PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 [145] 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. downpipe / o2 housing headache
  2. ??? if i build my head...what rpm
  3. Cams w/ no tune runs lean?
  4. next mod decision?
  5. looking for Greddy BOV type RS 8 port outlet
  6. TCase or Clutch noise - horrible noise
  7. tc and diff
  8. need help with this code!!
  9. Can not pass 11 psi. Help!
  10. Checking what cams are in my car?
  11. Extreme Turbo Systems - Turbo Manifold Sexiness Galore!
  12. Anyone using MAF translator with good success?
  13. Mach V powder coated intake pipe kit?
  14. Failled exedy twin HD + synchro warranty woes
  15. i want to upgrade my hks 272's what cams to go with???
  16. new turbo help
  17. Lessons learned along the way
  18. tranny help
  19. Garrett 60-1 Turbo how much lag?
  20. cam install
  21. Tranmission Help
  22. Buschur Race FMIC vs Deluxe FMIC (pics)
  23. **Dyno Results**
  24. best turbo for my setup
  25. Boost controller install? Wrong or right
  26. MAF sensor ?
  27. Evo IX with Aquamist HFS-5 kit and 25 psi pump gas
  28. 28 PSI peak boost vs 24 PSI peak boost on Stock Turbo Evo IX and pump with alcky
  29. Full Fluid Change. Fluid Suggestions.
  30. Considering PPI porting...
  31. My New Setup :)
  32. external wastegate
  33. loud exhaust sounds from exh manifold area?
  34. Yes... another SES post :)
  35. Clutch/tranny making odd sound!
  36. HKS Evo IX cams and tune results
  37. code p0401 (EGR)
  38. GSC 272 S1 Cams
  39. My buschur racing race gas evo
  40. An orgasmic combination of parts.......
  41. Show me pics or explain this to me!
  42. think I have a bad fuel pump need help!!
  43. cosworth cams question??
  44. Forgot to bolt up CAS durring my timing belt R/R
  45. Boost down, but LoadCalc up???
  46. Buschur turbo kit modifications needed to run Stock ECU & Stock location intercooler
  47. What to expect?
  48. Extreme Turbo Systems - ANOTHER Sick EVO Turbo Kit!
  49. **SickSilverNLow's ETS 57 Trim Dyno**
  50. godspeed intercoolers?
  51. Please help,Turbo!!!
  52. Evo IX 20 G from turbochargers.com on a Stage IV
  53. Clutch is almost gone.. Need help finding a new one!!! PLEASEE!!
  54. IS that a good deal??
  55. Retune after 10.5 & P/C manifold?...and some other questions
  56. warming up
  57. 457 TQ 430 WHP - Maxing out the stock injectors with 93 octane and alcky !
  58. Greddy M-Spec Intercooler Kit Mitsubishi EVO IX 06
  59. what is the problem !? help!
  60. Front LSD
  61. 968 AWD WHP ! Dyno Flash Evo with Buschur Power - (Video)
  62. VIII and IX Intercoolers - are they they identical?
  63. cause of cam gears wearing down/symptoms
  64. Shifter Bushings AMS OR BUSCHUR (6 Speed)
  65. Building Engine - Looking to Paint - Enamel Effects?
  66. HTA GT35r, any movment on this?
  67. Need help with ex manifold stud m8x1.25
  68. Very strange boost leak
  69. Car throwing 335 & 340 codes all of sudden
  70. Oil leak from underneath the intake manifold, but I can't see where exactly...
  71. Who is running aftermarket fan with GT35r
  72. Where does AEM UEGO O2 sensor go?? front or rear?
  73. Intercoolers??
  74. Clunking/Popping Noise Coming From Front Driverside Tire
  75. brian crowers 272 cams?
  76. looking for ported 65mm throttle body and intake gains
  77. ETS Tom - Joining the turbo kit fun!
  78. just got my aquamist HFS-1...... people with meth chime in
  79. RPM based Boost Controllers
  80. Attention: Racers At WRX vs EVO Shootout ! (Etown Aug 25)
  81. BOV to Intake coupler size???
  82. stock evo pistons...
  83. installed evo 9 turbo, mr02, and ams tb
  84. change my clutch
  85. Turbo upgrade and supporting mods
  86. my engine blew....any thoughts and help?
  87. cam break in?
  88. factory boost solenoid
  89. **HELP**Timing Mark of by 4-Teeth!
  90. Major Boost leak
  91. Help me figure out my turbo situation!!!
  92. clutch lock ring will not stay together
  93. Does A 50 Trim Need A "built" Motor?!
  94. Does A 50 Trim Need A "built" Motor?!
  95. Does A 50 Trim Need A "built" Motor?!
  96. Does A 50 Trim Need A "built" Motor?!
  97. Driveshaft question
  98. New mods New tune New thread
  99. 15th DSM Shootout Dyno Day - Video - Dyno Flash Evo makes 835 (Mustang Dyno) whp !
  100. greddy boost gauge help
  101. Clutch options....need recommendations
  102. For those removing A/C
  103. what should be the next upgrade for me? need help and good advice
  104. Hey guys noise in head need HeLP
  105. SHOP CT:Evo Green numbers are in...
  106. Any one have a clutchmaster clutch?
  107. Walbro 255
  108. Walbro fuel pump question
  109. intake ...which one??
  110. Max boost on stock motor ???
  111. high boost guys...some plug questions?
  112. why ?Evo IX transfer case leak
  113. blew up!!!!
  114. VTA, MAFT BOV issues
  115. We did some testing on GSC S2 cams and 1.02 to a 1.28 Divided housing on ETS42r
  116. update on my "noise"
  117. Need suggestions of possible problems! HELP!
  118. K U Eng. intake manifold?
  119. Did The Dealership Cause My Transfer Case Failure? (Expert/Mitsu Tech Help Please?!)
  120. Help identify turbo - pics on evo VIII with cast mani
  121. fp 3065 / ets 58trim
  122. ACT 2900 Street Disc........
  123. My Jam 2.3 Stroker Kit With Buschur Racing GT67 P Trim
  124. check engine light
  125. Boost problem
  126. how necessary is it to......
  127. Cosworth cam install questions
  128. Pros and Cons
  129. SBR's 20G updates?
  130. removing resonator...
  131. How are my stock plugs doing? 36,000 miles
  132. CBRD Product Development- updates...
  133. CBRD Product Development- updates...
  134. Bent Valve or Bad Cam Shaft?
  135. Found some FP EVOgreens
  136. evo 9 USDM gearbox
  137. Project: 2.3L stroker on stock turbo
  138. question
  139. The family...
  140. $#%&ing sound!!
  141. **VID**Help Me Identify This Whistling/Cricket Sound
  142. Magnaflow Questions
  143. Opinion on when to o-ring the head/block?
  144. Help!!!!!!!!!!!
  145. Stock block with Cosworth 272 Cams
  146. Oil Temp Question
  147. Tune problem with mods?
  148. Rear diff locked up --- where can I send it to be rebuilt???
  149. Help me diagnose this whistling/chirping sound **VID**
  150. o ring question
  151. Are you using an aftermarket wga??
  152. Build my Block Or Buy Built Shortblock?
  153. fuel pump and injectors
  154. driving without a snorkel?
  155. Buschur's advise(need help here)
  156. 5 bolt o2 housing for gt series (piecing together turbo kit)
  157. Nisei or ETS Intercooler...?
  158. O2 Housing
  159. where can i get a turbo rebuild kit? (gt30r)
  160. bov atmosphere with flash???
  161. evo ?s
  162. Has your TurboSmart BOV quit working?
  163. 2nd official post ......how bout some pics of some new goodies
  164. AMS or buschur FMIC...?
  165. stock ix fuel pump vs. walbro 255?
  166. Quickest spooling stock turbo
  167. Tune required for intake filter?
  168. aps bov needs adjustment
  169. Evo IX walbro inline pump install ???
  170. head noise need help
  171. evo mod ?
  172. over heating issues seeking help!
  173. help!!! questions about AMS VSR
  174. internal wastegate
  175. New Pulstar Plugs replacing spark plugs
  176. upgrades help
  177. Magnaflow 43000 series HFC OBD2 EPA CARB Compliant?!
  178. What to do if any before tune?
  179. Boost leak advice please
  180. shooting for low 10s, what should I do next?
  181. Why video tape a car on the dyno?
  182. Anybody using GT3571?? how much WHP???
  183. Anybody using GT3571?? how much WHP???
  184. Video of 612 awhp Evo 8 from NM
  185. i have a head noise need some outsiede opinions
  186. HKS 272 Cams - Timing Figures
  187. Offset 272 and 280
  188. **VID**HKS MIVEC Cams
  189. HKS intake pipe w/ Apexi' Filter problems
  190. go fast bits bov
  191. 2.3 or 2.4 stroker + Big Turbos (Explain Driving Experience)
  192. Possible Stripped Thread
  193. need some good advice for real!!
  194. Car idle like it got cam, but not sure.
  195. fluids for...
  196. Ticking On Deceleration!!!
  197. New Record??? Thanks Buschur.....
  198. Did I loose Second Gear?
  199. Does your BOV hold Boost?? What are you using?
  200. EVO 8 Turbo 10.5 Single Upgrade Turbocharger
  201. Help Me Spend my Money!! ~4k
  202. Collapsed Lifters
  203. Trans noise
  204. Why are Evo8's quiet and 9's loud with walbros?
  205. *HKS MIVEC Cams Installed: Dyno Inside*
  206. timing belt tensioner
  207. Best way to get 400-450hp.
  208. MIVEC Cam Gear Plug Cap broke
  209. For all you guys with the Blitz exhaust
  210. Need some input on bigger cams for our 42r setup
  211. GT30R questions
  212. rear diff leak?
  213. Full Race Turbo kits
  214. What do my Spark Plugs say (Pics)
  215. Mods to go with big turbo?
  216. Case Study - Evo IX w/ BR Stage II - 350 / 350 93 octane
  217. Friend's Evo, Tcase cracked in half.
  218. Injen Intake w/ Stock BOV ICP Popped Off.
  219. Clutch Problems
  220. p0300(random misfire) code when trying to start the EVO
  221. rattle noise
  222. Problem....Boost/Clutch/flywheel??? pls help
  223. which gauges + boost control: for more power
  224. shift lingage problem
  225. stored crate engine (4G63)
  226. C L U T C H
  227. put uicp on , now tranny is jerking
  228. will an O5 Exhaust manifold fit my IX
  229. ams test pipe
  230. Controlling Boost
  231. gsc s1 evo8 cams
  232. Boost controller
  233. Blew My First Clamps!!!
  234. JohnEB and JustDSM at it again, New Build!!!
  235. t3/t4 or evo green
  236. Anybody have magnacore plug wires?
  237. Clevite part # for main & thrust bearing?
  238. Cosworth 272 Cam Idle Rise and Fall
  239. Wtb Hks 272 !
  240. Cleaning HKS filter???
  241. Stock exhaust VS Megan Racing
  242. AMS VSR INTAKE or MAGNUS INTAKE
  243. XTD Clutch
  244. Will "Jun" come out w/mivec cams for the 9 or not?
  245. Clutch Help
  246. HKS EVC V problem holding boost
  247. Best cams for the $!!?!
  248. HELP! Injen Intake w/ IC Piping and HKS BOV Ver. 2 w/ IC Piping
  249. Trying To Get Rid Of Your Stock Turbo
  250. 400-450 to wheels theirs a catch tho
