PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 [158] 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Gates Racing Timing Belt
  2. Nanocomposites in future engines?
  3. Louder exhaust... louder BOV.
  4. real intercooler test on the way
  5. Injector Opinion
  6. Running lower rev limits reliably
  7. where to get intermidate pipe ?
  8. Lazy / Oen WGA???
  9. Valve/retainers and bov q's
  10. Help hooking up wideband
  11. Finally test data for ebay intercooler vs stock
  12. Opinions on the new Buschur cone filter from people that run it??
  13. Buschur turbo flange
  14. help me reach 400+hp or more
  15. Turbo Upgrade
  16. KAAZ and other REAR Diffs
  17. Question for those running E85 and big injectors.
  18. turbo flow numbers
  19. new Spec multi disc clutch
  20. Serious help needed w/ fuel cut
  21. Rear differential noise/pulsations when turning
  22. BR UICP issue??
  23. Quick DP fitment question
  24. Greddy Type-S related
  25. About the DC Sports 3" DP on an Evo IX...
  26. Uprgaded turbo kit w/ pump and no meth. Do I need a wideband?
  27. 50 trim on my Evo V, will be out on wednesday!
  28. power issues
  29. Recommended Max RPM for BR Springs
  30. Engine stumble after closing hood?
  31. Front motor mount + side motor mounts = less vibration?
  32. Ebay Oil Filter Sandwich
  33. Radiator working properly? Simple question, help?
  34. evo 8 and evo 9 intercooler 100% the same??
  35. Wastegate
  36. Is this a 10.5 hot side?
  37. Running higher rev limits reliably
  38. anyone have dyno #'s for a 20g 9 5?
  39. Transmission Problem Help Needed
  40. next mod???
  41. 50 trim dyno #'s are in................
  42. best twin-plate??
  43. I need a transfer case for my evo IV
  44. shep racing tranny
  45. Megan Racing Manifold
  46. need block ID help fast!!
  47. clutch smell
  48. Which turbo for my IX
  49. xs power/ebay parts
  50. ATP Tests Garrett's GT series Turbos, Very Interesting...
  51. Tial bolt sizes...
  52. PeakBoost Kits..Worth The Money???
  53. Boost Tap in Experiment Results
  54. Cam Combinations Need a little help
  55. EVO IX Spark plugs
  56. Tranny Problems?
  57. Rear Diff Specs (Poss. Sticky)
  58. *Two Manual Boost Controller Install Questions*
  59. EVO Motor Mounts
  60. help with adding powa
  61. Paradigm Performance Innovation (PPi) parts installed on my EVO!
  62. So just got my heart broken on dyno
  63. Am I missing anything before the reflash?
  64. WARNING- Ebay O2 housing from ssautochrome
  65. Transfer case???
  66. Instant help needed
  67. Loud Whinning Noice - Transmission?!?!?!
  68. Installed TBE, Lost power...
  69. MBC or EBC???
  70. Anyone running Brian Crower Cams?
  71. Guage ??
  72. exedy sport review
  73. Walbro 255lph?
  74. What next????
  75. Check this crap out
  76. boost leak test?
  77. will standard 03 (non MR) cams prevent my evogreen'd evo 8 breaking 315whp?
  78. who has pro street cam gears??
  79. cat + slow = very
  80. Does the Hi Power need relocation brackets?
  81. Looking to buy a greddy intercooler kit but have ????
  82. MR gearing rpm/mph question
  83. Stock clutch chatter?
  84. EBC whe?re to hook up BOV?
  85. IX Turbo on VIII, How do you like it?
  86. assembling project car 2.3 liter, finally
  87. MBC installation
  88. valves
  89. transmission fluid leak
  90. transmission problem
  91. Weird clutch noise
  92. EVO IX Cosworth Cam install info / FYI
  93. Which Spark Plugs should i use?
  94. Crank walk or bad balance shafts?
  95. E-85 electrical conductivity question
  96. FP3052...anyone use this turbo?
  97. How does the MIVEC actually work?
  98. Help: lowering boost on stock turbo
  99. TANABE Concept G Blue
  100. Gear oil help please
  101. Lean or Not ?
  102. Compression on 2.3L Stroker Engine
  103. High knocks, Low Power
  104. stupid question
  105. Any one runing sls turbo kit or manifold
  106. E85 and Exhaust Temps
  107. Intercooler Question
  108. care to diagnose?
  109. 4th and 5th gear.
  110. tial 38 bolts
  111. Building evo 9 2.3 strocker gcs280 or cosworth272 ????
  112. i think i put stock dv wrong way
  113. mivec assembly pics?
  114. When to Start Part Porting?
  115. HKS RS Intake
  116. Which EBAY intercooler
  117. Parts on hand for Green install??
  118. Bought used EVO with lower IC pipe. How do I tell which one?
  119. Leaking from BOTH axles after clutch install ??
  120. Question about GT35R
  121. compression test
  122. FP EvoGreen + AMS VSR?
  123. can anyone give me some info on stock 05 turbo.
  124. VTA BOV mount location?
  125. Fixed my codes
  126. Quick Question
  127. pressure drop in turbo xs intercooler
  128. Bigger Injectors?
  129. Bigger Injectors?
  130. Roll cage ??
  131. JDM anti lag runs off DV output?????
  132. Next mods for bolt-on Evo IX? cams, meth, or evogreen?
  133. AMS TBE IX MR rubbing
  134. gauge help
  135. Where is the best place to get a Short block!?
  136. Car boosting slow, loss of power
  137. Dp
  138. Low budget T3/T4 maifold combo!
  139. Home made oil catch can thread - post your pics
  140. mbc location
  141. Cam Install the car is slower and falls on its face.....??
  142. AWD problem.
  143. Stripped screw on intake manifold suggestions?
  144. Fuel Cell Installation
  145. oil pump cover removal???
  146. Clutch pedal force ???
  147. Dumb question about 20G LT vs. 20G-9-5
  148. Throttle Body Coolant recirculation
  149. Boost creep... how bad is it?
  150. advice needed on awd....
  151. MBC boost problem
  152. turbo exhaust housing
  153. evo 9 fmic
  154. You wont believe what Just Fin Happend, what a Crappy Day :(
  155. Greddy profec b 2
  156. new exhaust and downpipe installed...problems.
  157. My winter project. Not that i want to but have to.
  158. Turbosmart E-Boost Problem
  159. Invidia downpipe installation issue. Help, please
  160. 712whp on E85 and Meth, 560whp on straight E85
  161. tranny and t-case removal?
  162. New Fuel Injectors and sparkplugs?
  163. Engine ticking during warm up after cam install??
  164. Anyone Thought about making their exhaust
  165. another stock turbo evo ix tune..
  166. Intercooler information..........
  167. Quick ? about timing and balance belts...
  168. comparison of flow rate of turbos, VIII, IX, EVO Green
  169. REplacing Clutch with OEM clutch parts...
  170. how accurate is the stock boost gauge?
  171. 272 idle..
  172. VIII and IX mufflers the same?
  173. Building a 2.3 stroker balance shaft or no balance shaft ?????
  174. Plug life?
  175. Final Twin-Disc Clutch Thread
  176. how to get 320-350 reliable awhp
  177. Question about o2 housing...
  178. ATP port polish question
  179. Just installed my BRGT35R
  180. Just walked over to Turbokits.com.....
  181. 50 Trim guys with ALKY PLEASE LOOK!!!
  182. Cryo treating?
  183. 20G-LT and E85
  184. Rev limiter in ECUflash, stock internalled engine
  185. bigger injectors?
  186. Any one using DNP headers / manifold
  187. How to make atp gt35r turbo kit twin scroll.
  188. Quick question about bolts connecting mani to turbo.
  189. Comp 272's question
  190. stock turbo outlet size??
  191. Anyone recognize this header?
  192. Please Post your EVO GREEN FP 20gLT dyno numbers and graphs
  193. Just bought a Atp gt35r 63 ar turbo kit for my evo 9.
  194. Any info on Crower IX cams? ? ?
  195. 6sp transmission case question
  196. afi gt 35r?????
  197. Help!!!Spike and Creep problems!!!
  198. p507 code
  199. just saw this this second ... anyone heard anything about it?
  200. need help on somthing
  201. AMS TBE clips
  202. exhaust
  203. exhaust
  204. GT4094R, nobody has tried it on a evo yet?
  205. Best header for stock turbo???
  206. cams and gears ?
  207. TTP or Helix D/P+T/P Combo?
  208. Throttle body service!
  209. question on gt30r series turbo.
  210. Works ABM and IP sound
  211. A Public Apology To Shepard Racing.
  212. Valati controller......
  213. Please post Evo IX upgrade turbos and opinions
  214. PWR IC fitment and/or pics
  215. Best clutch for under 800$. .
  216. Crank pulley
  217. Question abot HKS Carbon TI Exhaust
  218. exhaust manifolds??
  219. Calling everybody with the HPF 3.5in turboback exhaust.
  220. broken evo!!!!
  221. Will an HKS Hi Power from 03 fit an 06?
  222. where can i get transfer case rebuilt?
  223. Tanabe or Espelir Downpipe
  224. spark plugs
  225. Looking to buy a gt37r turbo kit.
  226. My alternative to can style mufflers
  227. Fuel Pump for 21psi?
  228. How much preload on Forge WG Actuator?
  229. The Official MBC Install Picture Thread
  230. Oil Pressure Question
  231. Bad oil leak problem. I need some ideas.
  232. Differences in VIII and IX intermediate pipe (exhaust)
  233. rear o2 sensor for evo 9
  234. HELP previous owner re-installed bov backwards, i think
  235. Anyone using an AEM tru boost?
  236. Installed Apex'i power intake!
  237. help!!! greedy type s causing surging idle
  238. cant remember name of part.. makes it so u dont lose boost during shifts
  239. Please help! T case oils
  240. Custom Intercooler End Tank's
  241. Please analize my spark plug(pic inside)
  242. gt30
  243. gt35 r
  244. hks stand alone
  245. 20g9-5 VS. 20glt..
  246. forged divter valve fix a lot of problems
  247. drivebelt noise
  248. Apexi N1 Titanium
  249. o2 simulator
  250. Exedy Help
