PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 [221] 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. TME turbo or 10.5cm2 housing from FP
  2. Best Price on Exedy Twin Disc Clutch
  3. Tunning Question????????
  4. how many qts. of gear oil is needed to make a oil change?
  5. About Turbo Pressure and Hks Evc 5
  6. Cams question
  7. MAP pressure and boost gauge....
  8. mounting of oil pressure manometer
  9. tomei oil killer kit install..???
  10. Installed DNP header
  11. Perrin O2 Simulator the same for Subaru and Evo8?
  12. gaskets!
  13. boost??
  14. Gt3561
  15. Lancer Shop Shifter Kit Report
  16. clutch bleed problem
  17. WTF not this again !!!
  18. Megan Exhaust Manifold evo 8
  19. Stock idle vaccuum reading ?
  20. Cams 264/272 vs 272/272 ??
  21. Mitsubishi, synchros and us
  22. Clutch Replaced, Hard to get into Gear.. NEED HELP
  23. Dual Fuel Pump System!!!!
  24. Need Help ASAP!!!! Fuel Issues!!!
  25. what is this on this turbo?
  26. HELPTransmission Numbers
  27. Zeitronic A/F Meter
  28. Aftermarket oil coolers
  29. Cusco Carbon Twin Plate Just Installed
  30. Best clutch for relatively low power...
  31. XS Race Max Pipe Kit - Any thoughts??
  32. Which intercooler kits minimize piping?
  33. Street Racing Exhaust
  34. New clutch problems, Help?
  35. Bov Quesion?
  36. List of Important Evo Engine / Turbo / Drivetrain Threads
  37. boost leak
  38. Intercooler Upgrade for stock turbo??
  39. Ebay boost gauge
  40. Stock BOV in backwards.....does it really matter?
  41. Evo 4,5,6,7,8 engine????
  42. when is the right time to upgrade the fuel pump?
  43. T-SPORT Flat Shift
  44. removal of balancer
  45. EVO VII GSR Final Drive
  46. Technical Q! EVO8 AWD Drivetrain
  47. Resistor pack
  48. IC pipe blows off intake manifold...
  49. 272-272 cams. How is driving at very low speed?
  50. Blow off/Forge recirc question. No its not a ricer one...
  51. Will a High Flow cat make my car louder?
  52. Knock Link
  53. Where would I take oil cooler to have it flushed?
  54. Clutch Extender Rod - Lancer EVO 8
  55. optimal settings for boost controller
  56. My Impressions and a question on life expectancy of Exedy Twin Disk Clutch
  57. Front helical LSD
  58. Boost Leak Nightmare.....
  59. Gauges: oil pressure or oil temperature?
  60. K&N panel replacement filter question
  61. 19" wheels... At 4k RPM I was going 94 mph, is this normal on stock wheels?
  62. Injector help!
  63. Getting new clutch installed for under $60, what should i get??
  64. Ralliart Meter
  65. Greddy Boost control
  66. 300 miles new clutch slipping
  67. Downpipe bolt torque specs?
  68. 11psi... WTF??
  69. best way to run a mbc? manifold or compressor?
  70. Want an aftermarket pre-turbo exhaust manifold for the 16G
  71. RMR cat-back production problem
  72. Greddy type s position
  73. Which is the Best Clutch?
  74. Turbo shaft end play?
  75. Looking for 114-116MPH traps what will it take? Newbie
  76. ACT clutch chattter
  77. Turbo Trixx ECU Flash Question
  78. TOB problems/question
  79. Tight Model Evo - Short Shifter
  80. can't rev past 4.5k
  81. WTB: JUN 264 cams.... anyone??
  82. Life of Act vs. Cusco....
  83. Hks Evc V problem/question
  84. Boost controller OFF
  85. which comes 1st?
  86. Is my new clutch defective?
  87. Poll: Cone filter in the rain: Any problems?
  88. Cat Back help....Need advice
  89. How can you tell when your clutch is going bad
  90. 3" downpipe exhaust wrap
  91. Fidanza Aluminum Flywheels
  92. Stock Block Capability
  93. Would this cover repairs?
  94. Evo 4 Frankenstien
  95. Blitz SBC-Spec S EBC...Your thoughts...
  96. Thinking about going back to stock intake
  97. Evo IV Block Evo V ECU Evo VII Turbine.
  98. Aftermarket Acuator?
  99. boost controller question
  100. Any managment besides standalone/AEM that will control closed loop fueling??
  101. 300.4 on a Dyno Dynamics
  102. 4 inch intake
  103. Best turbo for the evo w/ a 2.3L stroker?
  104. Revolver Cams?
  105. Top end misfire
  106. Which test pipe will work with the stock exhaust system?
  107. DTC P0141?? Anyway to fix this?
  108. Car make a thunk noise when the clutch engages
  109. Are aftermarket radiators reliable?
  110. Fuel cut & weather or mods????
  111. CV Boot Replacement
  112. I need help ASAP! Am I in Limp Mode and what is the cause??
  113. Stock wastegate spring ?
  114. which exaust is the best?
  115. ECU for a Bigger Turbo
  116. loss in torque!!
  117. Wrapping the downpipe HELP
  118. mbc question
  119. help! car stalling horribly
  120. Need Advice!!!! Car is bucking top end!
  121. VTA BOV preference?
  122. Anyone running an APS cold air intake?
  123. HELP, K&N typhoon prob.
  124. spongey upper intercooler hose
  125. Limit of Factory injectors/Pump
  126. EGT probe location with stainless manifold
  127. Walbro fuel pump problems
  128. Weird Problem w/ Clutch
  129. 300.6 on dyno dynamics
  130. Please help me with my Dyno Results....
  131. what fluid do you use for the clutch?
  132. How to tell if the evo8 has titanium turbo
  133. TRANSMISSION, TRANFERCASE, & REAR DIFF. FLUIDS
  134. Driveshaft
  135. LSD Diff and Tranny Problem?? (long)
  136. hks Carbon TI exhaust
  137. Installed Buschur upper IC pipe now car takes a dump. Help
  138. Stock Bypass Valve?
  139. Break in methods, Beat it to death or baby it?
  140. Boost selenoid...
  141. Ralliart Filter
  142. gear timing for 264
  143. Help!!!
  144. 1.1 to 1.2 BAR (stock)
  145. DV/BOV questions.
  146. clutchmaster stage 3
  147. torque specs
  148. is this where you tapped boost from?
  149. Greddy type-s bov what do i need 2 do
  150. TurboXS Boost control
  151. SES Light,,, and highflow cat?
  152. AFPR Noise
  153. Help Too Much Boost
  154. Cusco twin-plate clutch...
  155. Exactly how much boost should I have?
  156. espelir exhaust
  157. Root Cause of BOV VTA Stalling
  158. MBC vs EBC whats better?
  159. Help - car won't start.
  160. Break In Process?
  161. EGT Sensor Placement?
  162. Dyno today.......unhappy
  163. what companies offer an o2 delete downpipe?
  164. optimal vacuum pressure?
  165. transmition problem
  166. Cam shaft position sensor cylinder?
  167. Turbine Housings
  168. Oil Dipstick Blew Out - Need Help!
  169. Toda Stroker engines 2.32 liters available.
  170. clutch finally took a doo doo
  171. Exedy Hyper Single PLate Clutch... HOLY CRAP!
  172. whats a good upper intercooler pipe...
  173. Question
  174. boost problems help!
  175. tranny build-up
  176. Greddy Type- s Flange Size
  177. poll: engine management
  178. Manifold for T3/T4 hybrid???????
  179. Replacing IC hoses with hard pipes
  180. questons about HKS turbo kits
  181. CEL again?
  182. Exhaust question - advice needed!
  183. Pennzoil Synchromesh review
  184. 2.3L Stroker Question 4G64 100mm Crank
  185. Combustion Pressure Tuning
  186. Free Re-flash dyno day
  187. Throwout bearing noise related to clutch failure
  188. What grade motor oil should i use for hot climate?
  189. Increased gear noise after lube change?
  190. Best WHP gain for basic bolt-ons?
  191. my clutch problem after launching
  192. GReddy Profec B spec II tuning, need help
  193. Hi Flow Cat Question!!
  194. Clutches And Transfer Cases Going Out!#@%!%#
  195. Boost
  196. boost spiking. please help
  197. Gt3071??
  198. Boost control question
  199. Boost Cut, :(
  200. Going over 600 whp!!!!
  201. IC pipes
  202. Single vs Dual disc clutches
  203. Cams INSTALLED!
  204. Does anyone have a Greddy Evo2 or SP2 exhaust?
  205. Vacuum readings = Healthy engine?
  206. It takes while to start the car? problems with cams, injectors?
  207. Odd Problem or Normal... ?
  208. tranny fluids
  209. transmition *CLANK* noise
  210. Limitations of stock turbo?
  211. Best Boost Controller?????
  212. Is this my Clutch going or Stock Cat cant process Newly Acquired Air Flow?
  213. Black Bumper
  214. how do you know when your T-case is broken??
  215. Anyone have info on FP 6.5 RSTM?
  216. CROWER rods on ebay for sale
  217. gauges, gauges, and more gauges...
  218. Who has had a broken transmission?
  219. Building new EVO Engine.. Stroke or Blueprint?
  220. Help please! Hard to select 4th
  221. Exedy racing twin carbon plate vs. Cusco twin plate
  222. What aftermarket BOV works best for EVO?
  223. im looking for all the piping and intercooler
  224. RE: Perrin FMIC
  225. What size bolts do i need?
  226. CO/high altitude owners - boost question
  227. boost control????
  228. thud from back of car?
  229. Disapointing Day with DYNOFLASH
  230. 330 WHP... any opinions on the performance?
  231. Think I threw a Rod please help
  232. HELP!!! Tranny "grinding sounds"
  233. HELP!!! Tranny "grinding sounds"
  234. Cam gears other than Vishnu
  235. need help cant get over 15psi boost
  236. Best Performance Mods ?
  237. Evolution 7 LHD expert. Ralliart ECU
  238. weird vacuum reading
  239. does anyone have the K&N EVO Typhoon Intake System
  240. Another Evo dyno'd
  241. Hyper Voltage System installed.
  242. Does your Greddy Ti exhaust Rattle?
  243. awesome gauge prices,
  244. Improper Clutch Bleeding
  245. will a k&n filter cause bogging?
  246. My AFR log (feedback)
  247. My Car Again !
  248. price on transfer case?
  249. Best oil for New Engine??
  250. Cam gears, and reference marks...was told to set them 1 tooth off when I install?
