View Full Version : Evo Engine / Turbo / Drivetrain
- shift lever feels notchy
- My 700+whp build...what am I forgetting?
- Spark plugs?
- P0401, P0300
- Test Pipe Vs. 100 cell cat
- Pressure Plate Wedge Collar Question
- Comp 280 Cam Users!
- Inside a JAM shortblock.
- at what psi is it needed to get ARP headstuds?
- New Transfer Case from Dealership.
- Help Oil Light On!!
- 272 cams..what else needed?
- Anywhere to get new version of HKS Cam gear in stock?
- Rear diffrential
- t3/t4 turbo on evo?
- cosworth cams worth it???
- whats next..
- MBC vs EBC
- My Evo at idle (1600cc, 2.3L, PT67, Jun, etc...)
- got tuned
- SPring racing!
- What would you guys do
- Ugraded FMIC on stock turbo ?
- Downpipe Dilemma
- Tial Wastegate spring question
- Center Diff - In the gearbox or transfer case
- HELP turbocharger evo 9rs
- Blue timing belt warning.
- Best BOV
- *****What PLUGS for my SETUP???*****
- Aftermarket power steering cap
- EGT gauge sensor question
- Losing boost...and didnt do it before..
- upgrading spark plug to colder range...
- boost lines
- 47k and clutch is finally slipping
- Cosworth 272's
- engine noise
- changing timing belt, TDC marks
- All GSC S2 users+anybody using S2's on stock valvetrain?
- GSC S2 vs. Revolver 272
- Knocking in front drivetrain area
- Front Diff Recommendations?
- Fluid Leak
- Beginning my engine build by Ron at Axis Power Tuning
- GSC S1 cams
- Greddy Rs vs IX stocker
- German Castrol VS Amsoil
- Turbo kit and gauge decision opinions needed!
- Car does not start...
- Q Horsepower Synthetic Oil....
- Aem Ems
- oil filter replacement
- Cut up my stock UICP
- Best clutch for DD need help
- invidia o2 fitment with tanabe dp
- Axle seal nightmare...
- how many hrs to swap motor?
- Prelim Numbers for Twin Scroll Setup
- Cloud of white smoke coming form exhasut?
- stiff shifter base bushings for MR 6 speed
- Tial wastegate control with an Apexi AVCR
- help a noob, what did I break
- photo request: Perrin "stealth" FMIC
- 70mm Throttle Body made in Japan! (EBAY)
- Anyone Selling A Shep Tranny?
- Forced Performance camshaft....Are they any good?
- Shep Tranny Help?
- Help my car run right
- Chattering/Vibration
- BOV questions- opinions on Greddy Type S
- PCV valve is Best place to catch oil
- resurfaced flywheel ok ?
- EVO 8 headgasket will fit EVO7?
- Weight Of Evo 8 5spd Tranny?
- HKS 1.6mm Headgasket ?
- Are all exhaust manifolds created equal?
- 50 trim dynoed evo 8
- Planning On Upgrading 8 Turbo???
- Finnaly Getting the TBE
- My ETS Tubular Ball Bearing 58 Trim Turbo Kit...Installed w/Pics...
- oil recommendations!!!
- Anybody Seen this downpipe?
- axle questions
- which downpipe
- Changing drivetrain fluid made easy!
- UICP or not?
- Greddy Evo2 Catback
- ACD fluid??
- Megan Type 2 stealth
- HTA 3076 turbo owners What injectors are you using?
- installed cams, fuel problem
- To Cam gear or not to Cam gear?
- Evo IX FQ360 tuning help
- Fuel System
- which plugs?
- Green hotside vs. regular 10.5 hotside: different?
- F1 stage 3 clutch
- Injectors needed w/ cam install
- Installed Mynes turbo manifold
- Axle Seal Question
- what size injectors??
- Blow Off Valve Question
- Dont know where to go from here...
- desial engine sound after build
- What's this clicking noise?
- Buschur mini Radiator??
- hallman pro question!
- Hyper Ground System?
- Help with test pipe
- Whats the best single scroll t3 manifold that gives the fastest turbo spool and best
- tme turbo
- Problem With Tranny, I Cant Get The Gear In At High Rpms
- hks exhaust resonator/driveshaft problem
- Spark Tech's 1000+HP Pro Drag 4 System..
- Why is my idle not stable???(It went lower) Feels like its misfiring....
- 8 vs 9 O2 housing differences ?
- Is it my synchro?
- Cam gears needed? Advantages?
- Mishimoto radiator
- new engine soon :(
- Gt28
- Help With BOV flutter!
- check engine light due to no cats.. anyway to shut it off?
- need help on curing compressor surge
- some maintenance and upgrades to the car with pictures 56k stay away
- One step colder plug or 2???
- AMS PUSH style clutch install (pics)
- Unofficial HKS EVC VI thread.
- ETS - Ridiculous Water-to-Air Intercooler + 45R for Paul's (ifarted2) 1000whp+ Beast!
- Drivetrain
- Help with Forge RS and uicp decision
- How do I remove the crankshaft sprocket? *Pic*
- ECU patch harness....
- High output Alt
- Should I get a IX Turbo?
- compression ratio for 600-700 hp
- Stay W/cosworths M2 or upgrade M3 or S2 ??
- twin scroll 35R spool
- Transfer Case
- 02 Housing for Gt3076r?
- Car is acting up, please help.
- Intake and IC Help
- Tune or no tune?
- O2 housing
- Evo9 turbo or 20G whats the power difference???
- Tail wastegate
- best turbo for 450-550 whp on pump gas
- Tach not working please help
- evo 7 & evo 8 engine plz help
- Here goes again 2nd time ordering a turbo kit...i ordered my AMS HTS 35R
- problem need help
- front axles
- Boost Leak
- Installed my Injen intake and IC pipe
- Cosworth Mivec 272's Idle problems
- turbo/ boost problem need help
- megan racing or QTP
- 100oct. and stock injectors?
- p0335 HELP!!!!!!!!
- which meth kit to get to hit my 500hp goal
- Alternative Boost article
- Q for Beatrush diff bushings users
- tps code...car dies when letting off throttle
- FINALLY installed my header!!!! VIDEO
- Evo top mount manifold
- Should I just resurface my stock flywheel?
- boost solenoid over boosting and spikes 20-25psi
- Question about Megan Manifold/DP
- 54 Trim?
- AMS NEW PRODUCT RELEASE: AMS EVO VII/VIII/IX Lexan Window Kit
- HELP!!! broken turbine tip
- MR six speed cold shifting
- Gears Hard to Engange on Fresh Rebuild
- Shearer Fab... Bling Bling
- Hole size for SMC nozzle????
- All exhausts that fit Varis Diffuser?
- Buschur Racing tests the new HTA3076
- Garrett Twin Scroll
- 50 Trim +
- Length of axles...
- Inside my lightly cooked tranny
- Bent shifter cable?
- Hotside Pipe and Outlet
- Tial BOV Question
- alright i need some help
- AMS 35R plus meth on 91 octane #s
- big problem!!
- P0090 Fuel Pressure Solonoid Circuit
- Stock turbo VS GT3076R Spool time...
- Now Available: Push Style EVO Clutch Kits
- Help!! No spark
- Opening up the hotside on the FPgreen
- 35R untuned, can I drive it? AMS
- Another cam question.
- Code P0125
- Question on HTa
- Turbo Boost Help Whats the differance?
- GSC S2's with stock turbo and ecu
- Anybody with the new Tial Q?
- Head skin is it ok?
- o2 sensor break in period? help, p0171 related
- Wheel locks up
- Intercooler Question/HELP??
- new boost controller problems
- Quick Update On Build.
- WHICH JEGS/QTP cutout size??
- Bruce Crower 272/272 and gears question
- What RPM am I capable of??
- Another transmission issue
- Who sells just the lower I/C coupler?
- Exedy HD or SD?
- Stock 249HP
- Are the IX & VIII wastegate actuators the same?
- Need some input
- Hks Cams
- BC 272 to HKS 280's
- What injectors to use (HTA)
- power distribustion between wheels
- Meth Question
- HKS EVC VI set up
- Stock turbo 20g upgrade
- People who have changed the Evo8 oil pressure sensor/switch help please
- Ultimate Turbo Kit build under 3k
- 6-speed MR clutch in a 5 speed?
- How Long Did U Wait To Get Your Hta?
- My Dyno Dynamics pulls...
- egr elimination
- Evo Electronic Cut Out Downpipe?
- Tranny locked in 5th, yay!
- hta turbos vs. pte boosted turbo's?
- clutch problem?
- E85 stock turbo english racing tune, dyno graph inside.
- Force Performance Evo 9 Cams...........
- Help identify these injectors
- lower intercooler piping
- Oil light flickers after WOT runs???
- So I changed my diff fluid today, found this...
- Gsc S1 Cams
- 44mm wastegate VS 38mm wastegate
- MBC problem
- HKS EVC VI REV grid axis help
- car whines when slowing down??
- Dejon Tools 4" Intake
- E-85
- Do I need a new wastegate actuator?
- Evo II & III tranny gear part #s
- arc intercooler piping?
- problem with stock clutch, any advice?
- extended or shorten release cylinder pushrod on stock clutch??
