PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 [116] 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. FP Red or BR 3065
  2. new twin plate clutch slipping on launch
  3. E brake ????
  4. High Pitch Noise or Squeal coming from my car. (not brakes related)
  5. bad boost controller???
  6. Intercooler End Tank Design/Theory
  7. Gears grinding at high speeds?
  8. Best hotside for 2.3 liter and HTA 35r .82 or 1.06???
  9. Mechanic put castrol gtx oil in my car >=[
  10. IS the USDM RS fitted with the JDM RS trannie?
  11. CEL: Random misfire code???
  12. 50 trim .86 ar?
  13. freak mini battery?!?
  14. Loud Engine BANGING
  15. WHICH 1s WOULD U USE?
  16. FP Red 18psi actuator touching outlet pipe
  17. ACD Error??
  18. Problem with Quartermaster Twin disk install.
  19. Timing belt question
  20. Did the Evo come with 2 different size o2 housings stock????
  21. best plugs/ wires?
  22. Sound camshaft Brian Crower 272/272
  23. Exedy triple cerametallic vs Exedy triple carbon
  24. FP Red and BR lower IC pipe fitment
  25. Which ACT flywheel would be best for me? Streetlite or Prolite??
  26. wierd noise at start up
  27. Running strait meth no IC
  28. Secret Number
  29. Exedy Triple Carbon went out on me...
  30. Someone Please help with measurements for injen hardpipes + intake
  31. Oil Feed Line Warning For Everyone
  32. Why did my turbo blow up?
  33. Blown transfer case prevention tips
  34. ACD pump not working
  35. Talon TSi Exaust manifold compatibility
  36. kelford cams anyone?
  37. sort of concerned about a long exhaust flame.
  38. Needed! High HP EVO's to Help Evaluate Carbon Clutch Technology
  39. Redline in Trans and T/C
  40. 4g64 setup. JDM evo VII water pump, no adapter
  41. Another Update on my BR Built Monster
  42. turbo-install tips
  43. 500WHP on Stock MAF&ECU
  44. hks dlii ignition system
  45. bolt size connecting hotside to o2 housing
  46. gap for my green
  47. First oil change.. used 5 quarts.. am I okay?
  48. best way to break in a clutch?
  49. Questions about some parts
  50. Evo Clutch???
  51. anti-siphon screen for EVO???
  52. SEXY Evo Red
  53. bleeding clutch
  54. Having Clutch Probs Need Help PLEASE
  55. Which fluids for ACD, Transmission, and transfer case
  56. Taking the T-Case Out...
  57. looking for evo 8 motor
  58. Fuel pump hot wire
  59. Need Second Opinion On Clutch
  60. 30K Service Fluid Color ....
  61. Green Dyno Sheet Review
  62. P0401.. not sure what to look for
  63. Springs/Retainers with Kelford 272's and 2.3 Stroker?? Need Advice!
  64. Clutch Pedal Adjusted All The Way Out
  65. EVO 8 question
  66. evo VIII ECU on evo IX motor???
  67. Cheapest way to reach the 350 whp range?
  68. Buschur or AMS???
  69. Wilson Manifolds California Spec v2
  70. Greddy Ti-C and AEM UEGO placement
  71. Need Torque specs for a 9mr turbo (20g)
  72. What numbers should I be making?
  73. whats wrong with my car?
  74. New Plugs now a lopey Rev
  75. Can't understand JDM Gauges
  76. Aftermarket Cams with stock springs/retainers?
  77. NEED HELP tcase problems
  78. 1000cc's, 93 = loss of drivability?
  79. MAF, need some help asap...
  80. Changed timing belt and now car won't start
  81. Hitting the rev limiter
  82. Evo VIII Oil Press Guage Install
  83. Fluids
  84. plugs
  85. Help/thoughts
  86. Improving drivablilty.
  87. Stock Clutch - Chatter when takeoff - Time to replace??
  88. Reving the stock bottom end (calling the fast cars)
  89. Clutch Advise
  90. cam gears
  91. valve springs or not
  92. 4G63 Buildbook?
  93. timing belt-like noise
  94. Indy/Wilson V2 Intake Manifold on stock turbo setup???
  95. Fp Green With Nitrous?
  96. timing belt-like noise
  97. Looking for a oil filter housing!! HELP!
  98. f1 clutch and flywheel: URGENT
  99. Hta35r
  100. brian crower 280 cam gear settings
  101. Changing your timing belt!
  102. Need help choosing a Evo Manifold to Re-Flange
  103. Rear diff clunks? What bushings?
  104. 5th and 6th Gear Lockout
  105. boost control
  106. Couple clutch install questions
  107. HELP clutch draging!!!!
  108. Rear engine mount vibrating
  109. Stuff you just gotta do while the motor is out...
  110. Switching BOV issue! HELP!
  111. f1 racing stage 3 clutch kit
  112. Boost issue question. Please help.
  113. new hks type r intercooler today
  114. Clutch problems?!?
  115. This is slipping rite? (clutch problem)
  116. Evo IX - vacuum levels at idle?
  117. Turbo Swap Question!
  118. ebay fpgreen, do NOT buy!!!
  119. so close to 400, is it enough?
  120. where can i get my stock ex. manifold ported and coated???
  121. Any Test Results For Indy/Wilson V0 Intake Manifolds, Yet?
  122. Humming Sound
  123. E85, John Shepherd, Buschur Racing and some good power.
  124. Boost Pressure and the correlation to WHP
  125. Throttle Body Question
  126. Yes, I am an Amsoil Hoe
  127. Gt30
  128. Bov Recirc question!!
  129. What do you guys think of this?
  130. What size intercooler piping?
  131. whats better with the gt3540-
  132. GT40r stockblock???
  133. Installed ETS FMIC now some issues.
  134. Oil level
  135. tranny, TC or clutch?
  136. Is the evo 8&9 thermostat the same???
  137. how bad is it?
  138. need comments on ferrea beehave for valvetrain
  139. Where can i buy a gt35r compressor wheel and housing?
  140. Need help with injen IC hard pipes + intake
  141. Quick Question: What trim is the Evo 8 Turbo?
  142. Max power out of Evo 9 Turbo
  143. AEM Wideband AF ratio
  144. Are Megan Exhaust manifolds and 02 Housings worth it?
  145. piston problem, head gasket, or valve seals
  146. Compcams 272 help !!
  147. Swaping TB's?
  148. Stalling and Idling Problems - No Leaks! What the heck?
  149. Thinking of running Evo9 Cams HKS 272 and 280 combo ??
  150. cossie m3s or kelford 272
  151. GM MAF aka Blowthrough setups w/stock ecu power?? please chime in!!
  152. MAF - Honeycomb
  153. Internal to external WG conversation?
  154. turbo boost
  155. FP Green + Aquamist, which kit?
  156. Removing t-case ?
  157. Cam Gains? Current Setup.
  158. HELP! Need Turbo NOW!
  159. oil consumption, 20% leak down and leaky valve guides: engine builder's advice needed
  160. lc-1 grounding?
  161. Engine heat issues after isntalling a strocker 2.4l kit
  162. evo tranny tranfer oil
  163. Not so smooth shifts......
  164. CAM Part #'s Anyone know the size of these?
  165. clutch pedal problem...
  166. ACD control
  167. Need a shop to install a clutch GA/TN Area
  168. FP Red install kit
  169. What next, 2.1, 2.2, 2.3 or 2.4?
  170. transfer case oil
  171. brain crower s3 vs cosworth m2.. worth $$?
  172. 450awhp Power Goal on 93oct
  173. My GT4088 set up fabrication (pictures inside)
  174. Picked my stuff up. COATED!
  175. my car won't start up right away. help
  176. which housing is better
  177. EVO 8 cylinder head
  178. cv shafts
  179. Buddy Club vs HKS Cams
  180. redline question
  181. Ambient Air Temps?
  182. 2.0L or 2.3L? for the gt40r
  183. An interesting dyno comparison of two EVO's
  184. 4g64 W/evo head head gasket
  185. stock clutch question.
  186. Peakboost or Mynes manifold ???
  187. greddy profec b problem
  188. greddy ti or ets?
  189. Power Enterprise Head Gasket for EVO IX?
  190. Help where does this wire go ??
  191. !!!!! reaching 550whp on hta35r?????
  192. Connecting the AEM Tru Boost solenoid
  193. hard to put car in gear
  194. intake problem?
  195. Intake Manifold Gasket HELP!
  196. Is it normal for your CEL light to just turn off?
  197. Machine Shop messed up BIG TIME!!!!!
  198. How much boost on stock internals
  199. perrin intake worth claims?
  200. 16g6 wheel power
  201. So i have Decided on an Exedy Twin ... any downsides?
  202. PO234 and PO300 out of nowhere?
  203. Evo 9 OEM spark plug cover
  204. Transfer Case had no oil
  205. Possible Dead Ecu?
  206. blow off valve question
  207. T case gone bad???
  208. E-85 & 1000cc injectors
  209. What is needed for a 6spd swap?
  210. is upgrading motor mounts needed?
  211. motor mounts?
  212. AWD Motorsports 700hp RS Build... 7-14 Days Total!!
  213. Injen LICP fitment issues
  214. Intake Inquiry
  215. Biiiig issue - stripped bolt in exhaust manifold (tried searching already)
  216. Need Help... No MO' Fuel
  217. Question
  218. Best choice of cams for my ix mr
  219. Catback size
  220. I have joined the dark side:D
  221. S1s on an VIII...Vid inside..
  222. Small mod ?
  223. BR exhaust vs ETS exhaust
  224. evo parts for sale
  225. Oil pump
  226. What does a IX need for a 10 ?
  227. Where!?!?!?!?
  228. Oil on valve cover, White smoke on decel, Dipstick popping up! Help!
  229. Resonators..how much flow...?
  230. Help with strange noise...please
  231. High Idle (with vid)
  232. BIG Electrical problem
  233. timing belt/cam install
  234. Anyone have the Jun BL Catback?
  235. problem after cam install
  236. AMS GT35R Kit. Is there ANYWAY to get a .82 Housing???
  237. 639whp/505tq evo 9 VIDEOS INSIDE!!
  238. Greddy Profec B
  239. Owens Development manifold on ebay!
  240. clutch issues...
  241. Little angels in the oil pan...
  242. Forge wastegate with red?
  243. Bucking potentially solved??? Weird solution.
  244. 8 turbo hardware, and 9 turbo hardware differences
  245. What else besides a GM MAF
  246. 1044 AWHP EVO 2 Dyno Video
  247. Sounds good but will it work?
  248. Piston and valve issue
  249. E85 vs Meth?
  250. Help...
