PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 [172] 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. In the quest for a Road Race Turbo Kit
  2. apex cone filter
  3. Please Help
  4. My RnR gt37r project
  5. SBR gt-35r kit (why i dont need a gf)
  6. Oil Return Line leak
  7. EVO VIII boosting problem....
  8. Need a replacement diaphram for the Greddy Type-S
  9. stock injector leaking boost??
  10. cooked head repair
  11. Falling Out of 3rd Gear on Track
  12. Tanabe Concept Blue and cell fix?
  13. Octaine booster?
  14. What you think of the AMS UICP w/ tial bov
  15. ARC FMIC for IX?
  16. 110 to 93 on tune
  17. What should a properly tuned BOV sound like??
  18. stock ecu with 35r
  19. Any LICP Dyno gains?
  20. Any aftermarket turbos bolt on to stock hotside?
  21. FS: USED K&N DROP IN FILTER W/ LESS THAN 4500 MILES ON IT.
  22. Crank Pulley Issue
  23. question about evo 9 cams
  24. Is it Blown?
  25. hks RS or stock w/K&N drop in?
  26. Best clutch for daily driver EVO
  27. Buschur running 8.95 @ 163?
  28. Flash psi vs MBC psi
  29. super scared possible clutch problem!! help!
  30. Questions on upgrades...
  31. Changed transfer case oil yesterday - low initially? (little long)
  32. gearbox oil gl-4 75w-90 75w-85 or straight 90!
  33. car running very badly
  34. prolbem with AEM wideband air/fuel
  35. Samco hoses
  36. best bang for the buck mod
  37. Whistle while under boost?
  38. launch rev limiter
  39. Adjusting clutch. It adjusts PEDAL height ONLY?
  40. Need help, can't boost to 28
  41. plug gap quesiton
  42. just installed HKS 264/272...
  43. Stock Injector Fuel Pressure
  44. Clutch update.....I think I'm done with the Evo
  45. Tuning and break-in period.. what to do?
  46. I Need Help - Oil Light Flicking - Yes I Searched
  47. Purpose of Replacement?
  48. misfire and sputtering(i did search, just read)
  49. how much is too much on the stock turbo?
  50. ebay 02 and manifold!?
  51. Oil filter housing plug sizes
  52. EXO IX CAMS, Comparison questions
  53. intake part question
  54. Gas pedal adjustment
  55. Greddy Type-S lower vaccume port question
  56. Boost problem !!!
  57. Help on boost loss issue
  58. problem at WOT....?
  59. Best downpipe on a IX??? Fitment/quality/craftsmanship/performance
  60. Opinions on Spec clutches
  61. greddy intercooler
  62. Hole in transfer case from exhaust...Help
  63. When should one upgrade the intercooler and radiator on a IX??
  64. Rs*R ExMag Downpipe
  65. valve clearance question (mivec)
  66. Pinks Evo!!!!!
  67. 20G Turbo
  68. Do revolvers only work on the east coast??
  69. Full Race Manifold stock manifold
  70. wierd gear grinding pattern
  71. overheating issue
  72. Am I getting screwed over?
  73. forge mbc with heavy spring?
  74. Tansfer Case Noise
  75. evo 9 cam??
  76. Stroker/35R cam choice?
  77. Clutch install ?
  78. Buschur Racing Raises the Bar.... A New Record has been set!
  79. Intakes on the IX
  80. has anyone ever use this clutch
  81. my 35r dynograph
  82. Which mod next?
  83. Prediction?
  84. bar and plate intercooler question
  85. sticky clutch pedal
  86. Air Research compressor maps
  87. evo ix intake cam
  88. Shimming JDM MR DV?
  89. Exhaust Question
  90. stock boost evo8
  91. Need Tune after raising the Boost?
  92. just installed tial race bov....
  93. fuel starvation prevention
  94. Rod bearings
  95. real boost pressure?
  96. Evo Cam Options?
  97. Thoughts on the tanabe medallion touring exhaust
  98. High octane leaded race gas?!?
  99. Best Way to make 30 whp
  100. Has anybody used the Gruppe-s Flywheel yet?
  101. Tomei Ehx. Mani - pictures
  102. New Clutch Questions
  103. Does B&B use Magnaflow mufflers?
  104. Is this normal after TBE install ?????
  105. hks ssqv problem
  106. Warrtalon Package
  107. My Evo Hiccuped today
  108. Blown turbo on a STOCK evo 9! Please Help! *pics inside*
  109. Sorry another engine noise question
  110. What threads are on Hallman MBC, 1/8 NPT?
  111. anyone w/AMS 3076R Turbo kit on thier IX
  112. evo 8 - no power
  113. 30r .63 and .82 actual comparison
  114. Help with flywheel autopsy
  115. No "balance-shafts" - Engineered 4G63 crankshaft.........??
  116. Can someone answer a rear diff question for me??
  117. 670 WHP/545ft/ib update 10.72@135mph
  118. A-Spec Titanium TP Review
  119. just installed 20g 9 5 overboosting?
  120. Not bad for ATP 3037s
  121. Whining issue
  122. MoTec - Mitsubishi Centre Diff Controller
  123. Eboost-2 ?
  124. Which part would you get?
  125. boost going up,down and up again
  126. Boost spazzing out
  127. Which clutch should I buy
  128. Oil question
  129. Is this Super AYC or a mechanical rear diff?
  130. Tough time shifting..... help
  131. Hi-Flow Cats causing CEL; solution?
  132. When spool-up matters
  133. exedy twin problem!!
  134. How Long Has Your Exedy Twin Plate Lasted?
  135. Stock Evo 8 16g or Evo 3 GT RRE B16g?
  136. Need Help: Installing Boost Lines To Tial Wastegate?????
  137. Clank when shifting from 2nd-3rd at low speed?
  138. questions about injectors/turbo/ic
  139. Boost spiking ?
  140. boost problem *need help*
  141. Did I MUFF up my car?
  142. Where do you get your tranny/diff fluids?
  143. Buschur bullet muffler and JDM rear ?
  144. Electronic Stethoscope For Knock Monitoring
  145. o2 housing now or wait for a hotside?
  146. Can AEM Serial gauge show EGT in over 1000c ?
  147. ISP turbo kit 537whp at 30 psi
  148. Is my car running lean?
  149. Is this correct for stock boost? (short vid link)
  150. TRE probably the most inconsiderate shop ever
  151. Invidia downpipe evo ix
  152. 2.4 block and Evo head?
  153. Vishnu or Buschur.... Decisions, decisions
  154. Cam Angle Sensor Gasket
  155. Who Sells a good head gasket for the IX
  156. Do EVO IX's regulate/stabilise oil pressure in head?
  157. Help on my JDM EVO7 Steptronic (pictures)
  158. Buschur GT3065 Review
  159. Throw out bearing stuff?
  160. A/F ratio under boost
  161. Anyone know this Cosworth Camshaft for EVO 9 ! *pic
  162. boost problme 05evo8
  163. Increasing down force?
  164. just got off the phone w/ mitsu
  165. Anyone have this "catch can" yet?
  166. found a walbro fuel pump in my spare parts box
  167. car not boosting
  168. Cosworth Head vs. Stock(EVO VIII)
  169. evo ix or tme turbo please help
  170. Strange stalling when raining
  171. How many miles has your stock clutch lasted?
  172. biggest turbo on stock flange?
  173. Check my setup..what else do I need?
  174. Ok, Had Enough, What Is This!
  175. Finally installed my Exedy Twin, w/ a couple of pics
  176. Problems with my intercooler piping!!!!
  177. Axle and Driveline Strength?
  178. just installed cams , gears and fuel pump
  179. Low Gas=Check Engine Light
  180. Intercooler piping question
  181. Where can i buy the....????
  182. 6 speed + non oem fluid = bye bye tranny
  183. Help! My RPMs are dropping at wot
  184. Does the Greddy Ti come with mounting hardware?
  185. Requesting a good engine pull writeup.
  186. Update..515 whp/362 ft bls, 93 octane alone........
  187. VIII exhaust bolt to IX?
  188. clutch issues
  189. Sleeper test pipe..
  190. 2nd gear grind
  191. 631 WHP/ 554 ft/ib WTQ, GT35R stroker!
  192. About to install exhaust....
  193. Dyno Database: Please Contribute
  194. IX runs slower until I re-set the ECU........ why?
  195. Cam position sensor on evo9 intake cam?
  196. catback & dp, what next?
  197. rear 02 cross reference
  198. 475 whp, 341 ft lbs, 93 octane and still going.....
  199. heater core
  200. Need Help With Egt Gauge
  201. HKS/EIDS/ECU Help
  202. Need some quick help ASAP
  203. SoCal Clutch Questions
  204. Problems with Injen intake for evo IX
  205. Has anyone seen this intake?
  206. My MBC mounting solution
  207. Very small dent on honey comb on maf...
  208. Dyno graphs of the twin scroll set up.
  209. Need Help/opinion
  210. After clutch install issues...
  211. Injen CAI/UICP owners:
  212. Is the MIVEC just in the cylinder head ?
  213. oxygen sensor question plz help!
  214. Help please
  215. new clutch possibly clutch problems?
  216. Forge DV lowering boost
  217. 11.4, no NOS, no Lag, no problem
  218. HELP! Need Clutch Install advice!
  219. Bad / Loud ticking noise at idle and low revs
  220. 2g to EVO8 Swapping?
  221. Automatic Evo
  222. Best Turbo kit for stock internals and quickest spool up?
  223. Gas mileage and my performance desires
  224. good aftermarket manifold?
  225. shifting problem
  226. white/grayish residue
  227. 25 psi, no power HELP!!!!
  228. Clutch started slipping today
  229. Tranny woes, please help
  230. Help!
  231. HELIX 3"Downpipe Ver.1
  232. ACD ECU location
  233. AMS Uicp w/ tial ?
  234. Found something neat while screwing around!
  235. MBC only gives me 18 psi ???
  236. new clutch to give many a run for their money
  237. Can't control my Tial38.
  238. Oil Cooler
  239. Noob Here!
  240. Adjustable cam gears on stock cams?
  241. break in?
  242. Modifying Fuel System
  243. Your thoughts on a new clutch ?
  244. I had this discussion at MOD 06
  245. AEM twin-fire
  246. HELP!HKS GD CLUTH Pro
  247. 4 bolt vs 5 bolt (ford style) discharge housing
  248. Blitz SBC Problems Help !
  249. HKS 272 ex cam on IX
  250. Major {thumbup} to Dyno4mance!
