View Full Version : Evo Engine / Turbo / Drivetrain
- Buschur Racing Fabricated Intake Manifold
- Twin battle: Exedy vs SPEC
- New Evo Owner needing some advice
- Can this be done evo 8 with mivec
- In Need Of Help
- Should I radius this edge?
- Beatrush Undertray And Aftermarket Intercoolers
- Exedy Twin Rubbing Sound
- Which turbo kit is this?
- Drivetrain??
- Oil Pressure Reading
- Evo 5/6 RS diff to replace AYC diff
- Reminder - Check Your IC Piping Couplers!
- Interesting case of problems on the dyno
- Best drop in cams...
- E-85 setup, not hitting 11's
- Anyone have a Walbro that wouldn't prime?
- O happy day
- Fuel System for e75... run out of fuel @ 32 psi..
- Turbo problem/suggestions
- Clutch help!!
- LSD Diff
- Spark plugs on e85
- 03 Evolution 8 Motor Question..
- TPS cel? bov?
- Well... i'd like some advice
- stock evo 8 tranny
- Balance shaft delete
- backfire/popping
- percision 1200cc
- Downpipe rub: Get tie rod spacers or kart boy hangers?
- oil light check help
- question about HKS 2.3l stroker
- compressor wheel-housing clearance
- IX plugs and ignition for 650whp
- Whine when turbo spools?
- Help: hallman MBC
- Weak spark - any test for coils?
- shifter is very stiff in neutral
- What Weight Oil Are You Using
- T-case rebuild kit
- New fuel system, Aeromotive/Injector Dynamics *PICS*
- TPS cel? bov?
- Swapping clutch discs
- 2.3L Crankshafts?
- Oil leaking from temperature sending unit
- wedge collar popped off NOW WHAT
- found this under my hood!!
- 700 whp maybe ?
- Buschur Dual pump, how much power?
- T case with LSD crush washer
- Anyone have good results with BC cams?
- HELP!!! Torque tube broke do I need to pull the whole tranny to replace it. Help!!!!
- New Exhaust Preview
- megan racing 3" turbo back or ?
- only running on 2 cylinders
- Blow Off Valve Question
- High RPM hesitation-HELP!
- clutch!! pita
- AMS Hardpipes?
- Donut Gasket help
- help please i have a tick!!
- bad oil pump
- HELP!! Whining noise at 50-65 MPH in 5th
- Tranny Install
- Major issue need help!
- HELP REMOVING HEAD FROM BLOCK please !!
- Build Suggestions-4g64
- cam gears
- Front drive axles need help!
- Higher rpm...into 5th grind
- Best Tcase solution?
- cel codes p0300 and p0420
- Easy 315awhp possible??
- turbobackk no tune
- Somethings in my intake
- sputter plz help a newb
- 2006 evo 9 rear diff acd or no acd ??
- Upgrading parts?
- Swain Tech Heat Treating Vs. Ceramic Coating
- Help pls. Huge problem.
- Tranny Swap
- new rods and maybe pistons
- Engine Rebuild Advice
- Tanabe Medallion
- Mobil 1 5w-30 time to change?
- please help!!!!!!!!!!!!!!!!!
- Opinions on a good turbo for a 2.3 liter stroker.
- can i get a T/S hta 3076?
- cams
- do i need to get Exhaust gaskets
- Looking into my O2Housing...
- Clutch hydro problem, I have tried everything. Need help!!
- Evo 8 Valve Question...
- RS LSD Diff - who do I turn to?
- 10w40 for 380WHP
- stock evo vacuum????
- FP RED 64mm VS 80mm
- Need some help with head removal !
- Does my Evo sound Right (sound clip)
- need help tranny? misfire?
- Need Help!! What is this?? Pics inside
- injectors install?
- help identify this cam
- Ultra-High RPM Dual Valve Spring / Titanium Retainer Set
- exhaust leaking at most joints.
- Best clutch for a dd??
- Exedy Clutch Question
- High Compression Engine Build
- Seriously confused about spark plug gap
- Knock up top with HKS 280's on stock turbo
- MAPerformance BS
- Having Issues with my car..
- E85 or Meth- Which is a cheaper setup?
- Cuts out at only at WOT
- An Affordible O2 Housing w/ External Dump? Fairy Tails and Make Believe?
- Intake Pipe!
- Valve train noise?
- what's next?
- Bent LICP
- boost gauge?
- Turbo not boosting
- wedge collar trouble
- Clutch not engaging or broken trans
- Clutch won't engage?
- boost issue on my buddies 03 Evo 8 GSR.
- Compressor Wheel is White and Pinkish???
- It sounds like a counter (clicking)
- Blown turbo?
- need help
- Vacuum hose size?
- 2010 all out build
- Boost compression (what affects it)
- Which turbo to gain 400hp atw on pump.
- Does jm fab o2 dump cause boost creeping?
- four channels egt monitor
- Major clutch problem! Help
- '03 Evo 8 running warm, possible causes?
- Help Needed ASAP! Car not running properly!
- Evo 9 MR tranny
- only boost controller
- 80mm fp red speed density intake choices?
- Hks gd pro twin clutch install help
- Clutch engagment changed on me.
- Nitrous kit questions
- Intercooler comparison
- The EVO IX Transmission Upgrade!
- A Bass Ackwards question.. Can you make an evo8 N/A?
- clutch master bango bolt, How do you tighte /loosen??
- Help!! oil leaking.. but from were?????
- Help! Need new clutch.. Suggestions!!
- 06 mr finally where i want to be 430!
- Boost Spike And Running Lean
- Help! Cant get transfer case out!
- Why'd these rod bearings spin?
- Cost to tune an EVO-VIII
- mobil one tranny fluid
- has anyone run the act MB7-XTG6?
- Weight reduction mods
- Who makes a better wideband kit? AEM UEGO or Innovate LC1?
- replace transmission housing
- Exhaust hanger broke off, left hole in exhaust.
- What is this?
- what boost controler are you using
- Loudest Recirculated BOV
- Car Killing Batteries?
- Gt2876r
- ACT you bastard
- Cam and Springs question
- clunking when i shift
- best way to make an evo stock appearing mid 11's on pump and stock catback?
- Idle Problem?help
- HKS Valve Springs and Retainers
- Whine but not TC question
- boost leak problem
- buschur double pumper
- i need internal/upgrade help
- help evo 9 idel rough and code p0300
- Kelford 280/272 is actually 280/276???
- When 4.0" Is Not Big Enough!! We have 5.0" and 6.0" Intercoolers!!
- crank replacement
- Does stock fuel pump whine ? way to identify walbrol
- Possible overboost? not sure need help..
- Apm Sponsors DG Motor's Drag Evo 8!!!
- TB shaft seals
- Buschur Intercooler help
- Copper Spray on Headgasket - Yay or Nay
- Walbro Problem EVO VIII
- JDM Evo with twin boost solenoid setup
- Grinding and Popping
- Ebay/Custom made Straight pipe.
- Exedy stage 2 clutch noise
- Which battery?
- big problem after filling up with gas
- Is acd pump considered a "drivetrain" part?
- Evo won't take gas
- Electrical Problems
- Best compression for e-85?
- Boost leak help
- Anyone using FIC Bluemax 1650cc inectors?
- 35r 2step boost???
- Boost gauge question
- Cusco front power brace with ARC intercooler?
- In need of assistance...
- New Exedy Twin, rattling when disengaging clutch
- high idol lean wideband
- Will a 3" intercooler be enough?
- coolant leak at TB side under hard acceleration.
- Exedy Hyper Single
- brian crower 288/288 cams?? mivec delete? injectors?? throttle body??
- Plz check out this engine bay!need help to locate engine parts
- ETS 42R Turbo Kit w/ Full Size Radiator? AC? and Power Steering!
- ETS Mitsubishi Evolution 8/9 Custom Vertical Flow Intercooler
- ETS Front Facing Billet 6765 Turbo Kit w/ V-Band Housing!!!!
- Recirc BOV's above 28PSI, info request
- What is this noise????
- What shifter bushings to get?
- Issues With 2nd Gear
- Anyone have a back door intercooler setup?
- ATF in the engine??? ; (
- What is E85 & How does it increase HP ?
- Cel codes p0133
- 60K service aftermath....
- gsc s1 cams on my evo 9 with red
- Maintenance
- update on my lifter noise
- p0441 and p0011 after clutch install
- motor help
- Evo v conversion.....
- noticed t case HOLE during clutch install
- Fitment question
- Need opinions on warranty..not voided????
- transfer case death whine
- Smoke After Boost Leak Test ??
- 50trim turbo question?!
- Quick Question, Evo wanting to stall
- Choking at high boost
- Balance Shaft Delete
- honey comb @ 28 psi
- Finally building 2.0L
- blown turbo
- Exhaust stud size?
- HOW TO eliminate BOV boost flutter?
- Injectors for HTA Green? plus other mods?
- help
- Emissions issue....
- Jerking issue
- Whining..?!?
- Closed Loop Boost Control
- Red turbo
