- Buschur "scca legal" catback yes or no.
- Best Standalone Comp
- quatermaster 8 leg clutch lock out in 4th gear?
- PCV Blowing out after catch can install
- ACT or Exedy stage 2 Clutch??
- need some advice....
- Rear diff error when wet
- Best Place to Buy 1st gen 4G63
- Suggestions on Transmission Gear Oil..
- Rod Bearing? *video*
- Where does this vacuum hose go? pic**
- Buzzing noise when I press the clutch
- Making Evo8 2wd for dyno purposes?
- leak from passenger axle
- Ignition systems
- Evo 5 sudden stall problems?
- will evo 9 wide tank ETS cooler fit evo 8
- Brand new HTA3586 bearing noise...bad bearing?? video inside
- Strange clutch noise w/ video
- Slipping clutch(hydraulic release beaing)
- Should I keep my stock oil feed location for a stock turbo running high boost?
- Basic (newb) Turbo Questions
- Cusco catch can issues
- Greddy type s bov
- Cam recommendations big turbo 6262 2.0
- ACD Relocation Help
- Help me with my potential build :)
- EF3 owners
- flywheel bolts
- Cat vs 6" Mid-Muffler - Which is Quieter?
- Amsoil Oil Filter Change
- Can an oily clutch be clean & re-usable?
- Clutch measurement question!!!!
- Forward Facing Manifold and A/C?
- Help~! Engin cuts (0RPM) on freeway, now can't start.
- need info on fp black!!
- ACD and MPG/Tread Wear
- For 4G63T with over 300WHP Gates or Mitsubishi timing belt?
- different bov sound
- Cams / heads / turbo spool?
- Fp red buy or not?
- spun main bearings now what
- P0420 Help
- Question about used Exedy twin disk...
- Anyone tried the eBay throttle body 70mm??? $129
- benefits of hydraulic release bearing over carbonetics/comps bearing?
- 9MR Trans Cooler Complete & Data
- need help with oil passage identification
- Quartermaster Failing?
- Transfer case fluid leak
- Bov? Recommendations
- ets upper intercooler piping not fitting right
- Need help with evo info
- 03 EVO VIII Radiator
- Metal shavings in transmission fluid
- Weird noise from rear evo 8
- Spark plug fortune tellers, come and see (Show & Tell)
- Help choosing a turbo for a DD
- Exedy twin plate noise
- Pennzoil Ultra vs. Mobil1 a fact or not?
- transmission issue..
- What happens if a Riced Econobox won against any EVO?
- Slow.Evo Build
- Engine Seized? What should I do.
- Rattle sound from clutch/tranny
- Looking for some input on clutch slippage.
- Brad Penn 20w-50 milage question
- Engine forged built 10W-30 or 10W-40 synthetic oil?
- 4G64T builders - Please look.
- not spooling until 6k
- Low speed whistling noise?
- gt3582
- opinions on injen fmic
- help if ya can
- ACD Pump gurus. Not your basic question. I need help
- EGR Delete plus Tune
- What will be a best Header for a 2.3l pte 6266 CEA
- What's the easiest way to replace your knock sensor?
- Getting locked out, need ideas.
- Stiffer Steering Response?
- Evo 5 only running 9psi?
- Compressor housing o-ring question
- What's wrong with my car!!!!
- how important is it to rewife the fuel fump to get power from the battery
- Evo 8/9 Magnus SMIM install - throttle body flip?
- Twin Scroll stock Frame With External Wastegate
- Where does this go (Exhaust)?
- Pte 6262BB won't spool on 2.0L block.
- FP GREEN 73HTA questions
- overboost evo 9
- Over heating under WOT with all new cooling system at 22 psi on HTA86
- Piston oil squirter tube in oil pan. Need suggestions.
- Entire car vibrates at about 70-80 mph
- can anyone verify that these clutch splines are stripped? *pics inside*
- HTA3786 Results?
- Need Help!!! Trying to release TOB and wedge collar is stuck!
- What is the best clutch and flywheel for evo 9
- IACV 8 vs 9, part number
- Carbon Fiber Goodness
- Shep Ultimate Transmission
- Can you Swtich from ACD to Non ACD
- Competition Clutch 6puck with Double Diaphragm PP!!!
- Why do 2.4L's have such random failures?
- Evo 8 Hotside?
- Accessories belt tight
- EVO 8 Transmission drain plug
- highest compression for pump gas
- Replacing water pump
- Transmission problems! 03 Evo VIII
- FIC 2150cc problem firing!? Help
- Evo 9 Coolant leak
- acd solenoid-how does it attach?
- DV recomendation for 22-25 psi ?
- Which Fuel Injectors will suit me?
- Evo starting issues
- How much can a stock Evo 8 drivetrain hold?
- Transfer Case whine? Options?
- Transfer case help
- last inch of rear axle does'nt go into the diff
- p0300 Misfire like hell
- Turbo drain (pan side) fitting
- Why can't my boost taper like normal?
- NEW 6466 came today
- Fuel pump help
- Engine squeals when cold after 60k
- Bearing clearances on a 2.1 build
- What the best timing up to date for a 2.4LR with pte 6766 or 6466
- Max boost a FP Black can run?
- evo 8 idle problem
- Need help with build ... 6 k budget.
- STM Half Radiator
- distribution box replacement?
- Another clicking noise thread
- Evo 8 11 psi max boost? tried everything.
- Crazy bucking when I hit any boost?
- Waste Gate Actuator Pressure 18 psi 25 psi whats that all about?
- what is this part?
- Evolution 4 Pilot bearing
- Starter spins but doesnt engage flywheel?
- Preping for Bigger turbo
- Ned help with wobbly shifter.
- remove ACD pump evo9 to relocate
- Magnus V5 Price Drop
- transfer case filler plug size?
- Idle problem
- Best options fro 2.4l shortblock
- Grimmspeed 3 Port Questions
- evo 8 megan manifold
- evo 8.5 turbo question
- will the Driveshaft handle a 2.3 stroker?
- FP 25psi WGA Question
- 6 speed short throw shifter
- Speed-source shifter bushing kit
- Torque Solutions Short Shifter impressions???
- How to Remove Engine Harness from Fuse Box?
- What do you see in the picture ?
- megan o2/ams downpipe hits tc?
- help diagnose culprit
- What Fuel Rail to use with the Full Blown TB
- Clutch break causality
- Notchy 2nd Gear...
- Transmission noise/sticking in gear
- Why my serpentine belt tore out?
- Gsc s3
- In boost wot engine breaking up 100% time. First things to check?
- cons of daily driving on 285/30/18?
- Can I use OEM headgasket with bored block?
- Is this too much for main bearing oil clearance?
- A very reputable shop tells me otherwise
- New Cosworth Race cams 280 and 290
- Advise on clutch for my usage? please!
- bolt on ?
- Type s recirc adapter. Interchangeable for a type rs?
- 02 sensor need help with tech aspects of the sensor and CEL
- BR Clutchless 4 speed in the 9's and M&H Slick update thread
- Goal of 400-450hp
- AMS 2.3 Build Fuel Question
- Quartermaster issues
- cylinder head porting
- Engine guru needed
- Help wavy boost!
- Evo 8 Shep Tranny 2nd Gear Help!
- Low Oil pressure problem on Evo 8
- Stock MR Oil Temp Gauge Sensor Connected to Aftermarket Gauge
- Cams for evo 8 DD!
- 3rd gear gone plese help
- Boost Leak test Before/after shaft seals
- Evo 8 Trust Exhaust??
- Evo 3 Clutch into Evo 6???
- If cost was not a factor; Stock frame or T4 setup for 450-550 hp
- Just bought this car, was this installed wrong??
- Technical cam questions
- Best sealant for -an fittings?
- Boost leak? need help!
- Timing Help! Piston not at highest point at TDC??
- Wiseco HD piston questions
- Questions about reassembling bottom end
- Timing belt Crank sensor rub
- Blew my motor!!!
- Smoke
- Any Shop want to Build my Longblock ???
- Sounds like card in bike spokes
- Boost controllers options
- Aftermarket fuel regulator
- A closer look at H and I Beams Con Rods
- Can rotating the motor in the wrong direction, cause a loss in cambelt tension..?
- what would cause this to happen?
- HTA 86 to 6466
- is this transfer case whine going bad?
- eBay Fuel Rail
- Evo 9 possible diff problem?
- Can a stock oem oil pump withstand 700awhp?
- FIC 1250cc Blue max(91/93 octane) any reviews ?
- ATP GTX3076R install
- Another low oil press. thread (evo IX-MR)
- Engine and transmission cost, Help please
- best pistons for 2.4lr
- pulled DS Axle and stub shaft came out (no c-clip)
- 1000cc ID injectors or Precision? or any other options?
- Fidanza V2 ... Anybody?
- evo 9 MR is down halpp
- White smoke coming from hood after rain?
- New Engine build advice.. 700whp
- Differences between evo 8 and 9 intake manifolds?????
- Who had a JB Green built by FP????how long did it take???
- Koyo radiator question
- Evo 4-8 transmision compatibility
- Can someone verify this FP Green?
- stock frame or big turbo for 600 awhp?
- What are my spark plugs telling you? *PIX*
- New Garret custom core pics
- Need advice on best clutch for my DD
- Switching from HKS 272 to GSC 2s
- Possible reasons for fuel pump shut off
- How does my timing belt look?
- Interchangable WBO2 Sensors
- question about cams
- P0335 after rebuild. Cranks, no start.
- Cerametallic and resurfacing
- Compression test results - thoughts?
- High Idle and Idle Surge only with AC on when engine is cold
- Best Flywheel for....
- evo 8 ACD system and pump pressures? cant seem to find info on it.
- greenish oil leaking from left front driver side axle
- TB sensors!!!
- Evo3 vs gc8 , drivetrain strenght?
- Tial 44mm wastgate problems
- balance shaft removal from front case
- buschur racing
- Stg 3 clutch and boost spuddering
