- will evo 8 turbo fit in an evo 9?
- Acd ecu failed
- Evo 8 Idling problems please help
- Help required - Evo won't start, codes inside
- Welding the Center Diff
- 60psi fuel pressure??
- Reality Check?
- Power Steering Pump Noises
- Weapon R Intake Manifold..Anyone Using it?
- Hotside Mating
- Trans help please.
- TOB C-clip keeps popping
- Leaking HKS Air Filter? Or Normal? Please Advise
- what else can it be besides the serpentine belt???
- Importance of the felt bushing
- Intercooler Help!
- Split my 2.3 4g64 crank in half !
- Vibrant Ultra Quiet Resonator vs Glasspack type?
- Cam suggestions wanted
- Spec Clutch?
- turbo troubles, help!
- Comp turbo Triple ceramic ball bearing
- new built motor high oil pressure
- Anyone ever experience this after installing o2 dump?
- Best way to beef up my low end????
- fujita intercooler piping and intake combo
- DTC P0106: Barometric Pressure Circuit Range/Performance Pro
- Its time to go fast ;)
- started
- xi turbo or fp green?
- jm fabrications intake manifold install how to?
- Hole in Transmission!!!!aaaahhh!
- Problem from 3rd to 2nd
- double inline walbros
- Exoticspeed ES430
- cam cap order? yep, i searched.
- OBX lsd??
- Problem: Evo 8 - Welded rear diff.
- Problem shifting under WOT
- Clutch engaging at top of pedal.
- Evo 8.5 tuning. What boost controller & ecu tune for driveability?
- wideband bung placement 8'' from turbo
- Jumpy gauge needle...
- Big Clutch Problem Need Help!!!!!!
- intercooler pipe questions
- Clutch help
- Calling Clutch Experts, Spring tabs on intermediate PP needed?
- GSC S1 v S2 Mivec Cams throttle response question.
- Buschur vs AMS Mustache Bar - Alot of questions
- boost controllers
- ACT steet disk or 6 puck
- BOV opening under boost
- Do I need injectors yet?
- fast clutch q
- best place to buy OEM fluids?
- please help new exedy tripple car wont go into gear when running
- Evo moves when launch control engaged
- E85 with meth injection results?
- injen intercooler piping and intake
- Front Wheel bearings
- 100mm Cranks
- i guess i killed my IX head?
- my driveshaft problem...
- Evo 8/9 OFH differences
- Help! Quatermaster assembly with pics
- Attention All Aluminum Rod Engine Owners....
- Help with HKS GT3037 Turbo Manifold
- borg warner turbo
- EVO 9 5 speed tranny question?
- Erratic boost - boost dyno graph incl
- fuel pumps
- TPS Adjustment Specifications
- which turbo
- Will a IX ACD pump fit a VIII Part #'s inside
- Evo IX with Injen iC piping - will stock airpipe and airbox fit?
- ACT HDSS or Exedy Stage 1 HD?
- Motor Swap in 8 hours?
- What is best oil use for 8500-9000 rpm ?
- Engine is overheating/ oil light at idle
- Wich camshafts??
- Intake vs. exhaust gas flow amount question
- Tial 38mm wastegate issue, can't find any info on it
- Anyone experience this type of coolant leak?
- acd on a shep transfer case?
- throttle body leak?
- FP 84mm Ported housing for 9 and BBK Full turbos ?
- TC or Tranny! Need serious help!
- Invidia EX Manifold or PPI?
- HELP: don't know what's wrong
- New motor mount/crossmember
- I want to make 350-400 whp!
- Spark plugs, any suggestions
- dual pump install now goes lean??
- anyone help.. what turbo???
- best Turbo to get 800whp?
- Problem with A/F
- Should I get a boost controller?
- MAGNUS V5 with fuel rail question
- Not holding boost very well??
- SES - p0300 + p0138
- Evo VIII Oil Cooler compatible on an Evo IX?
- first time at the track
- Anyone use AMSOIL Manual Synchromesh Transmission Fluid??
- Can I adjust clutch pedal/feel on Evo VIII?
- Fp Red Hotside...
- ER modified MIVEC or GSC S2 cams for this 2.3L stroker?
- Update on dead motor...
- ETS 1.50'' runner exhaust manifold on stock turbo
- Another SPEC Clutch Issue
- Tomei Oil Thermo Killer
- Transmission Going Bad
- Melting Electrode on Plugs
- HTA73 green spool data.
- My Evo is running like crap.Can't figure out whats wrong.
- How to clean up the cams???
- who has - Coil on Plug NON CDI System
- CV Boot
- What valve springs
- Spring and Retainer install ?'s
- What Color To Paint Valve Cover???
- Has anyone checked if he has any boost when in full throttle in reverse ???...
- 1st gear whining, 5th gear grind?
- K24/K20 vs. 4G64 max rpms???
- my factory VIII radiator fan exploded
- Bad boost leak help
- 11.5 housing.
- check engine; miss fire code?
- downpipe
- guick question
- Cracked megan exhaust manifold
- 2.3 stroker build.
- Manley crankshaft. Need opinions =)
- Irractic Boost issue! Please help
- Best turbos to use on Stroker/High compression.
- dual walbro inline help!
- Evo IV Not Geting full power
- Competition Twin Disk
- Downpipe install questions
- which exhaust
- Where to install lc1 wideband sensor???
- Max tq on Crower Rods?
- Newb question about upping my boost...
- dry sump...
- Tranny build
- transmission and tranfercase in a evo
- aftermarket water pump
- I need a new clutch!
- Looking to upgrade turbo!
- Upgraded fuel system for my EVO
- how many quarts should I buy for transfer case and rear diff?
- what is best cams for evo 9 mr ? plz help
- o2 housing install question
- Exhaust Manifolds
- Do I need a new clutch?
- wb02 question
- Another P0300 problem
- Throttle Hang - Will be the death of me - Frustrated
- P0300 Misfire Help
- Parts list for tranny rebuild?
- 6262
- Problems building boost with FP Red
- newb queston
- Turbo bearings shot?
- HKS filters???
- Evo VII RS2 rebuild help needed
- shearer manifold who has or had it?
- How F**Ked am I?
- boosting issues
- Evo feels like its falling on its face under boost at WOT? Spark plugs? boost leak?
- 4g64 questions
- 1100 hp drag build, need tcase and driveline info!!
- Need your advice with blow off valves please !
- info on springs and retainers..
- What do you think about the megan downpipe
- Clutch Vibration
- Clutch Vibration
- Leak near driveshaft
- Gains from exhaust ?
- Does anyone have a 2.3 RR ?
- Car Bog during launch
- Transfer case and rear diff metal filings
- Block - What is the port for?
- gear grind
- Tranny acting weird, almost stuck in gear.
- Help! Odd vibration I can't seem to pinpoint
- help goin g lean !!!!
- Noise... Can of bolts? anyone?
- will CUSCO front power brace support the bumper---more exp??
- Boost controller - evo 9
- Exhaust install issues
- Me 1 Throw out bearing 0
- Evo VIII rs, missing
- FP Black + stock block
- Need Exedy Snap Ring (on pressure plate cover) Part # CP01 Anyone???
- Rear Differential Issue
- Engine Sputter
- 6 speed disassembly guide??
- Harmonic Crank Pulley
- 5zigen Exhaust
- gt35r .63 vs 1.06
- Piston Play...
- Its a good day!!!
- Drivetrain problem
- people with anodized tial wastegates
- Evo 8 turbo very LOUD
- Fuel line upgrade
- visually identify 5 spd and 6 spd trans?
- Custom Crank Trigger Wheel questions
- 82,000 miles, Evo 8, hks 280 cams=will I need valve springs
- What is that???
- Doing springs and retainers
- Bad Injector?
- Do I need to worry about the 6-speed at stock power levels for HPDE?
- o2 dump without a tune?
- direction of rotation
- Trying to tighten Exedy Twin flywheel to crank, no mitsu tool
- BOV fluttering only in 4th and 5th gear.
- cam thread with comparions?
- Quick question before my tune!
- Did u resurface your new flywheel?
- Where do I go from HERE
- Help diagnose problem!!!!
- Forge 18 psi WGA
- Keep AEM tru-boost or back to MBC?
- Weird Noise from Engine Bay
- AEM wideband install
- You Get What You Pay For With AEM Tuning!!! Blown Motor Pics!!!
- Got my valvecover off... Have new GSC S1's but no $ to tune.. Swap anyway or wait???
- Exedy Clutch Kits @ Mellon Tuning Store
- MAF w/no honeycomb? do you run one?
- none of the original Evo Green turbos left ?
- Oil in the Spark plugs
- Vibration And CEL Light
- Big trouble in little china
- Bad wastegate?
- axles
- Post here if you run WITHOUT a blow-off-valve
- Evo 8 Plastic DV Leaks
- Bad ring? What do you think?
- Need input or help from people who rev to 8000-8500.
- Stock vs aftermarket intake manifold
- Turbo XS intercooler- anyone use one?
- exedy rebuild kit
- Exedy TwinHD Clutch Install - IX Questions
