PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Opinions/advice wanted on first motor build.....
  2. How much can I expect to gain from meth?
  3. Exhaust poll
  4. A question of good rods
  5. EVO8 oil pump after 15,000+ miles, short video
  6. strange clutch chatter/vibration
  7. cold start
  8. Evo injectors vs DSM injectors
  9. Fuel reg Install few pics
  10. Best cams for my set up?
  11. Coolant issue Coolant leaks from Rad cap?
  12. Whining and clunking noise when turning left...Help!!!
  13. Transmission/gear selector problem....
  14. Question for anyone who has ever replaced the motor in an evo. Look
  15. Turning Up the Boost
  16. EGR failing at 33k?
  17. HKS IC Piping dyno's?
  18. upgraded shift fork pin's?
  19. trans>trans mount
  20. new FP green 73hta and old green compare pics
  21. Loud clunking from front right of car
  22. Bad rattling from engine bay
  23. Kelfords, what springs/retainer kit
  24. Stock bov started to flutter
  25. Spending around $900. Meth, e-85, cams or turbo?
  26. HELP: Transfer case LEAKING!
  27. Buschur Racing engine tear down video!!
  28. Will going Speed Density stop my car from fluttering/surging on throttle?
  29. weird surging...tough gear changes
  30. SES flashing after/during WOT
  31. Metal shifter bushing
  32. will a evo 5-6 drivetrain fit in evo 7,8,9?
  33. Timing belt...?
  34. timing belt issue...
  35. Going from an A/R .63 to a .82 or larger please chime in...
  36. Oil pan leak question
  37. rebild help
  38. Transfer case install parts
  39. Redline Water Wetter
  40. Titanium exhaust note question
  41. will the HKS carbon ti catback exhaust fit the ix mr without problems?
  42. Next Step?
  43. Car stall after boost gauge installed.
  44. Is my BOV broken?
  45. Bad Gas QA?
  46. ac removal
  47. Forward facing question?
  48. Double Pumper N AEM
  49. Synapse Synchronic BOV installed
  50. How to get 200K miles out of an EVO?
  51. what injectors should i use on my hta green set up?
  52. WRC 2005 Car
  53. 32 PSI Old-School Green on 91 pump.
  54. Best Recirculating BOV for 35+psi
  55. Ets stock replacement tubular manifold?????
  56. Kelford 272 and stock turbo
  57. Filling an 4G63 block
  58. Boost Creep Issue
  59. Trying to install oil pressure gauge.
  60. Pedal Stops for Push style clutch?
  61. Aussie's got 10.8 hotsides now
  62. Rear Diff Options - Power Oversteer Found Here
  63. need advice before tune
  64. jerking?
  65. AGP licp
  66. New GSX eclispe turbo into evo 9.
  67. About Buschur racing HTA 3582r
  68. my clutch is starting to slip..need a new one soon.
  69. p0300 multiple misfire help
  70. PLEASE HELP....Balance shaft seal
  71. Clutch Slippage Question
  72. Aggressive cams and cold starts
  73. question about manifold
  74. Best Air Fuels to make safe power??
  75. p0401 EGR insufficient flow
  76. 2G's What would you do?
  77. how can i tell the difference between the bbk full and lite?
  78. About Shortblocks
  79. car Breaking up or misfire at High RPM
  80. AEM Tru Boost max psi
  81. Dual Exhaust / Cat Setup for Better Flow? (Drawing inside)
  82. Starter Motor
  83. Swapping from Forge RS DV to Stock IX DV
  84. Clutch Bleeding
  85. Sign of clutch going out?
  86. oil catch can
  87. Turbo oil feed restrictor fitting
  88. Changing sparkplugs!
  89. Custom Grind Cams
  90. map o2 eliminator or......????
  91. Skunk 2 TB needs spacer?
  92. HELP!! Transmission Drain Plug fell out
  93. camshaft help please!!!!
  94. Car sputters I've checked the forums already.
  95. Fujitsubo Owners
  96. MAPertormance SST Turbo
  97. Bov ?
  98. torque settings
  99. clutch/tranny issue
  100. HELP car shut Down and lights diming
  101. 9 turbo in an 8
  102. 1,2,3,4,5th gear whine
  103. Which Supertech dual valve springs should I get - SPR-M1007D or SPR-M1009D?
  104. Kansai service
  105. Rear end went out after clutch install
  106. Best camshafts for 2.0L with FP3065
  107. HKS 264 Cams Worth it or Not
  108. HKS 264 Cams Worth it or Not
  109. What kind of injectors are on an Evo 8
  110. Clutch recomendation
  111. Help me out!!! NEED IT ASAP!!
  112. forward facing manifold for stock frame turbos
  113. Not All End Tanks Are Created and Designed Equally!
  114. ignition coil FUSE...
  115. New to Mitsubishi build
  116. 05 mtsubshi evolution 8 5speed tranny issues
  117. will it fit?
  118. Which Turbo is best for me?
  119. Exhaust valves leaking, suggestions?
  120. 02 dump with Buschur intercooler
  121. Having a minor problem
  122. Timing Belt
  123. removing head?
  124. throttle body leak
  125. Stock Appearing Turbo question
  126. which exhaust manifold to go with??
  127. problems pulling tranny.
  128. Need help which plugs for one steo colder on a 9 ??????
  129. Head gasket replacment.
  130. Bump sound under high load shifting
  131. Is it possible to add another fuel gauge...
  132. painted IC
  133. problems with Nisei intercooler
  134. just got new clutch. judder when i downshift
  135. Can figure out what's causing this knock (video)
  136. 4g63 block problems ...
  137. Black vs 6262
  138. blown head gasket??
  139. HP with stock injectors?
  140. Anybody using 1.3mm Cosworth Head Gasket on 40psi+ boost?
  141. My Sweet Turbo (PTe 6262)
  142. Ams, Buscher and CBRD Fmic's
  143. O2 Dump Issues
  144. help removing transfer case
  145. wastegate overboosting
  146. boost loss/inconsistent boost-did search
  147. Quick Rear Diff/Axle Question
  148. maperformance o2 housing?
  149. Rear diff pulsating?
  150. Dual flapper or single flapper 10.5?
  151. oil pan question
  152. Help Please! Running rich, Wideband reads like a narrowband
  153. largest bore in a 4g63......86.5?
  154. Baro Press CEL and no Idle
  155. Putting in arp studs without taking the head off bad or good?
  156. Evo X SST transmission swap into EVo VIII/IX?
  157. wrist pin retainers, why...
  158. Carbonetics Rear Differential
  159. JDM Exos manifold vs USDM Exos manifold
  160. Replacing the clutch
  161. Tomei ARMS??
  162. Cannot remove tcase from the trans.....
  163. basic stock turbo mods... I dont want an intake.
  164. Tomei Poncam discovery in my Evo8
  165. Can the balance shafts be removed with motor in car
  166. Blown CAT?
  167. Shearer Fabrications 3" External 02 Dump Prototype!!!!
  168. slippage under higher boost
  169. video of my 2.3 with FP4Rs at idle
  170. PULL type clutch? Someone Please Explain
  171. Question about injector seals and o rings
  172. Estimation for this That A set Up !
  173. Air temp v.s. Air flow
  174. Locking up the ACD clutch with a switch?
  175. Dual Pump wiring Diagram for contstant power to both pumps
  176. Dual Pump wiring Diagram for contstant power to both pumps
  177. Question on clutch engagement point (Evo 9 + ACT)
  178. HELPPP please
  179. Need help restoring lost performance.
  180. BBK Vs Fp green hta 73
  181. Non-CDI COP as one of the first mods
  182. EVO III Advice..
  183. Has anyone faced the consequences of running the oil pump out of phase?
  184. problems with perrin turbo intake
  185. Stronger Transfer Gears?
  186. Dry nitrous setup
  187. Rear diff and t-case fluid
  188. "hanging RPMs" at speed...
  189. BC 2.6 Stroker Engine
  190. Need Turbo Advice for High Revving Time Attack Setup
  191. tried amsoil SSO today
  192. buschwacker tranny upgrade nd twin disc
  193. FP Red
  194. Please read!! Failed QuarterMaster Twin Disk. Literally getting VERY PISSED!!!
  195. Timing Belt Gone Wrong
  196. Question about turbo oil seals
  197. ATP 3071 bolt on turbo
  198. Rod and main bearings clearance.
  199. stock rod high hp runners/tuners
  200. 2.0 vs 2.2 for Drag race
  201. cusco front power brace question
  202. Joe Gibbs oil...
  203. Hole in tanny.. HELP!
  204. FPblack dyno charts are cool and all but...
  205. How Much TORQUE!!
  206. ACT 6 puck owners
  207. Installing fuel pump
  208. Transmission Overflow
  209. Car won't go into gear. Help!
  210. what if.....?
  211. ???? about turbo turbine housings
  212. smell of rotten eggs from motor
  213. Cooling Problem
  214. Evo 8 Idle noise... similar to sticky, but not <video>
  215. Converting to a exedy Triple disc???
  216. what can this motor rev to?
  217. Rebuilding the 20gmr MACHINE
  218. Flywheel dowels don't line up with clutch holes
  219. Clutch Issues ??
  220. What is needed to run a Mivec Head on a Non Mivec Block
  221. why dont too many people use 4/6-puck clutch's
  222. Price to rebuild a blown BB 6262?
  223. HP difference between the New green,and old green????
  224. fp black questions
  225. hallman MBC
  226. Underdrive pully cant be balanced :(
  227. Quartermaster uninstall
  228. This is **** UP!!!
  229. Weird vacuum readings
  230. clutch is slipping need some advice im an amature
  231. Drag Cam Recommendations
  232. Car is coming out of gear
  233. leaking boost??
  234. Holset powered Evo IX
  235. Insight on mods?
  236. What to put inside Oil Catch Can?
  237. Exedy Pressure Plate Difference?
  238. Supertech Single springs - When do they float?
  239. redline or Amsoil for 6 speed MR tranny?
  240. when to do a timing belt ??
  241. Turbo XS BC won't go over 15 psi
  242. 6 puck clutch
  243. WHere can i get the cheapest Exedy triple disc clutch??
  244. Cusco twin plate clutch
  245. exedy twin hd - real world results
  246. Competition Clutch review
  247. too thin of a flywheel?
  248. Any one use the TTP E-85 Injectors?
  249. Bad knock and almost everything is checked! Need ideas
  250. Help! Heater/ Water pump/ Solenoid noise
