PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Did lifters, now i own a subaru. HELP
  2. Original miles matter on a built engine?
  3. engine bearing clearence concerns
  4. Evo 8/9 reliability whp/wtq?
  5. O2 dump stuck open / no boost
  6. Issues getting blocked from 2nd gear at low speed...
  7. ikeya shifter
  8. Identify this Fp turbo?
  9. Having stalling problem when hot but starts fine when cooled off
  10. am i the luckiest guy on earth or what??
  11. HELP! Evo 9 high idle and jerky while driving
  12. rear balance shaft belt removal?
  13. oil pump rebuild?
  14. P0113 Code with Speed Density
  15. FP Red BB
  16. WTB: Full race T3 manifold for evo 8
  17. Rod Knock on new engine?
  18. 500 whp on pump gas
  19. Ets 4" intercooler on a 9
  20. how important is it to...
  21. precision 6870 open or divided? cant seem to decide
  22. Rebuild pump ACD
  23. Fresh Build: White smoke out exhaust & oil on top of pistons.
  24. Hydramat Setups
  25. Where might this oil come from?
  26. ACD Pump Shot! Delete it Totally?
  27. Radiator fan for half rad setup
  28. Identifying a 4.11 final drive
  29. misfire issue help!!!!
  30. power cable clip???
  31. stock block, stock head, stock turbo record
  32. Suggestions
  33. ETS TI 3.5" Catback
  34. Differential 101
  35. Used Motor Balance Shaft out of phase
  36. Rear main seal leaking
  37. Evo 9 Front End Clicking Noise
  38. Clutch noise
  39. currently around 450 whp, but want more
  40. Oil pump sprocket resistance
  41. Evo 9 stock turbo or Tomei Arms 7960 ?
  42. Blouch dominator 2.0
  43. Is my transfercase cracked?
  44. FP's new turbo downpipe option
  45. Evo 8 rebuild! Guide me there😁
  46. Normal for base fuel pressure to fluctuate a little bit?
  47. Evo 9 lean at high rpm after Walbro 255 install
  48. Evo 8 clutch&flywheel swap into a 6?
  49. Evo 9 Engine Oil Temperature
  50. Megan Header replacements?
  51. oil filter loosen up by itself?
  52. Evo 9 AC on deceleration idle and stall issue
  53. 1st post rear diff question
  54. Factory boost solenoid still connected?????
  55. FP Green or any better stock frame turbo
  56. Half-Size/Forward Facing AC Condenser Kit: All the details you need to know
  57. transfer case fluid-need help evo8
  58. 2.3 Stroker with turbos FP Red or smaller
  59. the car shut off after driving 7 miles
  60. Shift Linkage question
  61. Car won't start, spark issue
  62. Transmissions 101
  63. Evo x hks cz200scz4a
  64. Thoughts? help appreciated
  65. New FP green dosent sound right
  66. CHRA flush?
  67. New Throttle Body - Idles High - Tune or Screw adjustment?
  68. Need Help! Sun Hyper Force System
  69. turbo coolant lines
  70. Confusing Evo IX Sputtering Issue
  71. Is Anybod selling Port and Polish Clyinde rhead for Evo 9?
  72. .50 Oversized Rod Bearings?
  73. Exhaust Manifold Torque Sequence
  74. Which Stock location turbo for 500whp with 93oct
  75. MAP performance o2 housing why!??
  76. Fluidampr install
  77. ball bearing shaft play?
  78. 4g63 crank-block measurement needed
  79. Jic exhaust manifold evo 8
  80. Evo 9 Cam Gear Rattling? Help!! Video Inside
  81. Cleaned my throttle body...I know....question
  82. what should i do about engine.
  83. 9/1 2.0L with an PTE 5857 30lbs at 5K is this right?
  84. engine build "theory"
  85. need help with new clutch ideas
  86. Ebay Silicone radiator hose kit
  87. Clutch pedal assembly fracture
  88. Fuelab Pressure regulator HELP :((
  89. Flywheel Bolts Backing Out
  90. Evo 6 Clunking sound - rear diff? transfer case?
  91. GFB BOV Help
  92. Wow... o2 housing bolt snapped into hot side.. what to do?
  93. whining evo 8
  94. Help! Ignition issue, not sure the cause
  95. 4g63t dohc vr4 new cas now wont start??
  96. Low boost
  97. 2.4 LR - smooth as stock motor?
  98. Tomei 290's
  99. 27psi on 91oct????!!!
  100. ATTA turbo
  101. Will a EVO X turbo fit an VIII
  102. Extremely slow spool on my 2.4L
  103. Need new Clutch and flywheel.
  104. Will Evo 8 shafts fit on an Evo 4?
  105. Opinions on my EVO 8 setup
  106. HELP--Low compression on fresh build
  107. Beating a dead horse. Turbo question.
  108. Alternator Voltage drop after fuel pump rewire?
  109. Double Pumper Question
  110. Any fully built 2.0 guys on here?
  111. 9180 vs 6466 vs HTZ86
  112. I'm learning how to tig weld aluminum - made a boost controller bracket
  113. Fuel pump rewired questions
  114. New front case, new oil pump, leak from seal
  115. Ebay Oil Pump
  116. evo problem,need your help!
  117. Fuel Pump Housing Broken Valve
  118. can't decide to do balance shaft delete or not
  119. Need service limit on block surface flatness.
  120. Trouble with quick 2-3 shift
  121. evo8 bogging while cruising
  122. Throw out bearing snap ring.
  123. Oil feed line from oil filter housing or head?
  124. Double Pumper Install Fail
  125. p0090
  126. 93/E85 Dual Map or not? Do I have everything needed?
  127. Buschur Double Pumper Wiring
  128. **HELP PLEASE** Cannot figure out my issue
  129. Rear diff drain plug metal shavings
  130. MAP built motor?
  131. Crank trigger plate backwards?
  132. Need some advice for Vacuum plz help!!!
  133. T-case whine
  134. ID2000 install issues, please help
  135. Gsc beehive 5039 vs tomei springs.
  136. Oil Cooler Bypass question; Need clarification
  137. wastegate venting out of hood, will i have issues with rain water?
  138. evo4 with evo8 ecu, idle and revving issues
  139. Exedy Triple Disk engagement issue
  140. Evo 8 valvecover leak issue.
  141. Evo 8/9 TRANMISSION PARTS
  142. wrong C/R pistons??
  143. Forced performance 28psi wga
  144. Help finding W5M51 transmission parts
  145. Best way to protect from downpipe heat?
  146. turbo upgrade
  147. Clutch recommendation for an Evo VI
  148. Help identifying injector
  149. changing pistons
  150. Rear diff failure. This is what it looks like
  151. Spark plug gap Evo 8
  152. 2003 evo 8 tcase fluid help
  153. Maf needs to be cleaned?
  154. Is it normanl for a Transmission gears
  155. WideBand Replacement for Zeitronix Zt-2 Wideband
  156. Wide Band O2 Sensors [ Bosch 17014 and Bosch 17351 ]
  157. Flutter (maybe?) and low boost, turbo dead?
  158. Evolution 7 Forged rod and piston help
  159. Fuel Issue
  160. best syncro brand for evo 9 six speed
  161. Bad Turbo?
  162. GT4202R T4 1.22AR vs 1.01AR exhaust housing
  163. Evo 8 Transmission Seal Part # needed...
  164. New setup give some constructive comments please...
  165. Evolution 7 Turbo swap to 8 Help
  166. Piston Surface Roughness
  167. 4th gear noise on standin rev Evo 9 MR
  168. compression / leakdown
  169. FP Oil Line and Engine failure
  170. turbo manifol and highflow,HP gain?
  171. Going into 2nd easy turning right, Difficult going left
  172. 2.0 or 2.3 stroker with this gear ratio
  173. How is it posible to bend valves upon first fire up?
  174. Turbocharger Max PSI
  175. rough idle. brain fried
  176. Reputable ACD/AYC repair kit.
  177. Crank case pressure 2.3 evo 7 PTE 6262
  178. Grimmspeed EBCS 3 vs 2 Port
  179. confirming IACV is bad?
  180. Weird electrical issue with only #2 and #3 coils. Need help.
  181. valve stem seals OEM or other brand?
  182. CV axle compatibility/where to buy
  183. Evo IV rattling/clunking noise?
  184. Compressor cover.
  185. **help please car dies randomly**
  186. Nasty Valvetrain noise after timing belt install
  187. Evo 8 bell housing leak????
  188. 05 MR with bearing type noise coming from engine or trans.
  189. MHI Black Options
  190. Transmission leaking
  191. IACV and idle issues
  192. 3rd gear just up and left!?!?
  193. Will the aem uego with 4.9 sensor plug and play with aem emsU?
  194. Engine Build Options
  195. evo 8 cams
  196. need help plz ???????????????
  197. boost issues
  198. ATP intake pipe
  199. 2.3 stroker with 4g64 crank??
  200. Head Question
  201. Manual Boost Gauge Issue, no reading at all; ideas?
  202. fuel/ air ration
  203. ACT HDSS to Exedy Twin is it worth it?
  204. HKS exhaust manifold
  205. New ID1700 injectors
  206. Bad Harness Causeing Phantom Knock
  207. Looks like it wasn't the coil pack... so what's wrong with my car?! Please help!
  208. Good machine shop in Texas?
  209. 4G63 Camshaft Showcase
  210. EVO IX engine making noise
  211. STM or MAP
  212. Clutch Alignment Tool
  213. New FP EVO 8 Ti-AL 71HTA
  214. Anyone know what valves these are?
  215. Boost leak test help. Searched and still have questions
  216. hey, single valve springs or dual ??
  217. Help: Cylinder 4 not firing - strange issue
  218. Uicp hitting acd pump and bracket after installing jm fab drag manifold.
  219. Should Perrin Air Box Shroud Screws Cinch Up?
  220. Loose Head Bolts
  221. No compression after timing belt change!!
  222. FP4R2 cams? Do they make power??
  223. Crankshaft from Lancer 2.0 . Is it the same ?
  224. Car won't start
  225. Steering Wheel Click/Pop
  226. Evo 9 turbo from blown motor
  227. Evo 4 PCV Valve Problems
  228. Precisiom 6062 GEN 2
  229. carbonetics twin vs fx400
  230. P0135 code question
  231. Fitting Boost Control Solenoid
  232. 2.3L stroker +hta86 dyno#
  233. Heat reflective tape
  234. how to tell if stock block
  235. Evolution 5/6 CP9A Boost Restrictor Pill Location? =)
  236. Turbosmart 18psi internal wastegate actuator
  237. Hi im new here water temp help please
  238. M Factory Helical front Diff
  239. Front Wheels shuddering/scrubbing (feels like a locked diff?) Evo4/5/6 Frankenstein
  240. Kinugawa TD06SL2-20g
  241. Rear differential and AYC problem Evo IV CN9A
  242. Staggering Evo Cams
  243. exedy twin disk floater plate polishing?
  244. Time for a new clutch? Would like upgrade opinions
  245. Power estimations
  246. what are gsc cams made of?
  247. Evo 8 and 9 cams
  248. Lifters still ticking after bleeding.?
  249. Installing an Electronic Boost Controller w/ MBC as backup?
  250. Evo 9 turbo help
