- whats the best spark plug to get?
- ISC valve variations...03 - 06 interchangeable?
- changing radiator. How much cooling fluid should I put
- Looking for a high flow cat
- gt3076r vs Evogreen
- Spark Plugs for 400++whp!
- What would you change?
- Miata battery?
- HTA 35R nipple pressure source location?
- Rebuild kit for a TIAL BOV....
- FMIC Upgrade
- Evo Part Out
- 50trim cams
- Basic Trans Rebuild?
- What size ICP
- Cusco RS differential install help
- Stock Turbo!!
- 80mm Test Pipe?
- my head flow gains
- Another pump gas monster 35r evo awakes
- HTA 30R's?
- Retorquing cosworth head studs required?
- Boost problem
- Tial Recirc. Valve
- plz help! shifting problem
- overheating issues HELP
- AEM Logs and Other stuff from Our 162mph pass. Dont make fun of my Granny Shifting
- 20g turbo wheel question
- Misfiring after spark plug install. Help!!!!
- Finnaly done....16G antisurge
- Boost gauge T placement
- T3/T67 HO on anyone's Evo? Results?
- Ok to Tee off fuel pressure regulator?
- Which is less damaging to Evo drivetrain? slick vs street tires
- Fan Speed
- Need Some Help Guys. Much Appreciated.
- Evo 9 swap into 8, Has anyone done it?
- hks gt3240 vs apexi rx6
- Help EVO VIII Major Problems
- hybrid turbo experience - small exhaust & large compressor
- Evo 9 turbo question
- need help have a list of what to buy
- T3/T4 .60 A/R- Worth it?
- exedy hyper single rebuild kit
- Hi all from a noob. Quick question
- what should i gap my spark plugs at?
- can't get clean shifts, exedy twin disc clutch dragging
- MR T-case and Rear Diff OEM oils
- GSC S2's, stock turbo
- Exedy Stage 2 Clutch Feedback
- Blah, Clutch Problems :(
- ATP Turbo kit Dyno results,,,,
- I need a coupler
- clutch freeplay enguagment????
- Anyone ever think about running a cut out on the test pipe?
- Major Roadblock! Please Help!
- Anyone use the AEM Water - Alcohol Injection Kit?
- Who's out there running a 35R and Nitrous Oxide?
- estimated gains from bushur parts + others
- 6 SPEED OWNERS interested in special tranny fluid?
- clutch ?
- Driven Innovations Intake Manifold Saftey Notice
- SBR 2.5L Put to the test! Slowboy Rally engine takes to the streets!
- would this work
- QTP CUT-Out
- ACT Extream 6 puck?
- WOW!!!!! What a Comparison!!!
- Problem in wastegate/arm/actuator/MBC? HELP!
- Greddy Type S bov
- anyone have experience with these manifolds?
- Cosworth M2 and MR 02 Housing got 1 extra HP????
- Baffled muffler so the cops will shut up?
- timing mybe 180 degrees off (help
- need help here???????????????????
- Pre Lube Tank for Proper Engine Oiling
- Which stroker kit? Which crank? Which turbo kit?
- High hp but low torque on stock turbo set ups? Why?
- Best Oil for a Race Motor??
- Car in Neutral, let clutch out, car moves
- Maintenance time
- 2.6L Engine almost ready
- PLEASE HELP I have evo 9 GR.A but
- Rebuild Head, now problems.. Need your help badly.
- Oil cooler before the turbo
- Weird jerking
- 280/280 cam on stock turbo
- Go Fast goodies just arrived in Puerto Rico
- Convert EVO 8 to Mivec?
- AMS 50trim kit on and tuned
- Fp green help needed
- Help Troubleshoot: 2 dead heater cores
- AWD Motorsports Evo VIII.. 378whp / 367tq.. PUMP GAS!!
- Exhaust Housing for FPGREEN
- Running out of cat converter
- HKS DLI 2 or Sunauto hyper force
- Effects of a faulty IACV?
- HKS 4G63 Engine Oil
- Cant decide which clutch?!?!?!
- Exhaust leak or normal? (pics)
- signs of a bad fuel pump?
- HKS 272's
- Turbosmart boost controller with AQ HSF-1
- turbo oil line problems???
- Should I sell my EBC for a MBC?
- Dyno Flash Evo ready to battle at next weekends Buschur Shootout ! (dyno video)
- Re-Tourqing headstuds
- Advice: Installing Head Gasket on my IX!
- No start after fuel pump and injector install
- STOCK BLOCK, Pump Gas record??
- Anyone use Jack's Transmissions???
- Cusco vs Exedy twin discs..
- Turbo XS TBE silencer?
- leaking turbo oil drain hose
- Ikeya Formula Sequential Shifter
- Idle noise!!plz help
- evo 9mr growling
- 18psi Wga?
- NEW EVO what bolt ons to get need help!
- Cutouts
- T-gt3071r
- next step for more power in my 8
- Long Rod 2.0L. Anyone have it?
- Will my Megan Catback and Megan Cat Delete for IX fit on VIII?
- What Rods should I use to run 40psi+ boost?(I have Eagle Rods right now...HTA37R)
- Anybody regret going Green?
- swaping out stock boost gauge
- Injectors for FP3065?
- Can I paint my intercooler?
- Installing Cams: What Do You Need To Replace?
- ETS HTA3076 It's Here!
- service engine soon light! HELP!!!
- Suman's Revenge Part II - 633 Whp on Pump w/ Meth
- Oil Smells like gas
- Injen intake with turboXs bov?
- Low Hp Need Help.!
- Gsc S2's Without Springs And Retainers?!?
- Looking to move into fp green territory?
- Plug wire arcing?
- Question about Greddy EVO2, Tanabe Touring Medallion exhausts
- Converting a normal Lancer
- 35r Dissappointment then Happiness
- Is there a video of an Evo with the launching aide... launching?
- Help boost sensor not reading correct
- Help Boost sensor not reading right
- Vent to atmosphere?
- o2 housing install from hell
- RPM Acting Wierd
- Injen HPK= LOUD
- Shep transfer case help (again)
- transmission trouble
- Belt Snap.... help!
- Buschur mini battery kit
- does my hp sound right for what i have done?
- Royal Purple Synchromax?
- weird clunking noise!??
- Camshaft Position Sensor Installation Help Needed
- cbrd- some different dyno plots...hta, etc..
- (MELT-AGE) PULSTAR PLUGS you've NEVER SEEN BEFORE Guaranteed
- Question for David Buschur - missing power on pump gas "baby Bish"
- 3076 or 3076R
- can someone help me decide?
- Something wrong with this manifold?
- Hitting 350 whp
- waste gate question... need help asap!
- GL5 75-90 in all tranny !!! Is it ok?
- Team English Racing Get's Her Done
- 30R vs 50 trim which is better for daily driving?
- Alternator
- Project 10 second daily......
- Evo green power difference
- Turbo Reassembly
- Pump Gas on the stock ECU wars
- Batt relocation
- Downpipe
- Coolant Leaking after car is turned off!
- Defective AeroMotive FPR... Somehow but maybe ?
- HTA3076R vs FP3065
- Oil leaking from my exhaust mani gasket
- Where do you guys tap in for water temp?
- When do you need to O-ring the block?
- Intercooler piping kit
- Mustang Dyno comparison.
- UICP question
- Tuned - couldn't go over stock boost
- Turbo Kit Choices!
- Turbo Kit choices!
- 35r Profec B Settings
- Shifter Bushings
- aem oxygen sensor help.
- boost won't go higher then 15.9?
- 24R Owners And Experts; Need Some Advice
- Car wont go into 5th or reverse.. and got stuck in 4th.
- Install of BOV
- Boost Issue.
- got some questions on removeing engine
- Amsoil Ea Cone Air filters
- Top mount vs bottom mount manifolds?
- Question to EvoM members
- 6500 step not cutting it!!!
- Rnr 30r Turbo Kit
- Slipping Clutch
- Rapid Cylinder Wear??? w/pics
- My Goal is anything above 380awhp on my ix
- YES or NO on ACT
- quick dumb qeustion
- HELP!!! oil in intercooler and only boosting 12psi!!!!
- another CBRD twisted setup...
- Changed the Intake mani = lean air fuel
- Spring Type Noise
- D@#$ Radiator!
- hi i may be a novice but this is my question
- Please Help: Want to switch hotsides on AMS turbo Kit
- Evo 7 Injectors (Impedance Question)
- Car wont shift into second..
- EVO9, California 91 octane, a little alky and 500+ whp
- Anyone use Fidanza Clutch
- Buschur Racing Dual Stage MBC Installed - PICS!
- Suggestion on what to buy
- Clutch Slipping?
- Rod bearings issues for Evo IX GSR
- AMS Vs ARC Vs HKS FMIC
- What's causing my misfire/rich condition
- Twin-scroll skeptics...
- resistance on egt probe?
- Buschur Pump Gas domination
- HAFE O2 housing problem
- Which Intake and IC Pipes do you have? New product in the works.
- EVOLUNCHBOX sets new pump gas record on BR's dyno!
- ACT XTSS vs HDG6 6 Puck
- Wheres the oil?
- EVOLUNCHBOX's build, big power.
- it just keeps getting better and better: i have evo9 block with evo8 head??????
- help want to reach 400whp
- Sneek peak of my new setup!! 56K better luck next time
- prosport exhaust manifold
- how much power before forging engine
- Gearbox Problem?
- Which Race Fuel Does everyone use?
- buschur racing transmission w/ stock transfer case?
- Turbo Change
- evo9 transfercase ?
- gt35r... help plz..
- Making 380WHP with $635
- moroso oil pan
- Oil Temp Problem
- Evo 8 Upgrade Questions?
- Video Clip: Cosworth M3 cams, Greddy Ti Catback
- typical post turbo charge air temps
- need help! strange idle decreased boost
