PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 [128] 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. FSM Download
  2. Cosworth M2 dynotune
  3. Drivetrain Question..
  4. Switzer 627HP pump gas 35R dyno video
  5. Dealer replaced your clutch? How much $$$?
  6. Getting the fluids in the tranny/T-case/Diff
  7. AMS's WICKED 23rr Install pix
  8. Fuel Pump Question
  9. Boost problems after turbo swap
  10. Exhaust Piping Diameter Question
  11. vacuum hose - Need Help
  12. Full Race Twin scroll Results!!! GT35r
  13. Turbos
  14. Sparkplug Help
  15. boost problem. please help
  16. Full Race Twin Scroll Data
  17. Does it matter which springs,??
  18. The quest for for the pump gas record
  19. Installed new guages, WTF
  20. O2 Sensors on Espelir Downpipe
  21. First time changing TC fluid.
  22. what the 4th gear?
  23. 553 whp, 93 octane, just another day at the office.
  24. Question about replacing the turbo oil line-oil pan crush washers
  25. starting to think somethings wrong
  26. Car Fluid Alternatives
  27. upgrading turbo question
  28. Evo IX BOV stop leak mod?
  29. Aluminum undertray thickness?
  30. Noticed something about my shifts this morning...
  31. New Forge Spring Kit today - Any advice
  32. knock caused by dampner
  33. Got the cams now what to expect?
  34. Dumb question
  35. Evo 5 speed vs 6 speed help please
  36. Need help and opinion
  37. 2.3 guys how do you like your turbo setup?
  38. Zaklee shifter bushing install?
  39. 03 evo transfer case
  40. Does the Greddy Evo 2 exhaust taper anywhere?
  41. Wiseco-Eagle build...Pics inside!
  42. Greddy type s Problems :(
  43. engineers please answer
  44. ***DTM T3 Twin Scroll Results for 83MM Turbo***
  45. How to repair crankwealk?
  46. Time for Clutch...ACT HDSS or Exdey Twin plate?
  47. Where can i find Turbo Manifold gaskets.
  48. What does this add up to?
  49. new cosworth cams? cleaning?
  50. This ever happen to anyone??
  51. Photo's of my Green install
  52. E85 481whp Stock ECU and IX turbo
  53. 10% Ethanol
  54. Clean My Pistons????
  55. Are springs and retainers really really!!
  56. *vendor* Testing & Product Overview Since 2003
  57. 2 World Records Set Today!
  58. Boost Gauge ?
  59. I have OIL LEAK somewhere<<<<<----Please Help!
  60. 5th gear grind?
  61. Turbos on pump gas
  62. new turbo purchase
  63. RC injector lower seal fitment
  64. Engine swap question??
  65. Where do I mount this O2 for my WB ?
  66. What Turbo did I just buy ?
  67. Reusing the stock crank??
  68. Car will not go into gear when its running.
  69. Finally its here Buschur hta 3076. 82 turbo kit
  70. ETS 3065 kit installed with pics.
  71. need some turbo knowledge? any turbo scholars out there?
  72. Alternator bearings?
  73. Recommendations for HFC/Super Catalyzer
  74. 5th gear grind?
  75. Keep Blowing Fuse Number 8 - Help
  76. porting exhaust manifold
  77. best way to clean out Intake manifold
  78. Maf adapter + cone filter = low boost???
  79. Misfire at idle
  80. hks upper hard pipe w/hks bov.
  81. help with transmission leak :(
  82. Finally found my p0171 issue!!!!!!
  83. Gt3037R turbo o2 Housing
  84. New motor and all
  85. running rich?
  86. bov/diverter valve??
  87. Ok to install walbro 255?
  88. Twin Scroll kits
  89. Camss??
  90. What the dealership said:
  91. Misfire at idle
  92. Uicp pipe help
  93. To keep or not to keep...HKS 272 or 280s???
  94. Shameless EvoScan Gauge Layout
  95. Anyone use Motul trans fluid?
  96. setting the timing
  97. Evo 8 Forge wastegate on an 9 turbo
  98. ACT HDSS clutch kit or DISC suggestion
  99. Universal Fit Cold Air Box - [BINARY]
  100. RPM jump then drop/Boosting then Dropping
  101. Will this help shield heat??
  102. Tranny Alignment
  103. lifter tick
  104. bad sound after 100 in 5th gear
  105. Timing belt jumped - PLEASE HELP!
  106. Im Stuck/Lost
  107. Ridiculous lack of testing from Vendors
  108. *NEW* tune w/ cosworths
  109. Rear diff prob...
  110. Bad Bish Is Sold!!
  111. Axel output shaft Drivers side
  112. Alcohol Injection specific question
  113. 06 Evo, looking for ACD pump
  114. stripped dp bolt...
  115. Exhaust smell inside
  116. Evo VIII vs Evo IX : tuning potential
  117. Just got My EVO IX tuned with GSC S1 cams
  118. Just got My EVO IX tuned with GSC S1
  119. ams vsr gains??
  120. What power should I expect with this mods?
  121. cam question?
  122. Slipped out of 5th Gear
  123. I gots Mynes today :)
  124. Idle and a/f question
  125. My car feels jerking/hiccup a little bit while cruising...Is it my MAF???
  126. Cams for a 50 trim on 93
  127. Request for Tanabe SMH exhuast
  128. Who makes this turbo?
  129. Buschur cams with a Green???
  130. 780's or 1000's
  131. Lean A/F at peak torque?
  132. Dipstick....
  133. COBB accessposrt p0171 + p0300 fix ATTN: U2SLO
  134. hta 3076
  135. 2-step after blox front engine mount
  136. where to buy .82 housing?
  137. CYL 1 and 3 are DEAD!!!
  138. What's wrong with K&N Typhoon?
  139. need help please
  140. The quest for the record.............
  141. what turbo should i get
  142. Exedy Twin HD
  143. opinion onthus turbo and exhaust setup
  144. Coast Fabrication
  145. flywheel bolts stuck!?!?!?!
  146. pulsating suction sound from my blitz sus open pod during WOT
  147. front LSD = stronger Transfer Case?
  148. which mivec cams work best for evo ix?
  149. do i have everything
  150. Need a new clutch
  151. difference between 8 and 9 turbo
  152. Tial Bov
  153. Brian Crower Cams
  154. WHP goal question ( Evo 9)
  155. ACT clutch
  156. e85 and 1200cc injectors
  157. Just got retuned at DTM
  158. Buschur Racing's newest project, higher mileage EVO under the knife.
  159. Part interchange manual.......clutch slave cylinder?
  160. i am stumped
  161. Bad clutch maybe?
  162. The Answer To my very wired problem...
  163. Best MAF pipe?
  164. Just installed Exedy HD tiwn disc, should I remove the restrictor?
  165. Why not all 20G's are equal
  166. Benefit of Factory Air Intake Duct?
  167. Leaky VIII and MR BOVs, is this normal?
  168. HTA on a TS
  169. So, I changed my tranny fluid today and found...
  170. Agency Power
  171. Occasional lag/unresponsiveness
  172. Tial exhaust housing for turbo?
  173. Buschur HTA 35R help
  174. Shifter Question (seems stiff)
  175. Help
  176. 35R Coolant Line Hookup
  177. M3 Cams Results
  178. Got my PPI ported coated hotside :)
  179. 670 AWHP Daily Evo
  180. Biggest Turbo Kit that has no lag, stock spool ?
  181. Evo4 4WD stuffs onto 1.8 4G93 GSR CM5A
  182. Just made 1201 whp!!!
  183. Most Accurate Boost Gauge
  184. Oil light flicker fix
  185. Evolution IX MR 6speed
  186. what to upgrade on my evo 8 turbo?
  187. Car shakes when engine starts
  188. Finally Installed my LICP
  189. warranty issue!!!
  190. Minimum Stock Flywheel Thickness
  191. Installed Cams and tach is not working. Any Ideas
  192. Options for Upping the Boost on My IX
  193. MR won't shift into 6th gear?!
  194. Engine Stuttering/Farting when punching it in 3rd gear?
  195. How long do the ARC filters on the induction box last?
  196. Greddy Profec B-spec II
  197. Buschur Mustache Bar install
  198. Best Turbo Upgrade for my stage 4 VIII under $1000 ?
  199. AMS 1000 HP Fuel System
  200. BOV replacement
  201. how to change driveshaft
  202. Need More Fuel!
  203. HEAD REMOVAL..Some ?'s i need answer too
  204. Evo Balance shaft
  205. 1062 WHP - back tuning on the Dyno Flash Evo 8
  206. Turbo fitting problem
  207. engine "knocking" noise diagnosis
  208. Real quick questions please about Exhaust
  209. Megan test pipe bung location
  210. Gt3065 on Stage IV IX - 2.0 L vs 2.3 L
  211. O2 sensor output
  212. how do i log aem uego wideband to evo scan
  213. installing bigturbo and driving untuned
  214. Help with P0441
  215. 6sp Transmission problem
  216. HTA 35R Coolant Lines
  217. boost question
  218. need an opinion on clutch
  219. idle problems
  220. hesitation problems! i need some help
  221. My last dyno before going Green
  222. first mivec s2 on fpgreen
  223. Would you Recommend this DP?
  224. Needs some help from you tech heads
  225. DC sport downpipe install
  226. Injector Upgrade Advice
  227. Evo 9 FQ...
  228. 1081whp 41psi best so far. More to come next week
  229. black smoke??!?
  230. Help!!
  231. Which Wiseco's for 2.4/evo hybrid swap?
  232. tranny problems
  233. Need an opinion
  234. What Valves to buy?
  235. Is it ok to use a mityvac to bleed the clutch?
  236. weird noise from head
  237. I'm looking at getting a boost controller.
  238. Arc Vs Ams, Etc Ic
  239. 1st pull 28psi 813whp 2nd pull 983whp 679tq37psi WOW just started!!! Going to 55 psi!
  240. Wastegate Pressure Help
  241. Greddy Profec, wtf?
  242. full race ebay knock off!
  243. Best Way to Make 500+ HP Street Car... Wish List
  244. 50 trim dilemma
  245. need quick advice
  246. Need some info guys...(turbo specification)
  247. More lightweight parts to keep the differential in place
  248. While My Engine is Out??
  249. Best price on a Perrin 3" HFC (high flow cat)?
  250. Power Discussion
