- fuel pressure gauge, EGT, fuel rails, fuel bumps
- For people who swapped to 10.5 hotside
- just a ?
- HKS = 0 Stock intake =1
- ECU Wiring Diagram - EVO 9
- set-up
- Cat Delete- Resinator/Testpipe??
- Injector questions
- I Need A Fridanza Flywheel!!!!
- no boost after manifold install??
- Help going from EBC to MBC
- Simple list of parts needed to replace clutch.
- im scared...is this normal
- replacing ball joints
- Main and rod bearings question
- Quick Responses: Clutch problem
- po134...
- Inconsistant Boost - Please Help!
- which cat back
- anyone tried Redline MTL oil?
- should I wait to change fluids?
- which buschur intercooler
- Would a Garrett T3/T04E Hybrid Turbo fit an evo
- removing auto-tensioner...
- boost problem
- Clutch reccomendations?
- clutch vs friction plate....
- Megan Cat-back using stock cat problems!
- fuel injector questions..
- what to buy when changing clutch?
- ACD Settings? Snow, Gravel, Tarmac?
- What to do with $4k
- Best turbo kit for the evo9 MR
- glazed or toasted clutch?
- removing passenger side motor mount...
- What are you making on your 2.3L stroker kit????
- Why doesnt the stock turbo hold boost to redline?
- Kavlico (AEM) Boost sensor question
- Which Vendors Sell *9.8 hotside and *Studs
- Do timers actually do anyhting?
- EVO IX comes with an Aluminum BOV
- Super Major F'ed Up problem
- Weird A** Problem - BOOST CAPPED at 10PSI + Dealer Story + VIDEO
- New Evo owner
- Intermittent problem: only boosting 11psi
- i miss my evo
- Which dyno do you prefer and why?
- alky kit install: pics and a question
- Center diffs
- Hole in my clutch housing, on tranny, caused tranny leak. Dowel Pin flew out
- fuel pump going out because I never fill the tank FULL?!
- arp rod bolt torque
- o2 simulator
- Oil Filter Size
- Block O-ring opinions requested
- Racing Suction RELOADED?
- Cheap aftermarket manifold solutions
- Mods I've been thinking about....
- Evo 05 tranny question...?
- HKS Carbon Ti Exhaust Owners Please Read
- Stalling
- RPS vs TILTON C/C
- Question on transfer case fluid...?
- New Clutch...expect harder shifting?
- wont start
- My review of the Zaklee Shifter bushings on my 05 EVO
- Safe Boost levels for everyday driving
- Bolt in Turbo Question?
- 6000 miles service
- APS BOV sound
- ACT Clutch and High RPM lockout issues ??
- Jic and HKS
- What should i Do??????
- alternate locations for alky control unit
- GT35R clutch suggestions
- Perrin Mbc
- Alky gains while only pulling fuel and not adding timing?
- RSR Exmag exhaust
- *EVO* Clutch
- Case study # 109 - 90,000 miles with Dyno Flash - 366 whp !
- My Evo Project
- 550.8 on pumpgas, Shearer Gt35R
- Best cam gear settings for 272's at the strip?
- Anyone running the Weapon R intake manifold.
- Exedy Twin Pate CLUTCH
- evo coolant
- Black button on Alkycontrol control box???
- one-fab turbo manifolds.anyone using them?
- BOVs.. STOCK PIPES..??
- BOV vacuum line for boost gauge, ok?
- turbo question
- Engine Problems
- DC-Sport Manifold & Helix 02 Housing
- Cat-back choice
- Alcohol trunk mount kit?
- Need help BAD
- Boost issue on my 05
- To O2 housing or not
- Knock Detection
- which line for accurate boost?
- tranny grinds..
- boost setting w/ injectors and fuel pump
- NEED base AEM map
- Devils Own Alky Kit
- piecing a stroker kit together..opinions please
- Little help?
- Cam Gains?
- Can Everyone help me think of the possible leak points for a tranny?
- LPH 255 or Walbro 255
- Some questions about my axles..piqs included
- Megan racing o2 housing and manifold?
- Tre?
- MD Mustang AWD 500SE Dyno For Sale
- Help! Need Part Number
- Anyone who has a cutout read this!!
- Hurry, QUICK ? on 02 mechanical fix..
- Greddy Type S help
- To 6puck or not to 6puck....
- Hks 2.3l
- CAI, Works P1 Flash, little off on boost
- Donut Gasket between O2 & Downpipe
- espelir vs fujitsubo
- how to install zeitronix zt2?
- AEM wideband hookup
- help!!! wont start
- Clutchslipping???
- A question on boost setting on 91 w/ studs
- Precision Dyno..RETUNE IX...
- A way to go maf less (map)
- 270 whp looking to be at about 290 whp
- what happened to my boost? 19--->11 psi
- blitz diffuser (o2 housing)
- HELP..HKS cam gear timing marks
- signs of a leaking BOV?
- power fc question
- 5th gear grind
- people w/ adjustable cam gears
- Can stock clutch hold 500awhp on the Dyno ?
- Which turbo manifold is this?
- PO134 code after mani & o2housing swap..
- Is there an octane rating for denatred alcohol?
- NEED HELP.. car hesitating
- Which One?!?!
- sc61 vs. gt35r
- The hardest gear to shift into
- Anyone running Turbo XS turboback ?
- TME turbo/cams/fuel pump install Impressions
- Highest WHP on a 3076R
- 5-speed vs. 6-speed box
- Having serious boost problems...... PLEASE HELP!!!
- Recommended Fuel Rails
- WR feedback on latest group buy?
- do you downshift to first or coast to a stop?
- Vivid Racing Power Package 1
- Valve timing belt skipped a tooth (or two)
- why does my car die?
- blow my dip stick out..
- What's the gain from I/C with stock turbo
- Calculating Race gas/Pump gas Mix
- Nisei Intercooler
- Manual Boost Controller
- Helix or tsudo testpipe bung ?????
- Turbo Sputter?
- Scantool groupbuy interest
- AEM instead of Emanage
- Good way to make sure my alky is working?
- how much you pay for labor on 2.3L kit?
- need help
- 272 Cams work in the IX? Ideas - thoughts?
- Lightened flywheel -- Worth it?
- Which WASTEGATE ACTUATOR to Get?
- Yes, I searched?
- SS Clutch line. Remove restrictor?
- Rpm's raise in-between shifts?
- What Should I do next!
- Help losing power!
- revolver cams and valvetrain setup?
- Wastegate install
- hey sup need help
- Any of you guys upgrade your oil coolers??
- Forge UNOS Mounting
- A question for White Rabbit owners
- Which plugs with 100% Meth? still cold ones?
- dnp manifold and 10.5
- Wideband o2 question
- With a new tranny could you......
- Need engine and trans weight
- anyone using HKS clutch?
- Going to be rebuiding my engine soon and had some questions
- AMS (Gt35R?, Gt3071R?,GT3076)????
- car woes.. better but still yes, heres the story
- BG SYNCROSHIFT II or other???
- motor mount question
- Clutch adjustment tips (TRE Tranny and Exedy clutch)
- timing belt tensioner ?
- diameter questions?
- EGR blockoff?
- megan racing exhaust manifold????
- EVO IX MR dyno testing Results
- boomslang harness
- The DiaQueen gear oil question
- avcr help!!!!!
- Does anyone have a diagram of the vacum lines on the intake mani and throttle body?
- HKS twin plate clutch
- Walbro Fuel Pump
- Interesting ACT story 10.53@138MPH
- Hollow Cams Revisited...
- Blew 05 stock turbo
- 272 & 280 cams
- my cams say I hate blow off valves!
- Looking for a favor (if you have a Dynoflash/Buschur alky kit)
- *o2 housing*
- Problems with Exedy HD twin disk
- Piper Cam Vendor?
- Greddy Upper IC Pipe Rub??
- had an issue with the car this morning
- EGR valve question
- Self tuning....I'm having issues....
- Forge Wastegate Actuator
- Leaking Stock Headgasket
- Greddy a Player a Factor
- Exedy Twin Disc Issues
- What does the BOV nipple do?
- oil thread
- Need Fidanza cam gear instructions NOW! HELP!
- Can you use denatured alcohol like
- Anyone know the flow of the stock EVO fuel pump?
- Running rich?
- Motor mount removal
- I need help on clutch purchase
- 10.5 hotside exhaust housing
- Turbo problems.
- EVO Ring Lands
- can i still run my car with 750cc injectors and fuel pump but without tuning
- Need help choosing Injector size.
- BDL Industries???
- My roller rockers went bad? help.
- AMS Packages ?????
- Oh No! Am I screwed?
- Anyone used a Greddy Type R?
- Where to buy Megan racing header and 02 housing?
- tranny parts
- shifting w/o using the clutch..
- Buschur Racing @ SEMA
- need help with which fluids to use
- Do I really need the clear camgear cover??
- A few goods installed...Apexi N1, etc..lots of pics 56k maybe!!
- Anyone bought IX turbo yet?
- boost varying
- Need some help just installed a new clutch
