- arp rods/mains
- Quartermaster Hydrolic TOB kit?
- BISS screw removal?
- Help with engine rod bearing clearance
- evo 8 problem need info
- Magnaflow catback
- Battery voltage jumping to 11.5V
- I need help with pricing: Used 4g63 block and crank
- 400awhp daily
- Weighted shift knob
- Low flying airplane sound???
- Methanol Kit or Race Gas?
- Oil Gauge and Oil dash light flicker at Idle
- evo 8 clutch problem??
- TRE Max-Lock Rear Diff Demonstration
- I have a buschur cop cdi... but need help with mounting the cdi box to the small batt
- Muse Short Route Upper IC pipe question.
- starting problem/dieing
- Whats your favorite turbo-back exhaust system
- My clutch wont come off the floor!
- For those who have replaced the upper main bearings with engine still in car
- 500 WHP DP question
- Boost & Intake Manifold Defi Gauge
- no CEL light?
- Cam identification
- Please help heavy vibrate on accelerate
- Evo 8 Project - Engine water leak
- Thinking of upgrading to an HTA Green...have some questions though!
- Sparkplug Gap Recommendations
- 2.4 Build
- ** Smoking light blue smoke, no compression one cylinder HELP!!!
- Kiggly HLA Pressure Regulator Good or Bad
- Tapping/knocking nosie at idle
- Throttle body coolant lines
- p0106 code after installing Omni 4 bar
- Car randomly dies?
- Annoying noises
- HKS GD Max Twin Disc Minimum Disc Thickness
- no boost
- cam selection
- Hks twin original plate thickness??
- weird sound coming from underneath car
- engine bolt mounts
- Oil Recommendations
- Review of CBRD BBK Full Turbo vs. FP Green
- ACT clutch employee/member on here.
- Looking for a engine for My 03 Evo 8
- Need transmission work in VA Beach area
- evo crank has play
- New Quartemaster TOB installation question
- To ACD or not ACD that is the question
- Tial wastegate/hallman pro mbc
- help please, combo of problems
- ACD had no reservoir on it when i bought the car!
- Rpm hanging issue
- HELP! Delayed Throttle response between shifts
- HELP, loud clunking at weird times from front..axle?
- Tomei Valve spring float issue?
- comp cams XE248HR - need specs
- Can a Evo 6/6.5/6RS/7 Gearbox use in an Evo 5?
- Evo VI vs Evo 8/9 transmission half shaft spline differences
- Nick's Evo 9 FP Green HTA73 build just wrapped up..
- Quaife lsd in a daily driver?
- cann't shift into 5th after rebuild.
- new fuel pump test!
- RICH Issue Advice?
- Shiftlinkage problem!
- Would oil cause valve knock
- 500WHP on FP Green possible?
- pte turbo go bang
- Are .40 over pistons too extreme?
- EGR Valve
- Radiator doesn't suck in antifreeze..
- Use vag coil with Aem ver1
- megan testpipe/general testpipe question
- ETS 3.5" vs 4" core fitment
- Balance Shaft Elim Guru's
- Kelford 272s and Supertech dual springs?
- Flywheel/Clutch install, vacuum hoses mismatched.
- Video clip of stroker motor with cams
- Boost control solenoid hook up???
- Exedy Twin Problems.. Clutch pedal vibrations!!!!
- Were can i get my motor rebuilt near PA
- guru question on sierra sierra evo
- Problems with Reverse
- help please, car wont start sometimes
- Which clutch to get?
- Two Cosworth cams, only one part # stamp
- Red Line Engine break in additive
- DIY clutch install experiences! lets hear them!
- Installed invidia tubular manifold. spools slower now HELP!
- Alignment required after clutch install?
- Blitz sbc id help
- Fun With Coatings or How I learned to stop worrying and love ghetto motors
- Price Check : Stock Evo 9 MR BOV (metal) and Intercooler
- bkr8eix vs bpr8eix
- Horrible rattle above 3750 RPM
- Unique Clutch Problem
- Clutch slipping now need advice on replacement
- Been thinking about my next build...
- 4g64 block with power enterprise head gasket and O-ringing a block question
- what turbo should i go for?
- bpr7eix
- Lean, lean, lean
- Stock Evo IX: 190 whp (doh). Any ideas?
- Launch Help PT. 2
- New motor...now very rich!
- GSC s1 users
- Back/misfiring with any throttle
- BPR7EIX,BPR8EIX, or BPR8ES
- 4g67+4g63t
- Transmission line up pins?.
- Problem with Internal Wastegate adjustment
- Looking for data sheet 272 HKS cams
- Hks 272 camshaft setting - evo 5/6
- minimum thickness on evo 8 head?
- Porting will give me ???hp
- Evo 8 & Evo 9 Head
- Interesting article on oil viscosity vs fuel economy .
- Sandblasted Valve Cover Problem
- Headgasket leaking externally.
- Tcase housing cracked (pics)
- Which Magnaflow muffler do Buschur and Ultimate Racing use for their catbacks?
- messed around with MBC, now misfiring???
- help! , transmission install.
- What next?
- Missing Air Hose... Replacement?
- intake manifold - help
- Timing Belt Movement - Normal?
- using stock valves on a built head!?
- J pipe leaking oil?
- boost controler issue
- Hi Im New and Just Bought My car
- GSC S2 Lifter ??
- PTE 1600CC or FIC 1450CC to support my build :)
- 600 whp on pump gas with gt35 variant turbos?
- BR piston with HTA 35R comp ratio ??
- Not much POWER gain after tune???
- ACD pump death whine
- Quick bearing question
- tial qr
- boost leak test now fp black smokes
- Random Overboosting
- Engine harness connector help
- Looking for good clutch and flywheel setup
- Huge vacuum problem! Help!
- GS setupC 280 cams??? Good or not
- FP BLACK and the SYNAPSE SYNCHRONIC SURGING/STUDDERING PROBLEMS
- My car + E85 = bad idea?
- Dsm exhaust manifold gasket same as Evo?
- Weird exhaust question
- Standard Garrett GT3076R vs. Precsion PTE 8530R
- Looking for a place to tap...
- 2.3 motor build what cr to go with?
- What Part Next!?
- EGR Solenoid, please post picture of valve
- Half Width Radiator FF Setup
- MBC Testing by Boosted Tuning
- VR1 Racing Oil 20W-50 who's using it,,
- Car Boosts 3 lbs, any ideas?
- ARP headstuds, oil leak now
- evo 9 o2 sensor code.
- 2.0, 2.3, 2.4 ? Can't decide :(
- STM test pipe
- FREE CASE OF VALVOLINE VR1 "high zinc" synthetic oil
- Competition Clutch Stage 4 - anyone has it? power level?
- Bad idle and check engin light after changing cluster globes
- NEED KOYO STB5085 Bearing for TCase
- BOV, or WG flutter
- Starter keeps coming apart
- Buschur Down Pipe Question.
- No power to wheels when car is in gear.
- stock clutch gone 86K miles
- $400 rear diff removal and install too much?
- P0505 maybe O2 sensor's fault :P
- Manley rod torque spec??
- magnus v5 intercooler pipes
- Bad walbro fuel pump?
- o2 dump
- Shot Peening an Cryo Treating
- Tial Wastegate what spring to choose
- Help me out w my trans :(
- mild misfire help
- Anybody know who makes this bearing?
- Driveshaft Dilemma
- How exactly is 4G63T superior to 4B11T?
- Leaking valve seals? Pressure in Valve cover?
- ....to bead or not to bead? that is the question i have
- Amsoil introduces new Z-Rod high ZDDP oil line
- Amsoil SVG for trans?
- do i need to port my o2 housing since .....
- Dropping 2 & 4th injectors
- Amsoil Expanded Their SSO Lineup
- hks7460r vs bbk lite ,bbk full and hta green
- Bearings with .001 clearance questions, on rods but not mains?
- Bad Transmission sound help with video
- Help! 5 Speed or 6 Speed
- Synapse BOV Issues
- Why Oil Pressure Suddenly Surge?
- diy 50 trim setup
- Overboosting after FP Black installed
- A Clutch Odyssey
- smoke after boost and at idle
- piston to wall clearance shock theory
- Is it bad to not have the turbo heatshields on?
- can u supercharge an evo VIII
- Is this a radiator or intercooler issue?
- Will it be a big different by using S90 70mm TB?
- compression question?
- 450cc injectors limits???
- Hissing sound after new clutch and flywheel install.
- Main bearing clearances????
- EVO9 Fifth gear problem ? it drop to natual right after I shifted
- Exedy Twin Failure? Need Diagnosis Assistance...
- Hks GTII 7460R tune at 91 oct
- still not sure what intake manifold to get - looking to break 600whp
- HELP!! hard to shift to 2nd gear
- Good choice for a clutch?
- HKS DLI II users, need your input
- Invidia Test Pipe?
- 06 MR 5speed swap?
- Knock/rattle/grind noise only on warm start
- Weird issue with bov/engine revving
- broke my engine, need serious help!!
- Hks 7460?
- need opinion about this turbo
- new to SD and BOV venting and have a few Qs
- Works 76mm DP question
- opening up Six speed case
- billet evo 9 cams
- 06 MR grind into 6th
- What could I do for 10,000?
- Change main bearings with motor still in car
- Difference between these head gaskets
- Piston ring gaps
- 30 psi?
- Engine build help!
- Diaqueen LSD oil....help!! Lol
- Transfer Case Noise
- day is almost here
- Help: WOT lean... low voltage at fuel pump...
- Evo 9 mr clutch in evo 8 gsr
- downpipe clearence ac bracket
- block assembly, need help!
- Shifting Problem, Had this problem for a LONG time.
- chatter
- Evo 8 tcase on Evo 9?
- Strange Knock issues
- New HeadGames t-shirts!
- How to tell difference between Evo8 & Evo9 actuator?
