- Can someone please list ALL compatible trannys that mate to the Evo 4-9 4g63t?
- Support with aftermarket o2 housing.
- Uncertain Evo VIII Oil Leak
- Help: Injector Resistor Wiring for Evo 7/8/9
- Pulling engine
- Evo 8 Overbore
- exedy twin disc- question
- Twin Scroll Vband Manifold
- New member here
- JDM Evo 7 Engine Swap into '03 USDM Roller
- Big power DD friendly clutches? 700whp
- What exhaust is this?
- OEM Evo IX Hole in Intake Manifold
- Evo 9 / 80 series rebuild options
- Evo 7 gta not running well
- Gears dont go in when car its on
- Clutch not disengaging..
- Which exhaust? Help!
- Tuning MIVEC Advance question
- Evo 8 intercooler silicone hoses
- Oil pressure sensor location/type
- Race/street car electrical loads & alternator choice
- Gold specs in oil on first change
- Fixing the Evo Oil system - External Oil Pressure Regulator. Why and how?
- Slipping clutch??
- HKS help
- Radiator hose
- Boost creep after WGA spring upgrade
- 4th Gear Popping Out of Gear Under Load
- Half radiator
- Evo 8 Front Upstream 02 Sensor
- Irregular Idle/Startup/WOT issues
- 625 headstuds
- Rear Main Seal Position Question
- Mysterious white smoke (pics)
- Current Status of Mivec Evo 9 Intake cam failures
- Tranny problems
- Bearing Clearances: Tighter on the mains or rods and why?
- GSC S2 or S3 Cams?
- Evo 8 Fp red help
- AYC Pump causing large voltage draw/oscillation
- Whining noise?
- How did you guys get your cam gear bolts loose?
- Shaving intake manifold/vacuum box
- Extremely high idle + Boomba TB
- Do i need to remove or lower front cross member to remove engine?
- Ignition problem won't go away
- Shifter Slop in 3rd and 4th Gear
- Heaps of oil post compressor after cracking a piston
- Evo 5 turbo upgrade
- Evo IX trouble firing up, bad clicking
- Bad sounds after heavy launch, need diagnosis help!
- Throttle body vacuum
- Quartermaster triple or twin
- How DD friendly is a FF Turbo Kit?
- Fuel pump help.
- EVO VIII won't boost
- Weird inconsistent AFR issue
- Evo 8 bell housing problems please help!!!!
- Which size injectors should I run - Evo 7 450WHP E20
- Evo 8 Stock Turbo Replacement Suggestion
- Few Questions on O2 housings and horsepower limits.
- What are my spark plugs telling me?
- 6-Speed transmission rebuild
- Fuel set up question
- Question about crankwalk and aftermarket parts
- Ready to take to engine builders but having second thoughts....part 2
- Clutch pedal assembly for ABS?
- Timing belt install hiccup - engine timing question
- Accel ignition coil
- Uh oh.. oil all over my block
- Evo 9 - Recently Built Engine - Oil pooling on piston?!
- Sources of potential oil leaks behind timing cover?
- OEM Evo8 water pump lifespan (when did yours fail?)
- Help! Twin wastegate/no bov sound???
- Compression issue on #3 : New Build ..
- Oil leak on top of coil
- Evo 9 Dies While Driving and Won’t Turn Over After
- Denso 056800-2090 ayc relay
- A Question on Oil Lines for FP ball bearing turbos
- FP Super 94/99 compatible turbine housings?
- Valve cover issues?
- What parts make up an Evo 8 exhaust?
- Unknown MAP series turbo.
- What's Really Necessary in a Transfer Case/Rear Diff Build?
- Moving half radiator over
- Frozenboost WTA ic
- Evo 5 rebuild 2l
- Oil in spark plug chamber.
- Evo VII ACD
- Fuel Pump Rewire assistance
- FP 71HTA price increase
- 4" Intake for SD Setup?
- Any reinforcement ideas for the clutch pedal assembly cracking?
- Boostin Performance 1/2" L19 4G63 Head Stud Kit - 1200+WHP Red Demon Spec
- Wheel bearings issue
- Fuel Question
- Motor Build White Smoke On Startup
- NEED Help with PCV elbow sleeve removal!
- Best Performance trans for 550+ awhp, (Evo IX)
- EVO 1-3 Engine differences
- FP Green vs small precision turbo question
- Oil on Camshaft position sensor normal or not?
- Fuel Pulse Dampers?
- this fp black is a bb or jb?
- Mishimoto/Koyo Evo 6 Radiator + Stock Fan in Evo 9
- JMF mainfold
- cant find this boost leak
- Ticking/Clunking from Transmission...
- GSC or Supertech or Ferrea 6000 valves?
- Backfire. Tune? Injectors?
- Spun a rod, need your ideas/advice, pretty defeated
- 6870 kit recommendations
- Crankshaft
- Oil cap breather for crankcase pressure?
- Evo 8 FWD?
- FP 54 green bb
- Where can I buy NGK 1GR7A-G
- Cosworth Cam Help
- Evo 9 wont start, no crank, just whizzing electrical noise when turned over
- Driveshaft u joint aka cross
- Good AFR on low tank, Lean AFR on full tank
- need help ?
- New fuel pump setup
- Looking for the bolts on the flywheel cover
- Evo 8 need some help on bottom and built
- Whine when accelerating only
- "Another" Rear Diff issue - Have you seen this?
- Help is choosing correct Heat Gasket
- Engine issue
- Need advice on stealth build
- Fuel pressure gauge fluctuates all the time.
- Power loss/no boost
- Question about oil pump leak
- Favorite Big Turbo?
- TRE built trans and tcase. What fluids are you guys using?
- evo 8 Transmission final gear damage/ chipped
- Evo 8 engine swap to evo 6
- Evo ix tomei titanium exhaust drone at ~3k cruising
- OS giken clutch issue
- Intake cam seal size on MIVEC motor smaller than exhaust cam seal?
- New Stock frame turbos from comp turbo
- Absolute max?
- Intercooler question
- DW400 DW400 Walbro525
- External or internal wastegate?
- Weird fic injector issue.
- Balance shaft delete. Do you keep black cog underneath crank pulley??? Help!
- Oil pump debacle
- How badly did I mess up?
- Kiggly Billet 12 tooth crank trigger is it worth it?
- Can someone help me through diagnosing a no-boost problem?
- 2007 Evo 9 SE What is this sound?
- Transmission swap halted because of this odd thing, help please.
- Best turbo option for RHD EVO 8 GSR??
- FP black owners? EBC/Catch can issue
- how to check fuel pressure while running?
- I need a 5spd Transmission Service Manual.
- Transmission and Tcase questions
- 2.5" Screamer Pipe to a 3" Downpipe??
- Forced Performance intake pipe evo 8/9
- Megan o2 housing surprise
- Exhaust recommendations
- OMNI MAP sensor users who have had a failure - Please step in
- Gearbox repair / stripping gearbox parts
- Screamer Pipe Pros & Cons??
- EVO 8/9 Transfer Case Info - Lets talk
- Sheepey Bottom Mount Oil Drain Info
- Synthetic oil crystallization?
- Driveshaft Options?
- ETS Quick spool Turbo kit(G30)
- Help, whining when turning,
- Humming, deep horn, type of noise under hood
- Stock frame turbo
- Aftermarket Headgaskets (Cosworth, JE ProSeal, Tomei)
- Help with p0171/p134 codes
- Slave cylinder snapped from clutch fork. How to fix
- Long-term e-85 effects on fuel systems
- Throwout bearing not releasing, metal clip bent, Ahh!
- Turbo return line problem?
- Will an fp red blow my engine
- p0340 and p0335 its not the camshaft sensor
- FP green rpm full boost
- Timing Belt Job: Power steering pump removal
- Timing Belt Job: Cam position at TDC
- The oil cap retainer and nut fell into my engine(NEED HELP)
- Diy cop evo 8
- Engine rebuild bolt sizes
- Porting Catch Can - Crankcase Pressure
- Header and down pipe
- What ar exh housing for 650-750whp.
- MHI 18k for Evo 8/9
- Garrett Electric Turbochargers
- Boost issueee helpppp
- Transmission "control assembly" install 6-speed trans
- Timing belt bearings
- Built 2.0 on Gen 1 6266 dbb .82 t3 Potential?
- 4.11 on built 2.0 (700whp+)?
- OEM exhaust valve coating?
- Fp hta71
- Two brackets/heatshields from engine bay
- Is there anyway to tell if a motor is a stroker?
- Balance shaft question
- Need help, car jerky/buck when off the gas
- clutch pedal not fully returning and looses pressure while driving
- Can you guys check over my clutch replacement parts list?
- Temp gauge/boost issue
- maxed out FP GREEN?
- After my very long search I finally found inexpensive silicone hoses for Evolutions.
- 2.3L Easy Stroker Kit by Zed Performance Uk
- Evo 8 boosting issue
- Exedy Stage 1 HD Organic vs ACT XTSS
- ACD/Transfer case leak
- Turbo choice advice!
- JDM '03 Evo 8 Diff Setup
- Sounds like crankwalk but no shaft play?!?
- What is required to make my automatic GTA INVEC-II stronger?
- 5/6 speed gearing options
- Clutch pedal weird dead spot
- Did invidia fix/update their o2 housing since 2006 for Evo 8/9?
- Cam noise at idle...
- JUN 264 cams
- 4G69 bellhouse pattern?
- Upgraded transfer case Evo 4-6
- Evo 6 Valve cover AN Fittings
- Turbo Upgrades 500hp
- Boost leak?
- need advice from the clutch gods
- Heavy pedal clutch
- EVO 8/9 IAC - Lets talk
- Best options for bolt on turbo upgrade on evo 8
- Need some advice on a turbo upgrade
- Quaife diff broke
- Car moves a little. But doesnt accelerate. Found a chunk in bell housing need ideas
- Did I buy the wrong spark plugs ?
- Spoolinup COP evo8 fits evo9 ?
- Evo 9 Engine Rebuild
- Help Please Car starts but doesn't run for a while
- Exedy twin disk odd noise
- Valve cover lock washers
- Intercoolers compatible with Cusco Front Bar
- Best oem turbo w/restrictor
- Evo 6 propeller shaft
- Evo9 hks turbo back
- Power limitations
- 2.4 from hell story
- Can not figure out this clunking..
- Oil temp vs oil weight question
- Throttle body coolant line
- 255 + 450 double pumper
