- Can Airtrek Turbo Wiring Sockets used on Evo 5???
- My Build Thread
- My Evo 5 Engine Rebuilt...
- How Efficient those Smaller RAD?
- What plugs to run on a e85 2.3 black?
- help:ignition troubles?
- Where to buy Clutch Snap Ring?
- Grinding Into Reverse
- Questions on O2 Dumps????
- Exedy Triple Cerametallic
- Valve guide Q
- 2.3L Crank
- Cam journal sizes
- Transfer case death or Wheel bearing...
- The Truth about Speed Density on Stock ECU?
- transfer case bolt not goin in???
- Front O2 Sensor Info...
- engine sputters
- 2003 evo 5th gear noise!! :(
- Quaife Front LSD and Drivers side front Tire getting bald
- cylinder #4
- Pops & Bangs
- FP HTA3794r Forward Facing manifold, sparktech, awd motorsports, etc.. Build
- information please (tranny)
- Competition Clutch
- Turbo lag again...
- What is the Different - Turbo Evo 5 / TME / Evo 8 MR
- Please Advise - Will this affect Oil Suction?
- Clicking noise at low speed tc?
- Dnamotoring exhaust review (PICS)
- Clutch burn
- plese help to calculate optimal comprassion ratio
- clutch engagement
- fp white to green
- Is Porting the ex. manifold & hotside worth it?
- Electrical bulkhead pass through for twin in-tank pump setups
- new build, not fireing
- ETS Custom Top Mount Twin Scroll Borg Warner Turbo Kit! This Turbo is HUGE!!
- stiff clutch feel
- Oil Press sensor mounted on the Cylinder Head?
- ****HELP!!! A/C blows HOT air at WOT!!!
- fastest/highest hp to date?
- question about engine roll
- Do cylinder heads commonly warp?
- Help tranny won't come off
- Need HELP! broken bolts into o2 housing!
- Turbo selection for a 2.4
- Oil temp sensor by tapping into ecu?
- New Exedy Twin Slipping!
- Buschur SD exhaust
- Will an aftermarket radiator work well with a GT35R turbo kit?
- What turbo best suites me.
- differences between 8 n 9 shortblocks?
- heat and ac?
- Will a Evo VI Koyo radiator fit an Evo VIII-IX ?
- o2 compatability w/ WORKS Exhale DP (Downpipe) 76mm
- Do i need a tune?
- T-Case solid ring gasket removal?
- Help with evo!
- Problem Code po335
- Low boost IX
- ams shifter bushing help?????
- long block
- Turbo flow
- Carbon synchros
- Stock turbo question (tune related)
- wastegate actuator signal line hose diameter
- OEM vs MR Gasket MG-7235 exhaust manifold gasket
- need help kelford vs kelford
- How many labor hours to replace Timing Belt?
- My Spark plugs look alittle funny, what do you think?
- Phantom knock from Kelfords??
- Weird snapping noise? when stepping on the clutch?
- Ceramic coating a LICP. Worth it?
- oil under plate?
- Weird fuel pressure problem
- Rattle/Vibrations - Any help???
- those with a 2.4
- How NOT to install an Alky kit! DANGER! Pics inside may shock and horrify!
- strange boost gauge issue only when at the track,has this happened to anyone else?
- Dose any one know if i can make a T4 turbo work on a 08 Lancer??????????
- Which is better and Why: New Tial MVR 44mm or Percision Turbo PW46 46mm wastegate?
- Really Dangerous, stalling on decel when I clutch in
- Shaft play on FP HTA Green?
- power limit of evo drivetrains
- IX turbo install on Evo VIII
- Clutchmasters FX300 or Comp Clutch Stage 3? Need to order today
- How strong is the OEM front LSD?
- 5857dbb???
- Changing up my fuel system a bit
- Buschur Exhaust
- Dipstick popped off and spring missing! please help
- Negatives to using Half Width Radiator?
- Which cams to go with? GSC2, Kelford, JUN, Tomei
- New clutch, now it grinds into 5th...
- need help once more
- cam position sen. SES light still
- JDM RS gears + 6th in a 6-spd. box?
- Transmission part numbers??
- spark plugs
- car will not shift
- P0325 Knock Sensor
- No really this time...time for a new clutch!
- Pls Comment On My Set-Up...
- Any reviews/opinions on PTE 5865 or Holset HX40 on evos?
- New here, need help with rattling!!!
- Questios about my Broken Front Diff
- questions about exedy tripple
- Will my new Cobb downpipe melt my OEM undertray?
- Car died, wont start
- Is my clutch bad? HELP!
- Anyone have the ex-mag rs*r exhaust
- 2.3L 4g63 Stroker Questions (some new, some confirming)
- Spoolin up coils
- gearbox disassembly help..
- Any body having lockout issues with the act 6 puck sprung clutch?
- Clutch replacement in Dayton Ohio.
- Atsugi Clutch? anyone??
- Odd trans issue
- Revolver Cams
- Evo 8 gearbox
- Gum Out Flex-Fuel Injector Cleaner
- does anyone knife edge their crankshafts?
- Buschur Racing baffled oil pans and other oil control.
- sensor issue perhaps?
- MIVEC oil feedline leaking at head.
- LC-1 wideband help.
- How to remove and replace water jacket on block?
- The weirdest build yet?
- What to look for in a built trans...?
- Newly bought EVO 7... how do i fix these problems?
- What size injectors with fp red
- Balance shaft stuck after oil pump install??
- Fp turbo wheel sizes
- How to Re-seal Throttle body/Throttle plate
- Don't use mobil 1, it will ruin your journal turbo
- How to replace Crankshaft Position Sensor?
- Will an Evo 8 throttle body fit a Magnus i/m for a 1g DSM?
- HAVE A LOOK. Shops Cant Answer, Trouble Going in Gear.
- What downpipe do i have?
- Temp gauge rises when stopped
- ticking sound?
- OEM turbo size
- UEGO shows "- - - -" WOT!
- T4 Undivided turbos?
- BOV flow rate - would a Tial help me?
- Fuelling issue - way lean
- Box/Resevoir After the Intercooler...
- Help, Hallman MBC issues
- ID2000 injector latency values for AEM EMS
- Evo 8 misfire
- Strange vibration
- Off the shelf built short block options
- 03' Evo 8 wont Idle - Just dies
- EVO 8.5 and EVO 9 Compressor
- Help!!! My GSC ValveSprings cant fit into my Evo 5 Oem Retainer.
- Need New Block
- turbo lines
- can i drive the car untuned ?
- vmrevo9's mini build
- No boost on a 03 Evo VIII
- Anyone running hi-z Denso 2000cc?
- ACD install or DIY?
- fp red and intake
- what wastegate for HTA green!!!!HELP ordering within the hour
- Not running coolant to turbo ?
- Opinion: Removing the rear mount?
- Laggy fp-red?
- P0011 Code HELP!!!!
- Thrown Rod, Need help.
- All check engine lights keep comming on HELP?
- Name this engine failure!
- Question guys, whats the most wtq I can use on the evo transmission with breaking gea
- Lubrication thread
- Spark plug gapping help!
- Valvetrain ticking and phantom knock
- IX MR tranny hard to shift
- exedy twin slipping with low miles
- Did the tow truck driver eff-up my transfer case????
- Can 2.4 block hit redline?
- I'm looking for a custom clutch builder
- New Gaskets Offered from GRIMMSPEED @ MAP!
- check engine light'sss??
- Best spark plugs
- header coatings, long term.
- Rattling noise from the drive shaft?
- New Piston Oil Ring
- Symptoms of a leak??
- misfire/tps
- witch spark plugs to run?
- Oem Balance Shaft Reliability?
- Buschur exhaust question
- Engine removal tips?
- 2000 Mitsubishi Mirage w/ Evo Swap - Import Tuner
- Any twin discs with stapped floater plates?
- burning plastic smell
- 1992 lancer gl cc evo conversion
- About boost psi with MBC closed!!
- With stock frame turbo's being the it option, found an option that no one talks about
- JE 85.5 Piston Rings Mix-UP
- coolant bleeding issue
- Shifter grease?
- OEM Valve Seals - Color?
- Buschur Racing/RCBANKSracing.com goes 24 hour racing and DOMINATES
- 2005 evolution GSR Misfire
- ACD Pump Dealer is Fighting warranty
- Rebuilding Exedy HD Twin
- Oil return line what size is the id od???
- ID200's vs BluMAX 2150's
- stock evo 8-9 springs and retainers.
- Mivec inlet cam pulley-can it lock in one position?
- Typical JE and wiseco 86mm micrometric measure
- Walbro 255 ( question )
- Synapse Diverter Valve - where to get it?
- What is the Best Setting on GSC S2 Cams???
- This for for those that run E85. How often do you do change your oil?
- How often you do guy than run on E85 change your oil?
- Suggestions on a new setup
- my diy K20/24 series honda cop non cdi
- ClutchMasters FX300 Lockout......
- time for a new trany and clutch...
- Bad ISCV?
- P0139 Slow Response o2 sensor!
- Big Issues!!!
- Which is better? Oem or Eliminator for Balance Shaft???
- Need some suggestion, mbc or electronic boost controller
- Question about Clutch stiffness...
- Help: Stalling problem after installing FPR Aeromotive
- ACT HDSS w/ FP RED
- FP Red on my IX
- Startup Clatter/Clunk noise after some hard runs?
- How to Replace OEM Balance Shaft Front & Rear Bearings?
- Stock evo running lean? Opinions wanted please!
- Stalled with ebrake on, Any damage done?
- Going e85 the cons and bad.
- No power at higher RPM's when boosting
- HKS GT7460 Original Turbine, tested at Iveytune.
- Evo runs cold
- Spark plug wire recommendations...
- Back from Afghanistan, and now my car is dead? Pump issue?
- For those who are thinking about a downpipe...
- FP Red with stock clutch?
- Oil Pumps - aftermarket
- Please Advise on my Evo 5 Shaft...
- Ball Bearing FP Black - who want's one?
- Turbo TD06 T517Z 18G
- 5 turns of preload only 11psi?
- Vibration after warmed up?
- Anybody on here have an EXTRA Crankshaft Key ?
- Weird grinding noise from the rear
