View Full Version : Evo Engine / Turbo / Drivetrain
- GM 3 port BCS fluctuation
- 5 Speed ACD Trans.
- Universal K&N cone part number
- Fp Green turbine housing size?
- Fp Green turbo hot side
- Anyone get the shep stage 3 transfer case rebuild?
- EVO X BOV for EVO 8
- Need help finding out why my car stays in open loop???
- MostWanted's --- NEW --- BuildUp - Part ..3..
- my vacuum has been dipping really low?
- my external wastegate on stock turbo!!
- Boost Leak Test Results
- Drive w/o Transfer Case (temporary)
- Anyone using the ams ss lower clutch line? Feel a difference? Worth the 26 bucks?
- Stock Injector Mod?
- Buddy Club 272 Cams Info Needed!
- looking to switch turbo
- Greddy Type-m Intercooler?
- do SS clutch lines and removing the clutch restrictor make a difference?
- HKS 727's without cam gears?
- Which turbo kit would you choose?
- 2.3L Stroker from where???
- Buschur Race FMIC with ETS piping?
- ayc diff blown, need info on evo 8 n 9 diffs
- 5 bolt downpipe gasket?
- IntercoolerR BreakdownN
- Anyone tried the new Tial Recirc. Bov/
- 6 speed short shifter
- Tips for starting new motor??
- ACD HELP please
- Trans noise...bet ya cant guess what it is!!
- My Build project (Sort of build) Fp Red etc. Input Appreciated.
- stroker sounds like a diesel care to diagnose
- 28 pounds no meth!
- Turbine hotside ports bigger than gasket
- Whats the ideal spark plug gap for EVO 8, 50 Trim 30 PSI, and HKS DLI2?
- Starter relay wire?? Which one is it?
- AEM Twin Power settings on 300m coils and stock ECU
- exedy clutch
- belt size
- shifting gears
- Car problem after IC & intake install
- Getting ready to install my o2 dump
- Exhaust Rant/ Need help finding a shop in Salt Lake City
- is this the awful transfer case whine?!!!
- Buschar strokers use oil?
- V Band Bling
- How much of a gain will I see???
- Making COP setup, need source for Male connector
- stupid freeze plug
- Another boost thread
- AMS base shifter bushings
- need some help!
- Mods for my Evo IV
- Top Mount Manifold Question?
- Whereto have a head Oring'd
- oem diverter valve: silver top and gold top differences?
- PiPlease help.!!
- water + tubular manifold = bad??
- Car dies after walbro install
- Routing for GM 3 port and ewg
- How to fixp0420 code Need help !!!
- GREDDY SPEC V question
- my intake cam snapped?!!?
- Is there an N/A new style 4G63?
- Help! Brand New Engine Out of Oil!
- best combination?
- GT35r tuning ?
- best turbo for 2.3L
- Replacing Headgasket
- acl race bearings main
- Best hose clamps for stock UICP?
- Donation fund for Razorlab to test Twin versus Single Scroll
- Thinking of Stroking my Evo 6.5 Need some advice
- T-case Opinion
- Trans.
- torque specs using arp
- Transmission diagrams (inside view)
- Drive belt making alot of noise!
- Yet another head oem head gasket thread.. Share your personal abuse stories.
- Okada coils
- T3 Full-Race manifold doesn't fit my HTA37R ! ! !
- Manifold Question
- Shelf life of diaqueen?
- any experience with V bands??
- ? For all running AFTERMARKET turbo
- Wiseco HD piston to wall clearance
- Crank Pulley FELL OFF WTF!!!
- Retarded Rich AFRS with new mods
- drivetrain clunking in reverse?
- Leaking oil
- Universal rear 02 sensors...where to get them?
- Boost and Idle problems?
- Intake manifold, reinstall help etc
- Not building full boost..
- Evo 8 to Evo 9 Turbo
- help need ideas
- Eagle's Conrod For Evo 6 TME
- Whats wrong with my AEM Wideband?
- Snatch
- Mitsubishi dealer never heard of Diaqueen?
- SRS Light
- new mods, no boost??
- Oil cooler Position info
- Any of you with block heaters have problems blowing seals?
- Porting the Exhaust manifold?
- Vibrant maf adapter and amsoil fiter?
- Boost Issue
- Transmission Life ?'s
- 10.5 hotside + EPM O2 dump problems
- Extremely Loud Walbro 255 Fuel Pump...
- What did I do i have no boost!!!
- some pics of an HTA35r compressor housing with an HTA30r compressor wheel
- banged up evo...
- What Should I Put Here?
- Cbrd bbk
- clutch restrictor pill removal
- Best Short throw Shifter??
- am i screwed
- Is this true..
- boost question
- service engine light after car wash.
- Help me delete this...
- Evo 9.8cm or 10.5cm turbine?
- Drop in rods and pistons
- Injen Downpipe
- 6500rpm 2 step?
- Before my 1st tune.....
- what is this actually for?
- Where to get o2 sensor
- Injector sizing help
- sensor question
- Cam Gear adjustments?
- Size of damper bolts?
- clutch job need help!!
- FP RED on a V RS
- Blown/Torn Injector Rubber O-Ring?
- ETS IC any good?
- engine replacement
- installing ETS intercooler
- Help Decide on Turbo
- Helicoiling?
- external wastegate help
- hks stamp on evo9 mivec cams missing?
- Major tranny problem
- Very Strange Idle
- greddy M spec
- Fp red cost
- AC DELCO O2 Sensor Part Number?
- greddy type s bov prob
- 10-second, Full-Interior Evos That AutoX / Road Race?
- ACD Help
- Stalling problem- help!
- ACT HDG6 Users, needed your opinion
- We swapped out .63 37R for .82a/r 6262 on AMS manifold...pics inside!
- where i can get just one apex ev1 coilover?????
- 10.5 hotside on 8 turbo vs 9 turbo
- Question on stock air box modding
- OMG catch can thread!
- Best 1000cc Injectors
- AEM Tru Boost Tuning ..... advice?
- Is $700.00 for timing belt, water pump, and seals a good price
- Stroker Advice
- Best way to clean up a rusty block?
- Question for all u.
- Knocking sound....please help!!
- Evo 9 first gear really worth it?
- question/favor please
- DV Flutter Solved! not BOV, not what you want to hear
- Help arp rod bolts torgue value
- Just installed a new Clutch .. now it makes a noise any advise
- Air in clutch line?
- Boost leak??!
- $1,200 to fix a 5th gear at mistsubishi dealer ?
- Exhaust Wrap on a o2 Dump
- What is the best intake filter to use with fp red to help get the most power out of t
- ETS, English Racing 2009 Drag Evo Revamp
- Head gasket
- scratches
- ewg setup???
- noise after clutch and flywheel install
- What does this connect to?
- Some things I did over winter...
- ECU Help (HKS V-PRO)
- Catch Can
- fp green taper
- Turbo PROBLEMS, HELP!
- no spark on cylinder 1 and 4
- temp gauge video
- Good Place to Buy Die Grinder Bits
- p0300 break up in 5th on highway
- What type of Octane you feed your Evo
- after how many miles?
- Question about intercooler spray on 04 Evo GSR
- overheating...
- Turbo Upgrade
- smoke coming from exhaust
- Jun 272/S2's
- Knock Problem
- White rabbit need help
- best clutch
- Driving untuned?
- driveline slop...
- JE Pistons
- EVO 4 turbo manifold
- How often do you miss shifts?
- Holy Engine
- Running richer and richer...
- fp red or 35r
- boost leak?
- bleeding the acd
- Anyone interested??
- evo8 newb problems
- LSD front diff. pre load value?
- Oil leak on my Rebuild Engine
- 5 qts Mobil 1 Incl. Ext Perf Synth and Mobil 1 Filter $29.99 Until March 25th
- Which UICP would fit Perrin Intake? Nisei, Buschur?
- PTE injectors.
- help needed: cylinder #2 injector not supplying fuel
- White Rabbit need help....
- 2.0 Build
- Please help! Td05hr-16g6c-10.5t
- Not sure if head is built or not.
- Fluids ?
- What CEL Code
- need a pic of evo 8 viscous
- New APS BOV Stuck Open?
- What would you do? Turbo Upgrade ~
- Tranny/Transfer case problems?
- evo 9 motor in an evo 8???
- What direction does your rear swing?
- Need help on decision
- White Rabbit turbo making more noise
- Cannot put into 6th gear !!Argh!!
- Stock Evo 9, larger FMIC... any problems?
- ets or buschur intake pipe
- which one for trans?
- Idle idle idle... 1000 rpm to 500 and then back
- What should I convert a mirage into
- Encountered a problem. What you think?
- stock pistons??
- what weight oil do you use?
- Fuel Pump Install Kit
- Help: all three ACD lights are on
- Did I bust my center diff?? Description inside.
- Popping sound when turning left
- Need help!!!!
- Crank Sensor CODE
- Leaking front axle seal someone help!
- Need Advice for Timing Belt Replacement
