- Air Sound
- Flywheel + clutch
- intercooler upgrade
- Weird Stalling Problem?
- Do MAFs adjust richer as gears go up? Tuners & members please respond: Truth Squad
- UTEC: Big power capable? Tuner Issues? Truth Squad Inquiry
- Upside down bov
- Jun Flywheel
- New clutch installed...SES light???
- HKS Turbo Timer?
- Orderding Buschur Race FMIC...
- Stock Evo flow #'s
- Sorta a noob question....
- how can i repair a braided stainless line?
- tme 20g
- Best tranny fluid, don't car about warrenty!
- Bad banging/knocking from my engine
- Does USDM Evo 9 come with exhaust injection?
- Worth doing the cat-back?
- Help me keep my car! Motor Help needed
- Balance Shafts and Possible Fretting Wear?
- Help with installing a BOV
- Buschur TBE question
- car bucking
- Question for Mustang Dyno
- "turning up the boost"
- Just bought my new t-case with ralliart limited slip dif!!!!!
- Which battery kit would you recommend? Buschur/AMS/Nisei?
- Evo9 stock turbo vs. Evo9-20G
- building a fast/fun street/highway EVO 8
- Running rich when shifting under full boost
- TME to IX. Turbo Upgrade? or Lateral move?
- Post up your 35r spool numbers so we build a database of them
- Purple Oil?
- Bolt on 2.3 Stroker??
- Boost Loss From Intake?
- Tranny Fluid below min on new car?
- Buddy Club cams
- Car boosting OVER 2.0 BAR , PLease Help me
- Pose a ? to the board: Drop-In Vs. Cone...
- How did you install the coolant lines for your turbo?
- Stroker
- Manual Boost Controller Hose Length
- Powerflex Motor Mount Install
- Ams Bov?
- Exhaust temp and turbo durability
- JUN cam gears?
- engine problem getting pissed!!!
- 3"Downpipe for EVO 9------
- Anyone know if this is right?
- 3.5" exhaust?
- cold weather = high pitch bov?
- BOV for 05 gsr
- Best kit for my 06 evo? to make 500WHP
- Yet another problem...
- Yet another boost/bov/timing question...
- Can't sustain boost
- Tranny Fitment?
- stock turbo no cams
- HKS 280's
- Stroker Engine ?
- Question For Truth Squad Maybe??? Anyone Know Knows Please Chime In...
- Truth Squad: where will i be HP wise
- Cams: 272/272 with gears or no gears?????
- WATER INJECTION and BOOST
- CEL With RS-R Exhaust Components
- Whirring when doing handbrake turns
- Check Engine Blink Codes
- Full Fluid Replacement...what to go with ?
- EVO8 TURBO KITS bolt up to evo 9??
- Anyone transplanted a 9 turbo into an 8 yet?
- need to know?
- Can i put this in my rear diff?
- What is the spec for Operating Temp?
- Advice needed on Transfer case
- Does the stock ECU require the Evap stuff to run?
- Any vendors carry the Flex-a-lite FLX-110?
- Strange clutch problem
- how to change fluids.
- Truth Squad: Strenght Of ACD DIFF
- O2 cheater?
- Hallman Pro mbc makes a whistling noise anyone else experience this?
- i/c pipe clamps
- Freeze plug
- GT35r - Oil/Coolant line sizes?
- Anyone have experince with Nitromethane?
- Case Study # 119 - Member PHX EVO - Intake and Exhaust on IX = 300 plus whp and TQ !
- Case Study # 118 - Stock Evo IX on Mustang Dyno with 91 - IX rules !
- Buschur: Whats the status of your motor mounts?
- Tranny death
- Torn between these exhausts
- Winning from a roll.......20g vs GT35R
- Raising Compression
- Going back to stock intercooler pipe...Affect tune?
- Who has run the Piper Race Cams?
- Is Compressor Surge/Flutter Inevitable?
- Longitudinal 4G63?
- Car threw CEL .....
- Evo IX downpipe?
- Class in IHRA
- Works new catalytic converter, thoughts?
- remove ram air snorkel/scoop in 2005 evo?
- EVO IX, IC pipe that fits w/ stock airbox?
- CEL after snowstorm?
- Buddy Club PRO SPEC exhaust
- help engine knocking
- Po183?
- Truth Squad: AEM v. Xede at 530 whp
- where is the great thread on the profec B?
- o.k. guys, need advice with turbo choice....
- Only picked up @6hp with...
- Few important Questions regarding GT35R
- Vacuum Presure problem, need some advice
- HKS 2835 turbos... What's the difference between...
- howling noise
- RS drivetrain will it fit a GSR?
- Boost gauge,BOV and a problem I'm having
- burnt toast smell when I stopped
- HKS Boost controler offset help
- EVO IX bov questions...
- ACT Clutch Kit. 2600
- Bolt on turbo ?
- 6 puck question
- PLEASE look inside!! Motor problem that i cant figure out
- Bad vibration!!
- For those who have heatwrapped headers......A question
- Why my car is not pulling??
- boost leaks!
- Quick Intercooler pipe question
- Question on the transfer case?
- Retuned after cam / gears install 33whp gain!
- Need help compression test
- why is it so f@#$% hard to **** to 2nd?
- SFI Certifications
- Metal-substrate cat vs. old ceramic cat
- Used cam wear question
- Any special programming to install a new stock ecu?
- Has anyone tried the Dejon Tool intercooler?
- Aem + Hks Dli 2 ??
- please help
- Best clutch for around $500
- FQ 340 Which cams does this use??
- knock link- which one?
- anyone ever had a bad water temp sensor
- New toy
- pick one
- good 02 housing
- downpipe size
- urgent strut help needed
- Short video demonstrating an aggressive 2-step misfiring system =]
- Any before & after numbers for the AMS intake manifold
- T-Bolt Hose Clamps Size?
- Buschur TBE with hi flow cat and po420 code help
- my clutch
- td06-20g vs td05-20g
- Buschur Evo9-20G vs. Gt3076r on pump and alky?
- turbo spool
- New Tranny fluid for the Evo(Amsoil)
- Solid Rear Motor Mount
- HELP - Erratic drivability issues with my EVO.
- part # for "pillered" stock boost tube
- JIC Headers!!!
- A tough problem to solve on my evo 4(IV)
- TD05HR-16G6-10.5T New for 06??
- Exhaust comparisons.....you aren't getting what you paid for!
- Tilton Clutch Install
- nitrous question
- Clutch Question
- Trust PE2 catback
- best downpipe and test for money
- Buschur 20G-9 + RnR header/critique
- My Engine Meltdown!!!!!!!!!
- Why are my injectors maxed out?
- Would this manifold work on the Evo?
- Flywheel Blueing how much is too much???
- Transfer case is gone please help!!!!
- Removing Perrin Exhaust & Cat Delete: Power loss?
- overboost...cant figure it out
- check this out!
- Recently Dynoflashed w/ Alky Kit
- Significant difference b/w 2.75" and 3.0" downpipe??
- Dyno chart thread started at Buschur Racing...
- Found the problem w/ my car, really bad
- Turbo?
- Anyone have experience with megan o2 housing?? Getting po134.
- Christmas special on Dyno Tuning
- How a 2.4 really spools...
- Clutch purchasing help
- Is there an after market oil pan...
- Nisei IC, IC pipe kit, and battery kit--first impressions
- tranny vibrating
- Anyone running A tilton Cerametalic clutch yet?
- just got hks dli 2 - where to mount it
- Truth Squad Poll: Have your Evo's adjustable cam gears failed
- EVO 9 Mods
- Spark Plug Info...Part #'s
- Poll: How Much Did Your Clutch Install Cost?
- Weird thing happened...
- Banning "How do I/to get xxxHP?" threads
- My dyno sheet
- Evo engine troubles
- Found a decent injector prices
- 450 hp
- whats your alky settings on the SMC kit?
- 10.5 hotside porting?
- 10.5 porting?
- JDM BV and AMS LICP
- Vid/Sound clip of exhaust/cams
- Check out the New pics
- Head swap...
- After 5 hours reading&searching - Exhaust Question - never been asked
- Road Race Service Review...
- Possible starter problem
- Loud clunk in tranny?
- Alky Kit Pressure Gauge Question
- dyno #s from TT
- Same oil filter as old 4G63's
- Inline Fuel Pump Questions
- Where to get SFI Dampener Pulley
- diy porting and polishing
- stroker kit with a oem(ish) turbo (AMS, Buschur, Works, Turbotrix)
- GT30R - Part II
- Monster Sport IC Piping Question
- CAM Instal
- Car Feels like the throttle is stuck........
- engine oil dipstick is on low
- blow off problem
- Need Help with radiator fan controller connection
- 4g63 tubular & external wastgate
- exhaust help
- Megan exhaust manifold problem
- clutch pushrod extender question, clutch expert plz help
- AMS GT3071R or TurboTrix BB 50Trim Turbo kit
- eBay intercooler, junk?
- cam help please
- SES with "P000" code WTF????
- Walbro vs. Stock Pump
- Shorty engine dampener review - 2003 EVO
- Just got ACT clutch put in.
- AMS LICP fitment issues?
- engine rattles when I shut off the ignition
- ? on where to get flanges
- Need help diagnose the problem
- tial bov
- running 2 bovs?
- Any1 wanna trade bov's?
- clutch install fluids...
- Next Mods for this christmas- Help
- Case Study # 115 - HKS intake - 10.5 - 272 cams - ported 02 housing - big power
- Exhaust leak (o2 housing and downpipe)
