PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 [242] 243 244 245 246 247 248 249 250 251
  1. Loud whistle and boost drop help.
  2. what are good temp readings?
  3. Help! my EVO feels slow...
  4. ACD AYC install
  5. Vishnu Standard Exhaust - Audio/Video
  6. Turbo/octane
  7. ACD conversion from Viscous
  8. Lets get a definitive...Maximum Boost
  9. In for Service :(
  10. USDM EVO HKS Hi-power
  11. Problems w/ the Gas Gauge
  12. performace after HKS RS intake
  13. TurboXS RFL BOV
  14. Hi-Flow cat
  15. Nitrous oxide system in EVO...
  16. black smoke????
  17. gear box
  18. 1st problem with my EVO
  19. Divider inside stock air box snorkel??
  20. 7437 RPM's!
  21. Great Experience With Rnr..
  22. problem of transmission
  23. If no CAT? How are you all passing emissions? And what can I expect from no CAT?
  24. what is the stock psi does evo go
  25. Boost Guages
  26. BOV, Turbo Timer help
  27. Best prices on boost gauges?
  28. Throw-out Bearing issues
  29. I built my own exhaust, but have a question about sound
  30. poor evo transmission
  31. Perrin fuel rail
  32. Vishnu Cam Gears
  33. Buschur MAP vent line?
  34. Buschur 3" downpipe and cusco type 2
  35. Will 264 cams work with stock computer?
  36. JIC spartan Ti turboback - yes another exhaust question :)
  37. hks downpipe + 3" exhaust?
  38. Exhaust Help
  39. Any word on a Borla exhaust for EVO?
  40. Important Info
  41. Restrictor and SS Clutch line in.
  42. clutch restrictor
  43. start problem
  44. HKS HiPower vs B&B
  45. Fluctuating BOOST
  46. ask for how to use blitz SBC-ID
  47. EVO2 From Japan, check the mods
  48. Shift at 7200 7300 rpm 19 psi bad?
  49. Clutch Break-In on Exedey Twin Plate
  50. engine question
  51. Forge External BOV
  52. Transmission Issues...Again....
  53. RPMS fluctuating
  54. Mods to get an Evo to 360/370BHP?
  55. EBC vs MBC
  56. Feedback sought on water injection.
  57. 1G Crushed BOV
  58. Clutchmasters Stage 1 clutch, any thoughts, suggestions?
  59. sponsorships
  60. Just Got 272 hks cams, my thoughts!
  61. Tomei BOV for Evo
  62. SAFC and VTA
  63. Stock turbo?
  64. Vishnu exhaust Rocks!!!
  65. The aim - 400whp TME
  66. High altitude + high rev = problem?
  67. Part Throttle Full Boost ?
  68. Exhaust weight
  69. HS carbon-Ti cat-back
  70. $20 SS Clutch Line
  71. idle control valve
  72. Any vendors here carry Magnaflow?
  73. DSM G2 kit for HKS bov
  74. Need motor/tranny mount inserts, Perrin shifter and a transfer case
  75. Bogging when cold
  76. Can you run different exhaust w/ vishnu stages
  77. Gasket for installing axle back exhaust?
  78. Fuel cut/Pulled timing or just rich?
  79. Intake plugup for BOV
  80. perin short shifter and Stainless steel bushings
  81. Turbo Help
  82. what exaust should i get hks hiper or RmR?
  83. Highest fuel pressure?
  84. Socket sizes for the Evo
  85. JIC exhaust and perrin test pipe installed
  86. Whats the lowest price for
  87. What a difference!
  88. Exedy Hyper disc slipping already!
  89. Buschur Racing goes 12.09 at 115 mph
  90. Als
  91. need advice for first mod
  92. Intercooler Chiller
  93. Hks Gd Max
  94. HkS intake.
  95. Just replaced Forge DV with turbo XS
  96. Vishnu Standard Exhaust
  97. battery relocation kit..
  98. Restrictor Plate Removal?
  99. Another cruise control install...
  100. Anyone using a Forge D/V - BOV?
  101. Perrin shortshifter
  102. BOV-HKS sux, Forge sux, Greddy sux
  103. How to rid the low eng bog?
  104. Forge VTA BOV and Boost
  105. O2 CEL Fix???
  106. Twin Turbo on Evo VIII
  107. I have a question?
  108. The ugly battery in EVO
  109. huge power loss after bov install
  110. the EXHAUST thread
  111. Exhaust help
  112. Car makes a TICK noise once boost comes in with EBC
  113. APS Intake, is anyone using this???
  114. N-Tercooler tested: Skeptical, but convinced!
  115. Need help breaking in a clutch
  116. Type S adaptor
  117. EVO is hard to drive or is just AWD different?
  118. Computer Cable For Emanage
  119. Help ! Anyone using HKS FCD(fuel cut defencer ?
  120. For catback only, 2.5" or 3"?
  121. JIC exhaust slip joint torque numbers
  122. the obnoxious, rude and sponsored...
  123. RMR down pipe
  124. For Sale: USDM HKS Hi-Power Exhaust
  125. Does RMR make a good exhaust?
  126. Karman?
  127. Where can I get Redline oil for cheap for my tranny and differentials??
  128. Stock USDM Evo VIII Turbo Set-up
  129. Knock Setup on the SAFCII???
  130. Backfire issue returns...
  131. Tommi Makinen EVO VI Titanum Turbo
  132. Buschur Racing/SAFC II installed
  133. HKS cams vs JUN cams
  134. My ideas to help Mitsu in the new century
  135. RnR Catback: Installed
  136. How Much Fluid??
  137. Technical reasons for Evo clutch failures
  138. 19.5psi every gear all the way to redline, w/ no mods
  139. Replacing Hose clamps for the intercooler piping with T-Bolt clamps.
  140. HKS Downpipe
  141. Shifting Gears
  142. First Glipses at Ultimate Racing's upgraded turbo kit!
  143. HKS Hi-Power Exhaust
  144. Royal Purple engine oil
  145. who has the best price for HKS GD-max clutch?
  146. attn: VISHNU,AMS,RMR,BUSCHUR,Z1
  147. 338whp w/stage 1
  148. New Clutch line Banjo Bolt Leaking.
  149. Max boost 14psi Help!!
  150. ss clutch line
  151. Any input on Blitz Nur-Spec R for evo?
  152. 4G63 Facts
  153. BOV & Warranty
  154. WORKS Reflash + HKS Hi Power Exhaust
  155. wrong spark plugs..
  156. Fuel Cut Issue
  157. SAFC question
  158. AEM EMS Engine Management System
  159. Who Has Removed There Balancing Shaft
  160. I have a boost leak, please help me.
  161. Did Anyone Hit 11s With Stock Turbo and Front Mount yet??
  162. APEXi Exhaust for EVO 8?
  163. improving Turbo spool?
  164. No more CEL's with BR exhausts...
  165. Any muffler available on our BR system..
  166. Jic TT Exhaust Sound clips?
  167. Cams installed........new BR times.
  168. ABS (anti-lock) Light on!!!
  169. B&B Exhaust Installed/ long rant
  170. HELP! Blitz DTT install question!
  171. Idle
  172. Tried installing gauges, now evo won't start
  173. EVO 8 axle question
  174. RPM Drop
  175. SS Clutch Line $49
  176. Installed RMR Carbon Fiber CAI Scoop
  177. Another JIC exhaust incident...
  178. Tell me more about LS ss catback exhasut on lancershop.com
  179. Boost Controllers
  180. Full exhaust and no computer?
  181. Hayward and Scott
  182. Odyssey PC680/ARC oil catch can installed
  183. Broke something in the front of my car tonight...wtf?
  184. Anyone have problems with piggyback systems
  185. EMERGENCY PLZ HELP!! MBC problem
  186. providing I have a "normal" stock car...
  187. Drop in or Cone Filter?
  188. 19 PSi till Red.. what a change!!
  189. When was your first tranny and differential oil change?
  190. Engine misses normal???
  191. HSK Hi-Power Exhaust
  192. Help w/ fluttering Forge BOV
  193. noise w/clutch restrictor removed
  194. air flow sensor
  195. Jic exhaust question
  196. Restrictor question
  197. HKS Carbon Ti?
  198. 14.5psi only. PLEASE HELP!
  199. Rs-r
  200. No stroker kit for me
  201. 12's in QTR with just turbo back exhaust?
  202. Exedy twin plate installed.
  203. Who makes a front LSD for the EVO?
  204. hks exhaust sound clips
  205. Stainless steel manifolds are not for...
  206. Now this is an intake!
  207. upgrade path...
  208. Front Open-Type Differential
  209. Need Help Plz.. Lossing boost around 6 k
  210. part throttle
  211. Need 272 cams asap
  212. EXHAUST advice.
  213. is there a reason why I can't why..
  214. GL-4 vs. GL-5
  215. More dyno test results
  216. Evo Clutch install differences?
  217. statmosphere hyperboost diverter valve
  218. Comprehensive Turbo Timer List
  219. just got my 3inch full turbo back installed
  220. Profec b spec II settings
  221. HELP!!! Need Part # for the Vishnu catback "Muffler"
  222. Greddy Profec-E
  223. Exedy twin plate install - Need help!!
  224. Clutch availability
  225. K&N panel installed
  226. ARC Box and Fujitsubo Exhaust
  227. Tuners, what's the stock rev limiter???
  228. using XEDE with muffler delete pipe
  229. Exhaust help!!!
  230. rattle from downpipe install
  231. Redline?
  232. boost question!
  233. Fujitsubo exhaust
  234. Surge or just torque jerk?
  235. Need Help.....
  236. Boost seem different after dowshifting
  237. Can't hold steady boost....
  238. Any one done the installation of the RMR six-puck disc
  239. Where can I get an OBD-II diagnostic tool?
  240. Thinking about swaping the Xede for the E-man/e-o1
  241. Help Bov sound adjustment???
  242. JUN camshaft kit
  243. Which is the best clutch kit for evo IV
  244. need help with gauges
  245. BOV, Intake, Exhaust, Boost control
  246. The all new clutch poll!!!
  247. cams
  248. 3" cat
  249. WORKS flash w/3 inch turboback?
  250. Clutch Line: LancerShop vs Alamo
