PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 [106] 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Dump Turbo?
  2. HELP I drop a bolt!
  3. cosworth big valve head squish setting
  4. need ignition switch
  5. Weird problem after install
  6. does boost controller add power??
  7. PO830 code?
  8. mod question
  9. When Things don't go right
  10. Front motor mount bolt.. question on size
  11. Carbon build up on coilpack
  12. I know you see this title all the time. BUT I NEED HELP!
  13. Full Race Prostock Manifold Installed - Pics
  14. 0-30 or 10-30 AMS OIL??
  15. Just bought an AEM UEGO
  16. A Couple of Questions.....
  17. Got an exhaust question
  18. Aftermarket FMIC weight > Stock?
  19. Headlight intake
  20. Tomei Full Turbo Kit Install........
  21. problem with car idle
  22. Leakdown Test questions
  23. Visual diff. t6 vs t4 vs t3
  24. BOV/Turbo
  25. Poor response at WOT
  26. Damn boost issues...ugh...
  27. Fp Red Boost Creep PLEASE HELP!!!!!!
  28. Battery Maintenance
  29. Evo MR gauges
  30. FP RED Vs Greddy TD06-25G
  31. REQ! camshaft test?
  32. Do ya'll think my motor will last...?
  33. Best place to Buy Quartermaster Twin Rebuild kit???
  34. NEED HELP: HTA 35r Oil Feed Line
  35. Manifold adaptor
  36. Video Of AMS CNC Head.. :)
  37. Which is the Intake Cam?
  38. evo 1 clutch pedal play
  39. Block guided for head?? how to take out
  40. Should I swap out my cams?
  41. So, what do I need to do to solve the HKS intake idle prob?
  42. Any one using the HTA86 aka FP HTA3586 w/.63 AR Hotside???
  43. What exhaust manifold to choose?
  44. Buschur 2.0 liter motor pics just arrived
  45. garret gt28rs?????
  46. power problem
  47. UICP, Aluminium or Stainless steel? With & w/o meth
  48. aftermarket cams with a stockish sounding idle for a evo 9?
  49. Motor Rebuild (Only Rings & Bearings)
  50. service engine
  51. Question regarding Greddy Ti-C Exhaust
  52. so I replaced my TB shaft seals...
  53. Fuel Rail and Fuel Pressure Regulator Question
  54. Acessory belt broke, please look
  55. transmission question ?
  56. Right rebuild kit for the TD05HR?
  57. Did I get the wrong ebay o2?
  58. what is this?
  59. 4g63 block
  60. idle problem??
  61. Ticking noise
  62. Tomei Arms Turbo installed!!!
  63. Okada or HKS
  64. Installation beehive of valve springs
  65. Just ordered Fp Red, quick question. Thanks.
  66. PROBLEMS!!!! Need help guys.
  67. How can I seal up the hole?
  68. Trouble getting into First Gear
  69. High Powered Cars Running the T3 .63 AR Hotside??? Please Post in here!!!
  70. Is it possible for me to get close to 400whp with the following
  71. anymore twin turbo developement?
  72. OEM Timing Belt Limits?
  73. Bearing for eagle rod. ( broken engine )
  74. New addition!!!
  75. Ebay O2 Housing help.
  76. not sure on which clutch to buy
  77. Turbo inputs
  78. Buschur Racing begins "Project White" a wicked street build.
  79. o2 Sensor?
  80. Gear Noise... Please help!
  81. Do-Luck ACD controller evo 7,8,9
  82. Problem with HiFlow Cat!?!?!
  83. Test Pipe Help...?
  84. Test Pipe..?
  85. Short shifter for evo?
  86. Air Bearing Turbos in Testing
  87. Turbo doesnt kick in (cant go more than 40 MPH)
  88. Favorite Exhust Set-Up
  89. AEM Map sensor & stock intake manifold question
  90. Seperating the T-case????
  91. what to do
  92. Help! I think my transmission went bad.
  93. Installing Cams do I need new Timing Belt and Tensioner
  94. ->Perfect weather, perfect shifting<-
  95. FP Valve Springs
  96. Syncro tranny fluid
  97. Battery
  98. AMSOIL MTG Transmission Oil
  99. Valve Springs for M2's
  100. Cam Gear Questions
  101. Removing Cam Question
  102. PTE6765 on stock ecu??
  103. AMS 2.3? or Cossie 2.2 ?
  104. stm oil cooler
  105. Is my clutch going out?
  106. No Cats -- stinks worse than other cars??
  107. need help asap
  108. Head gasket?
  109. Porting
  110. re-adjusted clutch pedal.
  111. Whistling noise when car is driving!
  112. Car will not start....pulled codes and need your input
  113. Filter size affect power?
  114. Question on bov sound?
  115. Turbo Question
  116. EGR blockoff plate for the head?
  117. Extremely disappointed with EPM o2 dump
  118. Fuel Management Idea
  119. SBR SS Manifold?
  120. 1996 evo 4 blow off valve replacement
  121. Painting Headers ?
  122. Driver side axel popped out
  123. open dump for stock turbo
  124. T-bolt clamp help
  125. BOV VTA or Recirculate
  126. Exedy Twin Users with High HP Please Chime in!!!
  127. MHI Turbo and Blouch Turbo Same Thing?
  128. Stock Tranny Longevity ?
  129. Evo ECU Reset after Clutch Upgrade..
  130. 4g63 to a 4g64 block
  131. Just Changed Clutch & Now Check Engine Light On
  132. oil pressure
  133. boost problem evo 8
  134. turbonetics 60-1 hifi turbo
  135. installed new clutch need advice
  136. changed tc and tranny fluid (put royal p 75 90) is that ok
  137. skunk2 TB?????
  138. Gearing on 06' IX SE
  139. gain restored power from timing belt?
  140. Tial 50mm Q
  141. ATP turbo kits?
  142. Sae90
  143. how do to make sure its a 10.5 hotside?
  144. Has anyone tryed them Ebay gt35r turbos?
  145. Bosch 1000cc injectors on an Evo
  146. tell me about this turbo??
  147. noob exhaust product question
  148. Can someone help?
  149. FP Reds.
  150. Turbo XS FMIC brackets help
  151. Valve spring question for 280 HKS
  152. Intake pipe = boost creep
  153. Wrapping Full Race Headers?
  154. welded wastegate flapper on stock turbo
  155. what gear oil to use?
  156. e3 spark plugs
  157. Stock Radiator!!!
  158. Lower Radiator Hose Pressing On Linkage???
  159. **help please**
  160. aem oil pressure gauge help
  161. Oil residues in the coolant reservoir tank
  162. il residues in the coolant reservoir tank
  163. clutch or the tranny problem?
  164. need recomendations
  165. Problem (warning somewhat lengthy)
  166. a/c clutch clicking/ticking
  167. I wanted to show you guys something I've been working on.
  168. Max power on stock exhaust??
  169. NEED HELP: unstall turbo kit new one on!
  170. What o2 housing to choose???
  171. next step?!
  172. Help, will any 4g63 flywheel bolt work with Evo?
  173. Throttle Body Coolant Leak?
  174. GT35R boost creep
  175. 60k service
  176. BR double pumper or Full Blown for 700hp
  177. Turbo problem?
  178. Twin disc going out?
  179. OEM Replacement Plug Wires & Boots Won't Snap Down
  180. anyone removed the harmonic balancer
  181. Bov?
  182. Spark plugs & Gap for Evo9 on Meth
  183. Megan Racing vs. BR Magnaflow dB ??
  184. headstuds / cam install questions?
  185. GSC S2 cams or Kelford 280 cams for FP red
  186. Quartermaster twin, please some info...
  187. Upgrading turbo
  188. Need Help....Hard to Start and Idle Issues....
  189. Need Help....Hard to Start and Idle Issues....
  190. Built Block...What motor oil?
  191. Royal Purple 75W90
  192. At what stage is it best to buy injectors?
  193. How much for evo ix stock exhaust FULL
  194. Questions about oil pan
  195. apples to apples
  196. Think I need a Clutch...
  197. What HKS turbo is most like the GT35?
  198. i need the length of your...
  199. Cold engine full throttle?
  200. replacing cams need some suggestions
  201. Need Some Helppp!!
  202. To much pressure ? Loose connections ?
  203. IC sprayer problem
  204. anybody has idle problem?
  205. Boost leak causes knocks?
  206. how many people replace they clutch at there house?
  207. Greddy RZ BOV
  208. Anybody know whos Evo this is??
  209. p0138 code
  210. Where can i buy a "rally" style E-brake?
  211. M2's on Stock 8 Turbo
  212. car leaning out??
  213. Ignition setups
  214. oil return line being a pita
  215. Buschur RACE FMIC and AMS UICP?
  216. how to plumb boost control 101
  217. wear and tear?
  218. Tranny problem-- how screwed am I?
  219. Cracked/holes in tranny housing
  220. EvoPowerMods o2 dump vs QTP o2 dump
  221. Best Way to fix Rear end Clunk
  222. 3 evo in Russia (help)
  223. Stock rubber intake BR air filter kit?
  224. Dual pumper questions
  225. 6 Gear Lockout
  226. Wastegate to atmosphere ?? need some help
  227. Are all 5 speeds the same?
  228. fuel system for 800hpevo
  229. Funny metallic click noise
  230. test pipe questions
  231. help with mods
  232. Ignition options?
  233. is my turbo f***D ??
  234. car won't idle :(
  235. Attn engine builders
  236. Emission questions
  237. Precision 6162 on stock exhaust manifold
  238. Took my Evo in to dealer to get checked for whining noise
  239. self fit drop in's rods/pistons
  240. downshifting during clutch break in?
  241. antilock light
  242. Evo 9 rear o2 sensor
  243. Timing issues help please...look inside
  244. Exedy twin Specs
  245. hks 280 cams
  246. Evo9 Clutch pill
  247. From HTA35R to Full Race Borg Warner Setup
  248. About to buy an 02 housing...need help
  249. Can the stock clutch handle 400whp+?
  250. Clutch line help.
