PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Cure belt noise-Revised block bracket 1091A133 question
  2. Could you measure turbo exhaust back pressure through the EGR port in the head?
  3. Average cost of drive train for evo 8/9?
  4. Evo 8 T-Case and Diff oil
  5. Car running Rich
  6. Wire terminals and connectors
  7. Replacement belt for power steering
  8. Evo 8 with miss or lope.
  9. evo 8 whining with pulls
  10. Best quiet exhaust w/o losing performance?
  11. Setting T belt tension question
  12. Evo 8 rough idle
  13. New member with a blown engine :(
  14. A Fun-Filled Game of "Hunt the Boost Leak(R)"!
  15. Advice on Valve Cover Catch Can Lines
  16. question about my turbo
  17. Manley Billet 100mm crank - Cracked
  18. Tilton clutches
  19. Evo 9 hard start cold, no start hot
  20. Lean AFR during take off
  21. EVO 8 Whine
  22. Can you remove AYC and keep ABS working OK?
  23. 71HTA Install Problem: Won't Slide Into Turbine Housing
  24. Piston hitting plug?
  25. Aftermarket Lower intercooler pipe
  26. Tuner right or wrong
  27. New built cylinder head, can you drive it to tuner?
  28. 2.4LR Idling Woes
  29. modifying/TIG welding an aftermarket catback to fit jdm rear
  30. 400whp+ on stock higher mileage block
  31. will leakage from valve seal damage turbo?
  32. Tranfer Case whine or Rear diff whine
  33. 350whp EVO VII
  34. TOB Noob Questions...
  35. Trying to diagnose engine failure
  36. Evo seems to be running on 2 cylinders. Help!!
  37. Hoping for quick answer: play in axles after reinstall
  38. Evo Noobie first tune next week
  39. Evo 7 Rear Diff upgrade options - Drag racing Tech Help
  40. 02 houing downpipe advice..
  41. Is This Noise Normal?
  42. engine temps
  43. FIC 1800cc injectors...anyone have experience with these?
  44. Block deck question
  45. Help choosing wastegate spring for BBK 3B on a 2.4
  46. Wastegate preload question
  47. Melted Lower inter-cooler cupler
  48. Which one is my fuel return line?
  49. Do I need billet cams?
  50. Stock UICP coupler size '06 MR
  51. Evo8 with fp54
  52. Query: Cams for the Evo 7 GTA
  53. Anyone Know How to ID Cosworth Cams?
  54. Resonator delete require retune
  55. Comp Clutch Stage II Failure - Post Mortem Diagnosis
  56. Motor mount opinions
  57. PTE 6262 Downpipe Options?
  58. Tomei springs/retainers
  59. ACD/AYC Pump not activating
  60. Not going into gear 2nd
  61. AEM water/meth kit...need advise!
  62. Cams
  63. Lower my rpm's on my evo 5?
  64. Rear Diff Bearing Spacer, "SHIM"
  65. does hot weather temprature cause knock?
  66. Should I go E85?
  67. NA Stroker build
  68. how to warm up a carbon clutch?
  69. Compressor surge cure question.
  70. GSC 5040 vs 5041 springs
  71. Valve spring install method
  72. Coil and boost issues
  73. Is my Timing belt Tension correct?
  74. big turbo in stock engine tme evo 6
  75. Head gasket
  76. Bad T case.
  77. Evo 8 Won't Idle
  78. Run a staging brake with ABS
  79. decipher my tune
  80. Weird car noise coming from engine?
  81. COP Denso coils keep failing
  82. vibration at 6000+ RPM's..need help.
  83. Mustache bar bushings vs eliminator????
  84. What O2 sensor should I buy?
  85. help. ACD Diagnosis code 74
  86. Spark plugs
  87. Low oil pressure problems
  88. transmission trouble yes or no ?
  89. under powered evo 9 AMS 2.3L FP Black
  90. Afr acting crazy...any ideas welcome
  91. Velocity stack/filter for 4" diameter turbo inlet
  92. Dirty intake manifold? Evo 8
  93. Airtrek block direct swap?
  94. SS Turbo to manifold Studs
  95. DSS axles worth it? (vs used oem)
  96. Snapped Manifold Stud
  97. HELP, New spark plugs now lean??
  98. Clutch kit suggestion. Evo 8
  99. motor-bore-block help
  100. T-Case Oil Ring Replacement Advice
  101. Evo 8 Stutter Help
  102. Headgasket going?
  103. Going jb to bb
  104. I need to pull my head after all!
  105. Evo 9 S90 question
  106. -AN Hose Size for Cusco Oil Catch Can
  107. Would unplugging o2 Sensor rather than Crank sensor Skew Comp test results?
  108. New hot parts... retune needed?
  109. 4G63 swap
  110. Walboro fuel pump whine...replacement?
  111. High rpm
  112. help with oil
  113. Evo 5 transmission rebuild
  114. Radiator fitment help
  115. Stock 9.8 hotside/71HTA. Which actuator?
  116. Downpipe with ACD
  117. Risk with running engines with 1 or 2 low compression cylinders
  118. Gen 1 6466 vs gen 2 6266
  119. Engine install / drop-in question
  120. Need help building 2.0LR or 2.2LR Evo 9
  121. Wiseco rings
  122. Who sells a quality flywheel?
  123. "It Detonated"
  124. Evo 1 turbo help
  125. Possible timing issue? Fuel issue? Please help
  126. Car won't go to closed loop at idle or cruising.
  127. Tons of Issues, Help Please!
  128. block prep procedure
  129. 4WD not engaging
  130. Ford fuel injector harness clip install. Anyone?
  131. EVO 4-5-6 Tranny into 8/9
  132. 2.4lr
  133. Intake Discussion (Warning, this will be really long write-up)
  134. Few problems on Evo 9..New to the community
  135. Stock lower rad. hose for Koyo Half radiator?
  136. 4g69 Rebuild Thread
  137. Idle issues... AFR + RPM..
  138. Why won't my car do above 23PSI?
  139. Help identifying plug on my 9
  140. Turbo coolant feed replacement question
  141. Fuel cut problem
  142. Evo 8 DD, 400whp, best and cheapest clutch?
  143. ACD/AYC bleeding question?
  144. Evo 8 flywheel/clutch in a Evo 5
  145. Power steering delete
  146. Battery not holding charge
  147. Perrin fuel rail new setup figment!
  148. Synchro
  149. Anyone know if Shearer Fab turbo manifolds can fit a Xona XR 95-67?
  150. Easy on the wallet SS 3" exhaust kit for evo IX?
  151. Valve Seats on New OEM Head
  152. htuff rods
  153. head build
  154. Evo 9 water pipe on Evo 8????
  155. ACD Pump issues, what are my options?
  156. Journal to Ball Bearing turbo.
  157. Evo 2 with 8.5" flywheel ?
  158. Head Gasket and Timing Belt Changed - Now Problems
  159. Clutch Slave/Clutch Fork
  160. Evo 8 Evo Headgasket blown twice - Opinions pls
  161. **Boostin Performance Ported Stock Intake Manifold** (Evo 8/9)
  162. Boostin Performance Transmission Rebuild - 5 Speed (Evo 8/9)
  163. OEM Evo 8/9 WGA & Bigger Turbos / Discussion
  164. Identify this titanium muffler
  165. Alternator
  166. Recommended water pump for JDM Evo 8
  167. Kiggly crank Trigger wiring
  168. fuel pressure problem
  169. Front case breather mod ( at rear balance sprocket )
  170. Exedy HD or Exedy HD Sports Organic?
  171. Spark plugs BR7ES or BR8ES
  172. Crank Case Relief Passage
  173. What turbo
  174. Frontline Fabrication Evo 8 Ball Bearing Oil Pump
  175. Tial QR BOV goes off often at 4000rpm
  176. Whats broke?
  177. Evo 8/9 Rear Axle Upgrade Options
  178. 4G64 with Mivec Timing Help
  179. Engine Install
  180. Electric exhaust cutout question.
  181. low compression
  182. Iso: EVO IV Motor mounts
  183. Dented intercooler - repairable?
  184. Injectors
  185. Intake Pipe Idle Problem
  186. Ideas to make my evo more civilized?
  187. Underboosting Evo 8
  188. Hardwired pump running out of fuel??
  189. Ported head
  190. Constant open loop issue
  191. Is my engine no good?
  192. Double pumper light
  193. Compression results question
  194. Evo IV - Possible camshaft problem
  195. Broken Balance Shaft Belt
  196. Catch can question
  197. Intake manifold question
  198. What external wastegate dump tube for FP SS housing with FP Cast O2 Housing?
  199. TOB clip popped off after install
  200. Canton Racing Full-Pass Oil Filters
  201. 700hp target
  202. OEM Oil pump vs ACL Oil pump
  203. BLOX front motor mount - replacement bushings?
  204. Bolt sizes and ratings
  205. Apex Powered Titanium Evo 4-8/9 Coil On Plug Unit
  206. Occasional gear lockout and metal sound. Clutch? Trans? Driver mod?
  207. Should I build this block?
  208. Exedy MM022HR - Solid Twin Disk
  209. Rough idle after fuel pump
  210. Tdo6-hr 25g anyone running these turbos?
  211. Balance shaft timing
  212. Is this a evo 8 5 speed gear box? Pics inside!
  213. 1MM oversized Valve and mild porting
  214. STM Titanium Exhaust on Evo 9 - is it super loud?
  215. Small Turbo Comparison
  216. Evo VII won’t start plus noise before parked...
  217. can you run a stock BOV to atmosphere..
  218. Tomei 270 Poncams vs 272 Kelfords
  219. Fp Black Evi ix buid sheet.
  220. Rich idle after install a new turbo
  221. big turbo
  222. GSC S3 and stock EVO 8 valve train, can you?
  223. 06 Evo IX Rocker Arms numbers
  224. p0335 p0340 2005 evo 8
  225. Rebuilding 4G rod rattle
  226. External Fuel pump wiring
  227. Motor mount bolts stripped ok to put back on?
  228. FP red ss
  229. PCV vent / catch can on forward facing setup?
  230. Rough cost of reliable 500whp on fp red or black
  231. REM/ISF turn around time
  232. Drivable clutch for 475-500 WHP
  233. Rod bolts
  234. Magic Smoke - and some cool pics
  235. AMS Cylinder Head
  236. Precision 7275
  237. Timing, Balance, Accessory Belts
  238. triger plate
  239. O2 Housing Stud Size?
  240. Silicone Coolant Hoses
  241. Need T-case oil recommendation!
  242. Evo 8/9 88mm crankshaft options...
  243. evo 9 clutch limit
  244. ARP flywheel bolts question.
  245. Evo 7 turns on all 3 acd lights
  246. 8-9k rpm
  247. Balance Shaft Installation
  248. Injectors?
  249. Question on disabling egr system evo 8
  250. Clutch kit, budget! Help
