- Evo 9 turbo install kit for Evo 8
- Next up, turbo upgrade. Need help choosing between GT30/GT35R.
- is my clutch slipping?
- Car falls on its face during boost
- E85 + tuned for 93 octane = boom?
- RNR Turbo Kit made POWER with a DynoFlash tune!!
- Challenge: Who has a solution to my stall problem??
- Clutch issue
- turbo question!!!
- Ticking?
- ACPT CF driveshaft ??
- 37r question
- transfer case
- Quick question on the 3065
- New Set Up What Will I Make Whp??????
- cry about puck clutches.....
- my power curve...** :) **
- Anyone have experience w/ VP "Q16"
- Need advice on a problem.
- FPgreen or Full Race 30R twinscroll or other?
- Whine in 1st gear
- Rotational noise and vibration
- 2nd gear prob's!!!
- Just getting ready for BR 35R
- 480's-500+ whp?
- Could front drive axle be going bad?
- Wondering what the differences in the a/r and the hot side a/r (Ibelieve) are ?
- Hollow out HFC?
- Where to buy GM MAF blow through kit ?
- So i went over to Extreme Turbo Systems today( Wife not knowing)
- Jdm Oem Map Sensor
- Pure Tuning Evo IX Cosworth Cams Dyno Test
- Smoke on left turns only?
- Huge boost leak!
- Which Boost Controller is BEST?
- Looking to go with Speed Density Set up anyone know where to find ?
- Help please.......ABS/Speed Sensor help
- To all GT35r turbo owners
- sitting for 3 months, bad gas?
- Fuel Pump Noise...
- test pipe vs stock cat??
- Question for those running aftermarket intake manifolds.
- SWITZER TUNED EvoGreen, E85, 439HP/454TQ
- need some info on clutch upgrade
- Brian Crower IX cams, anyone?
- HEEEEEllllllllppppppppppp the mechanic is working on the car right now... HEEEEEELLPP
- exedy twin disc...i hate it
- Exedy twin HD Installed
- Rod bolts to instal or not to instal?
- emissions question???
- Q. for anyone w/ buschur moustache bar
- HFC....Any quieter?
- HELP code p0355 and p0340
- help on engine build
- SES light "E" - code (shift solenoid)
- AMS recommended Redline, i'm a bit worried....
- Best Buschur mod...new bullet muffler with a Magnaflow
- Air/Fuel Ratio
- 20GLT (fpgreen) dyno sheet from this weekend at Buschur Racing
- Which 35R Kit is Best? !!Make Money No Issue!!
- Oil cooler lines
- Looking for Tuner in RI anyone know of anyone ?
- Y-Block Location for Parallel Fuel Systems??
- code P0505
- new studs and gasket
- 810awhp on Superflow Dyno
- need help choosign a exhaust
- blown turbo......looking to upgrade
- Help out a Soon to be evo owner!!
- BOV/DV question..
- need advice on what to do next
- Power Steering Fluid??
- Royal purple to cause damage to T-Case?
- HELP! Stroker with a Lifter tap
- Exhaust Choices
- Can sum1 Explain ETS H Cover Turbo Kit ?
- ISP Racing 35R Kit anyone have any Input ??
- hks hipower and helix dp
- *It's Installed...ETS 50-Trim*
- Damaged front diff autocrossing?
- What can a 2.4 engine really be reved up to without failing.
- white smoke
- Clutch Pricing??
- Can't hold boost!!!
- Void Warrenty?
- HKS EVC V Help
- Buschur 35r lag video........
- turbo, evacuate! evacuate!
- HELP!!! Evo is not boosting.
- Upper Intercooler pipe.
- Works Short Throw, anyone using it?
- 35R at 26psi on stock block
- P0171, bank 1 lean
- EVO IX redyno 364whp new run 12.1@113
- Cold start idle issue
- 5th gear grinding????
- DSM equivalent of this turbo?
- Any One Try The OS STR Clutch
- Blitz SBC on stock evo?
- safe a/f
- valve cover ? v. powdercoat
- questions after manifold and 02 install
- Car sputtering and breaking up in between shifts
- Buschur Magnaflow?
- Car idle problem *HELP*
- Oil light / knocking question. looking for opinions
- Should I stop shifting 5th gear???HELP
- aftermarket trottle body with stock ecu
- lost all boost is drivng safe until fixed?
- Help EVO ticking like crazy!! PLS Help
- FP Green install questions
- Hesitation
- How to drain all the Transfer Case Fluid out?
- White smoke after WOT lift off
- jun 272 or tomei 270
- Find turbo peak efficiency?
- aftermarket lifters?
- another pump not priming
- Which option to retain power?
- EVO IX - Ivey Re-Tuned for HKS Cams
- DC Sports exhaust manifold cracked
- SSAutochrome's internal wastegate o2 housing dump.
- another turbo down?
- Boost problems after reflash
- Average downtime from BR for mail-in flash..
- Christmas in october..
- I want to run a antilag setup on my evo 9, what do I need?
- Water Overlow
- Boost problems
- What is the safest way to start a new engine?
- Forged High Compression Pistons in 4g63T do able ? and worth while ?
- 4g63 Block; 4g64 Crank; High Comp. Pistons ?
- Intake questions for '03 Evo
- Is there a specific FP turbo that out performs a diff. FP turbo
- 4g64 Crank and Stock 4g63T Block good combo ?
- Hondata Heat Shield
- same clutch on 5 and 6 speed?
- best "street" set-up?
- 2nd gear lockout
- Oil Change? Octane Boost?
- 1014.53WHP! & Learned the limits on Twin Scroll Exhaust Housing
- Couple of stock block FULL FUNCTION EVO's and a 2G DSM
- DC Sports Cat-Back
- Hard starting and I smell gas!
- Tilton Clutch causing wheel hop?
- High Oil Pressure, Help!!!!
- Modding opinions before purchase?
- HELP!! oil light came on
- I opened my cam gear cover and i saw....
- APEXi AVC-R questions
- Installed new clutch now I have ?s
- Springs and Retainers?
- intake dilemma
- AMS mini radiator weight w/ fan?
- Buschur Exhaust?
- 690AWHP@30psi
- Greddy Type-S Leak
- HELP fuel injectors not sealing at fuel rail
- Low octane, stock consequences
- Built motor time---> pics inside (56k no way)
- Any one look into the Forced Performance GT3082R Ballistic Concepts Turbo
- Evo V rack & pinion
- AMS has changed the Drag car yet again
- turbo needs
- is it common?
- Is this Worth it? Intake question
- wtb ac or pass seat
- New parts install.
- IGR7A-G vs BPR7EIX
- Can someone explain clipping a turbo?
- Dyno Tales: EVO8 351hp/354hp on pump (stock cams)!
- injecters help
- FP Green Turbo versus FP Red Turbo
- cam inatall IX how knows how
- Which stainless clutch line did you go with?
- vacuum loss at idle after LICP/UICP install
- Anyone ever look into water to air intercooling ?
- Im finally 100% satisfied with my evo...
- Hks rail off Ebay i think its not for Evo
- Need help! overboosting!
- turbo swap VIII to a IX
- Highest trap speed from FP Green on stock longblock and ECU???
- Front O2 sensor - Did it change from 8 to 9?
- lots of noob questions. intake bov ect.
- Evo 8 Head and ECU swap with Evo 9
- Buschur Racing's black EVO with new dyno record just in time for shootout.
- ethanol and high compression
- A reasonable clutch for a daily driven evo 8.
- For those with Exedy twin disc HD
- Release of Oliver's new, stronger rods.....
- Greddy Profec A/ Question?
- Best Shifter Lube
- Beware Of Garbage Gasoline
- Which UICP works with ARC induction box?
- Coolant leak? Advice appreciated
- QTP Downpipe, short review
- ralliart clutch??
- Balance shaft removal how to?
- evo ix boost ?
- My setup
- Vendors Who Sells Magnus Inatke Manifolds CHEAP
- Which exhaust combo?
- cam combination
- Tried searching with no luck..Need part #...
- IC Piping Diameter.. how it relates to power?
- GT3540R, pump gas, and stock cams...
- Which side does this gasket go on?
- The Ultimate Evo 8/9 Transmission Failure Survey
- RACE FUEL and BOOST
- green and 20 g LT the same?
- Good 02 housing?
- Cam question
- Problem with idling on a hill??
- Needed: Photo of coolant overflow bottle bracket
- flywheel comparison?
- Wheel speed sensor?
- How to remove throw out bearing from pressure plate?
- how much extra power can i put down with clutch and uicp?
- timing and cam R&R for 4b11
- Thanks FULL FUNCTION for 527 AWHP on Mustang Dyno
- IC Piping?
- Rear Diff/Mustache Bushing
- just a bit more power,....
- ATS triple carbon squeaking sound in startup
- How much power with my mods and what next??? please help!
- boost problem..Please read????????
- Evo IX MR diverter valve?
- Exedy twin...kinda problem..
- FP green turbo worth the price?
- HELP! Big oil leak and car doesn't want to start...
- Is a 20g worth it???
- HP gain????
- Car was driven with the park brake on for a mile or so...
- lost 3rd gear.....
- Where to get the clear things on the end of the injectors?
- o2 sensor wire ripped!
- How to install Greddy type S bov on evo
- 384 Hp / 396 Tq 100 octane!
- Triple carbon clutch woes
- I just re-made 400 WHP on 93 oct @ 22 psi w/FP Green
- Is it ok to dyno in FWD mode?
- 362whp/363.77wtq pump gas Evo IX!
- Which way does the 4g63 engine spin?
- dc3 oil catch can the best out there?
- Recirculate or Atmospheric Dump?
- trans or tcase problems?????
- Toluence
- All You stroker guys..What is the best way to get 2.3 liters
