PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Front Crash Beam with ETS IC?
  2. Does evo 8 gsr EDM 2005 front LSD?
  3. Evo 8 nasty clutch other minor issues
  4. MAP 650+ E85 Fuel System
  5. Aluminum rods and worries
  6. Rods & Pistons
  7. Evo 9 starter issue
  8. Best HKS 272 Cam timing FP RED???
  9. Competiton clucth twin disk failure
  10. Houston we have a problem!!!!!
  11. FP Black MHI vs SS Housing
  12. Troubleshoot. No boost build up, possible lifter tick
  13. no start after cam install
  14. Evo 8 GSR AYC/ACD Issue
  15. Greddy TiC Turbo Back Question
  16. Injector size
  17. Double Pumper Install
  18. BBK Full Wastegate
  19. Compression Test Difference
  20. Gear Linkage angle and gear selection issue
  21. bleeding lifter confusion/ help
  22. FP54 Green vs GSC s2 cams
  23. Mitsubishi evolution 8 lost boost pressure when its hot!
  24. MD366260 front case / oil pump flow rate?
  25. Rebuilt Forged Engine Run-In
  26. Talon 4g63 block vs evo 8 block ?
  27. Evo 4 Stock bottom end limit
  28. Need help on Wastegate flange sizing
  29. Tcase problem??
  30. Stock Frame Turbo Upgrade Suggestions
  31. Crankshaft Identification Help.
  32. Leak around transfer case
  33. 4g69 or 6g75 Tb that will fit evo IM
  34. At a loss with figuring out what is wrong with my Idle
  35. What am I missing on my transmission?
  36. Fly by wire (dbw) from evo x to evo 5
  37. From Q45 cable throttle to DBW
  38. Fuel system upgrade/evo 8
  39. Manley Crank question
  40. Evo IV transfer removal help
  41. Catch can in cold climate
  42. Swapped OEM throttle body to 65MM Curt Brown Throttle body issues
  43. Swapped OEM throttle body to 65MM Curt Brown Throttle body issues
  44. Running fuel line from trunk area
  45. ACD Buzzing
  46. Quieter Exhaust Help
  47. Evo 8 whining/humming noise
  48. Evo 8 mr jdm rear ayc diff rebuilt help
  49. 1st to 2nd gear change pop kick back feel
  50. New Competition Stage 3 Clutch (Segmented Ceramic)
  51. Balance Belt Inspection
  52. Rusty block
  53. Beyond disappointed with the TIAL BOV
  54. Bad Clutch Slave?
  55. Evo 9 diff or cda problem
  56. Evo 8/ head gasket
  57. Fuel pressure different readings
  58. 2019 Best BOV for SD? It’s been a while.
  59. Having a problem with cop kit after installed
  60. Wisco pistons rings question
  61. What are the best parts to get for my evo 9
  62. Test pipe?
  63. evo ix airflow question
  64. 2.4 Tensioner arm grind? New timing setup ?help?
  65. boost creep
  66. Evo IV power cut when hitting boost in cold weather
  67. Long cranking and slow start up issue
  68. Evo III misfire on 1 & 2
  69. Off Rhythmic Engine Noise after Timing Belt Job
  70. Evo VI (CP9A) ayc solenoid valve stuck open
  71. Block identification
  72. Question about Head Gasket
  73. FIC 1650s
  74. Skunk2 intake manifold observations
  75. Who Would Be Interested in a Drop In EFR Turbo?
  76. Help! I have a wierd turbo not on the lists and the seals are shot
  77. Which turbo for stock block evo 9
  78. 400+ whp with stock catback?
  79. Can anyone help my I'd thesecams
  80. evo 8 cam install w/o removing tb
  81. Misfire ??? tune related?
  82. 500hp Evo 8 build
  83. What to look for when buying a used motor?
  84. New FP cast manifold, coated bits, next mods
  85. New FP 28psi WGA
  86. Rod differences
  87. New harmonic balancer + knocking sound
  88. Spark plugs heat range choice!
  89. Evo 4 Intercooler Piping
  90. Evo VII turbo change
  91. Can't make more than 40psi??
  92. Misfire at idle and low rpm
  93. Leaking part on the Throttle body
  94. Help Mods needed for 450whp
  95. Evo 8 holds back at WOT
  96. evo 8 fuel line
  97. Oil rail ring too tight?
  98. Gtx3576r
  99. HELP !!! Oil filter housing
  100. 2004 EVO 8 Cranks but doesn't start
  101. Evo IX/9 silicone hose kit from ebay
  102. Hesitation after turbo swap
  103. evo 6 alternator help URGENT
  104. EGR removal question
  105. Manley Piston Ring Gap
  106. Evo 8 idle cold start
  107. Rear Axle Clips
  108. Evo 8 intake question
  109. Problem with evo 6
  110. Evo IV Ringing sound coming from belt side
  111. Evo 9 assembled shortblock.. what is it worth?
  112. Sticky gunk in intake manifold
  113. Rear differential horrors. Weir 12 plate, installer error, and more.
  114. Hey
  115. Fuel Pump & Injectors Advice
  116. Lancer 9 /2006/ non turbo
  117. Hi guys, I want to help a 5 speed gearbox with a number of w5m512x5bf What is Evo tha
  118. Wiseco 1400HD v CP Pistons?
  119. Pressure plate to Flyhweel bolts
  120. Bov question Evo IX
  121. Source of Mysterious Oil Leak
  122. AirTrek 4g63T Block Strength
  123. Building my EVO IX Engine, what compression should I use?
  124. Idle help, new IAC, BISS screw bottomed out
  125. Project 6062
  126. how does slave connect to fork ?
  127. Another Slim Fan thread...
  128. Tial bov problem
  129. Oil leak near turbo
  130. Built motor longevity
  131. Evo 9 six speed shifter feeling wobbly please help
  132. P0181 Fuel temp out of spec
  133. Shifter feeling sloppy/loose in neutral
  134. Evo IV temp guage dropping while driving
  135. Mystery Noise From Engine?
  136. Driveshaft Rust
  137. Transmission active when in neutral?
  138. 2003 Evolution 8 Transmission
  139. Snap ring size for shifter bushing
  140. Stock cams with GSC valvesprings and retainers
  141. Speed sensor issue after trans install
  142. lean afr at idle, yes i searched.
  143. fuel setup help
  144. Block and CR choice for high elevation... on 91 usually, sometimes E85, flexfuel
  145. 22 of the most popular intank fuel pumps tested!
  146. What would cause a misfire only in 5th gear?
  147. Evo 8 Speedo help
  148. Should I upgrade to an Infinity over my V2?
  149. Dear Weir. Why you no... Oooooh....
  150. Spring for a Tial Q bov
  151. Compression numbers before tune
  152. MAP Sensor?
  153. Can you tune meth kit on stock ecu?
  154. stumped.... help me out lifters?
  155. Evo iii won’t fire
  156. Idle at start up/idle issue
  157. Hot oil temps - Evo 8
  158. Hunting down this oil / trans fluid leak?
  159. 87mm head gasket in 86.5mm
  160. ATS triple metal plate
  161. MAP T3 kit Evo9
  162. Evolution 9 bov problem(video)
  163. Seal between TC and Transmission (and rear differential bearings)
  164. Evo 8 idle problems/smoking powerless
  165. Clutch Fork Pivot Position
  166. ATS twin plate metal - failed after 1 yr
  167. Transfer & Diff Oil from UK?
  168. Evo 9 p0120
  169. Evo 3 maybe 2 LHD conversion
  170. New Air filter Tune question
  171. Exhaust parts identification help
  172. Turbo/Build Guidance
  173. Valve Stem Beating - R2 Cams - Kiggley Springs
  174. CV Shaft replacement tips?
  175. Tapping sound from 3000-6000 RPM!
  176. Evo 8 2.3 6262 misfire?
  177. radiator fan control module
  178. Help code p0401
  179. Evo 6 2.0LR
  180. Evo sounds like a subaru
  181. Tuned without intake pipe on SD, am I able to put a 3.5 inch intake pipe afterwards
  182. Evo 9 won't start!!!
  183. OEM Cam Phasing
  184. 1000cc install need tune right away?
  185. Advice on 250kw build
  186. Idle rough/afr all over the place.
  187. 9PSI W.G spring hitting 15PSI...?
  188. EVO 9 Loud Ticking (Another...)
  189. Cam Gears
  190. High HP on Higher Mileage stock block
  191. My car needs to shift into 5th gear to go over 118 mph anyone experiene this
  192. Stock 8 rev hang
  193. Boost cut/drop issue
  194. Forward Facing w/ Up Pipes people
  195. Very Lean, rough idle, what the hell
  196. Catch can Install
  197. 4G64CRANK on my EVO 6
  198. 3 O2 sensors in 3 years
  199. lean idle after clutch install
  200. My current build
  201. Rod bearings.
  202. Tial Qrj problem! Any help please?
  203. 87.5mm Headgasket options
  204. Lean Spike at 3.5k - 4k RPM at WOT
  205. Looking for exhaust manifold advice (stock placement)
  206. Difference between HKS RACING SQV and HKS SUPER SQV RACING
  207. Evo8 oil pump cover plug came off
  208. Down pipe bolt removal help
  209. 4G63 EVO 8 Engine Value
  210. HELP my evo iv driving me crazy!
  211. GTX3576 GEN2 vs GTX3076 GEN2
  212. so I've decided I'm going to pull the engine and take to machine shop
  213. dip stick marks
  214. Evo leaking pics included
  215. OG DSM question: Dejon Tool Leak Stop 1G BOV
  216. Wont idle/Runs rough when warm----Evo 4
  217. ACD Transfer Case Backlash
  218. egr delete/plugging head question
  219. Fram Ultra Sizing for the Evo
  220. My Wier differential clutch pack destroyed on hill climb
  221. White smoke - headgasget?
  222. JMF new billet drag vs Magnus V5 vs Driven innovation
  223. Has anyone successfully hand honed (deglazed) their cylinders for a drop in?
  224. Question about good AF for E20 fuel
  225. Help needed: Connecting Turbo Oil Feed to Oil Filter Housing
  226. gsc 5041 question
  227. [Evo8] Running Extremely Rich
  228. Need help
  229. ACT Xtreme 6 puck lockout third gear/ Maybe transmission
  230. Evo 8 whine. T-Case? Vids included. Help!
  231. Exhaust getting hot quickly
  232. Oil getting past intake manifold gasket?
  233. Transmission oil leaking into Transfer Case
  234. ok my engine tests are in and my conclusions arn't good
  235. Evo 8 won't start
  236. Tomei Expreme Manifold
  237. Does this seem like an excessive amount of oil in intake?
  238. Whine when gas applied - need help asap!
  239. Drivetrain clunking 1st gear
  240. Evo 8 2L Build Piston Ring End Gaps & PTW
  241. Suddenly burning oil
  242. Strange issues with Evo 4
  243. Best trany and tcase fluid? Evo 8
  244. Rear Diff service required? 165k miles before Weir 12 plate
  245. Evo 8 trouble starting
  246. Evo 9 oil pump
  247. Evo 8 Cranks, But Wont Start After Trip
  248. fuel pump setup?
  249. Evo 7 starts but wont idle
  250. 2.3 Stroker Advice
