide: Remove TC w/out removing ACD line
  170. Exhaust Issue
  171. Lower ic piping worth the buck
  172. AEM Wideband gague issue...
  173. Radiator
  174. Tranny noise
  175. Cosworth Mivec Cams
  176. identify cam
  177. installed LICP, now front bumper wont go on...pics.
  178. Underbody exhaust heat shield - Can i remove?
  179. Velocity stack (maf and adapters)
  180. Curiosity question for those who have...
  181. Which Stroker kit....
  182. O2 housing questions
  183. Evo Viii And Ix Uicp?
  184. Missing part of my LC-1!
  185. Mod advise
  186. intercooler upgrade
  187. TurboXS FMIC question
  188. Help!! Broke something!!
  189. gsc s1's evo ix turbo dyno graphs!
  190. HELP! Car sounds like a diesel!
  191. 2005 transfer case removal
  192. Question about switching from 93 to 91 octane
  193. Injector Size
  194. Went back to OEM exhaust...left the rest of performance parts untouched
  195. Fuel guage - fuel pump/fuel level...
  196. Lots of unhappy sounds from somewhere
  197. exhaust mani. gaskets
  198. Saikou Mitchi can quick question
  199. manifold torque spec
  200. Tansfer Case Leaking Fluid Leak Letf Lipseal Axe
  201. Best Piston and rod combo
  202. Wideband(help)
  203. Mini-Battery Research
  204. Turbo xs rfl bov. . .
  205. Is this whine the walbro fuel pump?
  206. Major accident threw p0335 and p0340 codes
  207. WTB:evo9 stock waist gate actuator turbo heat shield
  208. throttle position sensor install
  209. Need help with sending unit for gauges
  210. downpipe,test pipe
  211. Dyno'd my IX today..
  212. problem fitting 35r kit
  213. Stock Evo 8, 8 grand to spend
  214. GT35R over GT37R
  215. P0403 Exhaust Gas Recirculation Circuit Malfunction
  216. Transfer case oil
  217. Injector question!!
  218. Not understanding the power loss!
  219. 2006 Evo TSB's
  220. Stroker Timing Question
  221. 8-9 Battery Sizes?
  222. Turbo Outlet.
  223. can't boost over 14psi, WHAT?
  224. Free HKS SSQV... should I do it?
  225. Need help......weird loss of power after parts install
  226. Boost fluctuation - any ideas welcome
  227. Battle of the Turbos - 50 Trim vs. GT35 - dyno comparision
  228. TBE and drop in filter with no tune...
  229. Evo 8, Smoke, Oil smell comin out of the exhaust when I let off the Gas.
  230. System Too Rich (PO172)
  231. clutch install, now steering problems
  232. My rebuilt engine (in process)
  233. car battery
  234. Extreme Turbo Systems - 5" Intercooler (PICS) Do you dare?
  235. Extreme Turbo Systems - More SEXY PIPES - Stock Battery UICP!
  236. Boost Leak
  237. Where to weld O2 bung on Fujitsubo catback exhaust?
  238. my first evo. need some input.
  239. TB boost leak
  240. 60K and timing belt
  241. Pics of my dead stock clutch/flywheel
  242. NEED HELP!! Tial Wastegate Connection
  243. 272 eXh Cam on a EVO IX
  244. Advice Please on Vishnu Stage 2 kit?
  245. Such thing as too much "preload"?
  246. Triple cerametallic exedy clutch
  247. pics of Tial Sport new SS gt42 turbine housing + Shearer Manifold
  248. What do I need???
  249. JDM MR Diverter or Forge Diverter?
  250. is there any type of over-the-counter exhaust heat coating? (not wrap)
